have network, but can't print
Discussion in 'Networking (Hardware & Software)' started by Marcelo, 2006/07/20.
  1. 2006/07/20
    Marcelo
    Marcelo Inactive Thread Starter
    Hello all,
    I have a laptop working fine except it cannot see the printer or ping another computer in the local netwotk.
    Again, I can access the internet with no problem.
    I'm posting the results of :
    ----> route print
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : blanca
    Node Type . . . . . . . . . . . . : Unknown
    Ethernet adapter Wireless Network Connection:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Ralink RT2500 Wireless LAN Card
    Physical Address. . . . . . . . . : 00-10-60-8E-A4-8B
    Dhcp Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    IP Address. . . . . . . . . . . . : 192.168.2.100
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.2.1
    DHCP Server . . . . . . . . . . . : 192.168.2.1
    DNS Servers . . . . . . . . . . . : 192.168.2.1
    Lease Obtained. . . . . . . . . . : Thursday, July 20, 2006 11:47:39 AM
    Lease Expires . . . . . . . . . . : Thursday, July 27, 2006 11:47:39 AM
    ---> ipconfig /all
    Interface List
    0x1 ........................... MS TCP Loopback interface
    0x2 ...00 10 60 8e a4 8b ...... Ralink RT2500 Wireless LAN Card - Packet Scheduler Miniport
    Active Routes:
    Network Destination Netmask Gateway Interface Metric
    0.0.0.0 0.0.0.0 192.168.2.1 192.168.2.100 30
    127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
    192.168.2.0 255.255.255.0 192.168.2.100 192.168.2.100 30
    192.168.2.10 255.255.255.255 192.168.2.4 192.168.2.100 1
    192.168.2.100 255.255.255.255 127.0.0.1 127.0.0.1 30
    192.168.2.255 255.255.255.255 192.168.2.100 192.168.2.100 30
    224.0.0.0 240.0.0.0 192.168.2.100 192.168.2.100 30
    255.255.255.255 255.255.255.255 192.168.2.100 192.168.2.100 1
    Default Gateway: 192.168.2.1
    Persistent Routes:
    Network Address Netmask Gateway Address Metric
    Hope you can help me. Many thanks, Marcelo
  2. 2006/07/20
    Marcelo
    I think I was not clear at all.
    The printer is on the local net, with ip 192.168.2.10
    The notebook gets its ip dynmicaly from a SMC router.
    Another notebook (different brand) sees the net with no problem.
    The ipconfig /all for the working computer has no "Persistent Route ", contrary to this one.
    The Node Type of the working computer is Peer-to-peer.
    I have no clue how to modify these values.
    Thanks, Marcelo
    Marcelo
    fixed
    The problem was that "persistent route" which got removed by typing:
    route -f
    thanks anyway. Marcelo.
  5. 2006/07/21
    Jason Qi
    Jason Qi Inactive
    Thank you for sharing your experience!
