Help! Security Alert popups
Discussion in 'Security and Privacy' started by Sal_gal, 2003/10/29.
  1. 2003/10/29
    Sal_gal
    Sal_gal Inactive Thread Starter
    Whenever I browse a site -- any site, I get this irritating Security Alert popup screen and it says the security clearance certificate has expired and is not valid.
    Problem solved(?) I uninstalled IE6 and reinstalled.
  2. 2003/10/29
    Thanx for the update. Interesting problem.
    Sal_gal
    Same problem recurring
    I thought the problem was fixed by uninstalling IE6/reinstalling. When I go to the bank site I get the popup window, click yes, go to the next screen, get the popup window again and again.
    Went to MS updates and it says my computer needs 0 updates.
    Called the Bank and it seems to a server side problem; so I'm calling the DSL company to inquire.
    SBC DSL tech doesn't have a clue. Been on the phone for 1/2 hour.
    Same security alert popup at the secure sites like shopping, Ebay and banking. ONLY those sites.
  5. 2003/10/31
    goddez1
    goddez1 Inactive
    Just out of curiousity, is your computer set to the correct time and date?
  6. 2003/10/31
    Sal_gal
    Wonderful it worked
    Computer was not set!
  7. 2003/10/31
    goddez1
    goddez1 Inactive
    Yeah,
    Glad it was that simple. Sometimes them easy things give you the hardest time. I can't believe your support tech's didn't have you double check this right from the get-go. Guess this was to low-tech for the high-techs. :D
    Thanks for the update.
