hard drive is split into four seperate hard drives
Discussion in 'Legacy Windows' started by LazyBOy, 2004/08/23.
  1. 2004/08/23
    LazyBOy
    LazyBOy Inactive Thread Starter
    I have a hard drive that seems to be read as four different drives whenever I look into the My Computer, how can I get it to where it doesnt do that?
  2. 2004/08/23
    Does it show up as C, D, E & F drive (or some combination)?
    If so, you'd have to purchase a program like Partition Magic OR start over with a blank empty drive after to Fdisk to remove the partitions.
    BillyBob Inactive
    How about one hard drive divided into 4 partitions ?
    Is this a drive that you have been using, or one that you got from somewhere else.
    How large is the HD. 20gig ? 40gig ?
    I 20 then I sugggest 2 partitions, If 40 then I suggest 3 or 4 partitions.
    The method behind this maddness to to keep just the OS on the C: drive and everything else on other partitions. Various program backups which should not be stored on the C: drive for one thing.
    That way if the C:/OS should go bad everything is not lost.
    Bottom line--Over a period of time it pays to keep things separated.
    BillyBob
  5. 2004/08/25
    LazyBOy
    well thanks I'll probably keep things seperate after thinking about it. although do you know how I can change the capacity each partition can have?
  6. 2004/08/25
    BillyBob Inactive
    You would need the above to resize the pratitions without losing the data on them.
    BillyBob
  7. 2004/08/25
