Help on expert on IE-8 on XP ?
Discussion in 'Internet Explorer & Microsoft Edge' started by tinto101, 2009/05/26.
  1. 2009/05/26
    tinto101
    tinto101 Inactive Thread Starter
    Basically you are being told that your current security settings expose the computer to risk - or so the Babel fish translation into English infers.
    Set each of the security settings to default - Tools > Internet Options > Security
    Alternatively Reset IE - Tools > Internet Options > Advanced - Reset
    tinto101
    re
    i try but none !!!
    is possible is
    either compromised your DNS or changed your hosts file?
    is possible is a porblem caused i go on internet via a
    server in my company ?
    help
  5. 2009/05/26
    Did IE 7 give you problems? If no problems uninstall IE 8 which should roll you back to IE 7.
    Maybe - ask your IT department.
  6. 2009/05/26
