Headers & Footers v4.5
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by TUBA4, 2002/03/03.
  1. 2002/03/03
    TUBA4
    TUBA4 Inactive Thread Starter
    NETSC 4.5, W98. How do i set the header/footer info? I can't find that dialog window. I need to do the same for my other machime also after i get this one set up. Also, i want to know how to change the font & font size. Thanks Y'all. Regards, TUBA4
  2. 2002/03/03
    Dreambird
    Dreambird Inactive
    You should be able to find most of what you're looking for under edit menu>preferences>appearance.
    You can change some things for the toolbars there, don't know if it'll do everything you're looking for... but fonts you can change... which one and the size under the font menu.
    Ramona
    Ramona Geek Member Alumni
    Hi TUBA4,
    By "Headers and Footers" are you referring to the Toolbars? If so, you can enable/disable the Navigation, Location, Personal, and Component bar in View | Show.
    HTH,
    Ramona :D
