Help with comp locking up
Discussion in 'Legacy Windows' started by Roddy, 2004/01/23.
  1. 2004/01/23
    Roddy
    Roddy Inactive Thread Starter
    When accessing the floppy drive, the machine locks up. I contrl/alt/delete, and I get a dialogue box telling me the "MPREXE IS NOT RESPONDING." What is the MPREXE and how do I fix the access problem? Thanks
  2. 2004/01/23
    Breakout
    Breakout Inactive
    I'm not sure if this will fix you're problem, but, it's a start. Good Luck!
    MPR EXE Problem
    goddez1
    goddez1 Inactive
    Microsoft says.......
    http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q178084&ID=KB;EN-US;Q178084
    This looks like a slippery little thing to pin down. If the password issue doesn't pan out and after making sure this is not viral or trojan in nature, I'd concentrate on the "Conflicting Application Scenario ".
    Possible A: floppy seek and virus program set to scan on floppy access.
    Close all un-needed running applications or tasks and see if error is reproduced or taken care of. Reduce/cleanup/stop startups.
    Clean the stopups and background runners you didn't even know you had. Are you familiar with spybot or adaware programs?
    Links to these can be found Pinned up in the "security" forum.
  5. 2004/01/24
    goddez1
    goddez1 Inactive
    Hi Roddy,
    I got your email and your most welcome but you did not specify how you fixed this problem.
    Please, please share the fix. Others may need it in the future.
    Besides, I'm curious what the problem was. Don't tear the last page out of this "Mystery Story "....:D
