home page problem
Discussion in 'Internet Explorer & Microsoft Edge' started by vincentjbl, 2006/03/14.
  1. 2006/03/14
    vincentjbl
    vincentjbl Inactive Thread Starter
    im unable to change my home page. I dont know what is wrong. I go to tools, internet options and change it and apply then ok. and I open internet explorer and it dont change. Can anyone help.
  2. 2006/03/14
    What's your default page right now? Have you checked for viruses/spywares ?
    vincentjbl
    charlesvar
    charlesvar Inactive Alumni
    Hello vincentjbl,
    Are you running MS AS? Seems likely since the setting is MSN :) If so, that's what's not letting you change the home page setting.
    Tools > Browser Restore > right pane > change restores to new url.
    Regards - Charles
  6. 2006/03/14
    vincentjbl
    Im not sure what MS AS is.
    and im also unable to find Tools > Browser Restore > right pane > change restores to new url. I dont have the browser restore option under tools in internet explorer
    Thank you
  7. 2006/03/14
    ggreg
    ggreg Inactive
    hmm, that's wierd. I think that I have had this problem once before, but it was so long ago I don't remember what I did to fix it.
    I can suggest this though...
    try it all over again.
    go to 'tools'>internet options and change the home page address.
    click ok and then log out before opening any pages.
    log back in and see if the change took.
  8. 2006/03/14
    charlesvar
    Hi vincent,
    MS AS is Microsoft Anti-Spyware.
    Lets try again :) - are you running Spybot Search&Destroy?
    If so:
    In the upper left corner > Mode > Advanced (if not turned on already) > in the panel below > Tools > Ie Tweaks > Start page > untick "Lock IE Start page setting against user changes (current user) "
    Regards - Charles
  9. 2006/03/14
    vincentjbl
    Im only using norton internet security 2005 right now. I will get Spybot Search&Destroy. and give it a try.
    thank you
  10. 2006/03/15
    vincentjbl
    I got the problem fixed. norton was blocking me from changeing my home page. I would like to thank everyone for there help.
  11. 2006/03/15
    charlesvar
    Thanks vincent for posting back with the solution.
    I should have asked what security software you were running :rolleyes: and asked you to look at the settings in it. I didn't think it was malware that was the problem - malware wouldn't direct you to MSN.
    Regards - Charles
