help!my machine reboot very often!
Discussion in 'Windows XP' started by linsion, 2006/07/24.
  1. 2006/07/24
    linsion
    linsion Inactive Thread Starter
    here is the crash dump file!
    1:
    Microsoft (R) Windows Debugger Version 6.5.0003.7
    Loading Dump File [D:\Documents and Settings\Linsion\桌面\Minidump\Mini071306-07.dmp]
    Symbol search path is: C:\windows\Symbol
    Executable search path is:
    Unable to load image ntoskrnl.exe, Win32 error 2
    *** WARNING: Unable to verify timestamp for ntoskrnl.exe
    Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Kernel base = 0x804e0000 PsLoadedModuleList = 0x80563420
    Debug session time: Thu Jul 13 19:39:43.640 2006 (GMT+8)
    System Uptime: 0 days 1:23:45.250
    Loading Kernel Symbols
    Loading unloaded module list
    Loading User Symbols
    * Bugcheck Analysis *
    BugCheck 1000000A, {fa0c2d44, 2, 1, 804e2136}
    Probably caused by : ntoskrnl.exe ( nt!KiXMMIZeroPage+9d )
    Followup: MachineOwner
    kd> !analyze -v
    IRQL_NOT_LESS_OR_EQUAL (a)
    interrupt request level (IRQL) that is too high. This is usually
    caused by drivers using improper addresses.
    If a kernel debugger is available get the stack backtrace.
    Arguments:
    Arg1: fa0c2d44, memory referenced
    Arg2: 00000002, IRQL
    Arg3: 00000001, value 0 = read operation, 1 = write operation
    Arg4: 804e2136, address which referenced memory
    Debugging Details:
    WRITE_ADDRESS: fa0c2d44
    CURRENT_IRQL: 2
    FAULTING_IP:
    804e2136 8902 mov [edx],eax
    CUSTOMER_CRASH_COUNT: 7
    DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT
    BUGCHECK_STR: 0xA
    LAST_CONTROL_TRANSFER: from 00000000 to 804e2136
    STACK_TEXT:
    f8950dfc 00000000 f8209dba 81e6c0d8 81eeb008 nt!KiXMMIZeroPage+0x9d
    FOLLOWUP_IP:
    SYMBOL_STACK_INDEX: 0
    FOLLOWUP_NAME: MachineOwner
    SYMBOL_NAME: nt!KiXMMIZeroPage+9d
    MODULE_NAME: nt
    IMAGE_NAME: ntoskrnl.exe
    DEBUG_FLR_IMAGE_TIMESTAMP: 42250ff9
    STACK_COMMAND: kb
    FAILURE_BUCKET_ID: 0xA_W_nt!KiXMMIZeroPage+9d
  2. 2006/07/24
    linsion
    another crash dump file:
    *** WARNING: Unable to verify timestamp for nv4_mini.sys
    Probably caused by : nv4_mini.sys ( nv4_mini!notifyBufferHWComplete+1317 )
    kd> !analyze -v
    Arguments:
    Arg1: 031c2d44, memory referenced
    Arg3: 00000000, value 0 = read operation, 1 = write operation
    Arg4: 804e20aa, address which referenced memory
    Debugging Details:
    READ_ADDRESS: 031c2d44
    CURRENT_IRQL: 2
    FAULTING_IP:
    nt!KiXMMIZeroPage+11
    804e20aa 8b02 mov eax,[edx]
    CUSTOMER_CRASH_COUNT: 6
    BUGCHECK_STR: 0xA
    LAST_CONTROL_TRANSFER: from 81c522b4 to 804e20aa
    STACK_TEXT:
    f8950e0c 81c522b4 81d44008 f8209df7 81d48ab8 nt!KiXMMIZeroPage+0x11
    WARNING: Frame IP not in any known module. Following frames may be wrong.
    f8950e10 81d44008 f8209df7 81d48ab8 81d44008 0x81c522b4
    f8950e14 f8209df7 81d48ab8 81d44008 0bb14d44 0x81d44008
    f8950e18 81d48ab8 81d44008 0bb14d44 f8308b01 nv4_mini!notifyBufferHWComplete+0x1317
    f8950e24 f8308b01 81d44008 0bb14d44 00000000 0x81d48ab8
    f8950e48 00bb14d4 81ecae38 f830bfbd 81c82000 nv4_mini!nvHalGrLoadHW+0x161
    00000000 00000000 00000000 00000000 00000000 0xbb14d4
    FOLLOWUP_IP:
    f8209df7 ?? ???
    SYMBOL_STACK_INDEX: 3
    SYMBOL_NAME: nv4_mini!notifyBufferHWComplete+1317
    MODULE_NAME: nv4_mini
    IMAGE_NAME: nv4_mini.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 4074b958
    STACK_COMMAND: kb
    FAILURE_BUCKET_ID: 0xA_nv4_mini!notifyBufferHWComplete+1317
