Resolved Hard Drive Failure, so what next?
Discussion in 'PC Hardware' started by jdblue1976, 2012/04/14.
  1. 2012/04/14
    jdblue1976 Contributing Member
    jdblue1976 Well-Known Member Thread Starter
    The HDD on my desktop crashed. Partition Wizard surface test fails, sometime. I think it might be heat related.
    System Info
    Asus P5B-E motherboard, running Windows XP Media Center
    3 HDD
    Boot Drive (failed) WD 320GB
    WD 1TB
    Samsung 750GB
    I've got the original XP discs.
    I'm looking for what people think I should do next. Advice vs. "How to "
    Reload XP MC on one of the remaining HDD?
    Get a new drive and load it on that?
    Upgrade to Windows 7?
    I was going to use Partition Wizard to copy off the data but it says it's going to delete data on the target drive. (not good.)
    Thoughts?
  2. 2012/04/14
    If you can't slave your Data from the drive - your choice.
    XP support will cease 2014.
    If your comp will handle W7 - might pay to make the change with a new HD.
    Cheers Neil.
    Probably a good opportunity to upgrade to Win 7, agreed.
    Installing it on a new HD could be easier, I guess. Plus it wouldn't disturb my existing data.
    Just wanted to explore all options before I jump into this.
    Any other opinion?
  5. 2012/04/15
    Hi jdblue1976. A agree with Neil. I think installing Windows 7 on a new harddrive is a good choice. Plus you could install the 64-bit version of windows 7 which should give your computer better performance.
  6. 2012/04/15
    Before you consider the option of Win 7 make sure that your hardware, software is up to it .....
    Windows 7 Upgrade Advisor
  7. 2012/04/15
    Thanks for the advise. I checked the Win 7 requirements and it looks to be good to go, but I not sure about 64 bit. I don't think I have a 64 bit processor, but I'll double check that first.
    I'll have to find all the drivers for the peripheral stuff which is always fun. I heard Vista drivers work if you can't find Win 7 drivers.
  8. 2012/04/15
    More often than not the case :)
  9. 2012/04/15
    dnmacleod
    dnmacleod Well-Known Member
    I'll bet that you do have a 64 bit processor as they've been around for a long time now. If you're in any doubt get SIW
      File size:
      130.7 KB
      8
  10. 2012/04/15
    SpywareDr
  11. 2012/04/15
    I brought up the BIOS and yes it's a 2.33GHz Core 2 Duo 64 bit CPU. I couldn't remember from when I had it built (2007-ish) if I went 64 or not.
    Since I'm doing all this I guess I should look into upgrading the CPU to a Quad.
  12. 2012/04/15
    BTW: To save money ($80) I'll buy the Upgrade version of Win 7. But this means I'll have to reinstall XP first. (Oh joy) Plus I'll have to keep this discs around just in case I have to do this again.
  13. 2012/04/15
    Not necessarily - Win 7 has built in disk imaging software.
  14. 2012/04/15
    Actually you won't have to reinstall Windows XP at all. Take a look here, Clean Install with an Upgrade Windows 7 Version.
