Homegroup problems Windows 7 64 bit
Discussion in 'Windows 7' started by Bearclaw, 2018/05/16.
  1. 2018/05/16
    Bearclaw
    Bearclaw Well-Known Member Thread Starter
    Running an HP 630 laptop with Windows 7 Home Premium 64 bit.
    I am getting the message 'cannot create homegoup on this computer' when attempting to join the homegroup via troubleshooting Homegroups. I also get a message that says 'no networks on this computer are joined to the homegroup', this message pops up while I am in the Homegroup troubleshooter itself. In the Network and sharing center it shows that the connected internet connection is of the Home network, which I don't think is the same as the homegroup.
    I do not know exactly when this problem came about but may have been installing some Windows updates. Nothing ran differently immediately after doing the updates so I was not aware of any changes that may have taken place with my internet connection. This matter has now gotten to the point that I have extremely limited access to the internet and when I am able to go online things are exceedingly slow and getting dropped off frequently.
    The only hint at getting the matter resolved I have found refers to the Peer Networking within the AppData. I have not been able to find such to even experiment with.
    Any ideas or suggestions would be greatly appreciated. Even going to the point of clearing any and/or all existing internet connection settings and starting it anew would be fine with me, if I only had a clue how to do it.
  2. 2018/05/16
    Were you connecting to a 'Homegroup' before the trouble?
    Bearclaw
    yes, I was connecting to the homegroup prior to the instance.
  5. 2018/05/17
    Either re-install your network group or try a System Restore prior to the updates.
  6. 2018/05/18
    Bearclaw
    Thanks for the help, I think the re-install would be the best thing to do at this juncture, however I don't know how to go about that, any instructions on where to go from here would be super. Thanks again for the help!
  7. 2018/05/18
  8. 2018/05/19
    Bearclaw
