How do I know if I have Ethernet?
Discussion in 'Networking (Hardware & Software)' started by ik0106, 2003/01/18.
  1. 2003/01/18
    ik0106
    ik0106 Inactive Thread Starter
    Is there a way to find out if my computer has an ethernet card and or adapter in it? I'm very clueless when it comes to these things. Thanks for your help.
  2. 2003/01/18
    MinnesotaMike
    MinnesotaMike Geek Member
    ik0106,
    An easy way is to look at the back of your system. Look for a telephone connection with two lights right next to the plug in. That will be your network card. You can also look in your Device Manager for Network adapters.
    Mike
    The plug opening will be larger than a phone plug but very similar and, in fact, your phone cord will plug into the center of it. Won't do anything but it will fit.
    vinodhprabhu
    vinodhprabhu Inactive
    hey,
    the easiest way is to just type
    ipconfig/all
    in command prompt. u will get all the details of the enthernet/adapters.
    vinodh prabhu
  6. 2003/02/01
    schamish
    schamish Inactive
    try runnning either belarc advisor or aida32 diagnostic programs
  7. 2003/02/01
    Er vinodhprabhu - ipconfig will only work IF you have TCP/IP bound to the network card. NetBeui & IPX/SPX don't have it.
    #6
