hardware problem
Discussion in 'PC Hardware' started by mrpdwhite, 2006/12/14.
  1. 2006/12/14
    mrpdwhite
    mrpdwhite Inactive Thread Starter
    HI i am new here but i really need your help
    my laptop is advent 7105 and after its last update from windows update its not working properly
    it starts up normal but theres now no sound or my network card or even the ethernet.
    I have had no errors unless i try to connect to the internet get blank pages
    in media player its says i dont have a sound card
    if i got into device manager there are no red x or yellow warning logos
    if i go to sytem info it says
    cannot access the windows managment instrumentation this may have been moved or missing
    i made a recovery dvd the day i bought it and have now rstored so theres nothng actually missing
    the problem seems to be in the actuall detection of my hardware
    i thought the usb would be down but it works so i assume its built into the mobo on a laptop
    i have years of experience messing with my pc but not ever with a laptop
    i really ant to avoid formatting
    can anyone help me out please
    i am also available on msn with removed by moderator for your security
  2. 2006/12/14
    sparrow
    sparrow Inactive
    Welcome to the forum.
    Your recovery dvd has an alternative according to this site. Unless you have followed your manual, suggest you try the method mentioned there.
    Also, the Realtek AC'97 audio "sound card" is most likely a chip on the motherboard, and if it no longer works, there's not much you can do at home. Would first try removing it in device manager and rebooting to see if it's re-installed.
    If all fails, and the laptop is not too old, you might contact the manufacturer to see if the hardware, most likely the motherboard, warrants replacement, i.e., if the cost is not excessive.
    mrpdwhite
    the laptop is only 5 months old m8
    right i think theres a bug somewhere as all my settings were set to disabled but i dont know how
    i have matched them to the settings on my pc and so far so good
    i have made a system restore straight at that point
    i just need to find out how all my settng have been set
