home networking problems
Discussion in 'Networking (Hardware & Software)' started by sford999, 2002/10/01.
  1. 2002/10/01
    sford999
    sford999 Inactive Thread Starter
    Hi
    I`m running a network of 2 computers and on the PC without the internet access i want it so it can connect to the internet by using the other computers internet access.
    How can i configure the 2 to use this?
    The PC with internet access is running Win ME and the other is running Win 98SE
  2. 2002/10/01
    dial-up or broadband (cable/dsl)?
    How are the two PCs connected for networking now?
    Any other networking equipment other than a modem and whatever connects the two PCs?
    sford999
    Hi newt
    I`m running 2 3Com Etherlink XL 10/100 NIC`s (3C905-TX) with a crossover cable between the 2.
    I have ADSL broadband internet access.
    The network is working perfectly fine with the exception of the "client" PC not being able to connect to the net
  5. 2002/10/02
    Miz
    Miz Inactive Alumni
    The information on this page might be what you're looking for.
    Miz,
    ICS will do it for sure. But will require a second NIC in the PC that acts as the server.
    You might do as well or better to get a router/switch and plug modem and PCs all into it. Costs a little more than only getting a 2nd NIC would but lots less hassle IMO.
    This Page has links to get a 4 port device for under $50. I use LinkSys. Have heard the DLink is also good but no first hand with it.
    You would also need a couple of straight (not cross-over) cables to hook the PCs to the switch. Crossover is probably what you'd need to the modem.
    #5
