Graphics Card Help
Discussion in 'PC Hardware' started by Chaosmachine420, 2010/03/19.
  1. 2010/03/19
    Chaosmachine420
    Chaosmachine420 Well-Known Member Thread Starter
    Im trying to find the best and right graphics card for my computer. The price I would pay is about $350 is the highest. I do play powerfull games on my computer along with using Maya, Mudbox, 3ds Max, Autocad, and Soildworks. I also need to know if I do get a new graphics card is if i need to up my power supply or keep the same.
  2. 2010/03/20
    hawk22
    hawk22 Geek Member
    Almost all new Graphics cards have Minimum System Requirements Information.
    You can Google them.
    See Tom's Hardware - Best Graphics Cards for the Money - March 2010. Then see my canned text below:
    Use the eXtreme PSU Calculator Lite to determine your power supply unit (PSU) requirements. Plug in all the hardware you think you might have in 2 or 3 years (extra drives, bigger or 2nd video card, more RAM, etc.). Be sure to read and heed the notes at the bottom of the page. I recommend setting Capacitor Aging to 30%, and if you participate in distributive computing projects (e.g. BOINC or Folding@Home) or extreme 3D animated gaming, I recommend setting both TDP and system load to 100%. These steps ensure the supply has adequate head room for stress free (and perhaps quieter) operation, and future hardware demands. Research your video card and pay particular attention to the power supply requirements for your card listed on your video card maker's website. If not listed, check a comparable card (same graphics engine and RAM) from a different maker. The key specifications, in order of importance are:
    1. Current (amperage or amps) on the +12V rail,
    2. Efficiency,
    3. Total wattage.
    Then look for power supply brands listed under the "Good" column of PC Mechanic's PSU Reference List. Ensure the supplied amperage on the +12V rails of your chosen PSU meets the requirements of your video card. Don't try to save a few dollars by getting a cheap supply. And don't count on supplies that come included with a case. They are often underrated, budget or poor quality models "tossed in" to make the case sale. Digital electronics, including CPUs, RAM, and today's advanced graphics cards, need clean, stable power. A good, well chosen supply will provide years of service and upgrade wiggle room. I strongly recommend you pick a supply with an efficiency rating equal to, or greater than 80%. Look for the 80 Plus - EnergyStar Compliant label. And don't forget to budget for a good UPS with AVR (automatic voltage regulation), as surge and spike protectors are inadequate.
    Bill,
    Chaosmachine420
    What about pins for it too if i need to put two power connectors on it or just on the one?
  6. 2010/03/20
    You won't know that until you select a card. That said, most current PSUs have the necessary connections.
    Bill,
    #5
