Help with norton partition magic 8.0 please
Discussion in 'Other PC Software' started by Fighter1405, 2007/08/31.
  1. 2007/08/31
    Fighter1405
    Fighter1405 Inactive Thread Starter
    Hi everyone,
    Before I start i just thought i would mention that i have spent many hours trying to fix this problem and i only came to this forum as a last resort. As such I would be hugely grateful for any help you can give me.
    The situation:
    I have previously dual booted my hard disk several times in order to try out different builds of linux etc. but I have always maintained a C: drive for windows. Recently I got feed up with my dual-booted OS (ubuntu linux as it happens) and so deleted the E: partition of my hdd and moved the unalocated space. I have always used norton partition magic without a problem to perform these tasks.
    However recently i decided that i would take 10 gb out of C: drive and leave it as unallocated space (I wanted to do this for a reason - too complex too explain). However norton partition magic gave me an error 1529 which reads "Information mismatch in directory entry ". I looked at the support on symnactics website and they said to run chkdsk /f. I did this and windows told me it could not get a lock on the drive so i selected the option to perform the scan at next reboot and then rebooted the computer. When the computer rebooted norton partition magic still wouldn't work.
    I then ran chkdsk in read-only mode and it did find problems. I also tried it on next reboot but it failed to fix the problem once again. I have also tried norton disk doctor and this also finds a problem but it again says you need to restart to fix the problem. When you restart it only seems to run a standard chkdsk scan (?).
    I also tried to run a disk defrag to see if that would help and the only thing that came out of it is that it failed to defragment \~pttest.dat. I don't know if thats relevent or not.
    Thanks in advance for any help,
    Fighter1405
    P.S. I'd be happy to answer any qs about my comp setup
  2. 2007/09/01
    Fighter1405
    btw soz about posting in the wrong section, I couldn't find a "other software" forum. I obviously didn't look hard enough. thanks for moving it
    Fighter1405
    just one more thing to add. I have now tried using BartsPE and running chkdsk from there. I can run chkdsk C: /f without having to reboot but it finds no problems. However partitioning still doesn't work
  5. 2007/09/02
    r.leale Lifetime Subscription
    r.leale Well-Known Member
    Which OS are you running, Vista, XP, 98?
    PM 8.0 is not Vista compatible.
    Roger:confused:
  6. 2007/09/02
    Fighter1405
    Im running win xp
    soz i should have added it but i origionally posted in the xp forum and it was moved here
    also i don't think a problem with norton pm because gparted also fails
