Help Needed Uninstalling Phone Monitor Options
Discussion in 'Other PC Software' started by user__11063, 2003/12/21.
  1. 2003/12/21
    user__11063
    user__11063 Well-Known Member Thread Starter
    Hi everyone, hope someone is able to help with my small annoying problem. A while ago I installed some software for my mobile phone from Ericsson and it installed into the control panel an option called 'PHONE MONITOR OPTIONS'. I now know longer need this function and for the life of me I can't find out how you remove this program. It is not listed under the add/remove programs and I (think) have deleted the entry in the registry. It's only an annoying thing but no longer need it and if someone can tell me how to uninstall the program I would be much appreciated.
    I am running Windows XP Home Edition with SP1 and am proficient in editing the registry.
    Martyn
  2. 2003/12/21
    You might want to post the question to the Sony Ericsson Tutorials forum.
    If you've removed any registry entries, my guess is that step #1 will be to reload the app if it has any sort of uninstall optioni.
