hardware or XP? mouse problem
Discussion in 'Windows XP' started by gw1500se, 2003/05/30.
  1. 2003/05/30
    gw1500se
    gw1500se Well-Known Member Thread Starter
    I have a strange problem with my mouse dieing under XP. The only way I can fix it is to use the keyboard to reboot.
    I have a 2-way KVM switch for an ME machine and the XP machine. Occasionally (not every time) when I switch back to XP the mouse is frozen. So I have 2 questions:
    1) Is there a way to get XP to reset the mouse other then rebooting?
    2) If anyone has experienced a similar problem is this a hardware issue or a problem with XP (my ME machine is fine).
    Thanks.
  2. 2003/05/30
    Your KVM switch may not work well with XP. I'd check their web site and see if you can find out.
    MnInShdw
    MnInShdw Inactive
    In case of your first question:
    Go to device manager, click the plus sign beside Mouse and other pointing devices, select your mouse and select scan hardware from the shortcut menu or your toolbar.
    MnInShdw
  5. 2003/05/31
    gw1500se
    Newt:
    Thanks but there is no reference to any operating systems. It is entirely hardware, independent of what it is connected to.
  6. 2003/05/31
    Cliffh
    Cliffh Inactive
    I've used 4 different brands & types of KVM switches over the last few years - had the same problem you're experiencing with different versions of Windows, all of them would drop the mouse occasionally.
    The solution I use - a seperate mouse for each computer.
  7. 2003/05/31
    gw1500se
    Rats! Thanks not very encouraging. Thanks anyway.
