hard drive speed
Discussion in 'PC Hardware' started by csnudelman, 2002/07/13.
  1. 2002/07/13
    csnudelman
    csnudelman Inactive Thread Starter
    Recently I have read conflicting reports regarding 5400rpm vs. 7200rpm hard drives. While there is the position that in the 'real world' the net result (speed wise for the task) in almost, if not all cases of use is negligible there seems to be more opinions that the additional cost and noise is worth it. Opinions? :confused:
  2. 2002/07/13
    orndog
    orndog Inactive
    Given all else equal, a 7200rpm is faster. I'm sure it depends upon the applications you run, and how you run them (ie, do you install the video portions of games to your HD) as to whether or not it is worth it. Another consideration, I would assume that the 7200rpm drive would also run hotter, although having two in my system doesn't appear to be causing a problem. I'm sure it ends up at the point of just what link is the hamstring in your system?
    I noticed quite a speed increase when I originally went from 5,400 to 7,200 RPM drives. This was on a PII/350.
    Like orndog said, if your system can handle the adittional data (meaning the disk subsystem isn't a bottle-neck), 7,200 RMP drives will deliver the data faster...
    Rancher
    Rancher Inactive
    speed vrs access
    I could never go back to 5400rpm (except slave for storage) the 7200 are fast access too & that's the real key even if ya don't have a newer mobo that has ATA/100 :)
