Hard drive benchmark issue
Discussion in 'PC Hardware' started by Joey, 2005/03/19.
  1. 2005/03/19
    Joey
    Joey Inactive Thread Starter
    I did a benchmark test on my hard drive with FreshDiagnose and the results were..
    Write Speed Average = 18.03MB/s
    Read Speed Average = 14.47MB/s
    Does this look right :confused: I have a 2.4g Pentium4, 512ram and a 80gig 8meg cache Western Digital hard drive. The hard drive is running at UDMA5 and cache enabled. I have defragged, checked for spyware and virus.
    Anything else I should check ? Any other good HD benchmark s/w ?
    Joey,
  2. 2005/03/20
    Hi,
    Suggest you get the Lifeguard utilities from WD website and run those.
    Joey
    I tried the WD Data Lifeguard program but it just says it passed, no specifics.
    Joey,
    That was a quick post this morning before work.
    I agree, you should be getting higher read speeds than writes.
    No data from Lifeguard? I thought it was more informative than that (haven't used it in a long time). Could try Maxtor's Maxblast or Powermax (I think Maxblast is pretty friendly for non-Maxtor drives, Powermax maybe not).
    There is also HDtach and doing the www.PCpitstop.com tests, but PCpitstop may not do read/write tests.
    You can find programs above by doing a Google search.
    There were a few posts on this forum a while ago (end of last year). Try looking them up with a search. (Let me know if you cannot find them.) I think HDtach is one of the only freebies they mention.
    Look into PCmark05, but I had no luck with it.
    If you happen to have it, Norton Utilities can do read/write tests, but my old version states that you should backup your data for write tests, soooo I haven't touched that.
    Hope something there does the trick.
    EDIT: Get Everest in my signature (I don't have it installed at the moment). Look at the SMART information, I think it has read/write information.
