help with cpu speed
Discussion in 'PC Hardware' started by djnb40, 2003/04/06.
  1. 2003/04/06
    djnb40
    djnb40 Inactive Thread Starter
    Today I bought an ECS motherboard with a 2.4GHz processor. It all works fine, but I cannot get the CPU to run any faster than 1.8GHz. In the BIOS settings under the 'CPU PnP Setup' there is a selection for 'ratio' but it says that it is locked. What do I need to do to get my CPU to run at its full speed?
    BTW my MB has AMIBIOS if that helps..
    thanks
    -DJ
  2. 2003/04/07
    Abraxas
    Abraxas Inactive
    Which ECS mb?
    Some mb's have board jumpers for internal clock speed. Others have them for the multiplier.
    I grabbed a random ECS manual. It looks like in that one, under Frequency/Voltage Control in the BIOS, there is a setting for clock speed. Yours appears to be set at 100 MHz and should be 133 since
    (1.8/100)*133=2.394
    (close enough!).
