[Help with CC Cleaner setup]
Discussion in 'Security and Privacy' started by Jewel2008, 2009/07/02.
  1. 2009/07/02
    Jewel2008
    Jewel2008 Inactive Thread Starter
    Hello,:)
    I would like some help please with CC Cleaner settings. I have looked through all the forums but can't find any answers to help me, hope it is ok to post this here.
    I have three computers ( desktop vista home basic, desktop windows xp, laptop vista premium ) all have installed the latest version of CC Cleaner. Could you please advice me using some screen shots of what I need to put a tick near to clean. Especially in the setting windows advanced and the Application. I have every thing ticked in the Applications but not in the windows Advanced.
    If you are able, some screen shots would be greatly appreciated.
    Thanking you for your advice and help.
    Jewel
  2. 2009/07/02
    This is how I have it set up (note: Firefox is my primary browser, so in IE, I clean, basically everything):
    http://209.85.48.8/228/109/upload/p4164870.jpg
    I have another option for you...
    Download Temp File Cleaner (TFC)
    No configuration needed, and it's even more thorough, than CCleaner.
    Jewel2008
    Thank you for replying Broni. I use IE8, will try your suggestions.
    cheers Jewel
