Graphics Problem [Digital Output]
Discussion in 'PC Hardware' started by Adele2001, 2006/02/09.
  1. 2006/02/09
    Adele2001
    Adele2001 Inactive Thread Starter
    Hi, I just bought a new PC, windows xp, media centre. The graphics card that came with it is an Nvidia GEforce 6800 which has digital capability. I have a Samsung SyncMaster 181T monitor which I want to hook up digitally. So far, I have everything plugged in right but the monitor is still displaying in analogue mode. I have phoned Dell and Samsung, no-one seems to be able to help me. I was told to find out if my graphics card is outputting analogue or digital but the guy couldn't tell me how to do that. Anyone have any ideas? Would be greatly appreciated.
  2. 2006/02/09
    The only thing you should have to do is connect using a DVI cable.
    You can click the Source button of the monitor, which will re-check the input used.
    Adele2001
    I'm still not sure if it is working on analogue or digital tho. There is a menu on the monitor which says under Display Mode, that it is Analog. However, on my display settings on the computer, my monitor is listed as being digital. I am pretty confused.:confused:
  5. 2006/02/09
    On My Samsung SyncMaster 930BF there's a separate button (left of "Auto "). When I press it, is checks and will show "Analog" > "Digital" > "Digital ", meaning the monitor is running in Digital mode.
    The OSD also has an "Info" screen, which sows:
    Digital
    63.8kHz 60Hz PP
    1280x1024​
    Adele2001
    On mine, left of auto, there are two small lights, A + B, A is lit, B is not. On the OSD Info screen, it reads :
    64.0khz 60Hz PP
    1280x1024
    Analog​
    :mad:
  7. 2006/02/09
    I assume you are using a DVI cable?
    I don't know anything else that would be needed to run digital.
  8. 2006/02/09
    Adele2001
    Yes it's the cable that came with the monitor
  9. 2006/02/10
    Adele2001
    I have been messing around with the display settings and something is happening, but it aint working right:mad: On display settings I have 1. Syncmaster (Analogue) 2. SyncMaster (Digital). Is it seeing two monitors? If I choose the digital one and click use this as my main monitor, (on pushing exit on the monitor, B light is now lit), my desktop will now not work. At least I have got as far as it seeing the digital, but something is still not right. Any other thoughts?
  10. 2006/02/10
    Zander
    Zander Geek Member Alumni
  11. 2006/02/10
    Adele2001
    Yes I have both cables connected, blue to blue and white to white, according to Samsung manual this is correct.
  12. 2006/02/10
    :confused:
    You only should have the DVI cable connected, not both.
  13. 2006/02/10
    Christer
    Christer Geek Member Staff
    I have downloaded and checked the 181T manual and it actually says to connect both cables ...... :confused: ...... I "never" read the manual ...... :rolleyes: ...... and I would only connect one or the other. Try disconnecting the VGA (blue) cable and see what happens.
    Graphics cards with two outputs, one DVI and one VGA, often come with an DVI-to-VGA adapter which enables the connection of a second monitor to the same graphics card (if both monitors are VGA).
    Christer
  14. 2006/02/10
    Adele2001
    When I disconnect the blue cable (vga) screen won't work at all, just says "no signal ".
  15. 2006/02/10
    I'm sorry, but If it was me I'd bring a technician. Insist with Dell they come out & service you.
  16. 2006/02/10
    Adele2001
    I would but the last time I phoned Dell I was left hanging on the phone for over half an hour until eventually I got put through to some guy in India, who was supposed to be technical support. I have no idea how some of these guys get jobs, I think I know more about computers myself. He went from unplug this to plug this in. I was on my knees for most of the time. In the end I was so mad, I put down the phone. Then he rings me back, I refused to answer the phone, so he leaves a message to the effect of try unplugging this and plugging this and that, same ole stuff again. Needless to say, I really don't want to go down that road again. I think I will continue to fiddle around with the settings myself and see if I can get anywhere. If I do, I will post back. In the meantime, thanks for your replies and interest. Much appreciated.
  17. 2006/02/10
    Adele2001
    Well I am getting somewhere at last.:D
    I went into device manager and looked under monitors, there were 4 listed, two defaults, one samsung analog and one samsung digital. I disabled all but the digital one.
    Now I am running digital:) All seems to be working fine now except for when I reboot I get a "error loading CTMBHA.DLL" message. I can click it away and all works fine but wonder what it means:confused:
