Help my computer wont defrag on 1 of the patitions
Discussion in 'Windows XP' started by dantheman69, 2006/04/18.
  1. 2006/04/18
    dantheman69
    dantheman69 Inactive Thread Starter
    hi i need help my pc wont defrag on 1 of my patiancians it tells me to run chkdsk i did and it and it also tells u to run scandisk but it couldnt find it. i really wont to find out how to fix please get back to me asap
    thanks
    :mad: dan
  2. 2006/04/18
    dantheman69
    this is wat it says
    deftragmentation of [D:] has been aborted due to inconsistancies that were detected in the file system please run chkdsk or scandisk on [D:] to repair these inconsistancies than run disk defragmentor
    BUT IT DOSNT WORK PLZ HELPPPPPP!:mad:
    dantheman69, Please Do NOT use all caps or all bold characters while posting - this is considered screaming & impolite.
    Regarding your problem, which is the OS you are running & what's the utility you are using for defragmentation?
  5. 2006/04/19
    dantheman69
    i am running windows xp profesional and i am using the standard defragmeting program witch came with xp pro
    thanks dan
  6. 2006/04/19
    So run chkdsk on disk D (Start > Run then type cmd and press enter, then type chkdsk /f and press enter) .
    For more info read: How to perform disk error checking in Windows XP
  7. 2006/04/20
    dantheman69
    Thanks mate it workin now
    thanks heaps for that im so glad its workin my comp runs much better now
    thanks dan:) :D
  8. 2006/04/20
    your welcome!
