How do I boot up my System into DOS Prompt?
Discussion in 'Windows XP' started by qch0001, 2002/02/24.
  1. 2002/02/24
    qch0001
    qch0001 Inactive Thread Starter
    In the previous versions of Windows you could start into the DOs prompt by pressing (F7 or F8 I cannot remember). Is there such an option in Windows XP? Thanks!:confused:
  2. 2002/02/24
    Kevin Lifetime Subscription
    Kevin Well-Known Member
    qch0001
    Thanks!!
    Yup. I figured a way to start the system. Thanks!!!
  5. 2002/02/25
    r1042
    r1042 Inactive
    TYPE COMMAND IN RUN..
    HOW DID YOU DO IT..?
