Resolved GuardedID corrupted system?
Discussion in 'Windows XP' started by eja, 2010/03/21.
  1. 2010/03/21
    eja
    eja Inactive Thread Starter
    I recently downloaded and installed a piece of software recommended by Lavasoft, called GuardedID. It is intended to prevent one's keystrokes from being detected and recorded by ne'er-do-well malware. Well, after installing it, I can no longer employ the driving function in two of my racing simulation programs, GTR2 and GT Legends. As soon as I click "DRIVE" to enter the track, the programs terminate ungracefully.
    I've uninstalled GuardedID, and uninstalled and re-installed both sims, and the behavior is the same.
    Has anyone heard of this? If so, do you know the fix?
    eja,
  2. 2010/03/22
    The only suggestion I'd have at this point is to do a system restore to a date prior to installing the GuardedID software.
    If Arie's suggestion doesn't work, look at resetting the driving controls in the game/s. Even just set them to some other controls, shut down and restart the game or even the computer , then reset them to the original (defaults?).
    PS: Maybe they think you should be guarded from playing those games, you ne'er-do-well :D
  5. 2010/03/30
    eja
    I brought my system to a professional PC wizard, and he did his magic and got them working. I hadn't had the checkpoint/restore function active; I didn't even know about it. It's active now...
    eja,
    Please mark this thread as 'Resolved', see .....
