Active Help Removing Anti Virus Live
Discussion in 'Malware and Virus Removal Archive' started by kenno, 2009/12/10.
  1. 2009/12/10
    kenno
    kenno Inactive Thread Starter
    [Active] Help Removing Anti Virus Live
    Hello
    My problem is exactly like this post listed here http://www.windowsbbs.com/malware-virus-removal/89164-resolved-antivirus-live-removal.html
    I have tried following that but I can not due to the fact when I download something the malware says the file is infected and will not let it install, so am unable to run ComboFix
    Any help in getting past this stage would be great, as I think think I should be able to follow the rest of the other post. But might need one of you very nice helpful people to check the logs for me
    Anyhelp any of you can give would be greatly appreciated
    Many Thanks Mark
  2. 2009/12/10
    Are you able to run DDS?
    kenno
    Hello
    Sorry for sounding like a idiot but what is DDS ?
    Thanks Mark
  5. 2009/12/13
    kenno
    Think I have found out what DDS is. I am guessing it is some sort of file scan and reporting software. I have downloaded it but it will not let me run or install this.
    I am going to try and restarting and clicking on this 1st which hopefully will be before the virus has started.
    Thanks Kenno
  6. 2009/12/13
    kenno
    Right after trying this on start up, it would not give me enough time to copy the notepad logs before the virus started and closed them down ( got about 2 seconds of viewing before closing)
    Anyway so I tried doing the same process but instead of DDS I quickly loaded ComboFix, it did say that ComboFix file had been compromised and then said to download a new one from bleebing computers, then it closed. I am not sure what this program does but it seems to have somehow disabled the virus for now.
    I have now been able to run DDS and here is the log
    DDS (Ver_09-12-01.01) - NTFSx86
    Run by KENNO at 12:09:56.57 on 13/12/2009
    Internet Explorer: 7.0.5730.11
    Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.2046.1631 [GMT 0:00]
    AV: Norton Internet Security *On-access scanning disabled* (Outdated) {E10A9785-9598-4754-B552-92431C1C35F8}
    FW: Norton Internet Security *disabled* {7C21A4C9-F61F-4AC4-B722-A6E19C16F220}
    C:\WINDOWS\system32\svchost -k DcomLaunch
    svchost.exe
    C:\WINDOWS\System32\svchost.exe -k netsvcs
    C:\WINDOWS\system32\svchost.exe -k WudfServiceGroup
    svchost.exe
    svchost.exe
    C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
    C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
    C:\WINDOWS\system32\svchost.exe -k imgsvc
    C:\WINDOWS\system32\svchost.exe -k netsvcs
    C:\Program Files\Canon\CAL\CALMAIN.exe
    C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
    C:\PROGRA~1\COMMON~1\AOL\AOLSPY~1\AOLSP Scheduler.exe
    C:\Program Files\Common Files\AOL\1187023374\ee\AOLSoftware.exe
    C:\WINDOWS\Samsung\ComSMMgr\ssmmgr.exe
    C:\Program Files\QuickTime\QTTask.exe
    C:\Program Files\AOL 9.0\aoltray.exe
    C:\Program Files\NETGEAR\WG111v2 Configuration Utility\RtlWake.exe
    C:\Program Files\Logitech\MouseWare\system\em_exec.exe
    C:\Program Files\NETGEAR\WG111v2 Configuration Utility\RtWLan.exe
    C:\WINDOWS\system32\ntvdm.exe
    C:\DOCUME~1\KENNO\MYDOCU~1\DOWNLO~1\DDS.COM
    uStart Page = hxxp://www.google.co.uk/
    uSearch Page = hxxp://www.google.com
    uDefault_Page_URL = hxxp://www.dell.co.uk/myway
    uSearchMigratedDefaultURL = hxxp://search.msn.co.uk/previewx.aspx?q={searchTerms}&FORM=CBPW&first=1&noredir=1
    uSearch Bar = hxxp://www.google.com/ie
    uInternet Connection Wizard,ShellNext = hxxp://us.mcafee.com/root/learnmore/learnmore.asp?close=true&lcode=en-us
    uSearchURL,(Default) = hxxp://search.aol.co.uk/web?isinit=true&query=%s
    uURLSearchHooks: &Yahoo! Toolbar: {ef99bd32-c1fb-11d2-892f-0090271d4f88} -
    BHO: Adobe PDF Reader Link Helper: {06849e9f-c8d7-4d59-b87d-784b7d6be0b3} - c:\program files\common files\adobe\acrobat\activex\AcroIEHelper.dll
    BHO: Adobe PDF Link Helper: {18df081c-e8ad-4283-a596-fa578c2ebdc3} - c:\program files\common files\adobe\acrobat\activex\AcroIEHelperShim.dll
    BHO: NCO 2.0 IE BHO: {602adb0e-4aff-4217-8aa1-95dac4dfa408} - c:\program files\common files\symantec shared\coshared\browser\2.5\coIEPlg.dll
    BHO: Symantec Intrusion Prevention: {6d53ec84-6aae-4787-aeee-f4628f01010c} - c:\progra~1\common~1\symant~1\ids\IPSBHO.dll
    BHO: SSVHelper Class: {761497bb-d6f0-462c-b6eb-d4daf1d92d43} - c:\program files\java\jre1.6.0_02\bin\ssv.dll
    BHO: Windows Live Sign-in Helper: {9030d464-4c02-4abf-8ecc-5164760863c6} - c:\program files\common files\microsoft shared\windows live\WindowsLiveLogin.dll
    TB: Show Norton Toolbar: {7febefe3-6b19-4349-98d2-ffb09d4b49ca} - c:\program files\common files\symantec shared\coshared\browser\2.5\CoIEPlg.dll
    TB: {4982D40A-C53B-4615-B15B-B5B5E98D167C} - No File
    uRun: [ctfmon.exe] c:\windows\system32\ctfmon.exe
    uRun: [AOL Dialer] c:\program files\common files\aol\acs\AOlDial.exe
    uRun: [fncxilmm] c:\documents and settings\kenno\local settings\application data\umlcus\ascesysguard.exe
    mRun: [AOLDialer] c:\program files\common files\aol\acs\AOLDial.exe
    mRun: [AOL Spyware Protection] "c:\progra~1\common~1\aol\aolspy~1\AOLSP Scheduler.exe "
    mRun: [Logitech Utility] Logi_MwX.Exe
    mRun: [HostManager] c:\program files\common files\aol\1187023374\ee\AOLSoftware.exe
    mRun: [ccApp] "c:\program files\common files\symantec shared\ccApp.exe "
    mRun: [osCheck] "c:\program files\norton internet security\osCheck.exe "
    mRun: [TkBellExe] "c:\program files\common files\real\update_ob\realsched.exe" -osboot
    mRun: [Samsung Common SM] "c:\windows\samsung\comsmmgr\ssmmgr.exe" /autorun
    mRun: [BluetoothAuthenticationAgent] rundll32.exe bthprops.cpl,,BluetoothAuthenticationAgent
    mRun: [QuickTime Task] "c:\program files\quicktime\QTTask.exe" -atboottime
    mRun: [fncxilmm] c:\documents and settings\kenno\local settings\application data\umlcus\ascesysguard.exe
    mRunOnce: [Malwarebytes' Anti-Malware] c:\program files\malwarebytes' anti-malware\mbamgui.exe /install /silent
    dRun: [CTFMON.EXE] c:\windows\system32\CTFMON.EXE
    dRunOnce: [RunNarrator] Narrator.exe
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\adobeg~1.lnk - c:\program files\common files\adobe\calibration\Adobe Gamma Loader.exe
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\aol90t~1.lnk - c:\program files\aol 9.0\aoltray.exe
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\wg111v~1.lnk - c:\program files\netgear\wg111v2 configuration utility\RtlWake.exe
    IE: &AOL Toolbar search - c:\program files\aol toolbar\toolbar.dll/SEARCH.HTML
    IE: {CD67F990-D8E9-11d2-98FE-00C0F0318AFE}
    IE: {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe
    IE: {FB5F1910-F110-11d2-BB9E-00C04F795683} - c:\program files\messenger\msmsgs.exe
    IE: {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - {CAFEEFAC-0016-0000-0002-ABCDEFFEDCBC} - c:\program files\java\jre1.6.0_02\bin\ssv.dll
    DPF: Microsoft XML Parser for Java - file:///C:/WINDOWS/Java/classes/xmldso.cab
    DPF: {00B71CFB-6864-4346-A978-C0A14556272C} - hxxp://messenger.zone.msn.com/binary/msgrchkr.cab31267.cab
    DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} - hxxp://www.apple.com/qtactivex/qtplugin.cab
    DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} - hxxp://upload.facebook.com/controls/2008.10.10_v5.5.8/FacebookPhotoUploader5.cab
    DPF: {149E45D8-163E-4189-86FC-45022AB2B6C9} - file:///C:/Program%20Files/Mahjong%20Escape%20-%20Ancient%20Japan/Images/stg_drm.ocx
    DPF: {166B1BCA-3F9C-11CF-8075-444553540000} - hxxp://download.macromedia.com/pub/shockwave/cabs/director/sw.cab
    DPF: {17492023-C23A-453E-A040-C7C580BBF700} - hxxp://go.microsoft.com/fwlink/?linkid=39204
    DPF: {17D667BA-5675-4AAB-9221-08B9379384D4} - hxxp://cdnimg.piczo.com/images/uploader/piczo_fast_uploader.cab
    DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} - hxxp://messenger.zone.msn.com/binary/msgrchkr.cab56986.cab
    DPF: {26FCCDF9-A7E1-452A-A73D-7BF7B4D0BA6C} - hxxp://o.aolcdn.com/pictures/ap/Resources/2.0.10.00/cab/aolpPlugins.10.6.0.6.cab
    DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} - hxxp://security.symantec.com/sscv6/SharedContent/vc/bin/AvSniff.cab
    DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} - hxxp://www1.snapfish.co.uk/SnapfishUKActivia.cab
    DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} - hxxp://download.mcafee.com/molbin/shared/mcinsctl/4,0,0,101/mcinsctl.cab
    DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} - hxxp://gfx1.hotmail.com/mail/w2/resources/MSNPUpld.cab
    DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} - hxxp://security.symantec.com/sscv6/SharedContent/common/bin/cabsa.cab
    DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} - hxxp://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1137353345015
    DPF: {78AEEDE8-7345-4FB5-A8FE-4BFF16EF25FC} - hxxp://us-download.mcafee.com/products/protected/mvt/mvt.cab
    DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_02-windows-i586.cab
    DPF: {8E0D4DE5-3180-4024-A327-4DFAD1796A8D} - hxxp://messenger.zone.msn.com/binary/MessengerStatsClient.cab31267.cab
    DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} - hxxp://fpdownload.macromedia.com/get/flashplayer/current/ultrashim.cab
    DPF: {A90A5822-F108-45AD-8482-9BC8B12DD539} - hxxp://www.crucial.com/controls/cpcScanner.cab
    DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} - hxxp://messenger.zone.msn.com/binary/ZIntro.cab56649.cab
    DPF: {BD393C14-72AD-4790-A095-76522973D6B8} - hxxp://messenger.zone.msn.com/binary/Bankshot.cab57213.cab
    DPF: {BF6BBE9A-0656-4598-A0CD-32DAC03959B5} - hxxp://www.tescophoto.com/wpp/tesco/app/opcuploader.cab
    DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} - hxxp://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab56907.cab
    DPF: {CAFEEFAC-0014-0002-0003-ABCDEFFEDCBA} - hxxp://java.sun.com/products/plugin/autodl/jinstall-142-windows-i586.cab
    DPF: {CAFEEFAC-0015-0000-0008-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.5.0/jinstall-1_5_0_08-windows-i586.cab
    DPF: {CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_01-windows-i586.cab
    DPF: {CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_02-windows-i586.cab
    DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_02-windows-i586.cab
    DPF: {CC450D71-CC90-424C-8638-1F2DBAC87A54} - file:///C:/Program%20Files/Mahjong%20Escape%20-%20Ancient%20Japan/Images/armhelper.ocx
    DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} - hxxp://fpdownload.macromedia.com/get/flashplayer/current/swflash.cab
    DPF: {DC6FEBC5-0A2D-458A-A01B-5DB15EEC4305} - hxxp://webc.madonbull.co.uk/auth/controls/IlosoftImageUpload.dll
    Notify: igfxcui - igfxdev.dll
    SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - c:\windows\system32\WPDShServiceObj.dll
    ================= FIREFOX ===================
    FF - ProfilePath - c:\docume~1\kenno\applic~1\mozilla\firefox\profiles\ps598cct.default\
    FF - prefs.js: browser.search.selectedEngine - Google
    FF - prefs.js: browser.startup.homepage - hxxp://www.google.co.uk/ig?hl=en
    FF - plugin: c:\program files\adobe\reader 9.0\reader\browser\nppdf32.dll
    FF - plugin: c:\program files\java\jre1.6.0_02\bin\npjava11.dll
    FF - plugin: c:\program files\java\jre1.6.0_02\bin\npjava12.dll
    FF - plugin: c:\program files\java\jre1.6.0_02\bin\npjava13.dll
    FF - plugin: c:\program files\java\jre1.6.0_02\bin\npjava14.dll
    FF - plugin: c:\program files\java\jre1.6.0_02\bin\npjava32.dll
    FF - plugin: c:\program files\java\jre1.6.0_02\bin\npjpi160_02.dll
    FF - plugin: c:\program files\java\jre1.6.0_02\bin\npoji610.dll
    FF - plugin: c:\program files\panda security\activescan 2.0\npwrapper.dll
    FF - plugin: c:\program files\quicktime\plugins\npqtplugin.dll
    FF - plugin: c:\program files\quicktime\plugins\npqtplugin2.dll
    FF - plugin: c:\program files\quicktime\plugins\npqtplugin3.dll
    FF - plugin: c:\program files\quicktime\plugins\npqtplugin4.dll
    FF - plugin: c:\program files\quicktime\plugins\npqtplugin5.dll
    FF - plugin: c:\program files\quicktime\plugins\npqtplugin6.dll
    FF - plugin: c:\program files\quicktime\plugins\npqtplugin7.dll
    FF - plugin: c:\program files\real\realarcade\plugins\mozilla\npracplug.dll
    FF - plugin: c:\program files\real\realplayer\netscape6\nppl3260.dll
    FF - plugin: c:\program files\real\realplayer\netscape6\nprjplug.dll
    FF - plugin: c:\program files\real\realplayer\netscape6\nprpjplug.dll
    FF - plugin: c:\program files\viewpoint\viewpoint experience technology\npViewpoint.dll
    FF - plugin: c:\program files\windows media player\npdrmv2.dll
    FF - plugin: c:\program files\windows media player\npdsplay.dll
    FF - plugin: c:\program files\windows media player\npwmsdrm.dll
    ---- FIREFOX POLICIES ----
    c:\program files\mozilla firefox\greprefs\security-prefs.js - pref( "security.ssl3.rsa_seed_sha ", true);
    R2 ccEvtMgr;Symantec Event Manager;c:\program files\common files\symantec shared\CCSVCHST.EXE [2008-1-25 149352]
    R2 ccSetMgr;Symantec Settings Manager;c:\program files\common files\symantec shared\CCSVCHST.EXE [2008-1-25 149352]
    R2 EAPPkt;Realtek EAPPkt Protocol;c:\windows\system32\drivers\EAPPkt.sys [2007-8-29 66048]
    R2 LiveUpdate Notice;LiveUpdate Notice;c:\program files\common files\symantec shared\CCSVCHST.EXE [2008-1-25 149352]
    R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\common files\symantec shared\eengine\EraserUtilRebootDrv.sys [2009-2-26 101936]
    R3 NAVENG;NAVENG;c:\progra~1\common~1\symant~1\virusd~1\20090425.005\NAVENG.SYS [2009-4-25 89104]
    R3 NAVEX15;NAVEX15;c:\progra~1\common~1\symant~1\virusd~1\20090425.005\NAVEX15.SYS [2009-4-25 876144]
    R3 RTLWUSB;NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter NT Driver;c:\windows\system32\drivers\wg111v2.sys [2007-8-29 167808]
    R3 SjyPkt;SjyPkt;c:\windows\system32\drivers\SjyPkt.sys [2007-8-29 13532]
    S3 COH_Mon;COH_Mon;c:\windows\system32\drivers\COH_Mon.sys [2008-1-12 23888]
    S3 Symantec Core LC;Symantec Core LC;c:\progra~1\common~1\symant~1\ccpd-lc\symlcsvc.exe [2008-4-25 1245064]
    2009-12-13 11:46:36 0 d--h--w- c:\windows\PIF
    2009-12-10 21:06:14 0 d-----w- c:\progra~1\Panda Security
    2009-12-10 21:02:57 0 d-----w- c:\progra~1\common~1\Wise Installation Wizard
    2009-12-03 16:14:06 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2009-12-03 16:13:56 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
    2009-04-30 06:53:08 25685128 ----a-w- c:\progra~1\wordview_en-us.exe
    2006-10-31 13:29:31 774144 ----a-w- c:\progra~1\RngInterstitial.dll
    2006-02-14 18:36:17 9917960 ----a-w- c:\progra~1\SpywareDocCompressed.zip
    2002-04-19 19:15:44 61 ----a-w- c:\progra~1\adobe photoshop 7.0 serial.txt
    2007-03-10 15:19:41 104 --sh--r- c:\windows\system32\B26CE715E6.sys
    2007-03-10 15:19:44 6580 --sha-w- c:\windows\system32\KGyGaAvL.sys
    ============= FINISH: 12:10:38.43 ===============
  7. 2009/12/13
    kenno
    ve now done a Malware Bytes quick scan and it found and removed 7 threats, here is the log
    Malwarebytes' Anti-Malware 1.42
    Database version: 3352
    Windows 5.1.2600 Service Pack 2
    Internet Explorer 7.0.5730.11
    13/12/2009 12:50:48
    mbam-log-2009-12-13 (12-50-44).txt
    Scan type: Quick Scan
    Objects scanned: 155944
    Time elapsed: 22 minute(s), 34 second(s)
    Memory Processes Infected: 0
    Memory Modules Infected: 0
    Registry Keys Infected: 2
    Registry Values Infected: 2
    Folders Infected: 0
    Files Infected: 3
    (No malicious items detected)
    HKEY_CURRENT_USER\SOFTWARE\AvScan (Trojan.FakeAlert) -> No action taken.
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\gaopdxserv.sys (Trojan.Agent) -> No action taken.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\fncxilmm (Trojan.FakeAlert) -> No action taken.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\fncxilmm (Trojan.FakeAlert) -> No action taken.
    Folders Infected:
    Files Infected:
    C:\Documents and Settings\KENNO\Local Settings\Application Data\umlcus\ascesysguard.exe (Trojan.FakeAlert) -> No action taken.
    C:\Documents and Settings\KENNO\Local Settings\Temp\5843.exe (Spyware.Passwords) -> No action taken.
    C:\Documents and Settings\KENNO\My Documents\downloads\explorer.com (Heuristics.Reserved.Word.Exploit) -> No action taken.
    Do I need to do anything else ?
  8. 2009/12/13
    kenno
    I have also done a Hi-Jack this scan and here is the log it created
    Scan saved at 13:07:23, on 13/12/2009
    MSIE: Internet Explorer v7.00 (7.00.6000.16705)
    C:\Program Files\Mozilla Firefox\firefox.exe
    C:\Documents and Settings\KENNO\Desktop\scanner.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.dell.co.uk/myway
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.co.uk/
    R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://search.aol.co.uk/web?isinit=true&query=%s
    R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://us.mcafee.com/root/learnmore/learnmore.asp?close=true&lcode=en-us
    R3 - URLSearchHook: &Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - (no file)
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
    O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
    O2 - BHO: NCO 2.0 IE BHO - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - C:\Program Files\Common Files\Symantec Shared\coShared\Browser\2.5\coIEPlg.dll
    O2 - BHO: Symantec Intrusion Prevention - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\PROGRA~1\COMMON~1\SYMANT~1\IDS\IPSBHO.dll
    O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_02\bin\ssv.dll
    O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
    O3 - Toolbar: Show Norton Toolbar - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files\Common Files\Symantec Shared\coShared\Browser\2.5\CoIEPlg.dll
    O4 - HKLM\..\Run: [AOLDialer] C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
    O4 - HKLM\..\Run: [AOL Spyware Protection] "C:\PROGRA~1\COMMON~1\AOL\AOLSPY~1\AOLSP Scheduler.exe "
    O4 - HKLM\..\Run: [Logitech Utility] Logi_MwX.Exe
    O4 - HKLM\..\Run: [HostManager] C:\Program Files\Common Files\AOL\1187023374\ee\AOLSoftware.exe
    O4 - HKLM\..\Run: [osCheck] "C:\Program Files\Norton Internet Security\osCheck.exe "
    O4 - HKLM\..\Run: [Samsung Common SM] "C:\WINDOWS\Samsung\ComSMMgr\ssmmgr.exe" /autorun
    O4 - HKLM\..\Run: [BluetoothAuthenticationAgent] rundll32.exe bthprops.cpl,,BluetoothAuthenticationAgent
    O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
    O4 - HKCU\..\Run: [AOL Dialer] C:\Program Files\Common Files\AOL\ACS\AOlDial.exe
    O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
    O4 - HKUS\S-1-5-18\..\RunOnce: [RunNarrator] Narrator.exe (User 'SYSTEM')
    O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
    O4 - HKUS\.DEFAULT\..\RunOnce: [RunNarrator] Narrator.exe (User 'Default user')
    O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
    O4 - Global Startup: AOL 9.0 Tray Icon.lnk = C:\Program Files\AOL 9.0\aoltray.exe
    O4 - Global Startup: WG111v2 Smart Wizard Wireless Setting.lnk = ?
    O8 - Extra context menu item: &AOL Toolbar search - res://C:\Program Files\AOL Toolbar\toolbar.dll/SEARCH.HTML
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_02\bin\ssv.dll
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_02\bin\ssv.dll
    O9 - Extra button: (no name) - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - (no file)
    O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe (file missing)
    O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe (file missing)
    O16 - DPF: {00B71CFB-6864-4346-A978-C0A14556272C} (Checkers Class) - http://messenger.zone.msn.com/binary/msgrchkr.cab31267.cab
    O16 - DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} (Facebook Photo Uploader 5 Control) - http://upload.facebook.com/controls/2008.10.10_v5.5.8/FacebookPhotoUploader5.cab
    O16 - DPF: {149E45D8-163E-4189-86FC-45022AB2B6C9} (SpinTop DRM Control) - file:///C:/Program%20Files/Mahjong%20Escape%20-%20Ancient%20Japan/Images/stg_drm.ocx
    O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
    O16 - DPF: {17D667BA-5675-4AAB-9221-08B9379384D4} (Image Uploader Control) - http://cdnimg.piczo.com/images/uploader/piczo_fast_uploader.cab
    O16 - DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} (Checkers Class) - http://messenger.zone.msn.com/binary/msgrchkr.cab56986.cab
    O16 - DPF: {26FCCDF9-A7E1-452A-A73D-7BF7B4D0BA6C} (AOL Pictures Uploader Class) - http://o.aolcdn.com/pictures/ap/Resources/2.0.10.00/cab/aolpPlugins.10.6.0.6.cab
    O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner) - http://security.symantec.com/sscv6/SharedContent/vc/bin/AvSniff.cab
    O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} (Snapfish Activia) - http://www1.snapfish.co.uk/SnapfishUKActivia.cab
    O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} - http://download.mcafee.com/molbin/shared/mcinsctl/4,0,0,101/mcinsctl.cab
    O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} (MSN Photo Upload Tool) - http://gfx1.hotmail.com/mail/w2/resources/MSNPUpld.cab
    O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/SharedContent/common/bin/cabsa.cab
    O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1137353345015
    O16 - DPF: {78AEEDE8-7345-4FB5-A8FE-4BFF16EF25FC} (McAfee Virtual Technician Control Class) - http://us-download.mcafee.com/products/protected/mvt/mvt.cab
    O16 - DPF: {8E0D4DE5-3180-4024-A327-4DFAD1796A8D} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsClient.cab31267.cab
    O16 - DPF: {A90A5822-F108-45AD-8482-9BC8B12DD539} (Crucial cpcScan) - http://www.crucial.com/controls/cpcScanner.cab
    O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (MSN Games - Installer) - http://messenger.zone.msn.com/binary/ZIntro.cab56649.cab
    O16 - DPF: {BD393C14-72AD-4790-A095-76522973D6B8} (CBreakshotControl Class) - http://messenger.zone.msn.com/binary/Bankshot.cab57213.cab
    O16 - DPF: {BF6BBE9A-0656-4598-A0CD-32DAC03959B5} (Image Uploader 3.0 Control) - http://www.tescophoto.com/wpp/tesco/app/opcuploader.cab
    O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab56907.cab
    O16 - DPF: {CC450D71-CC90-424C-8638-1F2DBAC87A54} (ArmHelper Control) - file:///C:/Program%20Files/Mahjong%20Escape%20-%20Ancient%20Japan/Images/armhelper.ocx
    O16 - DPF: {DC6FEBC5-0A2D-458A-A01B-5DB15EEC4305} (IlosoftImageUploadCtl Class) - http://webc.madonbull.co.uk/auth/controls/IlosoftImageUpload.dll
    O23 - Service: AOL Connectivity Service (AOL ACS) - AOL LLC - C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
    O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
    O23 - Service: Canon Camera Access Library 8 (CCALib8) - Canon Inc. - C:\Program Files\Canon\CAL\CALMAIN.exe
    O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: Symantec Lic NetConnect service (CLTNetCnService) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: COM Host (comHost) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\VAScanner\comHost.exe
    O23 - Service: DSBrokerService - Unknown owner - C:\Program Files\DellSupport\brkrsvc.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
    O23 - Service: LiveUpdate - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\LuComServer_3_4.EXE
    O23 - Service: LiveUpdate Notice - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: Intel NCS NetService (NetSvc) - Intel(R) Corporation - C:\Program Files\Intel\PROSetWired\NCS\Sync\NetSvc.exe
    O23 - Service: Symantec Core LC - Unknown owner - C:\PROGRA~1\COMMON~1\SYMANT~1\CCPD-LC\symlcsvc.exe
    End of file - 10908 bytes
  9. 2009/12/13
    kenno
    This is the log from rootrepeal
    ROOTREPEAL (c) AD, 2007-2009
    Scan Start Time: 2009/12/13 13:24
    Program Version: Version 1.3.5.0
    Windows Version: Windows XP SP2
    Drivers
    Image Path: C:\WINDOWS\System32\Drivers\dump_atapi.sys
    Address: 0xB00EF000 Size: 98304 File Visible: No Signed: -
    Status: -
    Image Path: C:\WINDOWS\System32\Drivers\dump_WMILIB.SYS
    Address: 0xF79A1000 Size: 8192 File Visible: No Signed: -
    Status: -
    Image Path: wtqygdj.sys
    Address: 0xF75F7000 Size: 54016 File Visible: No Signed: -
    Status: -
    Hidden/Locked Files
    Path: c:\documents and settings\kenno\local settings\application data\mozilla\firefox\profiles\ps598cct.default\cache\7a3c6d01d01
    Status: Size mismatch (API: 40620, Raw: 41199)
    Path: C:\Documents and Settings\KENNO\Local Settings\Application Data\Microsoft\Messenger\kenno_21@hotmail.com\SharingMetadata\swiftyjbc@hotmail.com\DFSR\Staging\CS{2BD1E926-F743-6760-7E90-DB076CF27773}\13\13-{1D~1.FRX:{59828bbb-3f72-4c1b-a420-b51ad66eb5d3}.XPRESS
    Status: Visible to the Windows API, but not on disk.
    SSDT
    #: 012 Function Name: NtAlertResumeThread
    Status: Hooked by "<unknown>" at address 0x8a137b78
    #: 013 Function Name: NtAlertThread
    Status: Hooked by "<unknown>" at address 0x8a137e70
    #: 017 Function Name: NtAllocateVirtualMemory
    Status: Hooked by "<unknown>" at address 0x8a146860
    #: 031 Function Name: NtConnectPort
    Status: Hooked by "<unknown>" at address 0x8a499098
    #: 041 Function Name: NtCreateKey
    Status: Hooked by "C:\WINDOWS\system32\Drivers\SYMEVENT.SYS" at address 0xb03d6020
    #: 043 Function Name: NtCreateMutant
    Status: Hooked by "<unknown>" at address 0x8a155d60
    #: 053 Function Name: NtCreateThread
    Status: Hooked by "<unknown>" at address 0x8a1cba50
    #: 057 Function Name: NtDebugActiveProcess
    Status: Hooked by "<unknown>" at address 0x8a1322c8
    #: 063 Function Name: NtDeleteKey
    Status: Hooked by "C:\WINDOWS\system32\Drivers\SYMEVENT.SYS" at address 0xb03d62a0
    #: 065 Function Name: NtDeleteValueKey
    Status: Hooked by "C:\WINDOWS\system32\Drivers\SYMEVENT.SYS" at address 0xb03d6800
    #: 083 Function Name: NtFreeVirtualMemory
    Status: Hooked by "<unknown>" at address 0x8a1be5f0
    #: 089 Function Name: NtImpersonateAnonymousToken
    Status: Hooked by "<unknown>" at address 0x8a135e90
    #: 091 Function Name: NtImpersonateThread
    Status: Hooked by "<unknown>" at address 0x8a137aa0
    #: 108 Function Name: NtMapViewOfSection
    Status: Hooked by "<unknown>" at address 0x8a1cd290
    #: 114 Function Name: NtOpenEvent
    Status: Hooked by "<unknown>" at address 0x8a1350b8
    #: 123 Function Name: NtOpenProcessToken
    Status: Hooked by "<unknown>" at address 0x8a13edf0
    #: 125 Function Name: NtOpenSection
    Status: Hooked by "<unknown>" at address 0x8a133678
    #: 129 Function Name: NtOpenThreadToken
    Status: Hooked by "<unknown>" at address 0x8a186238
    #: 206 Function Name: NtResumeThread
    Status: Hooked by "<unknown>" at address 0x8a479218
    #: 213 Function Name: NtSetContextThread
    Status: Hooked by "<unknown>" at address 0x8a1391a8
    #: 228 Function Name: NtSetInformationProcess
    Status: Hooked by "<unknown>" at address 0x8a18bd90
    #: 229 Function Name: NtSetInformationThread
    Status: Hooked by "<unknown>" at address 0x8a17b538
    #: 247 Function Name: NtSetValueKey
    Status: Hooked by "C:\WINDOWS\system32\Drivers\SYMEVENT.SYS" at address 0xb03d6a50
    #: 253 Function Name: NtSuspendProcess
    Status: Hooked by "<unknown>" at address 0x8a1338b0
    #: 254 Function Name: NtSuspendThread
    Status: Hooked by "<unknown>" at address 0x8a138170
    #: 257 Function Name: NtTerminateProcess
    Status: Hooked by "<unknown>" at address 0x8a13f058
    #: 258 Function Name: NtTerminateThread
    Status: Hooked by "<unknown>" at address 0x8a138558
    #: 267 Function Name: NtUnmapViewOfSection
    Status: Hooked by "<unknown>" at address 0x8a13da88
    #: 277 Function Name: NtWriteVirtualMemory
    Status: Hooked by "<unknown>" at address 0x8a487b60
    ==EOF==
  10. 2009/12/13
    kenno
    This is my log from hijack this
    Sorry for the bombarding of the logs but I am not advanced enough to understand these myself
  11. 2009/12/13
    **Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**
    • Please, never rename Combofix unless instructed.
    • Close any open browsers.
    • Close/disable all anti virus and anti malware programs so they do not interfere with the running of ComboFix.
    • Click on this link to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
    NOTE. If Combofix asks you to install Recovery Console, please allow it.
    • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
    • Double click on combofix.exe & follow the prompts.
    • When finished, it will produce a report for you.
    • Please post the "C:\ComboFix.txt" along with a new HijackThis log for further review.
  12. 2009/12/13
    kenno
    Thank you again for the reply.
    But I can not download ComboFix from either of them links, I get a 404 error from both, is there another link available at all
    Many thanks for your time
    Kenno
  13. 2009/12/13
    I'm sending you PM.
  14. 2009/12/13
    kenno
    I have replied to you
    Thanks Kenno
  15. 2009/12/13
    Please download [color= "#CC0000"]The Avenger[/color] by Swandog46 to your Desktop.
    - Right click on the Avenger.zip folder and select Extract All...
    - Follow the prompts and extract the avenger folder to your desktop
    Double click on avenger.exe.
    Click OK in pop-up window.
    Avenger window will open.
    Click on Execute button.
    Click OK in two consecutive pop-up windows.
    Your computer will re-boot now.
    Upon re-boot, Notepad window will open.
    Select all text, copy it, and paste it into next reply.
    NOTE. If the log doesn't open on reboot, open Avenger again, and go File>Open Log File.
  16. 2009/12/13
    kenno
    Here are the details of the log, to me there is nothing there but you guys will know more then me
    Logfile of The Avenger Version 2.0, (c) by Swandog46
    http://swandog46.geekstogo.com
    Script file opened successfully.
    Script file read successfully.
    Backups directory opened successfully at C:\Avenger
    Beginning to process script file:
    Rootkit scan active.
    No rootkits found!
    Completed script processing.
    Finished! Terminate.
  17. 2009/12/13
    Download Dr.Web CureIt to the desktop:
    ftp://ftp.drweb.com/pub/drweb/cureit/drweb-cureit.exe
    • Doubleclick the drweb-cureit.exe file and click Scan to run express scan. Click OK in pop-up window to allow scan.
    • This will scan the files currently running in memory and when something is found, click the Yes button when it asks you if you want to cure it. This is only a short scan.
    • Once the short scan has finished, select Complete scan.
    • Click the green arrow [​IMG] at the right, and the scan will start.
    • Click Yes to all if it asks if you want to cure/move the file.
    • When the scan has finished, in the menu, click File and choose Save report list
    • Save the report to your desktop. The report will be called DrWeb.csv
    • Close Dr.Web Cureit.
    • Important! Reboot your computer because it could be possible that files in use will be moved/deleted during reboot.
    • Copy and paste that log in the next reply. You can use Notepad to open the DrWeb.cvs report.
    NOTE. During the scan, pop-up window will open asking for full version purchase. Simply close the window by clicking on X in upper right corner.
    Post fresh HijackThis log as well.
  18. 2009/12/14
    kenno
    Dr Web log file, found some but would not move or delete all
    gtdownde_110.ocx;C:\WINDOWS\system32;Probably DLOADER.Trojan;Incurable.Deleted.;
    T-3545427-disco 2000.mp3;C:\Documents and Settings\KENNO\My Documents\LimeWire\Incomplete;Trojan.WMALoader;Cured.;
    nightlife.mp3;C:\Documents and Settings\KENNO\My Documents\LimeWire\Saved;Trojan.WMALoader;Cured.;
    waterboy soundtrack - best track ever.mp3;C:\Documents and Settings\KENNO\My Documents\LimeWire\Saved;Trojan.WMALoader;Cured.;
    1196745071jtun_firstexpirationpif.x00\Program Files\Common Files\PIF_B8E1\pifCrawl.exe;C:\Documents and Settings\All Users\Application Data\Symantec\LiveUpdate\Downloads\1196745071jtun_firstexpirationpif.x00;Trojan.Swizzor.based;;
    1196745071jtun_firstexpirationpif.x00;C:\Documents and Settings\All Users\Application Data\Symantec\LiveUpdate\Downloads;Archive contains infected objects;Moved.;
    P14-02-09_23.36.JPG;C:\Documents and Settings\KENNO\Desktop\My Pictures\mobile folder;Exploit.MS04-028;Incurable.Moved.;
    P15-02-09_10.48.JPG;C:\Documents and Settings\KENNO\Desktop\My Pictures\mobile folder;Exploit.MS04-028;Incurable.Moved.;
    P15-02-09_12.06.JPG;C:\Documents and Settings\KENNO\Desktop\My Pictures\mobile folder;Exploit.MS04-028;Incurable.Moved.;
    P15-02-09_15.28.JPG;C:\Documents and Settings\KENNO\Desktop\My Pictures\mobile folder;Exploit.MS04-028;Incurable.Moved.;
    Voyager105PPPoEDriver.exe/Setup.EXE\data018;C:\Documents and Settings\KENNO\Local Settings\Temp\Voyager105PPPoEDriver.exe/Setup.EXE;Probably DLOADER.Trojan;;
    Voyager105PPPoEDriver.exe/Setup.EXE\data019;C:\Documents and Settings\KENNO\Local Settings\Temp\Voyager105PPPoEDriver.exe/Setup.EXE;Trojan.KillDisk.307;;
    \Setup.EXE;C:\Documents and Settings\KENNO\Local Settings\Temp;Archive contains infected objects;;
    Voyager105PPPoEDriver.exe;C:\Documents and Settings\KENNO\Local Settings\Temp;Archive contains infected objects;Moved.;
    AOLInstaller.exe\data002;C:\Documents and Settings\KENNO\Local Settings\Temp\aoluk\Broadband Assistant\Chorus\AOLInstaller\AOLInstaller.exe;Probably MULDROP.Trojan;;
    AOLInstaller.exe;C:\Documents and Settings\KENNO\Local Settings\Temp\aoluk\Broadband Assistant\Chorus\AOLInstaller;Archive contains infected objects;Moved.;
    setup.exe;C:\Program Files\AOL\Installers\ASP 2.0;Probably BACKDOOR.Trojan;;
    aspupdate\data017;C:\Program Files\Common Files\AOL\AOL Spyware Protection\Update\aspupdate;Probably BACKDOOR.Trojan;;
    aspupdate;C:\Program Files\Common Files\AOL\AOL Spyware Protection\Update;Archive contains infected objects;Moved.;
    acssetup.exe\data010;C:\Program Files\Common Files\AOL\Backup\ACS\Rollback\acssetup.exe;Probably BACKDOOR.Trojan;;
    acssetup.exe;C:\Program Files\Common Files\AOL\Backup\ACS\Rollback;Archive contains infected objects;Moved.;
    pifCrawl.exe;C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08};Trojan.Swizzor.based;Deleted.;
    registry.exe;C:\Program Files\VoyagerModemDrivers\Voyager105\ProgramFiles;Trojan.MulDrop.origin;Incurable.Moved.;
    Voyager105pppoeDriver.exe/Setup.EXE\data018;C:\Program Files\VoyagerModemDrivers\Voyager105\Voyager105PPPoEDriver\Voyager105pppoeDriver.exe/Setup.EXE;Probably DLOADER.Trojan;;
    Voyager105pppoeDriver.exe/Setup.EXE\data019;C:\Program Files\VoyagerModemDrivers\Voyager105\Voyager105PPPoEDriver\Voyager105pppoeDriver.exe/Setup.EXE;Trojan.KillDisk.307;;
    \Setup.EXE;C:\Program Files\VoyagerModemDrivers\Voyager105\Voyager105PPPoEDriver;Archive contains infected objects;;
    Voyager105pppoeDriver.exe;C:\Program Files\VoyagerModemDrivers\Voyager105\Voyager105PPPoEDriver;Archive contains infected objects;Moved.;
    BBCheckup.exe/data026/data002\vendors/aoluk/content/template/driven_dev/BroadBandAsst/Voyager105/ProgramFiles/registry.exe;C:\Setup\BroadbandCheckup\BBCheckup.exe/data026/data002;Trojan.MulDrop.origin;;
    BBCheckup.exe/data026/data002/vendors/aoluk/content/template/driven_dev/BroadBandAsst/Voyager105/Voyager105PPPoEDriver/Voyager1;C:\Setup\BroadbandCheckup\BBCheckup.exe/data026/data002/vendors/aoluk/content/template/driven_dev/BroadBandAsst/Voyager105/Voya;Probably DLOADER.Trojan;;
    BBCheckup.exe/data026/data002/vendors/aoluk/content/template/driven_dev/BroadBandAsst/Voyager105/Voyager105PPPoEDriver/Voyager1;C:\Setup\BroadbandCheckup\BBCheckup.exe/data026/data002/vendors/aoluk/content/template/driven_dev/BroadBandAsst/Voyager105/Voya;Trojan.KillDisk.307;;
    \Setup.EXE;C:\Setup\BroadbandCheckup;Archive contains infected objects;;
    vendors/aoluk/content/template/driven_dev/BroadBandAsst/Voyager105/Voyager105PPPoEDriver/Voyager105pppoeDriver.exe;C:\Setup\BroadbandCheckup;Archive contains infected objects;;
    data002;C:\Setup\BroadbandCheckup;Archive contains infected objects;;
    data026;C:\Setup\BroadbandCheckup;Container contains infected objects;;
    BBCheckup.exe;C:\Setup\BroadbandCheckup;Archive contains infected objects;Moved.;
    chorus.exe/data002\vendors/aoluk/content/template/driven_dev/BroadBandAsst/Voyager105/ProgramFiles/registry.exe;C:\Setup\BroadbandCheckup\chorus.exe/data002;Trojan.MulDrop.origin;;
    chorus.exe/data002/vendors/aoluk/content/template/driven_dev/BroadBandAsst/Voyager105/Voyager105PPPoEDriver/Voyager105pppoeDriv;C:\Setup\BroadbandCheckup\chorus.exe/data002/vendors/aoluk/content/template/driven_dev/BroadBandAsst/Voyager105/Voyager105PPPoE;Probably DLOADER.Trojan;;
    chorus.exe/data002/vendors/aoluk/content/template/driven_dev/BroadBandAsst/Voyager105/Voyager105PPPoEDriver/Voyager105pppoeDriv;C:\Setup\BroadbandCheckup\chorus.exe/data002/vendors/aoluk/content/template/driven_dev/BroadBandAsst/Voyager105/Voyager105PPPoE;Trojan.KillDisk.307;;
    chorus.exe;C:\Setup\BroadbandCheckup;Container contains infected objects;Moved.;
    Restart.exe;C:\WINDOWS;Trojan.KillDisk.307;Deleted.;
  19. 2009/12/14
    kenno
    New Hijack this log
    Scan saved at 07:39:07, on 14/12/2009
  20. 2009/12/14
    Another PM sent.
  21. 2009/12/15
    kenno
    Thank you for the message, this time it seems to have installed and worked ok, here is the log file
    Thank you again for all your help
    ComboFix 09-11-23.02 - KENNO 15/12/2009 20:42.1.1 - x86
    Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.2046.1615 [GMT 0:00]
    Running from: c:\documents and settings\KENNO\Desktop\3c786fgt5.exe
    - REDUCED FUNCTIONALITY MODE -
    ((((((((((((((((((((((((( Files Created from 2009-11-15 to 2009-12-15 )))))))))))))))))))))))))))))))
    2009-12-13 11:46 . 2009-12-13 11:46 -------- d--h--w- c:\windows\PIF
    2009-12-10 21:06 . 2009-12-10 21:06 -------- d-----w- c:\program files\Panda Security
    2009-12-10 21:02 . 2009-12-10 21:02 -------- d-----w- c:\program files\Common Files\Wise Installation Wizard
    2009-12-10 20:22 . 2009-12-13 12:51 -------- d-----w- c:\documents and settings\KENNO\Local Settings\Application Data\umlcus
    2009-11-17 10:46 . 2009-11-17 10:46 -------- d-----w- c:\documents and settings\ANDREA\Local Settings\Application Data\Mozilla
    2009-12-15 20:28 . 2007-07-04 17:33 -------- d-----w- c:\program files\Common Files\Symantec Shared
    2009-12-13 13:23 . 2009-12-13 13:23 34816 ----a-w- c:\windows\system32\drivers\rootrepeal.sys
    2009-12-13 12:09 . 2009-01-25 12:57 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
    2009-12-13 12:09 . 2009-07-27 21:38 4844296 ----a-w- c:\documents and settings\All Users\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\mbam-setup.exe
    2009-12-10 21:21 . 2009-12-10 21:21 -------- d-----w- c:\documents and settings\Administrator\Application Data\Malwarebytes
    2009-12-09 10:30 . 2007-07-04 17:35 -------- d-----w- c:\documents and settings\All Users\Application Data\Symantec
    2009-12-03 16:14 . 2009-01-25 12:57 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2009-12-03 16:13 . 2009-01-25 12:57 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
    2009-11-26 22:42 . 2008-11-25 20:57 -------- d-----w- c:\documents and settings\KENNO\Application Data\FileZilla
    2009-11-22 11:06 . 2008-11-25 20:56 -------- d-----w- c:\program files\FileZilla FTP Client
    2009-11-17 10:46 . 2009-02-23 14:00 36088 ----a-w- c:\documents and settings\ANDREA\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
    2009-11-16 12:02 . 2006-01-20 18:17 1961720 ----a-w- c:\documents and settings\KENNO\Application Data\Macromedia\Flash Player\www.macromedia.com\bin\fpupdateax\fpupdateax.exe
    2009-11-16 09:07 . 2006-02-13 19:16 -------- d-----w- c:\program files\LimeWire
    2009-09-30 13:58 . 2008-01-25 16:47 9576 ----a-w- c:\documents and settings\All Users\Application Data\Symantec\LiveUpdate\LuRegManifests\Static\CCMSLLUM.DLL
    2009-09-25 12:06 . 2006-01-10 21:28 36088 ----a-w- c:\documents and settings\KENNO\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
    2009-04-30 06:53 . 2009-04-30 06:51 25685128 ----a-w- c:\program files\wordview_en-us.exe
    2006-10-31 13:29 . 2006-10-31 13:29 774144 ----a-w- c:\program files\RngInterstitial.dll
    2006-02-14 18:36 . 2006-02-14 18:34 9917960 ----a-w- c:\program files\SpywareDocCompressed.zip
    2002-04-19 19:15 . 2008-12-23 18:08 61 ----a-w- c:\program files\adobe photoshop 7.0 serial.txt
    2007-03-10 15:19 . 2006-01-10 21:28 104 --sh--r- c:\windows\system32\B26CE715E6.sys
    2007-03-10 15:19 . 2006-01-10 21:28 6580 --sha-w- c:\windows\system32\KGyGaAvL.sys
    "AOL Dialer "= "c:\program files\Common Files\AOL\ACS\AOlDial.exe" [2007-12-07 71008]
    "AOLDialer "= "c:\program files\Common Files\AOL\ACS\AOLDial.exe" [2007-12-07 71008]
    "AOL Spyware Protection "= "c:\progra~1\COMMON~1\AOL\AOLSPY~1\AOLSP Scheduler.exe" [2004-10-18 79448]
    "HostManager "= "c:\program files\Common Files\AOL\1187023374\ee\AOLSoftware.exe" [2006-11-17 50736]
    "ccApp "= "c:\program files\Common Files\Symantec Shared\ccApp.exe" [2008-10-17 51048]
    "osCheck "= "c:\program files\Norton Internet Security\osCheck.exe" [2008-02-06 718704]
    "TkBellExe "= "c:\program files\Common Files\Real\Update_OB\realsched.exe" [2008-04-30 185632]
    "Samsung Common SM "= "c:\windows\Samsung\ComSMMgr\ssmmgr.exe" [2005-07-03 372736]
    "QuickTime Task "= "c:\program files\QuickTime\QTTask.exe" [2009-05-26 413696]
    "Logitech Utility "= "Logi_MwX.Exe" - c:\windows\LOGI_MWX.EXE [2003-12-17 19968]
    "BluetoothAuthenticationAgent "= "bthprops.cpl" - c:\windows\system32\bthprops.cpl [2004-08-04 110592]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
    "CTFMON.EXE "= "c:\windows\system32\CTFMON.EXE" [2004-08-04 15360]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\RunOnce]
    "RunNarrator "= "Narrator.exe" - c:\windows\system32\narrator.exe [2004-08-04 53760]
    c:\documents and settings\All Users\Start Menu\Programs\Startup\
    Adobe Gamma Loader.lnk - c:\program files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2008-12-23 113664]
    AOL 9.0 Tray Icon.lnk - c:\program files\AOL 9.0\aoltray.exe [2007-6-20 156784]
    WG111v2 Smart Wizard Wireless Setting.lnk - c:\program files\NETGEAR\WG111v2 Configuration Utility\RtlWake.exe [2007-8-29 745472]
    [HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Reader Speed Launch.lnk]
    path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Adobe Reader Speed Launch.lnk
    backup=c:\windows\pss\Adobe Reader Speed Launch.lnkCommon Startup
    [HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^AOL Broadband Assistant.lnk]
    path=c:\documents and settings\All Users\Start Menu\Programs\Startup\AOL Broadband Assistant.lnk
    backup=c:\windows\pss\AOL Broadband Assistant.lnkCommon Startup
    [HKLM\~\startupfolder\C:^Documents and Settings^KENNO^Start Menu^Programs^Startup^Picture Motion Browser Media Check Tool.lnk]
    path=c:\documents and settings\KENNO\Start Menu\Programs\Startup\Picture Motion Browser Media Check Tool.lnk
    backup=c:\windows\pss\Picture Motion Browser Media Check Tool.lnkStartup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\services]
    "SDhelper "=2 (0x2)
    "LexBceS "=2 (0x2)
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecAntiVirus]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecFirewall]
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
    "EnableFirewall "= 0 (0x0)
    "c:\\Program Files\\AOL 9.0\\waol.exe "=
    "c:\\Program Files\\Common Files\\AOL\\ACS\\AOLDial.exe "=
    "c:\\Program Files\\Common Files\\AOL\\ACS\\AOLacsd.exe "=
    "c:\\Program Files\\Common Files\\AOL\\1187023374\\ee\\aolsoftware.exe "=
    "c:\\Program Files\\IVT Corporation\\BlueSoleil\\BlueSoleil.exe "=
    R2 EAPPkt;Realtek EAPPkt Protocol;c:\windows\system32\drivers\EAPPkt.sys [29/08/2007 16:03 66048]
    R2 LiveUpdate Notice;LiveUpdate Notice;c:\program files\Common Files\Symantec Shared\CCSVCHST.EXE [25/01/2008 16:47 149352]
    R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys [26/02/2009 07:23 101936]
    R3 RTLWUSB;NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter NT Driver;c:\windows\system32\drivers\wg111v2.sys [29/08/2007 16:03 167808]
    R3 SjyPkt;SjyPkt;c:\windows\system32\drivers\SjyPkt.sys [29/08/2007 16:03 13532]
    S3 COH_Mon;COH_Mon;c:\windows\system32\drivers\COH_Mon.sys [12/01/2008 17:32 23888]
    *NewlyCreated* - COMHOST
    2009-12-14 c:\windows\Tasks\Norton Internet Security - Run Full System Scan - KENNO.job
    - c:\program files\Norton Internet Security\Norton AntiVirus\Navw32.exe [2008-02-07 05:05]
    IE: &AOL Toolbar search - c:\program files\AOL Toolbar\toolbar.dll/SEARCH.HTML
    FF - ProfilePath - c:\documents and settings\KENNO\Application Data\Mozilla\Firefox\Profiles\ps598cct.default\
    FF - plugin: c:\program files\Real\RealArcade\Plugins\Mozilla\npracplug.dll
    FF - plugin: c:\program files\Viewpoint\Viewpoint Experience Technology\npViewpoint.dll
    c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref( "security.ssl3.rsa_seed_sha ", true);
    AddRemove-HijackThis - c:\documents and settings\KENNO\Desktop\HijackThis.exe
    AddRemove-RealJukebox 1.0 - c:\program files\Common Files\Real\Update_OB\r1puninst.exe RealNetworks|RealPlayer|6.0
    AddRemove-RealPlayer 6.0 - c:\program files\Common Files\Real\Update_OB\r1puninst.exe RealNetworks|RealPlayer|6.0
    Rootkit scan 2009-12-15 20:46
    Windows 5.1.2600 Service Pack 2 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    - - - - - - - > 'explorer.exe'(1636)
    c:\program files\Logitech\MouseWare\System\LgWndHk.dll
    c:\progra~1\WINDOW~2\wmpband.dll
    c:\program files\Common Files\Logitech\Scrolling\LgMsgHk.dll
    c:\program files\Common Files\Symantec Shared\NPC\2.0\NPCEXT.dll
    c:\windows\system32\PortableDeviceTypes.dll
    c:\windows\system32\PortableDeviceApi.dll
    Completion time: 2009-12-15 20:49
    ComboFix-quarantined-files.txt 2009-12-15 20:48
    Pre-Run: 15,789,768,704 bytes free
    Post-Run: 19,655,749,632 bytes free
    WindowsXP-KB310994-SP2-Home-BootDisk-ENU.exe
    [boot loader]
    timeout=2
    default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
    [operating systems]
    c:\cmdcons\BOOTSECT.DAT= "Microsoft Windows Recovery Console" /cmdcons
    multi(0)disk(0)rdisk(0)partition(2)\WINDOWS= "Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
    - - End Of File - - ED9BD3EBC4C70C0E19CFEB89C5FA9382
