Horizontal lines on monitor
Discussion in 'PC Hardware' started by Bucksone, 2006/10/26.
  1. 2006/10/26
    Bucksone
    Bucksone Well-Known Member Thread Starter
    My monitor has thin horizontal lines extending across the top of the screen. The lines currently extend about an inch to an inch and a half down from the top. This has been going on for the last couple of months, and is gradually getting worse. The monitor is a Gateway EV730 CRT type of monitor. My question is whether this is something I can correct, or do I just accept that my monitor is gradually kicking the bucket? It is several years old.
  2. 2006/10/26
    charlesvar
    charlesvar Inactive Alumni
    Hello Bucksone,
    It probably is the Monitor - video cards, once they go bad, generally fail within a short period of time. If you can, to make sure it is the Monitor, hook it up to another system.
    You can also test the display by using dxdiag:
    Start > run > type dxdiag > ok. Use the Display tab.
    You can also try changing your display settings to lower the strain on the Monitor: change the refresh rate lower - change the dpi setting lower.
    Regards - Charles
