'Help' won't open
Discussion in 'Other PC Software' started by Lugwalker, 2003/11/13.
  1. 2003/11/13
    Lugwalker Lifetime Subscription
    Lugwalker Forever Autumn Thread Starter
    When clicking on 'Help' in Photo Express I get the message: 'Unable to open information key in the windows registry'. Would this be a problem with Photo Express or with the windows registry? Any ideas would be welcome. Thank you. :confused:
  2. 2003/11/13
    brett
    brett Inactive Alumni
    ... or both!?!?!?
    I'd suggest a reinstall of Photo Express.
    First thought would be to uninstall the program, run a registry cleaner and then re-install it.
  5. 2003/11/13
    Thanks, Brett and Pete! I uninstalled the program and reinstalled it again. The problem seems to have been that in the 'typical' install several of the 'Help' features didn't come as standard. I chose 'Custom' and ticked the various 'Help' options. Now all is well. Many thanks to you for your help. :)
