Resolved Hard Drive Problem!
Discussion in 'PC Hardware' started by jodash, 2009/07/04.
  1. 2009/07/04
    jodash
    jodash Inactive Thread Starter
    Got a failed! Hard drive will not boot up,computer is on it's last legs so now using lap top is there a way I can transfer data
    Maxtor diamond max10 300 gb sata150 hdd
    bght a easy ide but connections are not right
    :confused:
  2. 2009/07/04
    Slave the drive in another computer, or if you have laptop only as your second computer, buy USB hard drive enclosure.
    jodash
    that worked thanks for the infomation
  5. 2009/07/11
    You're welcome :)
