Solved Google Redirecting Problems
Discussion in 'Malware and Virus Removal Archive' started by atlgman, 2010/11/10.
  1. 2010/11/10
    atlgman
    atlgman Inactive Thread Starter
    [Resolved] Google Redirecting Problems
    Hello Everyone,
    I have lots of problems lately, especially Google redirecting. Every time I click on a link I get transferred to some advertising website. The reports are below. Any and all help is greatly appreciated.
    Thank you,
    Greg
    Malwarebytes' Anti-Malware 1.46
    www.malwarebytes.org
    Database version: 5086
    Windows 5.1.2600 Service Pack 2
    Internet Explorer 6.0.2900.2180
    11/10/2010 6:41:17 AM
    mbam-log-2010-11-10 (06-41-17).txt
    Scan type: Quick scan
    Objects scanned: 154190
    Time elapsed: 1 hour(s), 16 minute(s), 39 second(s)
    Memory Processes Infected: 0
    Memory Modules Infected: 0
    Registry Keys Infected: 0
    Registry Values Infected: 0
    Registry Data Items Infected: 2
    Folders Infected: 0
    Files Infected: 1
    (No malicious items detected)
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\AntiVirusDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
    Folders Infected:
    Files Infected:
    C:\Documents and Settings\a\Application Data\avdrn.dat (Malware.Trace) -> Quarantined and deleted successfully.
    GMER 1.0.15.15530 - http://www.gmer.net
    Rootkit scan 2010-11-10 10:24:41
    Windows 5.1.2600 Service Pack 2 Harddisk0\DR0 -> \Device\Ide\IdeDeviceP0T0L0-3 TOSHIBA_MK6034GSX rev.AH101A
    Running: dpuozhfk.exe; Driver: C:\DOCUME~1\a\LOCALS~1\Temp\pftdypod.sys
    ---- System - GMER 1.0.15 ----
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwCreateKey [0xF786D0E0]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwDeleteKey [0xF786D0F4]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwDeleteValueKey [0xF786D120]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwMapViewOfSection [0xF786D176]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwOpenKey [0xF786D0CC]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwOpenProcess [0xF786D0A4]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwOpenThread [0xF786D0B8]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwRenameKey [0xF786D10A]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwSetSecurityObject [0xF786D14C]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwSetValueKey [0xF786D136]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwTerminateProcess [0xF786D1A0]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwUnmapViewOfSection [0xF786D18C]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) ZwYieldExecution [0xF786D160]
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) NtMapViewOfSection
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) NtOpenProcess
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) NtOpenThread
    Code mfehidk.sys (McAfee Link Driver/McAfee, Inc.) NtSetSecurityObject
    ---- Kernel code sections - GMER 1.0.15 ----
    ? frdris.sys The system cannot find the file specified. !
    ---- User code sections - GMER 1.0.15 ----
    .text C:\WINDOWS\system32\svchost.exe[212] ntdll.dll!NtCreateFile 7C90D0AE 5 Bytes JMP 00720000
    .text C:\WINDOWS\system32\svchost.exe[212] ntdll.dll!NtCreateProcess 7C90D14E 5 Bytes JMP 00720FD4
    .text C:\WINDOWS\system32\svchost.exe[212] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00720FE5
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!CreateFileA 7C801A24 5 Bytes JMP 00870FEF
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!VirtualProtectEx 7C801A5D 5 Bytes JMP 00870076
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 0087005B
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!LoadLibraryExW 7C801AF1 5 Bytes JMP 0087004A
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!LoadLibraryExA 7C801D4F 5 Bytes JMP 00870039
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!LoadLibraryA 7C801D77 5 Bytes JMP 00870FBC
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!GetStartupInfoW 7C801E50 5 Bytes JMP 008700B6
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!GetStartupInfoA 7C801EEE 5 Bytes JMP 00870F64
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!CreateProcessW 7C802332 5 Bytes JMP 008700F6
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!CreateProcessA 7C802367 5 Bytes JMP 008700D1
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!GetProcAddress 7C80ADB0 5 Bytes JMP 00870F38
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!LoadLibraryW 7C80AE5B 5 Bytes JMP 00870F97
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!CreateFileW 7C810770 5 Bytes JMP 00870FDE
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!CreatePipe 7C81E0D7 5 Bytes JMP 0087009B
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!CreateNamedPipeW 7C82F0EF 5 Bytes JMP 0087001E
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!CreateNamedPipeA 7C85FE94 5 Bytes JMP 00870FCD
    .text C:\WINDOWS\system32\svchost.exe[212] kernel32.dll!WinExec 7C86158D 5 Bytes JMP 00870F53
    .text C:\WINDOWS\system32\svchost.exe[212] ADVAPI32.dll!RegOpenKeyExW 77DD6AAF 5 Bytes JMP 00860036
    .text C:\WINDOWS\system32\svchost.exe[212] ADVAPI32.dll!RegCreateKeyExW 77DD776C 5 Bytes JMP 00860062
    .text C:\WINDOWS\system32\svchost.exe[212] ADVAPI32.dll!RegOpenKeyExA 77DD7852 5 Bytes JMP 00860025
    .text C:\WINDOWS\system32\svchost.exe[212] ADVAPI32.dll!RegOpenKeyW 77DD7946 5 Bytes JMP 0086000A
    .text C:\WINDOWS\system32\svchost.exe[212] ADVAPI32.dll!RegCreateKeyExA 77DDE9D4 5 Bytes JMP 00860FAF
    .text C:\WINDOWS\system32\svchost.exe[212] ADVAPI32.dll!RegOpenKeyA 77DDEFA8 5 Bytes JMP 00860FEF
    .text C:\WINDOWS\system32\svchost.exe[212] ADVAPI32.dll!RegCreateKeyW 77DFBA3D 5 Bytes JMP 00860047
    .text C:\WINDOWS\system32\svchost.exe[212] ADVAPI32.dll!RegCreateKeyA 77DFBCDB 5 Bytes JMP 00860FC0
    .text C:\WINDOWS\system32\svchost.exe[212] msvcrt.dll!_wsystem 77C2931E 5 Bytes JMP 00750FDE
    .text C:\WINDOWS\system32\svchost.exe[212] msvcrt.dll!system 77C293C7 5 Bytes JMP 0075005F
    .text C:\WINDOWS\system32\svchost.exe[212] msvcrt.dll!_creat 77C2D40F 5 Bytes JMP 00750033
    .text C:\WINDOWS\system32\svchost.exe[212] msvcrt.dll!_open 77C2F566 5 Bytes JMP 00750FEF
    .text C:\WINDOWS\system32\svchost.exe[212] msvcrt.dll!_wcreat 77C2FC9B 5 Bytes JMP 0075004E
    .text C:\WINDOWS\system32\svchost.exe[212] msvcrt.dll!_wopen 77C30055 5 Bytes JMP 0075000C
    .text C:\WINDOWS\system32\svchost.exe[212] WININET.dll!InternetOpenW 771BAF6D 5 Bytes JMP 0074000A
    .text C:\WINDOWS\system32\svchost.exe[212] WININET.dll!InternetOpenA 771C57BE 5 Bytes JMP 00740FEF
    .text C:\WINDOWS\system32\svchost.exe[212] WININET.dll!InternetOpenUrlA 771C5A8A 5 Bytes JMP 0074001B
    .text C:\WINDOWS\system32\svchost.exe[212] WININET.dll!InternetOpenUrlW 771D5C0F 5 Bytes JMP 00740FC8
    .text C:\WINDOWS\system32\svchost.exe[212] WS2_32.dll!socket 71AB3B91 5 Bytes JMP 0073000A
    .text C:\WINDOWS\Explorer.EXE[576] ntdll.dll!NtCreateFile 7C90D0AE 5 Bytes JMP 00C80FEF
    .text C:\WINDOWS\Explorer.EXE[576] ntdll.dll!NtCreateProcess 7C90D14E 5 Bytes JMP 00C80025
    .text C:\WINDOWS\Explorer.EXE[576] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00C8000A
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!CreateFileA 7C801A24 5 Bytes JMP 00E80FEF
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!VirtualProtectEx 7C801A5D 5 Bytes JMP 00E80F7A
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 00E80065
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!LoadLibraryExW 7C801AF1 5 Bytes JMP 00E80054
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!LoadLibraryExA 7C801D4F 5 Bytes JMP 00E80FA1
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!LoadLibraryA 7C801D77 5 Bytes JMP 00E80039
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!GetStartupInfoW 7C801E50 5 Bytes JMP 00E80F2E
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!GetStartupInfoA 7C801EEE 5 Bytes JMP 00E80080
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!CreateProcessW 7C802332 5 Bytes JMP 00E800A2
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!CreateProcessA 7C802367 5 Bytes JMP 00E80F09
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!GetProcAddress 7C80ADB0 5 Bytes JMP 00E800BD
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!LoadLibraryW 7C80AE5B 5 Bytes JMP 00E80FB2
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!CreateFileW 7C810770 5 Bytes JMP 00E80FDE
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!CreatePipe 7C81E0D7 5 Bytes JMP 00E80F5F
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!CreateNamedPipeW 7C82F0EF 5 Bytes JMP 00E80FCD
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!CreateNamedPipeA 7C85FE94 5 Bytes JMP 00E80014
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!WinExec 7C86158D 1 Byte [E9]
    .text C:\WINDOWS\Explorer.EXE[576] kernel32.dll!WinExec 7C86158D 5 Bytes JMP 00E80091
    .text C:\WINDOWS\Explorer.EXE[576] ADVAPI32.dll!RegOpenKeyExW 77DD6AAF 5 Bytes JMP 00E10FBC
    .text C:\WINDOWS\Explorer.EXE[576] ADVAPI32.dll!RegCreateKeyExW 77DD776C 5 Bytes JMP 00E10F75
    .text C:\WINDOWS\Explorer.EXE[576] ADVAPI32.dll!RegOpenKeyExA 77DD7852 5 Bytes JMP 00E10FCD
    .text C:\WINDOWS\Explorer.EXE[576] ADVAPI32.dll!RegOpenKeyW 77DD7946 5 Bytes JMP 00E10FDE
    .text C:\WINDOWS\Explorer.EXE[576] ADVAPI32.dll!RegCreateKeyExA 77DDE9D4 5 Bytes JMP 00E10032
    .text C:\WINDOWS\Explorer.EXE[576] ADVAPI32.dll!RegOpenKeyA 77DDEFA8 5 Bytes JMP 00E10FEF
    .text C:\WINDOWS\Explorer.EXE[576] ADVAPI32.dll!RegCreateKeyW 77DFBA3D 2 Bytes JMP 00E10F90
    .text C:\WINDOWS\Explorer.EXE[576] ADVAPI32.dll!RegCreateKeyW + 3 77DFBA40 2 Bytes [01, 89]
    .text C:\WINDOWS\Explorer.EXE[576] ADVAPI32.dll!RegCreateKeyA 77DFBCDB 5 Bytes JMP 00E10FAB
    .text C:\WINDOWS\Explorer.EXE[576] msvcrt.dll!_wsystem 77C2931E 5 Bytes JMP 00E00FA1
    .text C:\WINDOWS\Explorer.EXE[576] msvcrt.dll!system 77C293C7 5 Bytes JMP 00E00FB2
    .text C:\WINDOWS\Explorer.EXE[576] msvcrt.dll!_creat 77C2D40F 5 Bytes JMP 00E00FDE
    .text C:\WINDOWS\Explorer.EXE[576] msvcrt.dll!_open 77C2F566 5 Bytes JMP 00E00000
    .text C:\WINDOWS\Explorer.EXE[576] msvcrt.dll!_wcreat 77C2FC9B 5 Bytes JMP 00E00FC3
    .text C:\WINDOWS\Explorer.EXE[576] msvcrt.dll!_wopen 77C30055 5 Bytes JMP 00E00FEF
    .text C:\WINDOWS\Explorer.EXE[576] WININET.dll!InternetOpenW 771BAF6D 5 Bytes JMP 00DF0FD4
    .text C:\WINDOWS\Explorer.EXE[576] WININET.dll!InternetOpenA 771C57BE 5 Bytes JMP 00DF0FEF
    .text C:\WINDOWS\Explorer.EXE[576] WININET.dll!InternetOpenUrlA 771C5A8A 5 Bytes JMP 00DF000C
    .text C:\WINDOWS\Explorer.EXE[576] WININET.dll!InternetOpenUrlW 771D5C0F 5 Bytes JMP 00DF001D
    .text C:\WINDOWS\Explorer.EXE[576] WS2_32.dll!socket 71AB3B91 5 Bytes JMP 00D10FE5
    .text C:\WINDOWS\system32\services.exe[1060] ntdll.dll!NtCreateFile 7C90D0AE 5 Bytes JMP 00040000
    .text C:\WINDOWS\system32\services.exe[1060] ntdll.dll!NtCreateProcess 7C90D14E 5 Bytes JMP 00040025
    .text C:\WINDOWS\system32\services.exe[1060] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00040FE5
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!CreateFileA 7C801A24 5 Bytes JMP 00800FEF
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!VirtualProtectEx 7C801A5D 5 Bytes JMP 00800F9C
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 00800091
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!LoadLibraryExW 7C801AF1 5 Bytes JMP 00800076
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!LoadLibraryExA 7C801D4F 5 Bytes JMP 00800065
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!LoadLibraryA 7C801D77 5 Bytes JMP 00800039
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!GetStartupInfoW 7C801E50 5 Bytes JMP 00800F70
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!GetStartupInfoA 7C801EEE 5 Bytes JMP 00800F81
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!CreateProcessW 7C802332 5 Bytes JMP 00800F3A
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!CreateProcessA 7C802367 5 Bytes JMP 00800F55
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!GetProcAddress 7C80ADB0 5 Bytes JMP 008000EE
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!LoadLibraryW 7C80AE5B 5 Bytes JMP 0080004A
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!CreateFileW 7C810770 5 Bytes JMP 00800FD4
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!CreatePipe 7C81E0D7 5 Bytes JMP 008000A2
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!CreateNamedPipeW 7C82F0EF 5 Bytes JMP 00800FC3
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!CreateNamedPipeA 7C85FE94 5 Bytes JMP 00800014
    .text C:\WINDOWS\system32\services.exe[1060] kernel32.dll!WinExec 7C86158D 5 Bytes JMP 008000C9
    .text C:\WINDOWS\system32\services.exe[1060] ADVAPI32.dll!RegOpenKeyExW 77DD6AAF 5 Bytes JMP 00070036
    .text C:\WINDOWS\system32\services.exe[1060] ADVAPI32.dll!RegCreateKeyExW 77DD776C 5 Bytes JMP 00070F9B
    .text C:\WINDOWS\system32\services.exe[1060] ADVAPI32.dll!RegOpenKeyExA 77DD7852 5 Bytes JMP 0007001B
    .text C:\WINDOWS\system32\services.exe[1060] ADVAPI32.dll!RegOpenKeyW 77DD7946 5 Bytes JMP 0007000A
    .text C:\WINDOWS\system32\services.exe[1060] ADVAPI32.dll!RegCreateKeyExA 77DDE9D4 5 Bytes JMP 00070058
    .text C:\WINDOWS\system32\services.exe[1060] ADVAPI32.dll!RegOpenKeyA 77DDEFA8 5 Bytes JMP 00070FEF
    .text C:\WINDOWS\system32\services.exe[1060] ADVAPI32.dll!RegCreateKeyW 77DFBA3D 2 Bytes JMP 00070FC0
    .text C:\WINDOWS\system32\services.exe[1060] ADVAPI32.dll!RegCreateKeyW + 3 77DFBA40 2 Bytes [27, 88]
    .text C:\WINDOWS\system32\services.exe[1060] ADVAPI32.dll!RegCreateKeyA 77DFBCDB 5 Bytes JMP 00070047
    .text C:\WINDOWS\system32\services.exe[1060] msvcrt.dll!_wsystem 77C2931E 5 Bytes JMP 00060FA3
    .text C:\WINDOWS\system32\services.exe[1060] msvcrt.dll!system 77C293C7 5 Bytes JMP 00060038
    .text C:\WINDOWS\system32\services.exe[1060] msvcrt.dll!_creat 77C2D40F 5 Bytes JMP 00060FD2
    .text C:\WINDOWS\system32\services.exe[1060] msvcrt.dll!_open 77C2F566 5 Bytes JMP 00060000
    .text C:\WINDOWS\system32\services.exe[1060] msvcrt.dll!_wcreat 77C2FC9B 5 Bytes JMP 0006001D
    .text C:\WINDOWS\system32\services.exe[1060] msvcrt.dll!_wopen 77C30055 5 Bytes JMP 00060FE3
    .text C:\WINDOWS\system32\services.exe[1060] WS2_32.dll!socket 71AB3B91 5 Bytes JMP 00050FEF
    .text C:\WINDOWS\system32\lsass.exe[1072] ntdll.dll!NtCreateFile 7C90D0AE 5 Bytes JMP 00F00FEF
    .text C:\WINDOWS\system32\lsass.exe[1072] ntdll.dll!NtCreateProcess 7C90D14E 5 Bytes JMP 00F0000A
    .text C:\WINDOWS\system32\lsass.exe[1072] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00F00FD4
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!CreateFileA 7C801A24 5 Bytes JMP 00F40FEF
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!VirtualProtectEx 7C801A5D 5 Bytes JMP 00F40F7E
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 00F40F8F
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!LoadLibraryExW 7C801AF1 5 Bytes JMP 00F40069
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!LoadLibraryExA 7C801D4F 5 Bytes JMP 00F40058
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!LoadLibraryA 7C801D77 5 Bytes JMP 00F4002C
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!GetStartupInfoW 7C801E50 5 Bytes JMP 00F4009A
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!GetStartupInfoA 7C801EEE 5 Bytes JMP 00F40F48
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!CreateProcessW 7C802332 5 Bytes JMP 00F400BC
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!CreateProcessA 7C802367 5 Bytes JMP 00F400AB
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!GetProcAddress 7C80ADB0 5 Bytes JMP 00F400CD
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!LoadLibraryW 7C80AE5B 5 Bytes JMP 00F4003D
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!CreateFileW 7C810770 5 Bytes JMP 00F4000A
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!CreatePipe 7C81E0D7 5 Bytes JMP 00F40F59
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!CreateNamedPipeW 7C82F0EF 5 Bytes JMP 00F4001B
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!CreateNamedPipeA 7C85FE94 5 Bytes JMP 00F40FCA
    .text C:\WINDOWS\system32\lsass.exe[1072] kernel32.dll!WinExec 7C86158D 5 Bytes JMP 00F40F2D
    .text C:\WINDOWS\system32\lsass.exe[1072] ADVAPI32.dll!RegOpenKeyExW 77DD6AAF 5 Bytes JMP 00F3002F
    .text C:\WINDOWS\system32\lsass.exe[1072] ADVAPI32.dll!RegCreateKeyExW 77DD776C 5 Bytes JMP 00F30076
    .text C:\WINDOWS\system32\lsass.exe[1072] ADVAPI32.dll!RegOpenKeyExA 77DD7852 5 Bytes JMP 00F30FDE
    .text C:\WINDOWS\system32\lsass.exe[1072] ADVAPI32.dll!RegOpenKeyW 77DD7946 5 Bytes JMP 00F30FEF
    .text C:\WINDOWS\system32\lsass.exe[1072] ADVAPI32.dll!RegCreateKeyExA 77DDE9D4 5 Bytes JMP 00F30FAF
    .text C:\WINDOWS\system32\lsass.exe[1072] ADVAPI32.dll!RegOpenKeyA 77DDEFA8 5 Bytes JMP 00F30000
    .text C:\WINDOWS\system32\lsass.exe[1072] ADVAPI32.dll!RegCreateKeyW 77DFBA3D 5 Bytes JMP 00F30051
    .text C:\WINDOWS\system32\lsass.exe[1072] ADVAPI32.dll!RegCreateKeyA 77DFBCDB 5 Bytes JMP 00F30040
    .text C:\WINDOWS\system32\lsass.exe[1072] msvcrt.dll!_wsystem 77C2931E 5 Bytes JMP 00F20042
    .text C:\WINDOWS\system32\lsass.exe[1072] msvcrt.dll!system 77C293C7 5 Bytes JMP 00F20FB7
    .text C:\WINDOWS\system32\lsass.exe[1072] msvcrt.dll!_creat 77C2D40F 5 Bytes JMP 00F2001D
    .text C:\WINDOWS\system32\lsass.exe[1072] msvcrt.dll!_open 77C2F566 5 Bytes JMP 00F20FE3
    .text C:\WINDOWS\system32\lsass.exe[1072] msvcrt.dll!_wcreat 77C2FC9B 5 Bytes JMP 00F20FC8
    .text C:\WINDOWS\system32\lsass.exe[1072] msvcrt.dll!_wopen 77C30055 5 Bytes JMP 00F20000
    .text C:\WINDOWS\system32\lsass.exe[1072] WS2_32.dll!socket 71AB3B91 5 Bytes JMP 00F1000A
    .text C:\WINDOWS\system32\svchost.exe[1236] ntdll.dll!NtCreateFile 7C90D0AE 5 Bytes JMP 00DC000A
    .text C:\WINDOWS\system32\svchost.exe[1236] ntdll.dll!NtCreateProcess 7C90D14E 5 Bytes JMP 00DC0FE5
    .text C:\WINDOWS\system32\svchost.exe[1236] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00DC001B
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!CreateFileA 7C801A24 5 Bytes JMP 00E00FEF
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!VirtualProtectEx 7C801A5D 5 Bytes JMP 00E00F68
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 00E00F8D
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!LoadLibraryExW 7C801AF1 5 Bytes JMP 00E00F9E
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!LoadLibraryExA 7C801D4F 5 Bytes JMP 00E00FAF
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!LoadLibraryA 7C801D77 5 Bytes JMP 00E0002C
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!GetStartupInfoW 7C801E50 5 Bytes JMP 00E0009D
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!GetStartupInfoA 7C801EEE 5 Bytes JMP 00E00F4B
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!CreateProcessW 7C802332 5 Bytes JMP 00E00F15
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!CreateProcessA 7C802367 5 Bytes JMP 00E000AE
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!GetProcAddress 7C80ADB0 5 Bytes JMP 00E000C9
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!LoadLibraryW 7C80AE5B 5 Bytes JMP 00E00051
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!CreateFileW 7C810770 5 Bytes JMP 00E00000
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!CreatePipe 7C81E0D7 5 Bytes JMP 00E00078
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!CreateNamedPipeW 7C82F0EF 5 Bytes JMP 00E00FCA
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!CreateNamedPipeA 7C85FE94 5 Bytes JMP 00E0001B
    .text C:\WINDOWS\system32\svchost.exe[1236] kernel32.dll!WinExec 7C86158D 5 Bytes JMP 00E00F3A
    .text C:\WINDOWS\system32\svchost.exe[1236] ADVAPI32.dll!RegOpenKeyExW 77DD6AAF 5 Bytes JMP 00DF0036
    .text C:\WINDOWS\system32\svchost.exe[1236] ADVAPI32.dll!RegCreateKeyExW 77DD776C 5 Bytes JMP 00DF0F9E
    .text C:\WINDOWS\system32\svchost.exe[1236] ADVAPI32.dll!RegOpenKeyExA 77DD7852 5 Bytes JMP 00DF0025
    .text C:\WINDOWS\system32\svchost.exe[1236] ADVAPI32.dll!RegOpenKeyW 77DD7946 5 Bytes JMP 00DF0014
    .text C:\WINDOWS\system32\svchost.exe[1236] ADVAPI32.dll!RegCreateKeyExA 77DDE9D4 5 Bytes JMP 00DF0FAF
    .text C:\WINDOWS\system32\svchost.exe[1236] ADVAPI32.dll!RegOpenKeyA 77DDEFA8 5 Bytes JMP 00DF0FEF
    .text C:\WINDOWS\system32\svchost.exe[1236] ADVAPI32.dll!RegCreateKeyW 77DFBA3D 2 Bytes JMP 00DF0FCA
    .text C:\WINDOWS\system32\svchost.exe[1236] ADVAPI32.dll!RegCreateKeyW + 3 77DFBA40 2 Bytes [FF, 88]
    .text C:\WINDOWS\system32\svchost.exe[1236] ADVAPI32.dll!RegCreateKeyA 77DFBCDB 5 Bytes JMP 00DF0051
    .text C:\WINDOWS\system32\svchost.exe[1236] msvcrt.dll!_wsystem 77C2931E 5 Bytes JMP 00DE0F81
    .text C:\WINDOWS\system32\svchost.exe[1236] msvcrt.dll!system 77C293C7 5 Bytes JMP 00DE0F9C
    .text C:\WINDOWS\system32\svchost.exe[1236] msvcrt.dll!_creat 77C2D40F 5 Bytes JMP 00DE0FC1
    .text C:\WINDOWS\system32\svchost.exe[1236] msvcrt.dll!_open 77C2F566 5 Bytes JMP 00DE0FEF
    .text C:\WINDOWS\system32\svchost.exe[1236] msvcrt.dll!_wcreat 77C2FC9B 5 Bytes JMP 00DE000C
    .text C:\WINDOWS\system32\svchost.exe[1236] msvcrt.dll!_wopen 77C30055 5 Bytes JMP 00DE0FD2
    .text C:\WINDOWS\system32\svchost.exe[1236] WS2_32.dll!socket 71AB3B91 5 Bytes JMP 00DD0FE5
    .text C:\WINDOWS\system32\svchost.exe[1336] ntdll.dll!NtCreateFile 7C90D0AE 5 Bytes JMP 00860FEF
    .text C:\WINDOWS\system32\svchost.exe[1336] ntdll.dll!NtCreateProcess 7C90D14E 5 Bytes JMP 00860FB9
    .text C:\WINDOWS\system32\svchost.exe[1336] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00860FDE
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!CreateFileA 7C801A24 5 Bytes JMP 00950000
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!VirtualProtectEx 7C801A5D 5 Bytes JMP 00950F70
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 00950065
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!LoadLibraryExW 7C801AF1 5 Bytes JMP 00950054
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!LoadLibraryExA 7C801D4F 5 Bytes JMP 00950F97
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!LoadLibraryA 7C801D77 5 Bytes JMP 00950FB9
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!GetStartupInfoW 7C801E50 5 Bytes JMP 00950F3D
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!GetStartupInfoA 7C801EEE 5 Bytes JMP 00950F4E
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!CreateProcessW 7C802332 5 Bytes JMP 00950EFD
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!CreateProcessA 7C802367 5 Bytes JMP 00950F0E
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!GetProcAddress 7C80ADB0 5 Bytes JMP 009500B1
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!LoadLibraryW 7C80AE5B 5 Bytes JMP 00950FA8
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!CreateFileW 7C810770 5 Bytes JMP 00950FE5
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!CreatePipe 7C81E0D7 5 Bytes JMP 00950F5F
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!CreateNamedPipeW 7C82F0EF 5 Bytes JMP 00950025
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!CreateNamedPipeA 7C85FE94 5 Bytes JMP 00950FD4
    .text C:\WINDOWS\system32\svchost.exe[1336] kernel32.dll!WinExec 7C86158D 5 Bytes JMP 00950096
    .text C:\WINDOWS\system32\svchost.exe[1336] ADVAPI32.dll!RegOpenKeyExW 77DD6AAF 5 Bytes JMP 0089000A
  2. 2010/11/10
    Welcome aboard :)
    Please, observe following rules:
    • Read all of my instructions very carefully. Your mistakes during cleaning process may have very serious consequences, like unbootable computer.
    • If you're stuck, or you're not sure about certain step, always ask before doing anything else.
    • Please refrain from running tools or applying updates other than those I suggest.
    • Never run more than one scan at a time.
    • Keep updating me regarding your computer behavior, good, or bad.
    • The cleaning process, once started, has to be completed. Even if your computer appears to act better, it may still be infected. Once the computer is totally clean, I'll certainly let you know.
    • If you leave the topic without explanation in the middle of a cleaning process, you may not be eligible to receive any more help in malware removal forum.
    • I close my topics if you have not replied in 5 days. If you need more time, simply let me know. If I closed your topic and you need it to be reopened, simply PM me.
    GMER log is incomplete and I need other logs as well.
    I'm off to work, so I'll catch you later.
    atlgman
    .text C:\WINDOWS\System32\svchost.exe[1384] msvcrt.dll!_open 77C2F566 5 Bytes JMP 02730FE3
    .text C:\WINDOWS\System32\svchost.exe[1384] msvcrt.dll!_wcreat 77C2FC9B 5 Bytes JMP 0273002E
    .text C:\WINDOWS\System32\svchost.exe[1384] msvcrt.dll!_wopen 77C30055 5 Bytes JMP 02730000
    .text C:\WINDOWS\System32\svchost.exe[1384] WS2_32.dll!socket 71AB3B91 5 Bytes JMP 02710FEF
    .text C:\WINDOWS\System32\svchost.exe[1384] WININET.dll!InternetOpenW 771BAF6D 5 Bytes JMP 02720025
    .text C:\WINDOWS\System32\svchost.exe[1384] WININET.dll!InternetOpenA 771C57BE 5 Bytes JMP 02720000
    .text C:\WINDOWS\System32\svchost.exe[1384] WININET.dll!InternetOpenUrlA 771C5A8A 5 Bytes JMP 02720FEF
    .text C:\WINDOWS\System32\svchost.exe[1384] WININET.dll!InternetOpenUrlW 771D5C0F 5 Bytes JMP 02720FDE
    .text C:\Program Files\Mozilla Firefox\firefox.exe[1492] ntdll.dll!LdrLoadDll 7C915CD3 5 Bytes JMP 004013F0 C:\Program Files\Mozilla Firefox\firefox.exe (Firefox/Mozilla Corporation)
    .text C:\WINDOWS\system32\svchost.exe[1532] ntdll.dll!NtCreateFile 7C90D0AE 5 Bytes JMP 00880000
    .text C:\WINDOWS\system32\svchost.exe[1532] ntdll.dll!NtCreateProcess 7C90D14E 5 Bytes JMP 00880FE5
    .text C:\WINDOWS\system32\svchost.exe[1532] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00880011
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!CreateFileA 7C801A24 5 Bytes JMP 008C0FEF
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!VirtualProtectEx 7C801A5D 5 Bytes JMP 008C0071
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 008C0F7C
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!LoadLibraryExW 7C801AF1 5 Bytes JMP 008C0F8D
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!LoadLibraryExA 7C801D4F 5 Bytes JMP 008C0F9E
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!LoadLibraryA 7C801D77 5 Bytes JMP 008C0040
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!GetStartupInfoW 7C801E50 5 Bytes JMP 008C0F3A
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!GetStartupInfoA 7C801EEE 5 Bytes JMP 008C0082
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!CreateProcessW 7C802332 5 Bytes JMP 008C0EFD
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!CreateProcessA 7C802367 5 Bytes JMP 008C0F0E
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!GetProcAddress 7C80ADB0 5 Bytes JMP 008C0EEC
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!LoadLibraryW 7C80AE5B 5 Bytes JMP 008C0FB9
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!CreateFileW 7C810770 5 Bytes JMP 008C0FDE
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!CreatePipe 7C81E0D7 5 Bytes JMP 008C0F57
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!CreateNamedPipeW 7C82F0EF 5 Bytes JMP 008C0025
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!CreateNamedPipeA 7C85FE94 5 Bytes JMP 008C0014
    .text C:\WINDOWS\system32\svchost.exe[1532] kernel32.dll!WinExec 7C86158D 5 Bytes JMP 008C0F29
    .text C:\WINDOWS\system32\svchost.exe[1532] ADVAPI32.dll!RegOpenKeyExW 77DD6AAF 5 Bytes JMP 008B0FCD
    .text C:\WINDOWS\system32\svchost.exe[1532] ADVAPI32.dll!RegCreateKeyExW 77DD776C 5 Bytes JMP 008B0F8D
    .text C:\WINDOWS\system32\svchost.exe[1532] ADVAPI32.dll!RegOpenKeyExA 77DD7852 5 Bytes JMP 008B0FDE
    .text C:\WINDOWS\system32\svchost.exe[1532] ADVAPI32.dll!RegOpenKeyW 77DD7946 5 Bytes JMP 008B0FEF
    .text C:\WINDOWS\system32\svchost.exe[1532] ADVAPI32.dll!RegCreateKeyExA 77DDE9D4 5 Bytes JMP 008B004A
    .text C:\WINDOWS\system32\svchost.exe[1532] ADVAPI32.dll!RegOpenKeyA 77DDEFA8 5 Bytes JMP 008B000A
    .text C:\WINDOWS\system32\svchost.exe[1532] ADVAPI32.dll!RegCreateKeyW 77DFBA3D 5 Bytes JMP 008B002F
    .text C:\WINDOWS\system32\svchost.exe[1532] ADVAPI32.dll!RegCreateKeyA 77DFBCDB 5 Bytes JMP 008B0FA8
    .text C:\WINDOWS\system32\svchost.exe[1532] msvcrt.dll!_wsystem 77C2931E 5 Bytes JMP 008A0FAD
    .text C:\WINDOWS\system32\svchost.exe[1532] msvcrt.dll!system 77C293C7 5 Bytes JMP 008A0038
    .text C:\WINDOWS\system32\svchost.exe[1532] msvcrt.dll!_creat 77C2D40F 5 Bytes JMP 008A0FD2
    .text C:\WINDOWS\system32\svchost.exe[1532] msvcrt.dll!_open 77C2F566 5 Bytes JMP 008A0000
    .text C:\WINDOWS\system32\svchost.exe[1532] msvcrt.dll!_wcreat 77C2FC9B 5 Bytes JMP 008A0027
    .text C:\WINDOWS\system32\svchost.exe[1532] msvcrt.dll!_wopen 77C30055 5 Bytes JMP 008A0FEF
    .text C:\WINDOWS\system32\svchost.exe[1532] WS2_32.dll!socket 71AB3B91 5 Bytes JMP 00890FEF
    .text C:\WINDOWS\system32\svchost.exe[1644] ntdll.dll!NtCreateFile 7C90D0AE 5 Bytes JMP 0098000A
    .text C:\WINDOWS\system32\svchost.exe[1644] ntdll.dll!NtCreateProcess 7C90D14E 5 Bytes JMP 00980FDE
    .text C:\WINDOWS\system32\svchost.exe[1644] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00980FEF
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!CreateFileA 7C801A24 5 Bytes JMP 009C0FEF
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!VirtualProtectEx 7C801A5D 5 Bytes JMP 009C0F94
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 009C0FAF
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!LoadLibraryExW 7C801AF1 5 Bytes JMP 009C007D
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!LoadLibraryExA 7C801D4F 5 Bytes JMP 009C0FC0
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!LoadLibraryA 7C801D77 5 Bytes JMP 009C0051
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!GetStartupInfoW 7C801E50 5 Bytes JMP 009C0F41
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!GetStartupInfoA 7C801EEE 5 Bytes JMP 009C0F5C
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!CreateProcessW 7C802332 5 Bytes JMP 009C0F1F
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!CreateProcessA 7C802367 5 Bytes JMP 009C0F30
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!GetProcAddress 7C80ADB0 5 Bytes JMP 009C00D3
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!LoadLibraryW 7C80AE5B 5 Bytes JMP 009C006C
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!CreateFileW 7C810770 5 Bytes JMP 009C0000
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!CreatePipe 7C81E0D7 5 Bytes JMP 009C0F79
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!CreateNamedPipeW 7C82F0EF 5 Bytes JMP 009C0036
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!CreateNamedPipeA 7C85FE94 5 Bytes JMP 009C001B
    .text C:\WINDOWS\system32\svchost.exe[1644] kernel32.dll!WinExec 7C86158D 5 Bytes JMP 009C00A4
    .text C:\WINDOWS\system32\svchost.exe[1644] ADVAPI32.dll!RegOpenKeyExW 77DD6AAF 5 Bytes JMP 009B0051
    .text C:\WINDOWS\system32\svchost.exe[1644] ADVAPI32.dll!RegCreateKeyExW 77DD776C 5 Bytes JMP 009B007D
    .text C:\WINDOWS\system32\svchost.exe[1644] ADVAPI32.dll!RegOpenKeyExA 77DD7852 5 Bytes JMP 009B0036
    .text C:\WINDOWS\system32\svchost.exe[1644] ADVAPI32.dll!RegOpenKeyW 77DD7946 5 Bytes JMP 009B001B
    .text C:\WINDOWS\system32\svchost.exe[1644] ADVAPI32.dll!RegCreateKeyExA 77DDE9D4 5 Bytes JMP 009B0FC0
    .text C:\WINDOWS\system32\svchost.exe[1644] ADVAPI32.dll!RegOpenKeyA 77DDEFA8 5 Bytes JMP 009B000A
    .text C:\WINDOWS\system32\svchost.exe[1644] ADVAPI32.dll!RegCreateKeyW 77DFBA3D 2 Bytes JMP 009B0FDB
    .text C:\WINDOWS\system32\svchost.exe[1644] ADVAPI32.dll!RegCreateKeyW + 3 77DFBA40 2 Bytes [BB, 88]
    .text C:\WINDOWS\system32\svchost.exe[1644] ADVAPI32.dll!RegCreateKeyA 77DFBCDB 5 Bytes JMP 009B0062
    .text C:\WINDOWS\system32\svchost.exe[1644] msvcrt.dll!_wsystem 77C2931E 5 Bytes JMP 009A004E
    .text C:\WINDOWS\system32\svchost.exe[1644] msvcrt.dll!system 77C293C7 5 Bytes JMP 009A003D
    .text C:\WINDOWS\system32\svchost.exe[1644] msvcrt.dll!_creat 77C2D40F 5 Bytes JMP 009A0011
    .text C:\WINDOWS\system32\svchost.exe[1644] msvcrt.dll!_open 77C2F566 5 Bytes JMP 009A0000
    .text C:\WINDOWS\system32\svchost.exe[1644] msvcrt.dll!_wcreat 77C2FC9B 5 Bytes JMP 009A002C
    .text C:\WINDOWS\system32\svchost.exe[1644] msvcrt.dll!_wopen 77C30055 5 Bytes JMP 009A0FD7
    .text C:\WINDOWS\system32\svchost.exe[1644] WS2_32.dll!socket 71AB3B91 5 Bytes JMP 00990000
    .text C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe[1948] kernel32.dll!LoadLibraryA 7C801D77 5 Bytes JMP 62419A20 C:\Program Files\Common Files\McAfee\McProxy\mcproxy.dll (McAfee Proxy Service Module/McAfee, Inc.)
    .text C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe[1948] kernel32.dll!LoadLibraryW 7C80AE5B 5 Bytes JMP 62419AE2 C:\Program Files\Common Files\McAfee\McProxy\mcproxy.dll (McAfee Proxy Service Module/McAfee, Inc.)
    .text C:\Program Files\Messenger\msmsgs.exe[2704] ntdll.dll!NtCreateFile 7C90D0AE 5 Bytes JMP 00EE0000
    .text C:\Program Files\Messenger\msmsgs.exe[2704] ntdll.dll!NtCreateProcess 7C90D14E 5 Bytes JMP 00EE002C
    .text C:\Program Files\Messenger\msmsgs.exe[2704] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00EE0011
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!CreateFileA 7C801A24 5 Bytes JMP 00F30000
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!VirtualProtectEx 7C801A5D 5 Bytes JMP 00F30F8A
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 00F30075
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!LoadLibraryExW 7C801AF1 5 Bytes JMP 00F30064
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!LoadLibraryExA 7C801D4F 5 Bytes JMP 00F30047
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!LoadLibraryA 7C801D77 5 Bytes JMP 00F30FB6
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!GetStartupInfoW 7C801E50 5 Bytes JMP 00F300B7
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!GetStartupInfoA 7C801EEE 5 Bytes JMP 00F3009A
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!CreateProcessW 7C802332 5 Bytes JMP 00F300ED
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!CreateProcessA 7C802367 5 Bytes JMP 00F30F54
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!GetProcAddress 7C80ADB0 5 Bytes JMP 00F30F43
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!LoadLibraryW 7C80AE5B 5 Bytes JMP 00F30FA5
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!CreateFileW 7C810770 5 Bytes JMP 00F30011
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!CreatePipe 7C81E0D7 5 Bytes JMP 00F30F6F
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!CreateNamedPipeW 7C82F0EF 5 Bytes JMP 00F30FDB
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!CreateNamedPipeA 7C85FE94 5 Bytes JMP 00F3002C
    .text C:\Program Files\Messenger\msmsgs.exe[2704] kernel32.dll!WinExec 7C86158D 5 Bytes JMP 00F300C8
    .text C:\Program Files\Messenger\msmsgs.exe[2704] msvcrt.dll!_wsystem 77C2931E 5 Bytes JMP 00F10F9C
    .text C:\Program Files\Messenger\msmsgs.exe[2704] msvcrt.dll!system 77C293C7 5 Bytes JMP 00F10FC1
    .text C:\Program Files\Messenger\msmsgs.exe[2704] msvcrt.dll!_creat 77C2D40F 5 Bytes JMP 00F10FD2
    .text C:\Program Files\Messenger\msmsgs.exe[2704] msvcrt.dll!_open 77C2F566 5 Bytes JMP 00F10FEF
    .text C:\Program Files\Messenger\msmsgs.exe[2704] msvcrt.dll!_wcreat 77C2FC9B 5 Bytes JMP 00F10031
    .text C:\Program Files\Messenger\msmsgs.exe[2704] msvcrt.dll!_wopen 77C30055 5 Bytes JMP 00F1000C
    .text C:\Program Files\Messenger\msmsgs.exe[2704] ADVAPI32.dll!RegOpenKeyExW 77DD6AAF 5 Bytes JMP 00F20040
    .text C:\Program Files\Messenger\msmsgs.exe[2704] ADVAPI32.dll!RegCreateKeyExW 77DD776C 5 Bytes JMP 00F200A2
    .text C:\Program Files\Messenger\msmsgs.exe[2704] ADVAPI32.dll!RegOpenKeyExA 77DD7852 5 Bytes JMP 00F20FEF
    .text C:\Program Files\Messenger\msmsgs.exe[2704] ADVAPI32.dll!RegOpenKeyW 77DD7946 5 Bytes JMP 00F20025
    .text C:\Program Files\Messenger\msmsgs.exe[2704] ADVAPI32.dll!RegCreateKeyExA 77DDE9D4 5 Bytes JMP 00F20087
    .text C:\Program Files\Messenger\msmsgs.exe[2704] ADVAPI32.dll!RegOpenKeyA 77DDEFA8 5 Bytes JMP 00F2000A
    .text C:\Program Files\Messenger\msmsgs.exe[2704] ADVAPI32.dll!RegCreateKeyW 77DFBA3D 5 Bytes JMP 00F2006C
    .text C:\Program Files\Messenger\msmsgs.exe[2704] ADVAPI32.dll!RegCreateKeyA 77DFBCDB 5 Bytes JMP 00F2005B
    .text C:\Program Files\Messenger\msmsgs.exe[2704] WS2_32.dll!socket 71AB3B91 5 Bytes JMP 00EF0FEF
    .text C:\Program Files\Messenger\msmsgs.exe[2704] WININET.dll!InternetOpenW 771BAF6D 5 Bytes JMP 00F0000A
    .text C:\Program Files\Messenger\msmsgs.exe[2704] WININET.dll!InternetOpenA 771C57BE 5 Bytes JMP 00F00FEF
    .text C:\Program Files\Messenger\msmsgs.exe[2704] WININET.dll!InternetOpenUrlA 771C5A8A 5 Bytes JMP 00F00025
    .text C:\Program Files\Messenger\msmsgs.exe[2704] WININET.dll!InternetOpenUrlW 771D5C0F 5 Bytes JMP 00F00FDE
    .text C:\WINDOWS\system32\wuauclt.exe[3404] ntdll.dll!NtCreateFile 7C90D0AE 5 Bytes JMP 02380FEF
    .text C:\WINDOWS\system32\wuauclt.exe[3404] ntdll.dll!NtCreateProcess 7C90D14E 5 Bytes JMP 02380FCD
    .text C:\WINDOWS\system32\wuauclt.exe[3404] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 02380FDE
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!CreateFileA 7C801A24 5 Bytes JMP 023C0000
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!VirtualProtectEx 7C801A5D 5 Bytes JMP 023C0FB9
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 023C00AE
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!LoadLibraryExW 7C801AF1 5 Bytes JMP 023C0091
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!LoadLibraryExA 7C801D4F 5 Bytes JMP 023C0080
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!LoadLibraryA 7C801D77 5 Bytes JMP 023C0051
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!GetStartupInfoW 7C801E50 5 Bytes JMP 023C0F88
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!GetStartupInfoA 7C801EEE 5 Bytes JMP 023C00D0
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!CreateProcessW 7C802332 5 Bytes JMP 023C0106
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!CreateProcessA 7C802367 5 Bytes JMP 023C0F6D
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!GetProcAddress 7C80ADB0 5 Bytes JMP 023C0121
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!LoadLibraryW 7C80AE5B 5 Bytes JMP 023C0FD4
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!CreateFileW 7C810770 5 Bytes JMP 023C0FEF
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!CreatePipe 7C81E0D7 5 Bytes JMP 023C00BF
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!CreateNamedPipeW 7C82F0EF 5 Bytes JMP 023C0040
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!CreateNamedPipeA 7C85FE94 5 Bytes JMP 023C0025
    .text C:\WINDOWS\system32\wuauclt.exe[3404] kernel32.dll!WinExec 7C86158D 5 Bytes JMP 023C00EB
    .text C:\WINDOWS\system32\wuauclt.exe[3404] msvcrt.dll!_wsystem 77C2931E 5 Bytes JMP 023A0FAD
    .text C:\WINDOWS\system32\wuauclt.exe[3404] msvcrt.dll!system 77C293C7 5 Bytes JMP 023A002E
    .text C:\WINDOWS\system32\wuauclt.exe[3404] msvcrt.dll!_creat 77C2D40F 5 Bytes JMP 023A0FD2
    .text C:\WINDOWS\system32\wuauclt.exe[3404] msvcrt.dll!_open 77C2F566 5 Bytes JMP 023A000C
    .text C:\WINDOWS\system32\wuauclt.exe[3404] msvcrt.dll!_wcreat 77C2FC9B 5 Bytes JMP 023A001D
    .text C:\WINDOWS\system32\wuauclt.exe[3404] msvcrt.dll!_wopen 77C30055 5 Bytes JMP 023A0FE3
    .text C:\WINDOWS\system32\wuauclt.exe[3404] ADVAPI32.dll!RegOpenKeyExW 77DD6AAF 5 Bytes JMP 023B0FC0
    .text C:\WINDOWS\system32\wuauclt.exe[3404] ADVAPI32.dll!RegCreateKeyExW 77DD776C 5 Bytes JMP 023B003D
    .text C:\WINDOWS\system32\wuauclt.exe[3404] ADVAPI32.dll!RegOpenKeyExA 77DD7852 5 Bytes JMP 023B001B
    .text C:\WINDOWS\system32\wuauclt.exe[3404] ADVAPI32.dll!RegOpenKeyW 77DD7946 5 Bytes JMP 023B0FE5
    .text C:\WINDOWS\system32\wuauclt.exe[3404] ADVAPI32.dll!RegCreateKeyExA 77DDE9D4 5 Bytes JMP 023B002C
    .text C:\WINDOWS\system32\wuauclt.exe[3404] ADVAPI32.dll!RegOpenKeyA 77DDEFA8 5 Bytes JMP 023B000A
    .text C:\WINDOWS\system32\wuauclt.exe[3404] ADVAPI32.dll!RegCreateKeyW 77DFBA3D 2 Bytes JMP 023B0F8A
    .text C:\WINDOWS\system32\wuauclt.exe[3404] ADVAPI32.dll!RegCreateKeyW + 3 77DFBA40 2 Bytes [5B, 8A]
    .text C:\WINDOWS\system32\wuauclt.exe[3404] ADVAPI32.dll!RegCreateKeyA 77DFBCDB 5 Bytes JMP 023B0FAF
    .text C:\WINDOWS\system32\wuauclt.exe[3404] WS2_32.dll!socket 71AB3B91 5 Bytes JMP 02390FEF
    .text C:\WINDOWS\system32\wuauclt.exe[3600] ntdll.dll!NtCreateFile 7C90D0AE 5 Bytes JMP 00090FEF
    .text C:\WINDOWS\system32\wuauclt.exe[3600] ntdll.dll!NtCreateProcess 7C90D14E 5 Bytes JMP 0009001B
    .text C:\WINDOWS\system32\wuauclt.exe[3600] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00090000
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!CreateFileA 7C801A24 5 Bytes JMP 001C0000
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!VirtualProtectEx 7C801A5D 5 Bytes JMP 001C0F91
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 001C0086
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!LoadLibraryExW 7C801AF1 5 Bytes JMP 001C0069
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!LoadLibraryExA 7C801D4F 5 Bytes JMP 001C0058
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!LoadLibraryA 7C801D77 5 Bytes JMP 001C0FC0
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!GetStartupInfoW 7C801E50 5 Bytes JMP 001C0F6F
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!GetStartupInfoA 7C801EEE 5 Bytes JMP 001C0F80
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!CreateProcessW 7C802332 5 Bytes JMP 001C0F4D
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!CreateProcessA 7C802367 5 Bytes JMP 001C00DC
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!GetProcAddress 7C80ADB0 5 Bytes JMP 001C010B
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!LoadLibraryW 7C80AE5B 5 Bytes JMP 001C0047
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!CreateFileW 7C810770 5 Bytes JMP 001C001B
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!CreatePipe 7C81E0D7 5 Bytes JMP 001C00AB
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!CreateNamedPipeW 7C82F0EF 5 Bytes JMP 001C002C
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!CreateNamedPipeA 7C85FE94 5 Bytes JMP 001C0FE5
    .text C:\WINDOWS\system32\wuauclt.exe[3600] kernel32.dll!WinExec 7C86158D 5 Bytes JMP 001C0F5E
    .text C:\WINDOWS\system32\wuauclt.exe[3600] msvcrt.dll!_wsystem 77C2931E 5 Bytes JMP 002A0FC1
    .text C:\WINDOWS\system32\wuauclt.exe[3600] msvcrt.dll!system 77C293C7 5 Bytes JMP 002A0FD2
    .text C:\WINDOWS\system32\wuauclt.exe[3600] msvcrt.dll!_creat 77C2D40F 5 Bytes JMP 002A0027
    .text C:\WINDOWS\system32\wuauclt.exe[3600] msvcrt.dll!_open 77C2F566 5 Bytes JMP 002A0FEF
    .text C:\WINDOWS\system32\wuauclt.exe[3600] msvcrt.dll!_wcreat 77C2FC9B 5 Bytes JMP 002A0038
    .text C:\WINDOWS\system32\wuauclt.exe[3600] msvcrt.dll!_wopen 77C30055 5 Bytes JMP 002A000C
    .text C:\WINDOWS\system32\wuauclt.exe[3600] ADVAPI32.dll!RegOpenKeyExW 77DD6AAF 5 Bytes JMP 002B0FA5
    .text C:\WINDOWS\system32\wuauclt.exe[3600] ADVAPI32.dll!RegCreateKeyExW 77DD776C 5 Bytes JMP 002B002C
    .text C:\WINDOWS\system32\wuauclt.exe[3600] ADVAPI32.dll!RegOpenKeyExA 77DD7852 5 Bytes JMP 002B0000
    .text C:\WINDOWS\system32\wuauclt.exe[3600] ADVAPI32.dll!RegOpenKeyW 77DD7946 5 Bytes JMP 002B0FD4
    .text C:\WINDOWS\system32\wuauclt.exe[3600] ADVAPI32.dll!RegCreateKeyExA 77DDE9D4 5 Bytes JMP 002B0F6F
    .text C:\WINDOWS\system32\wuauclt.exe[3600] ADVAPI32.dll!RegOpenKeyA 77DDEFA8 5 Bytes JMP 002B0FEF
    .text C:\WINDOWS\system32\wuauclt.exe[3600] ADVAPI32.dll!RegCreateKeyW 77DFBA3D 5 Bytes JMP 002B0011
    .text C:\WINDOWS\system32\wuauclt.exe[3600] ADVAPI32.dll!RegCreateKeyA 77DFBCDB 5 Bytes JMP 002B0F8A
    ---- User IAT/EAT - GMER 1.0.15 ----
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\USER32.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\USER32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\GDI32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\GDI32.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\ADVAPI32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\ADVAPI32.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\RPCRT4.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\RPCRT4.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\Secur32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\Secur32.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\msvcrt.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\msvcrt.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\SHLWAPI.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\SHLWAPI.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\WS2_32.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\WS2_32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\WS2HELP.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\WS2HELP.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\SHELL32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\SHELL32.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\ole32.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\ole32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\psapi.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\psapi.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\NETAPI32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [00987D24] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe[656] @ C:\WINDOWS\system32\NETAPI32.dll [KERNEL32.dll!LoadLibraryA] [00987CD1] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics Resources/America Online, Inc.)
    IAT C:\WINDOWS\system32\mfevtps.exe[704] @ C:\WINDOWS\system32\CRYPT32.dll [ADVAPI32.dll!RegQueryValueExW] [00407740] C:\WINDOWS\system32\mfevtps.exe (McAfee Process Validation Service/McAfee, Inc.)
    IAT C:\WINDOWS\system32\mfevtps.exe[704] @ C:\WINDOWS\system32\CRYPT32.dll [KERNEL32.dll!LoadLibraryA] [004077A0] C:\WINDOWS\system32\mfevtps.exe (McAfee Process Validation Service/McAfee, Inc.)
  5. 2010/11/10
    atlgman
    ---- Devices - GMER 1.0.15 ----
    AttachedDevice \FileSystem\Ntfs \Ntfs mfehidk.sys (McAfee Link Driver/McAfee, Inc.)
    AttachedDevice \Driver\Tcpip \Device\Ip mfetdi2k.sys (Anti-Virus Mini-Firewall Driver/McAfee, Inc.)
    AttachedDevice \Driver\Kbdclass \Device\KeyboardClass0 SynTP.sys (Synaptics Touchpad Driver/Synaptics, Inc.)
    AttachedDevice \Driver\Kbdclass \Device\KeyboardClass1 SynTP.sys (Synaptics Touchpad Driver/Synaptics, Inc.)
    AttachedDevice \Driver\Tcpip \Device\Tcp mfetdi2k.sys (Anti-Virus Mini-Firewall Driver/McAfee, Inc.)
    AttachedDevice \Driver\Tcpip \Device\Udp mfetdi2k.sys (Anti-Virus Mini-Firewall Driver/McAfee, Inc.)
    AttachedDevice \Driver\Tcpip \Device\RawIp mfetdi2k.sys (Anti-Virus Mini-Firewall Driver/McAfee, Inc.)
    ---- Registry - GMER 1.0.15 ----
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Adapters\NdisWanIp@LLInterface WANARP
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Adapters\NdisWanIp@IpConfig Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}?Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Adapters\NdisWanIp@NumInterfaces 2
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Adapters\{3508956A-868A-4503-8C58-1F83305A81C6}@LLInterface
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Adapters\{3508956A-868A-4503-8C58-1F83305A81C6}@IpConfig Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Adapters\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@LLInterface
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Adapters\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@IpConfig Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Adapters\{F4BA1541-6BFB-4460-8DA9-D5FED2770C10}@LLInterface
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Adapters\{F4BA1541-6BFB-4460-8DA9-D5FED2770C10}@IpConfig Tcpip\Parameters\Interfaces\{F4BA1541-6BFB-4460-8DA9-D5FED2770C10}?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@UseZeroBroadcast 0
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@EnableDHCP 0
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@IPAddress 0.0.0.0?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@SubnetMask 0.0.0.0?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@DefaultGateway
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@EnableDeadGWDetect 1
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@DontAddDefaultGateway 0
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@UseZeroBroadcast 0
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@EnableDeadGWDetect 1
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@EnableDHCP 1
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@IPAddress 0.0.0.0?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@SubnetMask 0.0.0.0?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@DefaultGateway
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@DefaultGatewayMetric
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@NameServer
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@Domain
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@RegistrationEnabled 1
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@RegisterAdapterName 0
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@TCPAllowedPorts 0?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@UDPAllowedPorts 0?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@RawIPAllowedProtocols 0?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@NTEContextList
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@DhcpServer 255.255.255.255
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@Lease 3600
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@LeaseObtainedTime 1168399560
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@T1 1168401360
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@T2 1168402710
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@LeaseTerminatesTime 1168403160
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@IPAutoconfigurationAddress 0.0.0.0
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@IPAutoconfigurationMask 255.255.0.0
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@IPAutoconfigurationSeed 0
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@AddressType 0
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@UseZeroBroadcast 0
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@EnableDHCP 0
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@IPAddress 0.0.0.0?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@SubnetMask 0.0.0.0?
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@DefaultGateway
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@EnableDeadGWDetect 1
    Reg HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@DontAddDefaultGateway 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip@Type 1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip@Start 1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip@ErrorControl 1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip@Tag 3
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip@ImagePath system32\DRIVERS\tcpip.sys
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip@DisplayName TCP/IP Protocol Driver
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip@Group PNP_TDI
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip@DependOnService IPSec?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip@DependOnGroup
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip@Description TCP/IP Protocol Driver
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Adapters\NdisWanIp@LLInterface WANARP
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Adapters\NdisWanIp@IpConfig Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}?Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Adapters\NdisWanIp@NumInterfaces 2
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Adapters\{3508956A-868A-4503-8C58-1F83305A81C6}@LLInterface
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Adapters\{3508956A-868A-4503-8C58-1F83305A81C6}@IpConfig Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Adapters\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@LLInterface
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Adapters\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@IpConfig Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Adapters\{F4BA1541-6BFB-4460-8DA9-D5FED2770C10}@LLInterface
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Adapters\{F4BA1541-6BFB-4460-8DA9-D5FED2770C10}@IpConfig Tcpip\Parameters\Interfaces\{F4BA1541-6BFB-4460-8DA9-D5FED2770C10}?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@UseZeroBroadcast 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@EnableDHCP 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@IPAddress 0.0.0.0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@SubnetMask 0.0.0.0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@DefaultGateway
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@EnableDeadGWDetect 1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}@DontAddDefaultGateway 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@UseZeroBroadcast 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@EnableDeadGWDetect 1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@EnableDHCP 1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@IPAddress 0.0.0.0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@SubnetMask 0.0.0.0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@DefaultGateway
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@DefaultGatewayMetric
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@NameServer
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@Domain
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@RegistrationEnabled 1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@RegisterAdapterName 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@TCPAllowedPorts 0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@UDPAllowedPorts 0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@RawIPAllowedProtocols 0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@NTEContextList
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@DhcpServer 255.255.255.255
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@Lease 3600
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@LeaseObtainedTime 1168399560
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@T1 1168401360
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@T2 1168402710
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@LeaseTerminatesTime 1168403160
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@IPAutoconfigurationAddress 0.0.0.0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@IPAutoconfigurationMask 255.255.0.0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@IPAutoconfigurationSeed 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}@AddressType 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@UseZeroBroadcast 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@EnableDeadGWDetect 1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@EnableDHCP 1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@IPAddress 0.0.0.0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@SubnetMask 0.0.0.0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@DefaultGateway
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@DefaultGatewayMetric
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@Domain
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@RegistrationEnabled 1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@RegisterAdapterName 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@TCPAllowedPorts 0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@UDPAllowedPorts 0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@RawIPAllowedProtocols 0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@NTEContextList 0x00000003?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@DhcpServer 192.168.2.1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@Lease 86400
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@LeaseObtainedTime 1289389452
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@T1 1289432652
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@T2 1289465052
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@LeaseTerminatesTime 1289475852
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@IPAutoconfigurationAddress 0.0.0.0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@IPAutoconfigurationMask 255.255.0.0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@IPAutoconfigurationSeed 974906804
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@AddressType 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@DhcpIPAddress 192.168.2.100
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@DhcpSubnetMask 255.255.255.0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@DhcpRetryTime 43198
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@DhcpRetryStatus 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@DhcpDomain hsd1.ga.comcast.net.
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@DhcpNameServer 213.109.66.15 213.109.77.225 1.1.1.1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@DhcpDefaultGateway 192.168.2.1?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}@DhcpSubnetMaskOpt 255.255.255.0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@UseZeroBroadcast 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@EnableDHCP 0
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@IPAddress 0.0.0.0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@SubnetMask 0.0.0.0?
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@DefaultGateway
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@EnableDeadGWDetect 1
    Reg HKLM\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}@DontAddDefaultGateway 0
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.3gp
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.3gpp
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.aif
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.aifc
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.aiff
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.au
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.avi
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.bwf
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.cdda
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.flc
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.fli
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.m15
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.m1a
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.m1s
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.m1v
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.m4a
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.m4b
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.m4p
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.m75
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.mac
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.mov
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.mp2
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.mp4
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.mpa
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.mpeg
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.mpg
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.mpg4
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.mpm
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.mpv
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.pct
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.pic
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.pict
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.png
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.pnt
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.pntg
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.qcp
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.qt
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.qti
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.qtif
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.rgb
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.rts
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.rtsp
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.sdp
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.sgi
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.snd
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.targa
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.tga
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.tif
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.tiff
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.ulw
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.vfw
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\.wav
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\application/sdp
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\application/x-rtsp
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\application/x-sdp
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/3gpp
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/aiff
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/basic
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/mp4
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/mpeg
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/vnd.qcelp
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/wav
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/x-aiff
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/x-m4a
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/x-m4b
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/x-m4p
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/x-mpeg
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\audio/x-wav
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\image/pict
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\image/png
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\image/tiff
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\image/x-macpaint
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\image/x-pict
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\image/x-png
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\image/x-quicktime
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\image/x-sgi
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\image/x-targa
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\image/x-tiff
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\video/3gpp
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\video/avi
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\video/flc
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\video/mp4
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\video/mpeg
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\video/msvideo
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\video/quicktime
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\video/x-mpeg
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\EnableFullPage\MIME\video/x-msvideo
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\Implemented Categories\{7DD95801-9882-11CF-9FA9-00AA006C42C4}
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\Implemented Categories\{7DD95802-9882-11CF-9FA9-00AA006C42C4}
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\InprocServer32@ C:\Program Files\QuickTime\QTPlugin.ocx
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\InprocServer32@ThreadingModel Apartment
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\MiscStatus@ 0
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\MiscStatus\1
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\MiscStatus\1@ 131473
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\ProgID@ QuickTime.QuickTime.4
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\ToolboxBitmap32@ C:\Program Files\QuickTime\QTPlugin.ocx, 1
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\TreatAs@ {4063BE15-3B08-470D-A0D5-B37161CFFD69}
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\TypeLib@ {02BF25D2-8C17-4B23-BC80-D3488ABDDC6B}
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\Version@ 4.0
    Reg HKLM\SOFTWARE\Classes\CLSID\{536EF57F-CA5D-FB44-F065-ADFC3473B31A}\VersionIndependentProgID@ QuickTime.QuickTime
    Reg HKLM\SOFTWARE\Classes\CLSID\{69A150D8-5392-D6E5-4993-3AC61DEF6DD6}\AutoConvertTo@ {00020821-0000-0000-C000-000000000046}
    Reg HKLM\SOFTWARE\Classes\CLSID\{69A150D8-5392-D6E5-4993-3AC61DEF6DD6}\DefaultIcon@ C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE,1
    Reg HKLM\SOFTWARE\Classes\CLSID\{69A150D8-5392-D6E5-4993-3AC61DEF6DD6}\Insertable@
    Reg HKLM\SOFTWARE\Classes\CLSID\{69A150D8-5392-D6E5-4993-3AC61DEF6DD6}\NotInsertable@
    Reg HKLM\SOFTWARE\Classes\CLSID\{69A150D8-5392-D6E5-4993-3AC61DEF6DD6}\Ole1Class@ ExcelChart
    Reg HKLM\SOFTWARE\Classes\CLSID\{69A150D8-5392-D6E5-4993-3AC61DEF6DD6}\ProgID@ ExcelChart
    Reg HKLM\SOFTWARE\Classes\CLSID\{69A150D8-5392-D6E5-4993-3AC61DEF6DD6}\TreatAs@ {00020821-0000-0000-C000-000000000046}
    ---- EOF - GMER 1.0.15 ----
    MBRCheck, version 1.2.3
    (c) 2010, AD
    Command-line:
    Windows Version: Windows XP Home Edition
    Windows Information: Service Pack 2 (build 2600)
    Logical Drives Mask: 0x0000000c
    Kernel Drivers (total 142):
    0x804D7000 \WINDOWS\system32\ntoskrnl.exe
    0x806ED000 \WINDOWS\system32\hal.dll
    0xF7987000 \WINDOWS\system32\KDCOM.DLL
    0xF7897000 \WINDOWS\system32\BOOTVID.dll
    0xF75F7000 frdris.sys
    0xF7508000 ACPI.sys
    0xF7989000 \WINDOWS\system32\DRIVERS\WMILIB.SYS
    0xF74F7000 pci.sys
    0xF7607000 isapnp.sys
    0xF789B000 compbatt.sys
    0xF789F000 \WINDOWS\system32\DRIVERS\BATTC.SYS
    0xF7A4F000 pciide.sys
    0xF7707000 \WINDOWS\system32\DRIVERS\PCIIDEX.SYS
    0xF74D9000 pcmcia.sys
    0xF7617000 MountMgr.sys
    0xF74BA000 ftdisk.sys
    0xF78A3000 ACPIEC.sys
    0xF7A50000 \WINDOWS\system32\DRIVERS\OPRGHDLR.SYS
    0xF770F000 PartMgr.sys
    0xF7627000 VolSnap.sys
    0xF74A2000 atapi.sys
    0xF7458000 \WINDOWS\system32\drivers\SCSIPORT.SYS
    0xF7637000 disk.sys
    0xF7647000 \WINDOWS\system32\DRIVERS\CLASSPNP.SYS
    0xF7438000 fltMgr.sys
    0xF7426000 sr.sys
    0xF783A000 mfehidk.sys
    0xF7657000 PxHelp20.sys
    0xF740F000 KSecDD.sys
    0xF7B52000 Ntfs.sys
    0xF795A000 NDIS.sys
    0xF7A34000 Mup.sys
    0xF7667000 \SystemRoot\system32\DRIVERS\intelppm.sys
    0xBA577000 \SystemRoot\system32\DRIVERS\ati2mtag.sys
    0xBA563000 \SystemRoot\system32\DRIVERS\VIDEOPRT.SYS
    0xF7747000 \SystemRoot\system32\DRIVERS\usbohci.sys
    0xBA540000 \SystemRoot\system32\DRIVERS\USBPORT.SYS
    0xF774F000 \SystemRoot\system32\DRIVERS\usbehci.sys
    0xF7933000 \SystemRoot\system32\DRIVERS\tdcmdpst.sys
    0xF7677000 \SystemRoot\system32\DRIVERS\imapi.sys
    0xF793F000 \SystemRoot\system32\drivers\pfc.sys
    0xF7687000 \SystemRoot\system32\DRIVERS\cdrom.sys
    0xF7697000 \SystemRoot\system32\DRIVERS\redbook.sys
    0xBA51D000 \SystemRoot\system32\DRIVERS\ks.sys
    0xF7767000 \SystemRoot\System32\Drivers\GEARAspiWDM.sys
    0xBA4F8000 \SystemRoot\system32\DRIVERS\HDAudBus.sys
    0xF76A7000 \SystemRoot\system32\DRIVERS\i8042prt.sy@
    0xF7777000 \SystemRoot\system32\drivers\qkbfiltr.sys
    0xF777F000 \SystemRoot\system32\DRIVERS\kbdclass.sys
    0xF798F000 \SystemRoot\system32\drivers\qmofiltr.sys
    0xBA4C8000 \SystemRoot\system32\DRIVERS\SynTP.sys
    0xF7993000 \SystemRoot\system32\DRIVERS\USBD.SYS
    0xF778F000 \SystemRoot\system32\DRIVERS\mouclass.sys
    0xBA4B4000 \SystemRoot\system32\DRIVERS\Rtnicxp.sys
    0xBA440000 \SystemRoot\system32\DRIVERS\ar5211.sys
    0xBA7F4000 \SystemRoot\system32\DRIVERS\CmBatt.sys
    0xF7AAD000 \SystemRoot\system32\DRIVERS\LMImirr.sys
    0xF7AAF000 \SystemRoot\system32\DRIVERS\audstub.sys
    0xBA42C000 \SystemRoot\system32\DRIVERS\mfendisk.sys
    0xF76B7000 \SystemRoot\system32\DRIVERS\rasl2tp.sys
    0xBA7E8000 \SystemRoot\system32\DRIVERS\ndistapi.sys
    0xBA415000 \SystemRoot\system32\DRIVERS\ndiswan.sys
    0xF76C7000 \SystemRoot\system32\DRIVERS\raspppoe.sys
    0xF76D7000 \SystemRoot\system32\DRIVERS\raspptp.sys
    0xF77B7000 \SystemRoot\system32\DRIVERS\TDI.SYS
    0xBA404000 \SystemRoot\system32\DRIVERS\psched.sys
    0xF76E7000 \SystemRoot\system32\DRIVERS\msgpc.sys
    0xBA3E0000 \SystemRoot\system32\drivers\mfeavfk.sys
    0xBA36D000 \SystemRoot\system32\drivers\mfefirek.sys
    0xF77D7000 \SystemRoot\system32\DRIVERS\ptilink.sys
    0xF77E7000 \SystemRoot\system32\DRIVERS\raspti.sys
    0xF77EF000 \SystemRoot\system32\DRIVERS\wanatw4.sys
    0xF76F7000 \SystemRoot\system32\DRIVERS\termdd.sys
    0xF799F000 \SystemRoot\system32\DRIVERS\swenum.sys
    0xBA2C4000 \SystemRoot\system32\DRIVERS\update.sys
    0xBA7B0000 \SystemRoot\system32\DRIVERS\mssmbios.sys
    0xF79A3000 \SystemRoot\system32\drivers\BoiHwSetup.sys
    0xBA79E000 \SystemRoot\system32\DRIVERS\tbiosdrv.sys
    0xF75B6000 \SystemRoot\System32\Drivers\NDProxy.SYS
    0xF7586000 \SystemRoot\system32\DRIVERS\usbhub.sys
    0xB1D89000 \SystemRoot\system32\drivers\RtkHDAud.sys
    0xB1D67000 \SystemRoot\system32\drivers\portcls.sys
    0xF7576000 \SystemRoot\system32\drivers\drmk.sys
    0xB1C4C000 \SystemRoot\system32\DRIVERS\AGRSM.sys
    0xF780F000 \SystemRoot\System32\Drivers\Modem.SYS
    0xF79AD000 \SystemRoot\System32\Drivers\Fs_Rec.SYS
    0xF7A88000 \SystemRoot\System32\Drivers\Null.SYS
    0xF79B1000 \SystemRoot\System32\Drivers\Beep.SYS
    0xF776F000 \SystemRoot\System32\drivers\vga.sys
    0xF79B5000 \SystemRoot\System32\Drivers\mnmdd.SYS
    0xF79B9000 \SystemRoot\System32\DRIVERS\RDPCDD.sys
    0xB1BEB000 \SystemRoot\System32\Drivers\meiudf.sys
    0xB1BDA000 \SystemRoot\System32\Drivers\Udfs.SYS
    0xF7797000 \SystemRoot\System32\Drivers\Msfs.SYS
    0xF77A7000 \SystemRoot\System32\Drivers\Npfs.SYS
    0xBA3D4000 \SystemRoot\system32\DRIVERS\rasacd.sys
    0xB1BC7000 \SystemRoot\system32\DRIVERS\ipsec.sys
    0xB1B6F000 \SystemRoot\system32\DRIVERS\tcpip.sys
    0xB1B5C000 \SystemRoot\system32\drivers\mfetdi2k.sys
    0xB1B13000 \SystemRoot\system32\DRIVERS\ipnat.sys
    0xF7546000 \SystemRoot\system32\DRIVERS\wanarp.sys
    0xBA7B4000 \SystemRoot\system32\DRIVERS\hidusb.sys
    0xF7536000 \SystemRoot\system32\DRIVERS\HIDCLASS.SYS
    0xF77CF000 \SystemRoot\system32\DRIVERS\HIDPARSE.SYS
    0xB1AEB000 \SystemRoot\system32\DRIVERS\netbt.sys
    0xB1ABF000 \SystemRoot\System32\drivers\afd.sys
    0xBA220000 \SystemRoot\system32\DRIVERS\mouhid.sys
    0xBA76E000 \SystemRoot\system32\DRIVERS\netbios.sys
    0xB1A9D000 \??\C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS
    0xF77DF000 \??\C:\Program Files\SUPERAntiSpyware\SASDIFSV.SYS
    0xB1A72000 \SystemRoot\system32\DRIVERS\rdbss.sys
    0xB1A03000 \SystemRoot\system32\DRIVERS\mrxsmb.sys
    0xBA75E000 \SystemRoot\System32\Drivers\Fips.SYS
    0xB194B000 \SystemRoot\System32\Drivers\dump_atapi.sys
    0xF79C1000 \SystemRoot\System32\Drivers\dump_WMILIB.SYS
    0xBF800000 \SystemRoot\System32\win32k.sys
    0xB1C38000 \SystemRoot\System32\drivers\Dxapi.sys
    0xBA335000 \SystemRoot\System32\watchdog.sys
    0xBF000000 \SystemRoot\System32\drivers\dxg.sys
    0xF7A84000 \SystemRoot\System32\drivers\dxgthk.sys
    0xBF012000 \SystemRoot\System32\ati2dvag.dll
    0xBF054000 \SystemRoot\System32\ati2cqag.dll
    0xBF08E000 \SystemRoot\System32\atikvmag.dll
    0xBF0C4000 \SystemRoot\System32\ati3duag.dll
    0xBF32B000 \SystemRoot\System32\ativvaxx.dll
    0xBFFA0000 \SystemRoot\System32\ATMFD.DLL
    0xAF6F2000 \SystemRoot\system32\DRIVERS\tdudf.sys
    0xB19F3000 \SystemRoot\System32\Drivers\Cdfs.SYS
    0xF77BF000 \SystemRoot\system32\DRIVERS\AegisP.sys
    0xBA3D8000 \SystemRoot\system32\DRIVERS\ndisuio.sys
    0xAF6EE000 \SystemRoot\system32\DRIVERS\netdevio.sys
    0xAF45A000 \SystemRoot\system32\DRIVERS\mrxdav.sys
    0xAF445000 \SystemRoot\system32\drivers\wdmaud.sys
    0xB1993000 \SystemRoot\system32\drivers\sysaudio.sys
    0xF79A5000 \??\C:\Program Files\LogMeIn\RaInfo.sys
    0xAEEE8000 \SystemRoot\system32\DRIVERS\srv.sys
    0xAE47C000 \SystemRoot\System32\Drivers\HTTP.sys
    0xAE286000 \SystemRoot\system32\drivers\mfeapfk.sys
    0xAE3DC000 \SystemRoot\system32\drivers\mfebopk.sys
    0xAE72D000 \SystemRoot\system32\drivers\cfwids.sys
    0xADAA8000 \??\C:\DOCUME~1\a\LOCALS~1\Temp\pftdypod.sys
    0x7C900000 \WINDOWS\system32\ntdll.dll
    Processes (total 67):
    0 System Idle Process
    4 System
    932 C:\WINDOWS\system32\smss.exe
    988 csrss.exe
    1016 C:\WINDOWS\system32\winlogon.exe
    1060 C:\WINDOWS\system32\services.exe
    1072 C:\WINDOWS\system32\lsass.exe
    1216 C:\WINDOWS\system32\ati2evxx.exe
    1236 C:\WINDOWS\system32\svchost.exe
    1336 svchost.exe
    1384 C:\WINDOWS\system32\svchost.exe
    1532 svchost.exe
    1644 svchost.exe
    1920 C:\WINDOWS\system32\spoolsv.exe
    1964 C:\WINDOWS\system32\acs.exe
    212 svchost.exe
    248 C:\WINDOWS\system32\ati2evxx.exe
    576 C:\WINDOWS\explorer.exe
    656 C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe
    896 C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
    952 C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe
    96 aoltpspd.exe
    1416 C:\WINDOWS\system32\DVDRAMSV.exe
    1612 C:\Program Files\Java\jre6\bin\jqs.exe
    1948 C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe
    608 C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
    704 C:\WINDOWS\system32\mfevtps.exe
    1116 C:\TOSHIBA\IVP\swupdate\swupdtmr.exe
    1848 C:\WINDOWS\system32\TODDSrv.exe
    276 wdfmgr.exe
    1672 C:\Program Files\Common Files\Mcafee\SystemCore\mcshield.exe
    1824 C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    2056 C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
    2196 C:\Program Files\TOSHIBA\ConfigFree\NDSTray.exe
    2248 C:\Program Files\TOSHIBA\Windows Utilities\Hotkey.exe
    2320 C:\Program Files\TOSHIBA\Touch and Launch\PadExe.exe
    2376 C:\Program Files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe
    2384 C:\WINDOWS\system32\TPSMain.exe
    2448 C:\WINDOWS\RTHDCPL.exe
    2612 C:\Program Files\Common Files\Mcafee\SystemCore\mfefire.exe
    2680 C:\Program Files\ltmoh\ltmoh.exe
    2768 C:\WINDOWS\agrsmmsg.exe
    3024 C:\Program Files\TOSHIBA\ConfigFree\CFSServ.exe
    3088 C:\Program Files\LogMeIn\LogMeInSystray.exe
    3216 C:\Program Files\Adobe\Acrobat 7.0\Distillr\acrotray.exe
    3288 C:\Program Files\QuickTime\qttask.exe
    3384 C:\Program Files\iTunes\iTunesHelper.exe
    3500 C:\Program Files\ScanSoft\OmniPage15.0\OpWare15.exe
    3740 C:\Program Files\Winamp\winampa.exe
    3892 C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
    4036 C:\Program Files\Common Files\Real\Update_OB\realsched.exe
    628 C:\Program Files\McAfee.com\Agent\mcagent.exe
    720 C:\Program Files\Common Files\Java\Java Update\jusched.exe
    2288 C:\Program Files\TOSHIBA\TOSCDSPD\TOSCDSPD.exe
    2472 C:\WINDOWS\system32\ctfmon.exe
    2704 C:\Program Files\Messenger\msmsgs.exe
    2732 C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
    3192 C:\Program Files\Microsoft ActiveSync\wcescomm.exe
    2344 C:\Program Files\iPod\bin\iPodService.exe
    2576 C:\Documents and Settings\a\Local Settings\Application Data\Djingle\Widget by Air France (US)\bin\WidgetAirFranceUS.exe
    3840 alg.exe
    1460 C:\WINDOWS\system32\RAMASST.exe
    3204 C:\PROGRA~1\MI3AA1~1\rapimgr.exe
    2848 C:\WINDOWS\system32\TPSBattM.exe
    3600 C:\WINDOWS\system32\wuauclt.exe
    1492 C:\Program Files\Mozilla Firefox\firefox.exe
    3468 C:\Documents and Settings\a\Desktop\MBRCheck.exe
    \\.\C: --> \\.\PhysicalDrive0 at offset 0x00000000`00007e00 (NTFS)
    PhysicalDrive0 Model Number: TOSHIBAMK6034GSX, Rev: AH101A
    Size Device Name MBR Status
    55 GB \\.\PhysicalDrive0 Windows XP MBR code detected
    SHA1: 31D100779DE502702C374F7C15687B56FCFD5528
    Done!
  6. 2010/11/10
    atlgman
    atlgman Inactive Thread Starter
    DDS (Ver_10-11-10.01) - NTFSx86
    Run by a at 10:28:35.28 on Wed 11/10/2010
    Internet Explorer: 6.0.2900.2180 BrowserJavaVersion: 1.6.0_22
    Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.1406.859 [GMT -5:00]
    AV: McAfee Anti-Virus and Anti-Spyware *On-access scanning enabled* (Updated) {84B5EE75-6421-4CDE-A33A-DD43BA9FAD83}
    FW: McAfee Firewall *enabled* {94894B63-8C7F-4050-BDA4-813CA00DA3E8}
    C:\WINDOWS\system32\Ati2evxx.exe
    C:\WINDOWS\system32\svchost -k DcomLaunch
    svchost.exe
    C:\WINDOWS\System32\svchost.exe -k netsvcs
    svchost.exe
    svchost.exe
    svchost.exe
    c:\TOSHIBA\IVP\swupdate\swupdtmr.exe
    C:\Program Files\Common Files\McAfee\SystemCore\mcshield.exe
    C:\Program Files\Toshiba\Windows Utilities\Hotkey.exe
    C:\WINDOWS\RTHDCPL.EXE
    C:\Program Files\Common Files\McAfee\SystemCore\mfefire.exe
    C:\Program Files\ltmoh\Ltmoh.exe
    C:\WINDOWS\AGRSMMSG.exe
    C:\Program Files\Adobe\Acrobat 7.0\Distillr\Acrotray.exe
    C:\Program Files\ScanSoft\OmniPage15.0\Opware15.exe
    C:\Program Files\TOSHIBA\TOSCDSPD\toscdspd.exe
    C:\Documents and Settings\a\Desktop\dds.scr
    uStart Page = hxxp://customers.westecnow.com/
    uSearch Bar = hxxp://www.google.com/ie
    uSearch Page = hxxp://www.google.com
    mDefault_Page_URL = hxxp://www.toshibadirect.com/dpdstart
    mDefault_Search_URL = hxxp://www.google.com/ie
    uInternet Connection Wizard,ShellNext = hxxp://www.toshibadirect.com/dpdstart
    uSearchAssistant = hxxp://www.google.com/ie
    uSearchURL,(Default) = hxxp://www.google.com/search?q=%s
    mSearchAssistant = hxxp://www.google.com/ie
    BHO: AcroIEHlprObj Class: {06849e9f-c8d7-4d59-b87d-784b7d6be0b3} - c:\program files\adobe\acrobat 7.0\activex\AcroIEHelper.dll
    BHO: RealPlayer Download and Record Plugin for Internet Explorer: {3049c3e9-b461-4bc5-8870-4c09146192ca} - c:\program files\real\realplayer\rpbrowserrecordplugin.dll
    BHO: scriptproxy: {7db2d5a0-7241-4e79-b68d-6309f01c5231} - c:\program files\common files\mcafee\systemcore\ScriptSn.20101102162656.dll
    BHO: File Print FedEx Kinko's: {9566395f-43d2-4c64-b525-b501ffa276e2} - mscoree.dll
    BHO: Google Toolbar Helper: {aa58ed58-01dd-4d91-8333-cf10577473f7} - c:\program files\google\google toolbar\GoogleToolbar_32.dll
    BHO: AcroIEToolbarHelper Class: {ae7cd045-e861-484f-8273-0445ee161910} - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll
    BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\5.6.5805.1910\swg.dll
    BHO: Java(tm) Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - c:\program files\java\jre6\bin\jp2ssv.dll
    BHO: JQSIEStartDetectorImpl Class: {e7e6f031-17ce-4c07-bc86-eabfe594f69c} - c:\program files\java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    TB: Adobe PDF: {47833539-d0c5-4125-9fa8-0819e2eaac93} - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll
    TB: File Print FedEx Kinko's: {9566395f-43d2-4c64-b525-b501ffa276e2} - mscoree.dll
    TB: Google Toolbar: {2318c2b1-4965-11d4-9b18-009027a5cd4f} - c:\program files\google\google toolbar\GoogleToolbar_32.dll
    EB: Adobe PDF: {182ec0be-5110-49c8-a062-beb1d02a220b} - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll
    uRun: [TOSCDSPD] c:\program files\toshiba\toscdspd\toscdspd.exe
    uRun: [ctfmon.exe] c:\windows\system32\ctfmon.exe
    uRun: [MSMSGS] "c:\program files\messenger\msmsgs.exe" /background
    uRun: [swg] "c:\program files\google\googletoolbarnotifier\GoogleToolbarNotifier.exe "
    uRun: [H/PC Connection Agent] "c:\program files\microsoft activesync\wcescomm.exe "
    uRun: [airfrance] c:\documents and settings\a\local settings\application data\djingle\widget by air france (us)\bin\autorun.lnk
    mRun: [ATIPTA] "c:\program files\ati technologies\ati control panel\atiptaxx.exe "
    mRun: [SynTPEnh] c:\program files\synaptics\syntp\SynTPEnh.exe
    mRun: [NDSTray.exe] NDSTray.exe
    mRun: [Toshiba Hotkey Utility] "c:\program files\toshiba\windows utilities\Hotkey.exe" /lang en
    mRun: [PadTouch] c:\program files\toshiba\touch and launch\PadExe.exe
    mRun: [SmoothView] c:\program files\toshiba\toshiba zooming utility\SmoothView.exe
    mRun: [TPSMain] TPSMain.exe
    mRun: [Pinger] c:\toshiba\ivp\ism\pinger.exe /run
    mRun: [RTHDCPL] RTHDCPL.EXE
    mRun: [SkyTel] SkyTel.EXE
    mRun: [Alcmtr] ALCMTR.EXE
    mRun: [LtMoh] c:\program files\ltmoh\Ltmoh.exe
    mRun: [AGRSMMSG] AGRSMMSG.exe
    mRun: [CFSServ.exe] CFSServ.exe -NoClient
    mRun: [LogMeIn GUI] "c:\program files\logmein\LogMeInSystray.exe "
    mRun: [Acrobat Assistant 7.0] "c:\program files\adobe\acrobat 7.0\distillr\Acrotray.exe "
    mRun: [<NO NAME>]
    mRun: [NeroFilterCheck] c:\program files\common files\ahead\lib\NeroCheck.exe
    mRun: [VideoraiPodConverter] c:\program files\videoraipodconverter\VideoraConverter.exe -t
    mRun: [QuickTime Task] "c:\program files\quicktime\qttask.exe" -atboottime
    mRun: [iTunesHelper] "c:\program files\itunes\iTunesHelper.exe "
    mRun: [SSBkgdUpdate] "c:\program files\common files\scansoft shared\ssbkgdupdate\SSBkgdupdate.exe" -Embedding -boot
    mRun: [Opware15] "c:\program files\scansoft\omnipage15.0\Opware15.exe "
    mRun: [OpScheduler] "c:\program files\scansoft\omnipage15.0\OpScheduler.exe "
    mRun: [ScanSoft OmniPage 15.0-reminder] "c:\program files\scansoft\omnipage15.0\ereg\ereg.exe" -r "c:\documents and settings\all users\application data\scansoft\omnipage15.0\ereg\ereg.ini "
    mRun: [PDF3 Registry Controller] "c:\program files\scansoft\omnipage15.0\pdfconverter3\\RegistryController.exe "
    mRun: [WinampAgent] c:\program files\winamp\winampa.exe
    mRun: [ISUSPM Startup] c:\progra~1\common~1\instal~1\update~1\ISUSPM.exe -startup
    mRun: [ISUSScheduler] "c:\program files\common files\installshield\updateservice\issch.exe" -start
    mRun: [WinGuard Pro]
    mRun: [TkBellExe] "c:\program files\common files\real\update_ob\realsched.exe" -osboot
    mRun: [mcui_exe] "c:\program files\mcafee.com\agent\mcagent.exe" /runkey
    mRun: [SunJavaUpdateSched] "c:\program files\common files\java\java update\jusched.exe "
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\adobea~1.lnk - c:\windows\installer\{ac76ba86-1033-f400-7760-000000000002}\SC_Acrobat.exe
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\adobeg~1.lnk - c:\program files\common files\adobe\calibration\Adobe Gamma Loader.exe
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\ramasst.lnk - c:\windows\system32\RAMASST.exe
    IE: Convert link target to Adobe PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIECapture.html
    IE: Convert link target to existing PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIEAppend.html
    IE: Convert selected links to Adobe PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
    IE: Convert selected links to existing PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
    IE: Convert selection to Adobe PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIECapture.html
    IE: Convert selection to existing PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIEAppend.html
    IE: Convert to Adobe PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIECapture.html
    IE: Convert to existing PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIEAppend.html
    IE: E&xport to Microsoft Excel - c:\progra~1\micros~2\office11\EXCEL.EXE/3000
    IE: Google Sidewiki... - c:\program files\google\google toolbar\component\GoogleToolbarDynamic_mui_en_950DF09FAB501E03.dll/cmsidewiki.html
    IE: Open with Scansoft PDF Converter 3.0 - c:\program files\scansoft\omnipage15.0\pdfconverter3\IEShellExt.dll /100
    IE: {CD67F990-D8E9-11d2-98FE-00C0F0318AFE}
    IE: {FB5F1910-F110-11d2-BB9E-00C04F795683} - c:\program files\messenger\msmsgs.exe
    IE: {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - {2EAF5BB0-070F-11D3-9307-00C04FAE2D4F} - c:\progra~1\mi3aa1~1\INetRepl.dll
    IE: {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - {2EAF5BB0-070F-11D3-9307-00C04FAE2D4F} - c:\progra~1\mi3aa1~1\INetRepl.dll
    IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\micros~2\office11\REFIEBAR.DLL
    Trusted Zone: westec.net
    Trusted Zone: westecnow.com
    DPF: {079CBF9B-A2EF-47DF-B0A6-266FFE46210B} - hxxp://customers.westecnow.com/activex/westec.cab
    DPF: {76CA9E30-5094-46F9-BE90-D47AD59C2C2C} - hxxps://bte.radiantenterprise.com/02.103.0130.26/pe/clientdownloads/SuperCab.cab
    DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab
    DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} - hxxp://fpdownload.macromedia.com/get/flashplayer/current/ultrashim.cab
    DPF: {CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab
    DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab
    Notify: !SASWinLogon - c:\program files\superantispyware\SASWINLO.DLL
    Notify: AtiExtEvent - Ati2evxx.dll
    Notify: LMIinit - LMIinit.dll
    AppInit_DLLs: c:\progra~1\google\google~1\GOEC62~1.DLL
    SEH: SABShellExecuteHook Class: {5ae067d3-9afb-48e0-853a-ebb7f4a000da} - c:\program files\superantispyware\SASSEH.DLL
    ================= FIREFOX ===================
    FF - ProfilePath - c:\docume~1\a\applic~1\mozilla\firefox\profiles\xgptojz1.default\
    FF - prefs.js: browser.startup.homepage - hxxp://www.google.com/ig?hl=en
    FF - component: c:\program files\real\realplayer\browserrecord\firefox\ext\components\nprpffbrowserrecordext.dll
    FF - plugin: c:\program files\google\update\1.2.183.39\npGoogleOneClick8.dll
    FF - plugin: c:\program files\java\jre6\bin\new_plugin\npdeployJava1.dll
    FF - plugin: c:\program files\mozilla firefox\plugins\npdjingleplugin-airfrance.dll
    FF - plugin: c:\program files\viewpoint\viewpoint experience technology\npViewpoint.dll
    FF - HiddenExtension: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\microsoft.net\framework\v3.5\windows presentation foundation\dotnetassistantextension\
    FF - HiddenExtension: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}
    ---- FIREFOX POLICIES ----
    FF - user.js: dom.disable_open_during_load - false // Popupblocker control handled by McAfee Privacy Service
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbaam7a8h ", true);
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--fiqz9s ", true); // Traditional
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--fiqs8s ", true); // Simplified
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--j6w193g ", true);
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgberp4a5d4ar ", true);
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgberp4a5d4a87g ", true);
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbqly7c0a67fbc ", true);
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbqly7cvafr ", true);
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--kpry57d ", true); // Traditional
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--kprw13d ", true); // Simplified
    R0 mfehidk;McAfee Inc. mfehidk;c:\windows\system32\drivers\mfehidk.sys [2010-9-15 386840]
    R1 mfetdi2k;McAfee Inc. mfetdi2k;c:\windows\system32\drivers\mfetdi2k.sys [2010-9-15 84072]
    R1 SASDIFSV;SASDIFSV;c:\program files\superantispyware\sasdifsv.sys [2010-2-17 12872]
    R1 SASKUTIL;SASKUTIL;c:\program files\superantispyware\SASKUTIL.SYS [2010-5-10 67656]
    R2 LMIInfo;LogMeIn Kernel Information Provider;c:\program files\logmein\rainfo.sys [2006-10-6 11120]
    R2 McMPFSvc;McAfee Personal Firewall Service; "c:\program files\common files\mcafee\mcsvchost\McSvHost.exe" /McCoreSvc [2010-9-15 271480]
    R2 McNaiAnn;McAfee VirusScan Announcer; "c:\program files\common files\mcafee\mcsvchost\McSvHost.exe" /McCoreSvc [2010-9-15 271480]
    R2 McProxy;McAfee Proxy Service; "c:\program files\common files\mcafee\mcsvchost\McSvHost.exe" /McCoreSvc [2010-9-15 271480]
    R2 McShield;McShield;c:\program files\common files\mcafee\systemcore\mcshield.exe [2010-9-15 171168]
    R2 mfefire;McAfee Firewall Core Service;c:\program files\common files\mcafee\systemcore\mfefire.exe [2010-9-15 188136]
    R2 mfevtp;McAfee Validation Trust Protection Service;c:\windows\system32\mfevtps.exe [2010-9-15 141792]
    R2 tdudf;TOSHIBA UDF File System Driver;c:\windows\system32\drivers\tdudf.sys [2006-6-28 98816]
    R3 cfwids;McAfee Inc. cfwids;c:\windows\system32\drivers\cfwids.sys [2010-9-15 55840]
    R3 mfeavfk;McAfee Inc. mfeavfk;c:\windows\system32\drivers\mfeavfk.sys [2010-9-15 152960]
    R3 mfebopk;McAfee Inc. mfebopk;c:\windows\system32\drivers\mfebopk.sys [2010-9-15 52104]
    R3 mfefirek;McAfee Inc. mfefirek;c:\windows\system32\drivers\mfefirek.sys [2010-9-15 313288]
    R3 mfendiskmp;mfendiskmp;c:\windows\system32\drivers\mfendisk.sys [2010-9-15 88544]
    S2 gupdate1ca89c1c055ef92;Google Update Service (gupdate1ca89c1c055ef92);c:\program files\google\update\GoogleUpdate.exe [2009-12-30 133104]
    S3 CampaignEnterprise9;CampaignEnterprise9;c:\progra~1\campai~1\Campaign9.exe [2006-12-27 1896448]
    S3 mfendisk;McAfee Core NDIS Intermediate Filter;c:\windows\system32\drivers\mfendisk.sys [2010-9-15 88544]
    S3 mferkdet;McAfee Inc. mferkdet;c:\windows\system32\drivers\mferkdet.sys [2010-9-15 84264]
    2010-11-10 03:36:32 -------- d-----w- c:\docume~1\a\applic~1\Malwarebytes
    2010-11-10 03:36:21 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2010-11-10 03:36:20 20952 ----a-w- c:\windows\system32\drivers\mbam.sys
    2010-11-10 03:36:20 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
    2010-11-10 03:36:20 -------- d-----w- c:\docume~1\alluse~1\applic~1\Malwarebytes
    2010-11-06 18:52:12 73728 ----a-w- c:\windows\system32\javacpl.cpl
    2010-10-20 16:38:38 -------- d-s---w- c:\documents and settings\a\UserData
    2010-10-18 15:19:24 -------- d-----w- c:\docume~1\alluse~1\applic~1\SUPERAntiSpyware.com
    2010-10-18 15:19:23 -------- d-----w- c:\docume~1\a\applic~1\SUPERAntiSpyware.com
    2010-10-18 15:19:10 -------- d-----w- c:\program files\SUPERAntiSpyware
    2010-10-15 20:31:32 -------- d-----w- C:\spoolerlogs
    2010-11-06 18:51:47 472808 ----a-w- c:\windows\system32\deployJava1.dll
    2010-10-14 02:28:54 141792 ----a-w- c:\windows\system32\mfevtps.exe
    ============= FINISH: 10:29:43.51 ===============
    UNLESS SPECIFICALLY INSTRUCTED, DO NOT POST THIS LOG.
    IF REQUESTED, ZIP IT UP & ATTACH IT
    Boot Device: \Device\HarddiskVolume1
    Install Date: 11/25/2006 6:05:38 AM
    System Uptime: 11/10/2010 6:43:33 AM (4 hours ago)
    Motherboard: TOSHIBA | | Satellite L35
    Processor: Intel(R) Celeron(R) M CPU 420 @ 1.60GHz | U23 | 1600/100mhz
    ==== Disk Partitions =========================
    C: is FIXED (NTFS) - 56 GiB total, 21.044 GiB free.
    D: is CDROM ()
    ==== Disabled Device Manager Items =============
    ==== System Restore Points ===================
    RP918: 8/12/2010 6:43:29 PM - System Checkpoint
    RP919: 8/13/2010 7:46:06 PM - System Checkpoint
    RP920: 8/15/2010 2:39:13 PM - System Checkpoint
    RP921: 8/16/2010 2:57:55 PM - System Checkpoint
    RP922: 8/17/2010 3:31:57 PM - System Checkpoint
    RP923: 8/18/2010 4:27:45 PM - System Checkpoint
    RP924: 8/19/2010 8:55:47 PM - System Checkpoint
    RP925: 8/20/2010 8:58:33 PM - System Checkpoint
    RP926: 8/22/2010 12:37:15 PM - System Checkpoint
    RP927: 8/23/2010 2:07:08 PM - System Checkpoint
    RP928: 8/24/2010 3:04:01 PM - System Checkpoint
    RP929: 8/25/2010 3:48:35 PM - System Checkpoint
    RP930: 8/26/2010 4:03:03 PM - System Checkpoint
    RP931: 8/27/2010 5:20:43 PM - System Checkpoint
    RP932: 8/28/2010 8:41:39 PM - System Checkpoint
    RP933: 8/29/2010 9:04:09 PM - System Checkpoint
    RP934: 8/30/2010 9:22:38 PM - System Checkpoint
    RP935: 9/10/2010 9:04:11 PM - System Checkpoint
    RP936: 9/11/2010 9:45:05 PM - System Checkpoint
    RP937: 9/13/2010 4:44:39 PM - System Checkpoint
    RP938: 9/14/2010 5:15:52 PM - System Checkpoint
    RP939: 9/15/2010 11:36:10 AM - Software Distribution Service 3.0
    RP940: 9/15/2010 11:59:55 AM - Installed Java(TM) 6 Update 21
    RP941: 9/16/2010 4:28:41 PM - System Checkpoint
    RP942: 9/17/2010 4:45:04 PM - System Checkpoint
    RP943: 9/20/2010 1:39:26 PM - System Checkpoint
    RP944: 9/21/2010 2:27:32 PM - System Checkpoint
    RP945: 9/22/2010 5:12:29 PM - System Checkpoint
    RP946: 9/23/2010 6:09:17 PM - System Checkpoint
    RP947: 9/24/2010 8:51:51 PM - System Checkpoint
    RP948: 9/27/2010 3:51:04 PM - System Checkpoint
    RP949: 9/28/2010 4:09:48 PM - System Checkpoint
    RP950: 10/1/2010 12:40:46 AM - System Checkpoint
    RP951: 10/4/2010 8:14:12 PM - System Checkpoint
    RP952: 10/5/2010 8:48:56 PM - System Checkpoint
    RP953: 10/7/2010 2:00:22 PM - System Checkpoint
    RP954: 10/9/2010 2:52:14 PM - System Checkpoint
    RP955: 10/11/2010 2:32:31 PM - System Checkpoint
    RP956: 10/12/2010 2:40:41 PM - System Checkpoint
    RP957: 10/13/2010 11:05:13 PM - System Checkpoint
    RP958: 10/15/2010 5:31:23 PM - System Checkpoint
    RP959: 10/16/2010 7:02:59 PM - System Checkpoint
    RP960: 10/17/2010 10:38:20 PM - System Checkpoint
    RP961: 10/18/2010 11:01:17 PM - System Checkpoint
    RP962: 10/19/2010 1:19:10 PM - Software Distribution Service 3.0
    RP963: 10/20/2010 1:31:41 PM - System Checkpoint
    RP964: 10/21/2010 3:45:06 PM - System Checkpoint
    RP965: 10/22/2010 4:46:09 PM - System Checkpoint
    RP966: 10/23/2010 5:28:14 PM - System Checkpoint
    RP967: 10/24/2010 8:59:33 PM - System Checkpoint
    RP968: 10/25/2010 9:20:40 PM - System Checkpoint
    RP969: 10/26/2010 9:38:26 PM - System Checkpoint
    RP970: 10/28/2010 1:45:52 PM - System Checkpoint
    RP971: 10/29/2010 1:50:04 PM - System Checkpoint
    RP972: 10/30/2010 3:02:11 PM - System Checkpoint
    RP973: 10/31/2010 3:38:05 PM - System Checkpoint
    RP974: 11/1/2010 4:34:43 PM - System Checkpoint
    RP975: 11/2/2010 7:09:53 PM - System Checkpoint
    RP976: 11/3/2010 7:19:15 PM - System Checkpoint
    RP977: 11/4/2010 7:55:33 PM - System Checkpoint
    RP978: 11/5/2010 9:48:38 PM - System Checkpoint
    RP979: 11/6/2010 2:48:53 PM - Removed Java(TM) 6 Update 21
    RP980: 11/6/2010 2:51:38 PM - Installed Java(TM) 6 Update 22
    RP981: 11/7/2010 2:37:06 PM - System Checkpoint
    RP982: 11/8/2010 3:35:06 PM - System Checkpoint
    RP983: 11/9/2010 4:35:09 PM - System Checkpoint
    RP984: 11/10/2010 3:01:40 AM - Software Distribution Service 3.0
    ==== Installed Programs ======================
    Adobe Acrobat 7.0 Professional - English, Français, Deutsch
    Adobe Audition 2.0
    Adobe Bridge 1.0
    Adobe Common File Installer
    Adobe Flash Player 10 Plugin
    Adobe Flash Player ActiveX
    Adobe Help Center 1.0
    Adobe InDesign 2.0
    Adobe Photoshop CS2
    Adobe Premiere Elements 2.0
    Adobe Stock Photos 1.0
    Adobe SVG Viewer 3.0
    America Online (Choose which version to remove)
    AOL Coach Version 2.0(Build:20041026.5 en)
    AOL Connectivity Services
    AOL Spyware Protection
    AOL You've Got Pictures Screensaver
    Atheros Client Utility
    Atheros Wireless LAN MiniPCI/PCIe card Driver
    ATI Control Panel
    ATI Display Driver
    AutoUpdate
    Avant Browser (remove only)
    AviSynth 2.5
    Blasterball 2 Revolution
    Campaign Enterprise 9
    CD/DVD Drive Acoustic Silencer
    CuteFTP 7 Professional
    Desktop Dialer
    DirectVobSub (remove only)
    DivX Codec
    DivX Player
    DVD-RAM Driver
    DVD Shrink 3.2
    FATE
    File, Print FedEx Kinko's
    Google Chrome
    Google Desktop
    Google Toolbar for Internet Explorer
    Google Update Helper
    High Definition Audio Driver Package - KB888111
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB953595)
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB958484)
    Hotfix for Windows Media Format SDK (KB902344)
    Hotfix for Windows Media Format SDK (KB910998)
    Hotfix for Windows XP (KB893357)
    Hotfix for Windows XP (KB894871)
    Hotfix for Windows XP (KB895200)
    Hotfix for Windows XP (KB909394)
    Hotfix for Windows XP (KB910728)
    Hotfix for Windows XP (KB935448)
    Hotfix for Windows XP (KB952287)
    Hotfix for Windows XP (KB954550-v5)
    Hotfix for Windows XP (KB961118)
    Hotfix for Windows XP (KB970653-v3)
    Hotfix for Windows XP (KB976098-v2)
    Hotfix for Windows XP (KB979306)
    Hotfix for Windows XP (KB981793)
    InterActual Player
    InterVideo WinDVD for TOSHIBA
    iTunes
    Java Auto Updater
    LogMeIn
    Macromedia Dreamweaver 8
    Macromedia Extension Manager
    Macromedia Fireworks 8
    Macromedia Flash 8
    Macromedia Flash 8 Video Encoder
    Macromedia Flash Player 8 Plugin
    Macromedia FlashPaper 2
    Macromedia FreeHand 10
    McAfee Total Protection
    Microsoft .NET Framework 1.1
    Microsoft .NET Framework 1.1 Security Update (KB979906)
    Microsoft .NET Framework 2.0 Service Pack 2
    Microsoft .NET Framework 3.0 Service Pack 2
    Microsoft ActiveSync 4.0
    Microsoft Office FrontPage 2003
    Microsoft Office Professional Edition 2003
    Mozilla Firefox (3.6.12)
    MSN
    MSXML 4.0 SP2 (KB927978)
    MSXML 4.0 SP2 (KB936181)
    MSXML 4.0 SP2 (KB954430)
    MSXML 4.0 SP2 (KB973688)
    MSXML 6 Service Pack 2 (KB973686)
    muvee autoProducer 5.0
    MyODBC
    Nero 7 Ultra Edition
    Office 2003 Trial Assistant
    Penguins!
    Picasa 2
    Polar Golfer
    Pure Networks Port Magic
    QuickTime
    RealPlayer
    REALTEK GbE & FE Ethernet PCI NIC Driver
    Realtek High Definition Audio Driver
    ScanSoft PDF Converter 3.0
    ScanSoft PDF Create 3.0
    SCRABBLE
    Security Update for Step By Step Interactive Training (KB898458)
    Security Update for Windows Media Player (KB911564)
    Security Update for Windows Media Player (KB952069)
    Security Update for Windows Media Player (KB954155)
    Security Update for Windows Media Player (KB968816)
    Security Update for Windows Media Player (KB973540)
    Security Update for Windows Media Player (KB978695)
    Security Update for Windows Media Player 10 (KB917734)
    Security Update for Windows Media Player 10 (KB936782)
    Security Update for Windows Media Player 6.4 (KB925398)
    Security Update for Windows XP (KB2229593)
    Security Update for Windows XP (KB890046)
    Security Update for Windows XP (KB893066)
    Security Update for Windows XP (KB893756)
    Security Update for Windows XP (KB896358)
    Security Update for Windows XP (KB896422)
    Security Update for Windows XP (KB896423)
    Security Update for Windows XP (KB896424)
    Security Update for Windows XP (KB896428)
    Security Update for Windows XP (KB896688)
    Security Update for Windows XP (KB899587)
    Security Update for Windows XP (KB899589)
    Security Update for Windows XP (KB899591)
    Security Update for Windows XP (KB900725)
    Security Update for Windows XP (KB901017)
    Security Update for Windows XP (KB901190)
    Security Update for Windows XP (KB901214)
    Security Update for Windows XP (KB902400)
    Security Update for Windows XP (KB904706)
    Security Update for Windows XP (KB905414)
    Security Update for Windows XP (KB905749)
    Security Update for Windows XP (KB908519)
    Security Update for Windows XP (KB908531)
    Security Update for Windows XP (KB911562)
    Security Update for Windows XP (KB911567)
    Security Update for Windows XP (KB911927)
    Security Update for Windows XP (KB912812)
    Security Update for Windows XP (KB912919)
    Security Update for Windows XP (KB913446)
    Security Update for Windows XP (KB913580)
    Security Update for Windows XP (KB914388)
    Security Update for Windows XP (KB914389)
    Security Update for Windows XP (KB917344)
    Security Update for Windows XP (KB917422)
    Security Update for Windows XP (KB917953)
    Security Update for Windows XP (KB918118)
    Security Update for Windows XP (KB918439)
    Security Update for Windows XP (KB919007)
    Security Update for Windows XP (KB920213)
    Security Update for Windows XP (KB920670)
    Security Update for Windows XP (KB920683)
    Security Update for Windows XP (KB920685)
    Security Update for Windows XP (KB921398)
    Security Update for Windows XP (KB921503)
    Security Update for Windows XP (KB922616)
    Security Update for Windows XP (KB922819)
    Security Update for Windows XP (KB923191)
    Security Update for Windows XP (KB923414)
    Security Update for Windows XP (KB923561)
    Security Update for Windows XP (KB923689)
    Security Update for Windows XP (KB923694)
    Security Update for Windows XP (KB923980)
    Security Update for Windows XP (KB924191)
    Security Update for Windows XP (KB924270)
    Security Update for Windows XP (KB924496)
    Security Update for Windows XP (KB924667)
    Security Update for Windows XP (KB925454)
    Security Update for Windows XP (KB925486)
    Security Update for Windows XP (KB925902)
    Security Update for Windows XP (KB926255)
    Security Update for Windows XP (KB926436)
    Security Update for Windows XP (KB927779)
    Security Update for Windows XP (KB927802)
    Security Update for Windows XP (KB928090)
    Security Update for Windows XP (KB928255)
    Security Update for Windows XP (KB928843)
    Security Update for Windows XP (KB929123)
    Security Update for Windows XP (KB929969)
    Security Update for Windows XP (KB930178)
    Security Update for Windows XP (KB931261)
    Security Update for Windows XP (KB931768)
    Security Update for Windows XP (KB931784)
    Security Update for Windows XP (KB932168)
    Security Update for Windows XP (KB933566)
    Security Update for Windows XP (KB933729)
    Security Update for Windows XP (KB935839)
    Security Update for Windows XP (KB935840)
    Security Update for Windows XP (KB936021)
    Security Update for Windows XP (KB937143)
    Security Update for Windows XP (KB938127)
    Security Update for Windows XP (KB938464)
    Security Update for Windows XP (KB938829)
    Security Update for Windows XP (KB939653)
    Security Update for Windows XP (KB941202)
    Security Update for Windows XP (KB941568)
    Security Update for Windows XP (KB941569)
    Security Update for Windows XP (KB941644)
    Security Update for Windows XP (KB941693)
    Security Update for Windows XP (KB942615)
    Security Update for Windows XP (KB943055)
    Security Update for Windows XP (KB943460)
    Security Update for Windows XP (KB943485)
    Security Update for Windows XP (KB944338)
    Security Update for Windows XP (KB944533)
    Security Update for Windows XP (KB944653)
    Security Update for Windows XP (KB945553)
    Security Update for Windows XP (KB946026)
    Security Update for Windows XP (KB946648)
    Security Update for Windows XP (KB947864)
    Security Update for Windows XP (KB948590)
    Security Update for Windows XP (KB948881)
    Security Update for Windows XP (KB950749)
    Security Update for Windows XP (KB950759)
    Security Update for Windows XP (KB950760)
    Security Update for Windows XP (KB950762)
    Security Update for Windows XP (KB950974)
    Security Update for Windows XP (KB951066)
    Security Update for Windows XP (KB951376-v2)
    Security Update for Windows XP (KB951376)
    Security Update for Windows XP (KB951698)
    Security Update for Windows XP (KB951748)
    Security Update for Windows XP (KB952004)
    Security Update for Windows XP (KB952954)
    Security Update for Windows XP (KB953838)
    Security Update for Windows XP (KB953839)
    Security Update for Windows XP (KB954211)
    Security Update for Windows XP (KB954600)
    Security Update for Windows XP (KB955069)
    Security Update for Windows XP (KB956390)
    Security Update for Windows XP (KB956391)
    Security Update for Windows XP (KB956572)
    Security Update for Windows XP (KB956802)
    Security Update for Windows XP (KB956803)
    Security Update for Windows XP (KB956841)
    Security Update for Windows XP (KB956844)
    Security Update for Windows XP (KB957095)
    Security Update for Windows XP (KB957097)
    Security Update for Windows XP (KB958215)
    Security Update for Windows XP (KB958470)
    Security Update for Windows XP (KB958644)
    Security Update for Windows XP (KB958687)
    Security Update for Windows XP (KB958690)
    Security Update for Windows XP (KB958869)
    Security Update for Windows XP (KB959426)
    Security Update for Windows XP (KB960225)
    Security Update for Windows XP (KB960714)
    Security Update for Windows XP (KB960715)
    Security Update for Windows XP (KB960803)
    Security Update for Windows XP (KB960859)
    Security Update for Windows XP (KB961371)
    Security Update for Windows XP (KB961373)
    Security Update for Windows XP (KB961501)
    Security Update for Windows XP (KB963027)
    Security Update for Windows XP (KB968537)
    Security Update for Windows XP (KB969059)
    Security Update for Windows XP (KB969897)
    Security Update for Windows XP (KB969898)
    Security Update for Windows XP (KB969947)
    Security Update for Windows XP (KB970238)
    Security Update for Windows XP (KB970430)
    Security Update for Windows XP (KB971468)
    Security Update for Windows XP (KB971486)
    Security Update for Windows XP (KB971557)
    Security Update for Windows XP (KB971633)
    Security Update for Windows XP (KB971657)
    Security Update for Windows XP (KB971961)
    Security Update for Windows XP (KB972260)
    Security Update for Windows XP (KB972270)
    Security Update for Windows XP (KB973346)
    Security Update for Windows XP (KB973354)
    Security Update for Windows XP (KB973507)
    Security Update for Windows XP (KB973525)
    Security Update for Windows XP (KB973869)
    Security Update for Windows XP (KB973904)
    Security Update for Windows XP (KB974112)
    Security Update for Windows XP (KB974318)
    Security Update for Windows XP (KB974392)
    Security Update for Windows XP (KB974455)
    Security Update for Windows XP (KB974571)
    Security Update for Windows XP (KB975025)
    Security Update for Windows XP (KB975467)
    Security Update for Windows XP (KB975560)
    Security Update for Windows XP (KB975561)
    Security Update for Windows XP (KB975562)
    Security Update for Windows XP (KB976325)
    Security Update for Windows XP (KB977165)
    Security Update for Windows XP (KB977816)
    Security Update for Windows XP (KB977914)
    Security Update for Windows XP (KB978037)
    Security Update for Windows XP (KB978251)
    Security Update for Windows XP (KB978262)
    Security Update for Windows XP (KB978338)
    Security Update for Windows XP (KB978542)
    Security Update for Windows XP (KB978601)
    Security Update for Windows XP (KB978706)
    Security Update for Windows XP (KB979309)
    Security Update for Windows XP (KB979482)
    Security Update for Windows XP (KB979559)
    Security Update for Windows XP (KB979683)
    Security Update for Windows XP (KB980195)
    Security Update for Windows XP (KB980218)
    Security Update for Windows XP (KB980232)
    Security Update for Windows XP (KB981350)
    Security Update for Windows XP (KB982381)
    SUPERAntiSpyware
    Synaptics Pointing Device Driver
    TOSHIBA Assist
    TOSHIBA ConfigFree
    TOSHIBA Direct Disc Writer
    TOSHIBA Disc Creator
    TOSHIBA Game Console
    TOSHIBA PC Diagnostic Tool
    TOSHIBA Power Saver
    Toshiba Registration
    TOSHIBA Software Modem
    TOSHIBA Software Upgrades
    TOSHIBA Speech System Applications
    TOSHIBA Speech System SR Engine(U.S.) Version1.0
    TOSHIBA Speech System TTS Engine(U.S.) Version1.0
    Toshiba Touchpad Utility
    Toshiba Utility
    Touch and Launch
    Update for Windows XP (KB894391)
    Update for Windows XP (KB898461)
    Update for Windows XP (KB900485)
    Update for Windows XP (KB910437)
    Update for Windows XP (KB911280)
    Update for Windows XP (KB916595)
    Update for Windows XP (KB920872)
    Update for Windows XP (KB922582)
    Update for Windows XP (KB925720)
    Update for Windows XP (KB927891)
    Update for Windows XP (KB930916)
    Update for Windows XP (KB931836)
    Update for Windows XP (KB933360)
    Update for Windows XP (KB936357)
    Update for Windows XP (KB938828)
    Update for Windows XP (KB942763)
    Update for Windows XP (KB942840)
    Update for Windows XP (KB946627)
    Update for Windows XP (KB951072-v2)
    Update for Windows XP (KB955759)
    Update for Windows XP (KB955839)
    Update for Windows XP (KB967715)
    Update for Windows XP (KB968389)
    Update for Windows XP (KB971737)
    Update for Windows XP (KB973687)
    Update for Windows XP (KB973815)
    Update for Windows XP (KB976749)
    Update for Windows XP (KB978207)
    Update for Windows XP (KB980182)
    Videora iPod Converter 0.91
    Viewpoint Media Player
    WebFldrs XP
    Westec Remote
    WildTangent Web Driver
    Winamp (remove only)
    Windows Genuine Advantage Notifications (KB905474)
    Windows Imaging Component
    Windows Installer 3.1 (KB893803)
    Windows Media Format Runtime
    Windows Media Player 10 Hotfix - KB894476
    Windows XP Hotfix - KB873339
    Windows XP Hotfix - KB884018
    Windows XP Hotfix - KB885250
    Windows XP Hotfix - KB885835
    Windows XP Hotfix - KB885836
    Windows XP Hotfix - KB886185
    Windows XP Hotfix - KB887472
    Windows XP Hotfix - KB888113
    Windows XP Hotfix - KB888302
    Windows XP Hotfix - KB888622
    Windows XP Hotfix - KB889673
    Windows XP Hotfix - KB890175
    Windows XP Hotfix - KB890859
    Windows XP Hotfix - KB891781
    Windows XP Hotfix - KB893056
    WinRAR archiver
    Yahoo! Music Engine
    ==== Event Viewer Messages From Past Week ========
    11/6/2010 12:40:54 PM, error: Service Control Manager [7023] - The Application Management service terminated with the following error: The specified module could not be found.
    11/6/2010 12:40:54 PM, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the Windows Installer service to connect.
    11/6/2010 12:40:54 PM, error: Service Control Manager [7000] - The Windows Installer service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
    11/6/2010 12:40:54 PM, error: DCOM [10005] - DCOM got error "%1053" attempting to start the service MSIServer with arguments " " in order to run the server: {000C101C-0000-0000-C000-000000000046}
    11/6/2010 11:57:44 AM, error: Service Control Manager [7000] - The SASDIFSV service failed to start due to the following error: Cannot create a file when that file already exists.
    11/5/2010 9:21:33 PM, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the iPod Service service to connect.
    11/5/2010 9:21:33 PM, error: Service Control Manager [7000] - The iPod Service service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
    11/5/2010 9:21:26 PM, error: DCOM [10005] - DCOM got error "%1053" attempting to start the service iPod Service with arguments " " in order to run the server: {063D34A4-BF84-4B8D-B699-E8CA06504DDE}
    11/10/2010 6:52:06 AM, error: atapi [11] - The driver detected a controller error on \Device\Ide\IdePort0.
    11/10/2010 6:49:27 AM, error: atapi [9] - The device, \Device\Ide\IdePort0, did not respond within the timeout period.
    11/10/2010 6:45:18 AM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: KR10N
    11/10/2010 6:44:05 AM, error: sr [1] - The System Restore filter encountered the unexpected error '0xC0000001' while processing the file '' on the volume 'HarddiskVolume1'. It has stopped monitoring the volume.
    ==== End Of File ===========================
    I was unable to post everything due to character limitations.
    Thank you for your help Broni.
  7. 2010/11/10
    [color= "Blue"]**Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**[/color]
    2. Close any open browsers.
      • Click on [color= "Red"]this link[/color] to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      NOTE1. If Combofix asks you to install Recovery Console, please allow it.
      • Close any open browsers.
      • [color= "Red"]WARNING:[/color] Combofix will disconnect your machine from the Internet as soon as it starts
    6. Please post the "C:\ComboFix.txt"
    NOTE.
    If, for some reason, Combofix refuses to run, try one of the following:
    1. Run Combofix from Safe Mode.
    2. Delete Combofix file, download fresh one, but rename combofix.exe to your_name.exe BEFORE saving it to your desktop.
    Do NOT run it yet.
    Please download and run the below tool named Rkill (courtesy of BleepingComputer.com) which may help allow other programs to run.
    There are 4 different versions. If one of them won't run then download and try to run the other one.
    Vista and Win7 users need to right click Rkill and choose Run as Administrator
    You only need to get one of these to run, not all of them. You may get warnings from your antivirus about this tool, ignore them or shutdown your antivirus.
    Rkill.com
    Rkill.scr
    Rkill.pif
    Rkill.exe
    • Double-click on the Rkill desktop icon to run the tool.
    • If using Vista or Windows 7 right-click on it and choose Run As Administrator.
    • A black DOS box will briefly flash and then disappear. This is normal and indicates the tool ran successfully.
    • If not, delete the file, then download and use the one provided in Link 2.
    • If it does not work, repeat the process and attempt to use one of the remaining links until the tool runs.
    • Do not reboot until instructed.
    • If the tool does not run from any of the links provided, please let me know.
    Once you've gotten one of them to run, immediately run your_name.exe by double clicking on it.
    If normal mode still doesn't work, run BOTH tools from safe mode.
    In case #2, please post BOTH logs, rKill and Combofix.
  8. 2010/11/10
    atlgman
    ComboFix 10-11-10.01 - a 11/10/2010 22:51:21.1.1 - x86
    Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.1406.921 [GMT -5:00]
    Running from: c:\documents and settings\a\Desktop\ComboFix.exe
    AV: McAfee Anti-Virus and Anti-Spyware *On-access scanning disabled* (Updated) {84B5EE75-6421-4CDE-A33A-DD43BA9FAD83}
    FW: McAfee Firewall *disabled* {94894B63-8C7F-4050-BDA4-813CA00DA3E8}
    ((((((((((((((((((((((((( Files Created from 2010-10-11 to 2010-11-11 )))))))))))))))))))))))))))))))
    2010-11-10 03:36 . 2010-11-10 03:36 -------- d-----w- c:\documents and settings\a\Application Data\Malwarebytes
    2010-11-10 03:36 . 2010-04-29 20:39 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2010-11-10 03:36 . 2010-11-10 04:16 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
    2010-11-10 03:36 . 2010-11-10 03:36 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
    2010-11-10 03:36 . 2010-04-29 20:39 20952 ----a-w- c:\windows\system32\drivers\mbam.sys
    2010-11-06 18:52 . 2010-11-06 18:52 -------- d-----w- c:\program files\Common Files\Java
    2010-11-06 18:52 . 2010-11-06 18:51 73728 ----a-w- c:\windows\system32\javacpl.cpl
    2010-10-24 18:11 . 2010-10-24 18:13 -------- d-----w- c:\documents and settings\NetworkService\Local Settings\Application Data\Temp
    2010-10-20 16:38 . 2010-10-20 16:38 -------- d-s---w- c:\documents and settings\a\UserData
    2010-10-18 15:19 . 2010-10-18 15:19 -------- d-----w- c:\documents and settings\All Users\Application Data\SUPERAntiSpyware.com
    2010-10-18 15:19 . 2010-10-18 15:19 -------- d-----w- c:\documents and settings\a\Application Data\SUPERAntiSpyware.com
    2010-10-18 15:19 . 2010-11-06 16:01 -------- d-----w- c:\program files\SUPERAntiSpyware
    2010-10-15 20:31 . 2010-10-15 20:31 -------- d-----w- C:\spoolerlogs
    2010-11-06 18:51 . 2010-09-15 16:00 472808 ----a-w- c:\windows\system32\deployJava1.dll
    2010-10-14 02:28 . 2010-09-15 16:16 9344 ----a-w- c:\windows\system32\drivers\mfeclnk.sys
    2010-10-14 02:28 . 2010-09-15 16:16 141792 ----a-w- c:\windows\system32\mfevtps.exe
    2010-10-14 02:28 . 2010-09-15 16:15 88544 ----a-w- c:\windows\system32\drivers\mfendisk.sys
    2010-10-14 02:28 . 2010-09-15 16:15 84264 ----a-w- c:\windows\system32\drivers\mferkdet.sys
    2010-10-14 02:28 . 2010-09-15 16:15 84072 ----a-w- c:\windows\system32\drivers\mfetdi2k.sys
    2010-10-14 02:28 . 2010-09-15 16:15 52104 ----a-w- c:\windows\system32\drivers\mfebopk.sys
    2010-10-14 02:28 . 2010-09-15 16:15 386840 ----a-w- c:\windows\system32\drivers\mfehidk.sys
    2010-10-14 02:28 . 2010-09-15 16:15 313288 ----a-w- c:\windows\system32\drivers\mfefirek.sys
    2010-10-14 02:28 . 2010-09-15 16:15 95600 ----a-w- c:\windows\system32\drivers\mfeapfk.sys
    2010-10-14 02:28 . 2010-09-15 16:15 55840 ----a-w- c:\windows\system32\drivers\cfwids.sys
    2010-10-14 02:28 . 2010-09-15 16:15 152960 ----a-w- c:\windows\system32\drivers\mfeavfk.sys
    2010-10-14 02:28 . 2010-09-15 16:16 24376 ----a-w- c:\program files\mozilla firefox\components\Scriptff.dll
    "TOSCDSPD "= "c:\program files\TOSHIBA\TOSCDSPD\toscdspd.exe" [2004-12-30 65536]
    "swg "= "c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-07-27 68856]
    "airfrance "= "c:\documents and settings\a\Local Settings\Application Data\Djingle\Widget by Air France (US)\bin\autorun.lnk" [2009-05-30 2253]
    "ctfmon.exe "= "c:\windows\system32\ctfmon.exe" [2004-08-03 15360]
    "CFSServ.exe "= "CFSServ.exe -NoClient" [X]
    "ATIPTA "= "c:\program files\ATI Technologies\ATI Control Panel\atiptaxx.exe" [2005-12-12 344064]
    "SynTPEnh "= "c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2006-04-07 761946]
    "NDSTray.exe "= "NDSTray.exe" [BU]
    "Toshiba Hotkey Utility "= "c:\program files\Toshiba\Windows Utilities\Hotkey.exe" [2006-08-01 1773568]
    "PadTouch "= "c:\program files\TOSHIBA\Touch and Launch\PadExe.exe" [2005-12-06 1077322]
    "SmoothView "= "c:\program files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe" [2005-04-26 122880]
    "TPSMain "= "TPSMain.exe" [2005-06-01 282624]
    "Pinger "= "c:\toshiba\ivp\ism\pinger.exe" [2005-03-18 151552]
    "RTHDCPL "= "RTHDCPL.EXE" [2006-09-06 16262656]
    "SkyTel "= "SkyTel.EXE" [2006-05-17 2879488]
    "LtMoh "= "c:\program files\ltmoh\Ltmoh.exe" [2005-12-16 188416]
    "AGRSMMSG "= "AGRSMMSG.exe" [2006-03-18 89541]
    "LogMeIn GUI "= "c:\program files\LogMeIn\LogMeInSystray.exe" [2006-10-07 303864]
    "Acrobat Assistant 7.0 "= "c:\program files\Adobe\Acrobat 7.0\Distillr\Acrotray.exe" [2004-12-14 483328]
    "NeroFilterCheck "= "c:\program files\Common Files\Ahead\Lib\NeroCheck.exe" [2006-01-12 155648]
    "QuickTime Task "= "c:\program files\QuickTime\qttask.exe" [2006-10-25 282624]
    "iTunesHelper "= "c:\program files\iTunes\iTunesHelper.exe" [2006-10-30 256576]
    "SSBkgdUpdate "= "c:\program files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe" [2003-09-30 155648]
    "Opware15 "= "c:\program files\ScanSoft\OmniPage15.0\Opware15.exe" [2005-07-06 69632]
    "ScanSoft OmniPage 15.0-reminder "= "c:\program files\ScanSoft\OmniPage15.0\Ereg\ereg.exe" [2005-06-03 729088]
    "PDF3 Registry Controller "= "c:\program files\ScanSoft\OmniPage15.0\PDFConverter3\\RegistryController.exe" [2005-04-12 106496]
    "WinampAgent "= "c:\program files\Winamp\winampa.exe" [2006-11-21 35328]
    "ISUSPM Startup "= "c:\progra~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe" [2004-08-09 221184]
    "ISUSScheduler "= "c:\program files\Common Files\InstallShield\UpdateService\issch.exe" [2004-08-09 81920]
    "TkBellExe "= "c:\program files\Common Files\Real\Update_OB\realsched.exe" [2009-12-31 198160]
    "mcui_exe "= "c:\program files\McAfee.com\Agent\mcagent.exe" [2010-09-30 1193848]
    "SunJavaUpdateSched "= "c:\program files\Common Files\Java\Java Update\jusched.exe" [2010-05-14 248552]
    c:\documents and settings\All Users\Start Menu\Programs\Startup\
    Adobe Acrobat Speed Launcher.lnk - c:\windows\Installer\{AC76BA86-1033-F400-7760-000000000002}\SC_Acrobat.exe [2006-12-27 25214]
    Adobe Gamma Loader.lnk - c:\program files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2006-12-27 110592]
    RAMASST.lnk - c:\windows\system32\RAMASST.exe [2006-8-21 155648]
    [hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
    "{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} "= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 77824]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\!SASWinLogon]
    2009-09-03 22:21 548352 ----a-w- c:\program files\SUPERAntiSpyware\SASWINLO.DLL
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\LMIinit]
    2006-10-07 00:56 11504 ----a-w- c:\windows\system32\LMIinit.dll
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\mcmscsvc]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MCODS]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeAntiVirus]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeFirewall]
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
    "EnableFirewall "= 0 (0x0)
    "c:\\TOSHIBA\\ivp\\NetInt\\Netint.exe "=
    "c:\\TOSHIBA\\Ivp\\ISM\\pinger.exe "= c:\\TOSHIBA\\IVP\\ISM\\pinger.exe
    "c:\\Program Files\\Common Files\\AOL\\Loader\\aolload.exe "=
    "c:\\Program Files\\Common Files\\AOL\\ACS\\AOLDial.exe "=
    "c:\\Program Files\\Common Files\\AOL\\ACS\\AOLacsd.exe "=
    "c:\\Program Files\\America Online 9.0\\waol.exe "=
    "c:\\Program Files\\Common Files\\AOL\\TopSpeed\\2.0\\aoltsmon.exe "=
    "c:\\Program Files\\Common Files\\AOL\\TopSpeed\\2.0\\aoltpspd.exe "=
    "c:\\Program Files\\Common Files\\AOL\\1156187317\\EE\\AOLServiceHost.exe "=
    "c:\\Program Files\\Common Files\\AOL\\System Information\\sinf.exe "=
    "c:\\Program Files\\Common Files\\AOL\\AOL Spyware Protection\\AOLSP Scheduler.exe "=
    "c:\\Program Files\\Common Files\\AOL\\AOL Spyware Protection\\asp.exe "=
    "c:\\Program Files\\Common Files\\AolCoach\\en_en\\player\\AOLNySEV.exe "=
    "c:\\Program Files\\Yahoo!\\Yahoo! Music Engine\\YahooMusicEngine.exe "=
    "c:\\Program Files\\iTunes\\iTunes.exe "=
    "c:\\Program Files\\Nero\\Nero 7\\Nero Home\\NeroHome.exe "=
    "c:\program files\Microsoft ActiveSync\rapimgr.exe "= c:\program files\Microsoft ActiveSync\rapimgr.exe:169.254.2.0/255.255.255.0:Enabled:ActiveSync RAPI Manager
    "c:\program files\Microsoft ActiveSync\wcescomm.exe "= c:\program files\Microsoft ActiveSync\wcescomm.exe:169.254.2.0/255.255.255.0:Enabled:ActiveSync Connection Manager
    "c:\program files\Microsoft ActiveSync\WCESMgr.exe "= c:\program files\Microsoft ActiveSync\WCESMgr.exe:169.254.2.0/255.255.255.0:Enabled:ActiveSync Application
    "c:\\WINDOWS\\system32\\spool\\drivers\\w32x86\\3\\SAGENT4.EXE "=
    "c:\\Program Files\\Kinko's\\FPFK\\FPKMain.exe "=
    "c:\\Program Files\\Kinko's\\FPFK\\Kinkos.Jupiter.GUI.Queue.exe "=
    "c:\\Program Files\\Avant Browser\\avant.exe "=
    "c:\\Program Files\\Common Files\\Mcafee\\McSvcHost\\McSvHost.exe "=
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
    "26675:TCP "= 26675:TCP:169.254.2.0/255.255.255.0:Enabled:ActiveSync Service
    R1 mfetdi2k;McAfee Inc. mfetdi2k;c:\windows\system32\drivers\mfetdi2k.sys [9/15/2010 11:15 AM 84072]
    R1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\sasdifsv.sys [2/17/2010 1:25 PM 12872]
    R1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.SYS [5/10/2010 1:41 PM 67656]
    R2 LMIInfo;LogMeIn Kernel Information Provider;c:\program files\LogMeIn\rainfo.sys [10/6/2006 7:56 PM 11120]
    R2 McMPFSvc;McAfee Personal Firewall Service; "c:\program files\Common Files\Mcafee\McSvcHost\McSvHost.exe" /McCoreSvc [9/15/2010 11:15 AM 271480]
    R2 McNaiAnn;McAfee VirusScan Announcer; "c:\program files\Common Files\Mcafee\McSvcHost\McSvHost.exe" /McCoreSvc [9/15/2010 11:15 AM 271480]
    R2 mfefire;McAfee Firewall Core Service;c:\program files\Common Files\Mcafee\SystemCore\mfefire.exe [9/15/2010 11:16 AM 188136]
    R2 mfevtp;McAfee Validation Trust Protection Service;c:\windows\system32\mfevtps.exe [9/15/2010 11:16 AM 141792]
    R2 tdudf;TOSHIBA UDF File System Driver;c:\windows\system32\drivers\tdudf.sys [6/28/2006 1:50 PM 98816]
    R3 cfwids;McAfee Inc. cfwids;c:\windows\system32\drivers\cfwids.sys [9/15/2010 11:15 AM 55840]
    R3 mfefirek;McAfee Inc. mfefirek;c:\windows\system32\drivers\mfefirek.sys [9/15/2010 11:15 AM 313288]
    R3 mfendiskmp;mfendiskmp;c:\windows\system32\drivers\mfendisk.sys [9/15/2010 11:15 AM 88544]
    S2 gupdate1ca89c1c055ef92;Google Update Service (gupdate1ca89c1c055ef92);c:\program files\Google\Update\GoogleUpdate.exe [12/30/2009 9:34 PM 133104]
    S3 CampaignEnterprise9;CampaignEnterprise9;c:\progra~1\CAMPAI~1\Campaign9.exe [12/27/2006 2:16 AM 1896448]
    S3 mfendisk;McAfee Core NDIS Intermediate Filter;c:\windows\system32\drivers\mfendisk.sys [9/15/2010 11:15 AM 88544]
    S3 mferkdet;McAfee Inc. mferkdet;c:\windows\system32\drivers\mferkdet.sys [9/15/2010 11:15 AM 84264]
    *Deregistered* - mfeavfk01
    2010-11-11 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
    - c:\program files\Google\Update\GoogleUpdate.exe [2009-12-31 02:34]
    2010-11-11 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
    IE: Convert link target to Adobe PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
    IE: Convert link target to existing PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
    IE: Convert selected links to Adobe PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
    IE: Convert selected links to existing PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
    IE: Convert selection to Adobe PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
    IE: Convert selection to existing PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
    IE: Convert to Adobe PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
    IE: Convert to existing PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
    IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
    IE: Google Sidewiki... - c:\program files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_950DF09FAB501E03.dll/cmsidewiki.html
    IE: Open with Scansoft PDF Converter 3.0 - c:\program files\ScanSoft\OmniPage15.0\PDFConverter3\IEShellExt.dll /100
    FF - ProfilePath - c:\documents and settings\a\Application Data\Mozilla\Firefox\Profiles\xgptojz1.default\
    FF - plugin: c:\program files\Google\Update\1.2.183.39\npGoogleOneClick8.dll
    FF - plugin: c:\program files\Java\jre6\bin\new_plugin\npdeployJava1.dll
    FF - plugin: c:\program files\Mozilla Firefox\plugins\npdjingleplugin-airfrance.dll
    FF - plugin: c:\program files\Viewpoint\Viewpoint Experience Technology\npViewpoint.dll
    FF - HiddenExtension: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbaam7a8h ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--fiqz9s ", true); // Traditional
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--fiqs8s ", true); // Simplified
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--j6w193g ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgberp4a5d4ar ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgberp4a5d4a87g ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbqly7c0a67fbc ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbqly7cvafr ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--kpry57d ", true); // Traditional
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--kprw13d ", true); // Simplified
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "dom.ipc.plugins.enabled ", false);
    HKLM-Run-VideoraiPodConverter - c:\program files\VideoraiPodConverter\VideoraConverter.exe
    HKLM-Run-OpScheduler - c:\program files\ScanSoft\OmniPage15.0\OpScheduler.exe
    HKLM-Run-WinGuard Pro - (no file)
    Rootkit scan 2010-11-10 23:19
    Windows 5.1.2600 Service Pack 2 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\i8042prt]
    "ImagePath "= "system32\DRIVERS\i8042prt.sy@ "
    [HKEY_LOCAL_MACHINE\software\Microsoft\Windows\CurrentVersion\Installer\UserData\LocalSystem\Components\•€|ÿÿÿÿ "•€|ù•Ôw*]
    "5E7CEC10DF0760D4F8DAFB12FDC06CCD "= "02:\\Software\\Adobe\\FeatureSubscriptions\\DVAAdobeDocMeta\\{01CEC7E5-70FD-4D06-8FAD-BF21DF0CC6DC}\\Registered "
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\Adapters\NdisWanIp]
    @DACL=(02 0000)
    "LLInterface "= "WANARP "
    "IpConfig "=multi: "Tcpip\\Parameters\\Interfaces\\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}\00Tcpip\\Parameters\\Interfaces\\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}\00\00 "
    "NumInterfaces "=dword:00000002
    "IpInterfaces "=hex:af,25,f3,0a,8a,ed,0f,42,be,c3,71,81,e3,cb,17,04,c2,00,d5,f9,
    ee,33,e3,47,90,d2,ec,f8,1b,90,f7,07
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\Adapters\{3508956A-868A-4503-8C58-1F83305A81C6}]
    @DACL=(02 0000)
    "LLInterface "=" "
    "IpConfig "=multi: "Tcpip\\Parameters\\Interfaces\\{3508956A-868A-4503-8C58-1F83305A81C6}\00\00 "
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\Adapters\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}]
    @DACL=(02 0000)
    "LLInterface "=" "
    "IpConfig "=multi: "Tcpip\\Parameters\\Interfaces\\{8944A4DF-AEB6-46D8-98DF-030B648C8C0A}\00\00 "
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\Adapters\{F4BA1541-6BFB-4460-8DA9-D5FED2770C10}]
    @DACL=(02 0000)
    "LLInterface "=" "
    "IpConfig "=multi: "Tcpip\\Parameters\\Interfaces\\{F4BA1541-6BFB-4460-8DA9-D5FED2770C10}\00\00 "
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\Interfaces\{080C3C00-9AF2-416D-B37D-A8D4C9128037}]
    @DACL=(02 0000)
    "UseZeroBroadcast "=dword:00000000
    "EnableDHCP "=dword:00000000
    "IPAddress "=multi: "0.0.0.0\00\00 "
    "SubnetMask "=multi: "0.0.0.0\00\00 "
    "DefaultGateway "=multi: "\00 "
    "EnableDeadGWDetect "=dword:00000001
    "DontAddDefaultGateway "=dword:00000000
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\Interfaces\{0AF325AF-ED8A-420F-BEC3-7181E3CB1704}]
    @DACL=(02 0000)
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\Interfaces\{2BF3DC99-3F61-489A-AFB3-11579EBB6FEA}]
    @DACL=(02 0000)
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\Interfaces\{3508956A-868A-4503-8C58-1F83305A81C6}]
    @DACL=(02 0000)
    "EnableDHCP "=dword:00000001
    "DefaultGatewayMetric "=multi: "\00 "
    "NameServer "=" "
    "Domain "=" "
    "RegistrationEnabled "=dword:00000001
    "RegisterAdapterName "=dword:00000000
    "TCPAllowedPorts "=multi: "0\00\00 "
    "UDPAllowedPorts "=multi: "0\00\00 "
    "RawIPAllowedProtocols "=multi: "0\00\00 "
    "NTEContextList "=multi: "\00 "
    "DhcpClassIdBin "=hex:
    "DhcpServer "= "255.255.255.255 "
    "Lease "=dword:00000e10
    "LeaseObtainedTime "=dword:45a45cc8
    "T1 "=dword:45a463d0
    "T2 "=dword:45a46916
    "LeaseTerminatesTime "=dword:45a46ad8
    "IPAutoconfigurationAddress "= "0.0.0.0 "
    "IPAutoconfigurationMask "= "255.255.0.0 "
    "IPAutoconfigurationSeed "=dword:00000000
    "AddressType "=dword:00000000
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\Interfaces\{53C85DB1-0CBD-4E89-918A-38016EB0877F}]
    @DACL=(02 0000)
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\Interfaces\{F9D500C2-33EE-47E3-90D2-ECF81B90F707}]
    @DACL=(02 0000)
    - - - - - - - > 'winlogon.exe'(1040)
    c:\windows\system32\Ati2evxx.dll
    - - - - - - - > 'explorer.exe'(1868)
    c:\program files\ScanSoft\OmniPage15.0\OpHook15.dll
    c:\windows\system32\TPwrCfg.DLL
    c:\windows\system32\TPwrReg.dll
    c:\windows\system32\TPSTrace.DLL
    ------------------------ Other Running Processes ------------------------
    c:\windows\system32\Ati2evxx.exe
    c:\windows\system32\acs.exe
    c:\program files\Common Files\AOL\ACS\AOLAcsd.exe
    c:\program files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
    c:\program files\TOSHIBA\ConfigFree\CFSvcs.exe
    c:\program files\Common Files\AOL\TopSpeed\2.0\aoltpspd.exe
    c:\windows\system32\DVDRAMSV.exe
    c:\program files\Java\jre6\bin\jqs.exe
    c:\program files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
    c:\toshiba\IVP\swupdate\swupdtmr.exe
    c:\windows\system32\TODDSrv.exe
    c:\windows\system32\wdfmgr.exe
    c:\program files\Common Files\McAfee\SystemCore\mcshield.exe
    c:\program files\TOSHIBA\ConfigFree\NDSTray.exe
    c:\windows\system32\TPSMain.exe
    c:\windows\RTHDCPL.EXE
    c:\windows\AGRSMMSG.exe
    c:\program files\TOSHIBA\ConfigFree\CFSServ.exe
    c:\windows\system32\TPSBattM.exe
    c:\program files\iPod\bin\iPodService.exe
    c:\documents and settings\a\Local Settings\Application Data\Djingle\Widget by Air France (US)\bin\WidgetAirFranceUS.exe
    c:\progra~1\MI3AA1~1\rapimgr.exe
    Completion time: 2010-11-10 23:41:20 - machine was rebooted
    ComboFix-quarantined-files.txt 2010-11-11 04:41
    Pre-Run: 22,522,290,176 bytes free
    Post-Run: 22,710,079,488 bytes free
    WindowsXP-KB310994-SP2-Home-BootDisk-ENU.exe
    [boot loader]
    timeout=2
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
    [operating systems]
    c:\cmdcons\BOOTSECT.DAT= "Microsoft Windows Recovery Console" /cmdcons
    UnsupportedDebug= "do not select this" /debug
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS= "Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
    - - End Of File - - 8CE0541C4D4732C295461A364D2E3451
    Thanks, Broni
  9. 2010/11/10
    Not much there.
    Which browser is getting redirected?
    Did you try different browser?
    Download OTL to your Desktop.
    • Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
    • Under the Custom Scan box paste this in:
    netsvcs
    drivers32
    %SYSTEMDRIVE%\*.*
    %systemroot%\Fonts\*.com
    %systemroot%\Fonts\*.dll
    %systemroot%\Fonts\*.ini
    %systemroot%\Fonts\*.ini2
    %systemroot%\Fonts\*.exe
    %systemroot%\system32\spool\prtprocs\w32x86\*.*
    %systemroot%\REPAIR\*.bak1
    %systemroot%\REPAIR\*.ini
    %systemroot%\*.scr
    %systemroot%\*._sy
    %APPDATA%\Adobe\Update\*.*
    %ALLUSERSPROFILE%\Favorites\*.*
    %APPDATA%\Microsoft\*.*
    %PROGRAMFILES%\*.*
    %APPDATA%\Update\*.*
    %systemroot%\*. /mp /s
    CREATERESTOREPOINT
    %systemroot%\System32\config\*.sav
    %PROGRAMFILES%\bak. /s
    %systemroot%\system32\bak. /s
    %ALLUSERSPROFILE%\Start Menu\*.lnk /x
    %systemroot%\system32\config\systemprofile\*.dat /x
    %systemroot%\*.config
    %systemroot%\system32\*.db
    %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x
    %USERPROFILE%\Desktop\*.exe
    %PROGRAMFILES%\Common Files\*.*
    %systemroot%\*.src
    %systemroot%\install\*.*
    %systemroot%\system32\DLL\*.*
    %systemroot%\system32\HelpFiles\*.*
    %systemroot%\system32\rundll\*.*
    %systemroot%\winn32\*.*
    %systemroot%\Java\*.*
    %systemroot%\system32\test\*.*
    %systemroot%\system32\Rundll32\*.*
    %systemroot%\AppPatch\Custom\*.*
    %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x
    %PROGRAMFILES%\PC-Doctor\Downloads\*.*
    %PROGRAMFILES%\Internet Explorer\*.tmp
    %PROGRAMFILES%\Internet Explorer\*.dat
    %USERPROFILE%\My Documents\*.exe
    %USERPROFILE%\*.exe
    %systemroot%\ADDINS\*.*
    %systemroot%\assembly\*.bak2
    %systemroot%\Config\*.*
    %systemroot%\REPAIR\*.bak2
    %systemroot%\SECURITY\Database\*.sdb /x
    %systemroot%\SYSTEM\*.bak2
    %systemroot%\Web\*.bak2
    %systemroot%\Driver Cache\*.*
    %PROGRAMFILES%\Mozilla Firefox\0*.exe
    %ProgramFiles%\Microsoft Common\*.*
    %ProgramFiles%\TinyProxy.
    %USERPROFILE%\Favorites\*.url /x
    %systemroot%\system32\*.bk
    %systemroot%\*.te
    %systemroot%\system32\system32\*.*
    %ALLUSERSPROFILE%\*.dat /x
    %systemroot%\system32\drivers\*.rmv
    dir /b "%systemroot%\system32\*.exe" | find /i " " /c
    dir /b "%systemroot%\*.exe" | find /i " " /c
    %PROGRAMFILES%\Microsoft\*.*
    %systemroot%\System32\Wbem\proquota.exe
    %PROGRAMFILES%\Mozilla Firefox\*.dat
    %USERPROFILE%\Cookies\*.txt /x
    %SystemRoot%\system32\fonts\*.*
    %systemroot%\system32\winlog\*.*
    %systemroot%\system32\Language\*.*
    %systemroot%\system32\Settings\*.*
    %systemroot%\system32\*.quo
    %SYSTEMROOT%\AppPatch\*.exe
    %SYSTEMROOT%\inf\*.exe
    %SYSTEMROOT%\Installer\*.exe
    %systemroot%\system32\config\*.bak2
    %systemroot%\system32\Computers\*.*
    %SystemRoot%\system32\Sound\*.*
    %SystemRoot%\system32\SpecialImg\*.*
    %SystemRoot%\system32\code\*.*
    %SystemRoot%\system32\draft\*.*
    %SystemRoot%\system32\MSSSys\*.*
    %ProgramFiles%\Javascript\*.*
    %systemroot%\pchealth\helpctr\System\*.exe /s
    %systemroot%\Web\*.exe
    %systemroot%\system32\msn\*.*
    %systemroot%\system32\*.tro
    %AppData%\Microsoft\Installer\msupdates\*.*
    %ProgramFiles%\Messenger\*.*
    %systemroot%\system32\systhem32\*.*
    %systemroot%\system\*.exe
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install|LastSuccessTime /rs
    /md5start
    /md5stop
    • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
    • When the scan completes, it will open two notepad windows: OTL.txt and Extras.txt. These are saved in the same location as OTL.
    • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post them back here.
  10. 2010/11/11
    atlgman
    atlgman Inactive Thread Starter
    OTL logfile created on: 11/11/2010 7:03:53 AM - Run 1
    OTL by OldTimer - Version 3.2.17.3 Folder = C:\Documents and Settings\a\Desktop
    Windows XP Home Edition Service Pack 2 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 6.0.2900.2180)
    Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
    1.00 Gb Total Physical Memory | 1.00 Gb Available Physical Memory | 67.00% Memory free
    2.00 Gb Paging File | 1.00 Gb Available in Paging File | 71.00% Paging File free
    Paging file location(s): C:\pagefile.sys 576 1152 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 55.88 Gb Total Space | 21.19 Gb Free Space | 37.93% Space Free | Partition Type: NTFS
    Computer Name: MSIMIC | User Name: a | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: Current user | Quick Scan
    Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
    PRC - [2010/11/11 06:48:10 | 000,575,488 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\a\Desktop\OTL.exe
    PRC - [2010/10/13 21:28:54 | 000,188,136 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Common Files\Mcafee\SystemCore\mfefire.exe
    PRC - [2010/10/13 21:28:54 | 000,141,792 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\system32\mfevtps.exe
    PRC - [2010/09/30 12:10:36 | 001,193,848 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee.com\Agent\mcagent.exe
    PRC - [2010/08/24 13:57:38 | 000,171,168 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Common Files\Mcafee\SystemCore\mcshield.exe
    PRC - [2010/06/30 23:07:46 | 001,155,256 | ---- | M] (McAfee, Inc.) -- c:\Program Files\McAfee\MSC\mcupdmgr.exe
    PRC - [2010/03/10 09:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe
    PRC - [2009/12/30 21:37:23 | 000,198,160 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files\Common Files\Real\Update_OB\realsched.exe
    PRC - [2009/04/29 18:21:00 | 007,927,044 | ---- | M] () -- C:\Documents and Settings\a\Local Settings\Application Data\Djingle\Widget by Air France (US)\bin\WidgetAirFranceUS.exe
    PRC - [2007/07/27 18:40:32 | 000,068,856 | ---- | M] (Google Inc.) -- C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
    PRC - [2007/06/13 05:23:07 | 001,033,216 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
    PRC - [2006/11/21 12:38:22 | 000,035,328 | ---- | M] () -- C:\Program Files\Winamp\winampa.exe
    PRC - [2006/10/06 19:55:48 | 000,303,864 | ---- | M] (LogMeIn, Inc.) -- C:\Program Files\LogMeIn\LogMeInSystray.exe
    PRC - [2006/08/01 12:57:06 | 001,773,568 | ---- | M] (TOSHIBA Inc.) -- C:\Program Files\TOSHIBA\Windows Utilities\Hotkey.exe
    PRC - [2006/06/20 22:36:22 | 001,207,080 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft ActiveSync\wcescomm.exe
    PRC - [2006/06/20 22:36:00 | 000,187,176 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft ActiveSync\rapimgr.exe
    PRC - [2006/05/25 20:30:16 | 000,114,688 | ---- | M] (TOSHIBA Corporation) -- C:\WINDOWS\system32\TODDSrv.exe
    PRC - [2006/05/19 14:13:38 | 000,798,720 | ---- | M] (TOSHIBA CORPORATION) -- C:\Program Files\TOSHIBA\ConfigFree\CFSServ.exe
    PRC - [2006/03/16 15:58:50 | 000,974,848 | ---- | M] (TOSHIBA CORPORATION) -- C:\Program Files\TOSHIBA\ConfigFree\NDSTray.exe
    PRC - [2005/12/16 04:41:28 | 000,188,416 | ---- | M] (Agere Systems) -- C:\Program Files\ltmoh\ltmoh.exe
    PRC - [2005/12/06 00:06:10 | 001,077,322 | ---- | M] (TOSHIBA) -- C:\Program Files\TOSHIBA\Touch and Launch\PadExe.exe
    PRC - [2005/09/26 14:22:28 | 000,036,864 | ---- | M] () -- C:\WINDOWS\system32\acs.exe
    PRC - [2005/07/12 19:14:42 | 000,040,960 | ---- | M] () -- c:\TOSHIBA\IVP\swupdate\swupdtmr.exe
    PRC - [2005/07/06 00:58:36 | 000,069,632 | ---- | M] (ScanSoft, Inc.) -- C:\Program Files\ScanSoft\OmniPage15.0\OpWare15.exe
    PRC - [2005/05/31 23:00:12 | 000,282,624 | ---- | M] (TOSHIBA Corporation) -- C:\WINDOWS\system32\TPSMain.exe
    PRC - [2005/05/31 22:59:58 | 000,045,056 | ---- | M] (TOSHIBA Corporation) -- C:\WINDOWS\system32\TPSBattM.exe
    PRC - [2005/04/26 18:13:20 | 000,122,880 | ---- | M] (TOSHIBA Corporation) -- C:\Program Files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe
    PRC - [2005/01/17 18:38:38 | 000,040,960 | ---- | M] (TOSHIBA CORPORATION) -- C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe
    PRC - [2004/12/30 02:32:20 | 000,065,536 | ---- | M] (TOSHIBA) -- C:\Program Files\TOSHIBA\TOSCDSPD\TOSCDSPD.exe
    PRC - [2004/12/14 02:12:02 | 000,483,328 | ---- | M] (Adobe Systems Inc.) -- C:\Program Files\Adobe\Acrobat 7.0\Distillr\acrotray.exe
    PRC - [2004/10/20 08:40:04 | 000,010,328 | R--- | M] (America Online) -- C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe
    PRC - [2004/10/15 15:54:14 | 000,100,016 | ---- | M] (America Online, Inc) -- C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
    PRC - [2004/10/15 15:54:12 | 000,046,768 | ---- | M] (America Online Inc) -- C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltpspd.exe
    PRC - [2004/08/28 02:37:00 | 000,155,648 | ---- | M] (Matsushita Electric Industrial Co., Ltd.) -- C:\WINDOWS\system32\RAMASST.exe
    PRC - [2004/08/28 02:33:00 | 000,110,592 | ---- | M] (Matsushita Electric Industrial Co., Ltd.) -- C:\WINDOWS\system32\DVDRAMSV.exe
    PRC - [2004/08/09 05:03:38 | 000,081,920 | ---- | M] (InstallShield Software Corporation) -- C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
    MOD - [2010/11/11 06:48:10 | 000,575,488 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\a\Desktop\OTL.exe
    MOD - [2009/12/30 21:38:21 | 000,102,400 | ---- | M] (RealPlayer) -- c:\Program Files\real\realplayer\browserrecord\chrome\hook\rpchromebrowserrecordhelper.dll
    MOD - [2009/08/13 08:55:04 | 001,748,992 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6001.22319_x-ww_f0b4c2df\GdiPlus.dll
    MOD - [2006/08/25 10:45:55 | 001,054,208 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl32.dll
    MOD - [2005/07/06 00:58:14 | 000,135,168 | ---- | M] (ScanSoft, Inc.) -- C:\Program Files\ScanSoft\OmniPage15.0\OpHook15.dll
    SRV - File not found [On_Demand | Stopped] -- C:\WINDOWS\System32\appmgmts.dll -- (AppMgmt)
    SRV - [2010/10/13 21:28:54 | 000,188,136 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\McAfee\SystemCore\mfefire.exe -- (mfefire)
    SRV - [2010/10/13 21:28:54 | 000,141,792 | ---- | M] (McAfee, Inc.) [Unknown | Running] -- C:\WINDOWS\system32\mfevtps.exe -- (mfevtp)
    SRV - [2010/10/07 20:34:28 | 000,364,216 | ---- | M] (McAfee, Inc.) [On_Demand | Stopped] -- C:\Program Files\McAfee\VirusScan\mcods.exe -- (McODS)
    SRV - [2010/08/24 13:57:38 | 000,171,168 | ---- | M] () [Unknown | Running] -- C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe -- (McShield)
    SRV - [2010/03/10 09:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (McProxy)
    SRV - [2010/03/10 09:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (McNASvc)
    SRV - [2010/03/10 09:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (McNaiAnn)
    SRV - [2010/03/10 09:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (mcmscsvc)
    SRV - [2010/03/10 09:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (McMPFSvc)
    SRV - [2007/04/17 13:03:50 | 000,063,040 | ---- | M] (LogMeIn, Inc.) [Disabled | Stopped] -- C:\Program Files\LogMeIn\x86\LogMeIn.exe -- (LogMeIn)
    SRV - [2006/12/27 01:19:09 | 000,069,632 | ---- | M] (Macromedia) [On_Demand | Stopped] -- C:\Program Files\Common Files\Macromedia Shared\Service\Macromedia Licensing.exe -- (Macromedia Licensing Service)
    SRV - [2006/10/06 19:55:54 | 000,062,200 | ---- | M] (LogMeIn, Inc.) [Disabled | Stopped] -- C:\Program Files\LogMeIn\RaMaint.exe -- (LMIMaint)
    SRV - [2006/05/25 20:30:16 | 000,114,688 | ---- | M] (TOSHIBA Corporation) [Auto | Running] -- C:\WINDOWS\system32\TODDSrv.exe -- (TODDSrv)
    SRV - [2005/09/26 14:22:28 | 000,036,864 | ---- | M] () [Auto | Running] -- C:\WINDOWS\system32\acs.exe -- (ACS)
    SRV - [2005/09/14 11:53:32 | 001,896,448 | ---- | M] (Arial Software, LLC) [On_Demand | Stopped] -- C:\Program Files\CampaignEnterprise9\Campaign9.exe -- (CampaignEnterprise9)
    SRV - [2005/07/12 19:14:42 | 000,040,960 | ---- | M] () [Auto | Running] -- c:\TOSHIBA\IVP\swupdate\swupdtmr.exe -- (Swupdtmr)
    SRV - [2005/01/17 18:38:38 | 000,040,960 | ---- | M] (TOSHIBA CORPORATION) [Auto | Running] -- C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe -- (CFSvcs)
    SRV - [2004/10/20 08:40:04 | 000,010,328 | R--- | M] (America Online) [Auto | Running] -- C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe -- (AOL ACS)
    SRV - [2004/10/15 15:54:14 | 000,100,016 | ---- | M] (America Online, Inc) [Auto | Running] -- C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe -- (AOL TopSpeedMonitor)
    SRV - [2004/08/28 02:33:00 | 000,110,592 | ---- | M] (Matsushita Electric Industrial Co., Ltd.) [Auto | Running] -- C:\WINDOWS\system32\DVDRAMSV.exe -- (DVD-RAM_Service)
    DRV - File not found [Kernel | On_Demand | Running] -- C:\ComboFix\catchme.sys -- (catchme)
    DRV - [2010/10/13 21:28:54 | 000,386,840 | ---- | M] (McAfee, Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\drivers\mfehidk.sys -- (mfehidk)
    DRV - [2010/10/13 21:28:54 | 000,313,288 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfefirek.sys -- (mfefirek)
    DRV - [2010/10/13 21:28:54 | 000,152,960 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfeavfk.sys -- (mfeavfk)
    DRV - [2010/10/13 21:28:54 | 000,095,600 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfeapfk.sys -- (mfeapfk)
    DRV - [2010/10/13 21:28:54 | 000,088,544 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfendisk.sys -- (mfendiskmp)
    DRV - [2010/10/13 21:28:54 | 000,088,544 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mfendisk.sys -- (mfendisk)
    DRV - [2010/10/13 21:28:54 | 000,084,264 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mferkdet.sys -- (mferkdet)
    DRV - [2010/10/13 21:28:54 | 000,084,072 | ---- | M] (McAfee, Inc.) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\mfetdi2k.sys -- (mfetdi2k)
    DRV - [2010/10/13 21:28:54 | 000,055,840 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\cfwids.sys -- (cfwids)
    DRV - [2010/10/13 21:28:54 | 000,052,104 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfebopk.sys -- (mfebopk)
    DRV - [2010/05/10 13:41:30 | 000,067,656 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS -- (SASKUTIL)
    DRV - [2010/02/17 13:25:48 | 000,012,872 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\sasdifsv.sys -- (SASDIFSV)
    DRV - [2006/10/06 19:56:02 | 000,011,120 | ---- | M] (3am Labs Ltd.) [Kernel | Auto | Running] -- C:\Program Files\LogMeIn\rainfo.sys -- (LMIInfo)
    DRV - [2006/09/06 18:04:12 | 004,377,600 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\RtkHDAud.Sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
    DRV - [2006/06/28 13:50:00 | 000,098,816 | ---- | M] (TOSHIBA Corporation) [File_System | Auto | Running] -- C:\WINDOWS\system32\drivers\tdudf.sys -- (tdudf)
    DRV - [2006/04/07 18:18:46 | 000,193,056 | ---- | M] (Synaptics, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\SynTP.sys -- (SynTP)
    DRV - [2006/04/01 20:46:28 | 000,471,264 | ---- | M] (Atheros Communications, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ar5211.sys -- (AR5211)
    DRV - [2006/03/18 09:36:42 | 001,155,584 | ---- | M] (Agere Systems) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\AGRSM.sys -- (AgereSoftModem)
    DRV - [2006/03/02 20:49:50 | 000,015,360 | ---- | M] (TOSHIBA Corporation.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\tdcmdpst.sys -- (tdcmdpst)
    DRV - [2006/02/27 07:46:20 | 000,081,408 | ---- | M] (Realtek Semiconductor Corporation ) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\Rtnicxp.sys -- (RTL8023xp)
    DRV - [2006/01/19 20:41:52 | 000,010,368 | R--- | M] (Padus, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\pfc.sys -- (pfc)
    DRV - [2006/01/12 18:21:18 | 000,031,872 | ---- | M] (Quanta Computer, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\qkbfiltr.sys -- (qkbfiltr)
    DRV - [2005/12/12 01:40:44 | 001,414,656 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ati2mtag.sys -- (ati2mtag)
    DRV - [2005/08/24 17:20:28 | 000,009,472 | ---- | M] () [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\tbiosdrv.sys -- (tbiosdrv)
    DRV - [2005/06/10 23:42:00 | 000,005,504 | ---- | M] (Quanta Computer Corp) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\BoiHwSetup.sys -- (BoiHwsetup)
    DRV - [2005/06/02 05:33:00 | 000,102,384 | ---- | M] (Matsushita Electric Industrial Co.,Ltd.) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\meiudf.sys -- (meiudf)
    DRV - [2005/05/05 16:27:38 | 000,007,936 | ---- | M] (Quanta Computer, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\qmofiltr.sys -- (qmofiltr)
    DRV - [2005/01/11 12:05:46 | 000,204,160 | ---- | M] (TOSHIBA CORPORATION) [Kernel | Boot | Running] -- C:\WINDOWS\system32\drivers\KR10N.sys -- (KR10N)
    DRV - [2005/01/07 19:07:18 | 000,138,752 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\Hdaudbus.sys -- (HDAudBus)
    DRV - [2004/08/03 17:31:34 | 000,020,992 | ---- | M] (Realtek Semiconductor Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\RTL8139.sys -- (rtl8139) Realtek RTL8139(A/B/C)
    DRV - [2004/08/03 16:00:00 | 000,052,736 | ---- | M] (Microsoft Corporation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\i8042prt.sy@ -- (i8042prt)
    DRV - [2003/01/29 16:35:00 | 000,012,032 | ---- | M] (TOSHIBA Corporation.) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\Netdevio.sys -- (Netdevio)
    DRV - [2003/01/10 15:13:04 | 000,033,588 | R--- | M] (America Online, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\wanatw4.sys -- (wanatw) WAN Miniport (ATW)
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = %SystemRoot%\system32\blank.htm
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Default_Search_URL = http://www.google.com/ie
    IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = http://www.google.com
    IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://customers.westecnow.com/
    IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant = http://www.google.com/ie
    IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    ========== FireFox ==========
    FF - prefs.js..browser.startup.homepage: "http://www.google.com/ig?hl=en "
    FF - prefs.js..extensions.enabledItems: {ABDE892B-13A8-4d1b-88E6-365A6E755758}:1.0
    FF - prefs.js..extensions.enabledItems: jqs@sun.com:1.0
    FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}:6.0.22
    FF - HKLM\software\mozilla\Mozilla Firefox 3.6.12\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/11/02 15:26:56 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Mozilla Firefox 3.6.12\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/10/29 16:37:58 | 000,000,000 | ---D | M]
    [2008/06/17 16:32:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\a\Application Data\Mozilla\Extensions
    [2009/09/03 11:05:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\a\Application Data\Mozilla\Firefox\Profiles\xgptojz1.default\extensions
    [2009/09/03 10:59:24 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\Documents and Settings\a\Application Data\Mozilla\Firefox\Profiles\xgptojz1.default\extensions\{20a82645-c095-46ed-80e3-08825760534b}(2)
    [2010/11/10 23:52:34 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
    [2010/11/06 13:52:15 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}
    [2010/10/13 21:28:54 | 000,024,376 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Mozilla Firefox\components\Scriptff.dll
    [2010/11/06 13:51:48 | 000,472,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npdeployJava1.dll
    [2009/04/29 18:21:00 | 000,107,008 | ---- | M] (DJINGLE) -- C:\Program Files\Mozilla Firefox\plugins\npdjingleplugin-airfrance.dll
    O1 HOSTS File: ([2010/11/10 23:14:37 | 000,000,027 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
    O2 - BHO: (AcroIEHlprObj Class) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll (Adobe Systems Incorporated)
    O2 - BHO: (RealPlayer Download and Record Plugin for Internet Explorer) - {3049C3E9-B461-4BC5-8870-4C09146192CA} - c:\Program Files\real\realplayer\rpbrowserrecordplugin.dll (RealPlayer)
    O2 - BHO: (scriptproxy) - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\Common Files\Mcafee\SystemCore\ScriptSn.20101102162656.dll (McAfee, Inc.)
    O2 - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
    O2 - BHO: (AcroIEToolbarHelper Class) - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.6.5805.1910\swg.dll (Google Inc.)
    O3 - HKLM\..\Toolbar: (Google Toolbar) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
    O3 - HKLM\..\Toolbar: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O3 - HKCU\..\Toolbar\ShellBrowser: (Google Toolbar) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
    O3 - HKCU\..\Toolbar\ShellBrowser: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O3 - HKCU\..\Toolbar\WebBrowser: (Google Toolbar) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
    O3 - HKCU\..\Toolbar\WebBrowser: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O4 - HKLM..\Run: [Acrobat Assistant 7.0] C:\Program Files\Adobe\Acrobat 7.0\Distillr\Acrotray.exe (Adobe Systems Inc.)
    O4 - HKLM..\Run: [CFSServ.exe] File not found
    O4 - HKLM..\Run: [ISUSPM Startup] C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe (InstallShield Software Corporation)
    O4 - HKLM..\Run: [ISUSScheduler] C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe (InstallShield Software Corporation)
    O4 - HKLM..\Run: [LogMeIn GUI] C:\Program Files\LogMeIn\LogMeInSystray.exe (LogMeIn, Inc.)
    O4 - HKLM..\Run: [LtMoh] C:\Program Files\ltmoh\ltmoh.exe (Agere Systems)
    O4 - HKLM..\Run: [mcui_exe] C:\Program Files\McAfee.com\Agent\mcagent.exe (McAfee, Inc.)
    O4 - HKLM..\Run: [NDSTray.exe] File not found
    O4 - HKLM..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe (Nero AG)
    O4 - HKLM..\Run: [Opware15] C:\Program Files\ScanSoft\OmniPage15.0\Opware15.exe (ScanSoft, Inc.)
    O4 - HKLM..\Run: [PadTouch] C:\Program Files\TOSHIBA\Touch and Launch\PadExe.exe (TOSHIBA)
    O4 - HKLM..\Run: [PDF3 Registry Controller] C:\Program Files\ScanSoft\OmniPage15.0\PDFConverter3\RegistryController.exe (ScanSoft, Inc.)
    O4 - HKLM..\Run: [Pinger] c:\toshiba\ivp\ism\pinger.exe (TOSHIBA Corporation)
    O4 - HKLM..\Run: [ScanSoft OmniPage 15.0-reminder] C:\Program Files\ScanSoft\OmniPage15.0\Ereg\ereg.exe (ScanSoft, Inc.)
    O4 - HKLM..\Run: [SkyTel] C:\WINDOWS\SkyTel.exe (Realtek Semiconductor Corp.)
    O4 - HKLM..\Run: [SmoothView] C:\Program Files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe (TOSHIBA Corporation)
    O4 - HKLM..\Run: [SSBkgdUpdate] C:\Program Files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe (Scansoft, Inc.)
    O4 - HKLM..\Run: [TkBellExe] C:\Program Files\Common Files\Real\Update_OB\realsched.exe (RealNetworks, Inc.)
    O4 - HKLM..\Run: [Toshiba Hotkey Utility] c:\Program Files\Toshiba\Windows Utilities\Hotkey.exe (TOSHIBA Inc.)
    O4 - HKLM..\Run: [TPSMain] C:\WINDOWS\System32\TPSMain.exe (TOSHIBA Corporation)
    O4 - HKLM..\Run: [WinampAgent] C:\Program Files\Winamp\winampa.exe ()
    O4 - HKCU..\Run: [airfrance] C:\Documents and Settings\a\Local Settings\Application Data\Djingle\Widget by Air France (US)\bin\autorun.lnk ()
    O4 - HKCU..\Run: [H/PC Connection Agent] C:\Program Files\Microsoft ActiveSync\wcescomm.exe (Microsoft Corporation)
    O4 - HKCU..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe (Google Inc.)
    O4 - HKCU..\Run: [TOSCDSPD] C:\Program Files\TOSHIBA\TOSCDSPD\TOSCDSPD.exe (TOSHIBA)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Acrobat Speed Launcher.lnk = C:\WINDOWS\Installer\{AC76BA86-1033-F400-7760-000000000002}\SC_Acrobat.exe ()
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe (Adobe Systems, Inc.)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\RAMASST.lnk = C:\WINDOWS\system32\RAMASST.exe (Matsushita Electric Industrial Co., Ltd.)
    O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
    O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
    O8 - Extra context menu item: Convert link target to Adobe PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert link target to existing PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert selected links to Adobe PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert selected links to existing PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert selection to Adobe PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert selection to existing PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert to Adobe PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert to existing PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Google Sidewiki... - C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_950DF09FAB501E03.dll (Google Inc.)
    O8 - Extra context menu item: Open with Scansoft PDF Converter 3.0 - C:\Program Files\ScanSoft\OmniPage15.0\PDFConverter3\IEShellExt.dll (ScanSoft, Inc.)
    O9 - Extra Button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\Program Files\Microsoft ActiveSync\INetRepl.dll (Microsoft Corporation)
    O9 - Extra 'Tools' menuitem : Create Mobile Favorite... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\Program Files\Microsoft ActiveSync\INetRepl.dll (Microsoft Corporation)
    O15 - HKCU\..Trusted Domains: westec.net ([]http in Trusted sites)
    O15 - HKCU\..Trusted Domains: westecnow.com ([]http in Trusted sites)
    O16 - DPF: {079CBF9B-A2EF-47DF-B0A6-266FFE46210B} http://customers.westecnow.com/activex/westec.cab (WWVLive Control)
    O16 - DPF: {76CA9E30-5094-46F9-BE90-D47AD59C2C2C} https://bte.radiantenterprise.com/02.103.0130.26/pe/clientdownloads/SuperCab.cab (CClientInfo Object)
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab (Java Plug-in 1.6.0_22)
    O16 - DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} http://fpdownload.macromedia.com/get/flashplayer/current/ultrashim.cab (Reg Error: Key error.)
    O16 - DPF: {CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab (Java Plug-in 1.6.0_22)
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab (Java Plug-in 1.6.0_22)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 213.109.66.15 213.109.77.225 1.1.1.1
    O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\WINDOWS\explorer.exe (Microsoft Corporation)
    O20 - Winlogon\Notify\!SASWinLogon: DllName - C:\Program Files\SUPERAntiSpyware\SASWINLO.DLL - C:\Program Files\SUPERAntiSpyware\SASWINLO.DLL (SUPERAntiSpyware.com)
    O20 - Winlogon\Notify\AtiExtEvent: DllName - Ati2evxx.dll - C:\WINDOWS\System32\ati2evxx.dll (ATI Technologies Inc.)
    O20 - Winlogon\Notify\LMIinit: DllName - LMIinit.dll - C:\WINDOWS\System32\LMIinit.dll (LogMeIn, Inc.)
    O24 - Desktop WallPaper: C:\WINDOWS\Toshiba.bmp
    O24 - Desktop BackupWallPaper: C:\WINDOWS\Toshiba.bmp
    O28 - HKLM ShellExecuteHooks: {5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} - C:\Program Files\SUPERAntiSpyware\SASSEH.DLL (SuperAdBlocker.com)
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2006/12/27 02:44:14 | 000,000,050 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
    O37 - HKLM\...com [@ = ComFile] -- "%1" %*
    NetSvcs: 6to4 - File not found
    NetSvcs: AppMgmt - C:\WINDOWS\System32\appmgmts.dll File not found
    NetSvcs: Ias - File not found
    NetSvcs: Iprip - File not found
    NetSvcs: Irmon - File not found
    NetSvcs: NWCWorkstation - File not found
    NetSvcs: Nwsapagent - File not found
    NetSvcs: WmdmPmSp - File not found
    Drivers32: msacm.iac2 - C:\WINDOWS\system32\iac25_32.ax (Intel Corporation)
    Drivers32: msacm.l3acm - C:\WINDOWS\system32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: msacm.sl_anet - C:\WINDOWS\System32\sl_anet.acm (Sipro Lab Telecom Inc.)
    Drivers32: msacm.trspch - C:\WINDOWS\System32\tssoft32.acm (DSP GROUP, INC.)
    Drivers32: vidc.cvid - C:\WINDOWS\System32\iccvid.dll (Radius Inc.)
    Drivers32: vidc.DIVX - C:\WINDOWS\System32\DivX.dll (DivX, Inc.)
    Drivers32: vidc.iv31 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv32 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv41 - C:\WINDOWS\System32\ir41_32.ax (Intel Corporation)
    Drivers32: vidc.iv50 - C:\WINDOWS\System32\ir50_32.dll (Intel Corporation)
    Drivers32: vidc.yv12 - C:\WINDOWS\System32\DivX.dll (DivX, Inc.)
    CREATERESTOREPOINT
    Restore point Set: OTL Restore Point (16620578542714880)
    ========== Files/Folders - Created Within 30 Days ==========
    [2010/11/11 06:47:46 | 000,575,488 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\a\Desktop\OTL.exe
    [2010/11/10 22:47:51 | 000,000,000 | RHSD | C] -- C:\cmdcons
    [2010/11/10 22:43:40 | 000,212,480 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWXCACLS.exe
    [2010/11/10 22:43:40 | 000,161,792 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWREG.exe
    [2010/11/10 22:43:40 | 000,136,704 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWSC.exe
    [2010/11/10 22:43:40 | 000,031,232 | ---- | C] (NirSoft) -- C:\WINDOWS\NIRCMD.exe
    [2010/11/10 22:43:29 | 000,000,000 | ---D | C] -- C:\WINDOWS\ERDNT
    [2010/11/10 22:42:52 | 000,000,000 | ---D | C] -- C:\Qoobox
    [2010/11/09 22:36:32 | 000,000,000 | ---D | C] -- C:\Documents and Settings\a\Application Data\Malwarebytes
    [2010/11/09 22:36:21 | 000,038,224 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
    [2010/11/09 22:36:20 | 000,020,952 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
    [2010/11/09 22:36:20 | 000,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
    [2010/11/09 22:36:20 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Malwarebytes
    [2010/11/09 22:34:27 | 006,153,352 | ---- | C] (Malwarebytes Corporation ) -- C:\Documents and Settings\a\Desktop\mapp.exe.exe
    [2010/11/09 22:32:22 | 000,000,000 | ---D | C] -- C:\Documents and Settings\a\Desktop\old
    [2010/11/06 13:52:42 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Java
    [2010/10/24 13:11:27 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Temp
    [2010/10/20 11:38:38 | 000,000,000 | --SD | C] -- C:\Documents and Settings\a\UserData
    [2010/10/18 10:19:24 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\SUPERAntiSpyware.com
    [2010/10/18 10:19:23 | 000,000,000 | ---D | C] -- C:\Documents and Settings\a\Application Data\SUPERAntiSpyware.com
    [2010/10/18 10:19:10 | 000,000,000 | ---D | C] -- C:\Program Files\SUPERAntiSpyware
    [2010/10/15 15:31:32 | 000,000,000 | ---D | C] -- C:\spoolerlogs
    [1 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
    ========== Files - Modified Within 30 Days ==========
    [2010/11/11 07:11:02 | 000,000,886 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
    [2010/11/10 23:25:19 | 000,002,335 | ---- | M] () -- C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Acrobat Speed Launcher.lnk
    [2010/11/10 23:18:50 | 000,001,637 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\McAfee Total Protection.lnk
    [2010/11/10 23:14:37 | 000,000,027 | ---- | M] () -- C:\WINDOWS\System32\drivers\etc\hosts
    [2010/11/10 23:13:47 | 000,000,882 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
    [2010/11/10 23:12:48 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
    [2010/11/10 23:12:17 | 1474,473,984 | -HS- | M] () -- C:\hiberfil.sys
    [2010/11/10 22:48:07 | 000,000,327 | RHS- | M] () -- C:\boot.ini
    [2010/11/10 22:39:37 | 003,907,429 | R--- | M] () -- C:\Documents and Settings\a\Desktop\ComboFix.exe
    [2010/11/10 21:15:16 | 000,000,484 | ---- | M] () -- C:\WINDOWS\ODBC.INI
    [2010/11/10 10:26:39 | 000,630,272 | ---- | M] () -- C:\Documents and Settings\a\Desktop\dds.scr
    [2010/11/10 10:25:05 | 000,080,384 | ---- | M] () -- C:\Documents and Settings\a\Desktop\MBRCheck.exe
    [2010/11/10 06:48:07 | 000,296,448 | ---- | M] () -- C:\Documents and Settings\a\Desktop\dpuozhfk.exe
    [2010/11/10 06:46:42 | 000,001,158 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
    [2010/11/09 22:36:24 | 000,000,738 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
    [2010/11/09 22:35:06 | 006,153,352 | ---- | M] (Malwarebytes Corporation ) -- C:\Documents and Settings\a\Desktop\mapp.exe.exe
    [2010/11/08 15:17:10 | 000,001,855 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Google Chrome.lnk
    [2010/11/08 01:20:24 | 000,089,088 | ---- | M] () -- C:\WINDOWS\MBR.exe
    [2010/11/07 19:37:35 | 000,445,938 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
    [2010/11/07 19:37:35 | 000,072,978 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
    [2010/10/31 19:39:40 | 000,002,497 | ---- | M] () -- C:\Documents and Settings\a\Desktop\Microsoft Office Word 2003.lnk
    [2010/10/19 12:29:52 | 000,000,195 | ---- | M] () -- C:\WINDOWS\System32\MRT.INI
    [2010/10/18 10:19:14 | 000,001,720 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\SUPERAntiSpyware Free Edition.lnk
    [2010/10/13 22:18:44 | 000,000,116 | ---- | M] () -- C:\WINDOWS\NeroDigital.ini
    [2010/10/13 21:28:54 | 000,386,840 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfehidk.sys
    [2010/10/13 21:28:54 | 000,313,288 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfefirek.sys
    [2010/10/13 21:28:54 | 000,152,960 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfeavfk.sys
    [2010/10/13 21:28:54 | 000,141,792 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\mfevtps.exe
    [2010/10/13 21:28:54 | 000,095,600 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfeapfk.sys
    [2010/10/13 21:28:54 | 000,088,544 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfendisk.sys
    [2010/10/13 21:28:54 | 000,084,264 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mferkdet.sys
    [2010/10/13 21:28:54 | 000,084,072 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfetdi2k.sys
    [2010/10/13 21:28:54 | 000,055,840 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\cfwids.sys
    [2010/10/13 21:28:54 | 000,052,104 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfebopk.sys
    [2010/10/13 21:28:54 | 000,009,344 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfeclnk.sys
    [2010/11/10 23:18:49 | 000,001,637 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\McAfee Total Protection.lnk
    [2010/11/10 22:48:07 | 000,000,211 | ---- | C] () -- C:\Boot.bak
    [2010/11/10 22:48:01 | 000,260,272 | RHS- | C] () -- C:\cmldr
    [2010/11/10 22:43:40 | 000,256,512 | ---- | C] () -- C:\WINDOWS\PEV.exe
    [2010/11/10 22:43:40 | 000,098,816 | ---- | C] () -- C:\WINDOWS\sed.exe
    [2010/11/10 22:43:40 | 000,089,088 | ---- | C] () -- C:\WINDOWS\MBR.exe
    [2010/11/10 22:43:40 | 000,080,412 | ---- | C] () -- C:\WINDOWS\grep.exe
    [2010/11/10 22:43:40 | 000,068,096 | ---- | C] () -- C:\WINDOWS\zip.exe
    [2010/11/10 22:39:27 | 003,907,429 | R--- | C] () -- C:\Documents and Settings\a\Desktop\ComboFix.exe
    [2010/11/10 10:26:34 | 000,630,272 | ---- | C] () -- C:\Documents and Settings\a\Desktop\dds.scr
    [2010/11/10 10:25:00 | 000,080,384 | ---- | C] () -- C:\Documents and Settings\a\Desktop\MBRCheck.exe
    [2010/11/10 06:48:00 | 000,296,448 | ---- | C] () -- C:\Documents and Settings\a\Desktop\dpuozhfk.exe
    [2010/11/09 22:36:24 | 000,000,738 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
    [2010/10/19 12:29:52 | 000,000,195 | ---- | C] () -- C:\WINDOWS\System32\MRT.INI
    [2010/10/18 10:19:14 | 000,001,720 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\SUPERAntiSpyware Free Edition.lnk
    [2009/04/01 17:56:24 | 000,007,680 | ---- | C] () -- C:\Documents and Settings\a\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2008/05/13 22:37:08 | 000,000,000 | ---- | C] () -- C:\WINDOWS\iPlayer.INI
    [2008/01/21 20:57:38 | 000,000,050 | ---- | C] () -- C:\WINDOWS\cdplayer.ini
    [2007/11/29 17:30:28 | 003,596,288 | ---- | C] () -- C:\WINDOWS\System32\qt-dx331.dll
    [2007/11/28 16:52:32 | 000,012,288 | ---- | C] () -- C:\WINDOWS\System32\DivXWMPExtType.dll
    [2007/08/07 15:26:40 | 000,002,508 | ---- | C] () -- C:\Documents and Settings\a\Application Data\$_hpcst$.hpc
    [2007/08/07 15:25:38 | 000,000,116 | ---- | C] () -- C:\WINDOWS\NeroDigital.ini
    [2007/08/07 15:24:29 | 000,000,124 | ---- | C] () -- C:\Documents and Settings\a\Local Settings\Application Data\fusioncache.dat
    [2007/06/15 08:50:04 | 000,000,026 | ---- | C] () -- C:\WINDOWS\FPKPMSV.INI
    [2006/12/27 03:44:13 | 000,000,399 | ---- | C] () -- C:\WINDOWS\MAXLINK.INI
    [2006/12/27 02:34:02 | 000,034,308 | ---- | C] () -- C:\WINDOWS\System32\BASSMOD.dll
    [2006/09/09 14:29:20 | 000,204,800 | ---- | C] () -- C:\WINDOWS\System32\IVIresizeW7.dll
    [2006/09/09 14:29:20 | 000,200,704 | ---- | C] () -- C:\WINDOWS\System32\IVIresizeA6.dll
    [2006/09/09 14:29:20 | 000,192,512 | ---- | C] () -- C:\WINDOWS\System32\IVIresizeP6.dll
    [2006/09/09 14:29:20 | 000,192,512 | ---- | C] () -- C:\WINDOWS\System32\IVIresizeM6.dll
    [2006/09/09 14:29:20 | 000,188,416 | ---- | C] () -- C:\WINDOWS\System32\IVIresizePX.dll
    [2006/09/09 14:29:20 | 000,020,480 | ---- | C] () -- C:\WINDOWS\System32\IVIresize.dll
    [2006/09/09 14:28:14 | 000,128,113 | ---- | C] () -- C:\WINDOWS\System32\csellang.ini
    [2006/09/09 14:28:14 | 000,045,056 | ---- | C] () -- C:\WINDOWS\System32\csellang.dll
    [2006/09/09 14:28:14 | 000,010,165 | ---- | C] () -- C:\WINDOWS\System32\tosmreg.ini
    [2006/09/09 14:28:14 | 000,007,671 | ---- | C] () -- C:\WINDOWS\System32\cseltbl.ini
    [2006/09/09 14:25:07 | 000,143,360 | ---- | C] () -- C:\WINDOWS\System32\RtlCPAPI.dll
    [2006/08/21 18:44:11 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
    [2006/08/21 13:54:33 | 000,000,000 | ---- | C] () -- C:\WINDOWS\NDSTray.INI
    [2006/08/21 13:53:47 | 000,011,122 | ---- | C] () -- C:\WINDOWS\HWSetupStr.ini
    [2006/08/21 13:53:47 | 000,002,036 | ---- | C] () -- C:\WINDOWS\SVPW32Str.ini
    [2006/08/21 12:30:37 | 000,000,484 | ---- | C] () -- C:\WINDOWS\ODBC.INI
    [2006/08/21 12:22:29 | 000,001,793 | ---- | C] () -- C:\WINDOWS\System32\fxsperf.ini
    [2006/08/21 12:06:11 | 000,000,341 | ---- | C] () -- C:\WINDOWS\System32\OEMINFO.INI
    [2006/08/21 05:18:50 | 000,004,328 | ---- | C] () -- C:\WINDOWS\ODBCINST.INI
    [2006/08/01 12:56:40 | 000,122,880 | ---- | C] () -- C:\WINDOWS\System32\TPeculiarity.dll
    [2005/12/08 13:56:50 | 000,151,552 | ---- | C] () -- C:\WINDOWS\System32\tsbwls.dll
    [2005/08/24 17:20:28 | 000,009,472 | ---- | C] () -- C:\WINDOWS\System32\drivers\tbiosdrv.sys
    [2005/02/03 19:59:44 | 002,129,920 | ---- | C] () -- C:\WINDOWS\System32\myodbc3S.dll
    [2004/09/16 15:24:26 | 003,375,104 | ---- | C] () -- C:\WINDOWS\System32\qt-mt331.dll
    [2003/01/07 15:05:08 | 000,002,695 | ---- | C] () -- C:\WINDOWS\System32\OUTLPERF.INI
    [2006/09/09 15:05:17 | 000,000,000 | ---D | M] -- C:\Documents and Settings\a\Application Data\InterVideo
    [2009/04/01 17:58:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\a\Application Data\ScanSoft
    [2006/08/21 13:48:20 | 000,000,000 | ---D | M] -- C:\Documents and Settings\a\Application Data\toshiba
    [2006/12/27 02:40:19 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\muvee Technologies
    [2006/12/27 03:48:28 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\ScanSoft
    [2006/08/21 14:09:10 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Viewpoint
    [2006/11/25 06:10:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\WildTangent
    [2006/08/21 14:12:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\YAHOO
    [2006/12/27 03:48:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\zeon
    ========== Custom Scans ==========
    < %SYSTEMDRIVE%\*.* >
    [2006/12/27 01:32:14 | 000,001,024 | ---- | M] () -- C:\.rnd
    [2007/01/09 22:24:10 | 000,024,174 | ---- | M] () -- C:\ASLog.txt
    [2006/12/27 02:44:14 | 000,000,050 | ---- | M] () -- C:\AUTOEXEC.BAT
    [2006/11/25 06:05:11 | 000,000,211 | ---- | M] () -- C:\Boot.bak
    [2004/08/03 23:00:00 | 000,260,272 | RHS- | M] () -- C:\cmldr
    [2010/11/10 23:41:22 | 000,023,702 | ---- | M] () -- C:\ComboFix.txt
    [2006/08/21 12:25:45 | 000,000,000 | ---- | M] () -- C:\CONFIG.SYS
    [2006/08/21 12:25:45 | 000,000,000 | RHS- | M] () -- C:\IO.SYS
    [2006/08/21 14:10:02 | 000,001,186 | -H-- | M] () -- C:\IPH.PH
    [2006/08/21 12:25:45 | 000,000,000 | RHS- | M] () -- C:\MSDOS.SYS
    [2002/01/05 03:38:38 | 000,054,784 | ---- | M] (Microsoft Corporation) -- C:\msvci70.dll
    [2004/08/03 16:00:00 | 000,047,564 | RHS- | M] () -- C:\NTDETECT.COM
    [2004/08/03 16:00:00 | 000,250,032 | RHS- | M] () -- C:\ntldr
    [2010/11/10 23:11:45 | 603,979,776 | -HS- | M] () -- C:\pagefile.sys
    [2009/08/08 21:44:06 | 000,000,640 | ---- | M] () -- C:\wgpro7.txt
    < %systemroot%\Fonts\*.com >
    [2006/04/18 14:39:28 | 000,026,040 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalMonospace.CompositeFont
    [2006/06/29 13:53:56 | 000,026,489 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSansSerif.CompositeFont
    [2006/04/18 14:39:28 | 000,029,779 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSerif.CompositeFont
    [2006/06/29 13:58:52 | 000,030,808 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalUserInterface.CompositeFont
    < %systemroot%\Fonts\*.dll >
    < %systemroot%\Fonts\*.ini >
    [2006/08/21 12:25:16 | 000,000,067 | -HS- | M] () -- C:\WINDOWS\Fonts\desktop.ini
    < %systemroot%\Fonts\*.ini2 >
    < %systemroot%\Fonts\*.exe >
    < %systemroot%\system32\spool\prtprocs\w32x86\*.* >
    [2008/07/06 07:06:10 | 000,089,088 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\filterpipelineprintproc.dll
    [2006/10/06 19:56:14 | 000,025,840 | ---- | M] (3am Labs Ltd.) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\LMIproc.dll
    [2003/06/18 17:31:48 | 000,018,944 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\mdippr.dll
    [2008/07/06 05:50:03 | 000,597,504 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\printfilterpipelinesvc.exe
    < %systemroot%\REPAIR\*.bak1 >
    < %systemroot%\REPAIR\*.ini >
    < %systemroot%\system32\*.jpg >
    < %systemroot%\*.jpg >
    < %systemroot%\*.png >
    < %systemroot%\*.scr >
    [2004/12/08 18:04:46 | 000,045,056 | ---- | M] (TOSHIBA) -- C:\WINDOWS\cfdemo.scr
    < %systemroot%\*._sy >
    < %APPDATA%\Adobe\Update\*.* >
    < %ALLUSERSPROFILE%\Favorites\*.* >
    < %APPDATA%\Microsoft\*.* >
    < %PROGRAMFILES%\*.* >
    < %APPDATA%\Update\*.* >
    < %systemroot%\*. /mp /s >
    < %systemroot%\System32\config\*.sav >
    [2006/08/21 05:17:25 | 000,094,208 | ---- | M] () -- C:\WINDOWS\system32\config\default.sav
    [2006/08/21 05:17:25 | 000,634,880 | ---- | M] () -- C:\WINDOWS\system32\config\software.sav
    [2006/08/21 05:17:25 | 000,876,544 | ---- | M] () -- C:\WINDOWS\system32\config\system.sav
    < %PROGRAMFILES%\bak. /s >
    < %systemroot%\system32\bak. /s >
    < %ALLUSERSPROFILE%\Start Menu\*.lnk /x >
    [2006/08/21 12:25:52 | 000,000,294 | -HS- | M] () -- C:\Documents and Settings\All Users\Start Menu\desktop.ini
    < %systemroot%\system32\config\systemprofile\*.dat /x >
    < %systemroot%\*.config >
    < %systemroot%\system32\*.db >
    < %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x >
    [2007/08/07 15:23:22 | 000,000,119 | -HS- | M] () -- C:\Documents and Settings\a\Application Data\Microsoft\Internet Explorer\Quick Launch\desktop.ini
    [2002/05/05 22:19:46 | 000,000,079 | ---- | M] () -- C:\Documents and Settings\a\Application Data\Microsoft\Internet Explorer\Quick Launch\Show Desktop.scf
    < %USERPROFILE%\Desktop\*.exe >
    [2010/07/08 14:11:00 | 000,216,045 | ---- | M] (Oleg N. Scherbakov) -- C:\Documents and Settings\a\Desktop\rds.exe
    < %PROGRAMFILES%\Common Files\*.* >
    < %systemroot%\*.src >
    < %systemroot%\install\*.* >
    < %systemroot%\system32\DLL\*.* >
    < %systemroot%\system32\HelpFiles\*.* >
    < %systemroot%\system32\rundll\*.* >
    < %systemroot%\winn32\*.* >
    < %systemroot%\Java\*.* >
    < %systemroot%\system32\test\*.* >
    < %systemroot%\system32\Rundll32\*.* >
    < %systemroot%\AppPatch\Custom\*.* >
    < %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x >
    < %PROGRAMFILES%\PC-Doctor\Downloads\*.* >
    < %PROGRAMFILES%\Internet Explorer\*.tmp >
    < %PROGRAMFILES%\Internet Explorer\*.dat >
    < %USERPROFILE%\My Documents\*.exe >
    [2009/04/23 17:35:03 | 038,692,440 | ---- | M] () -- C:\Documents and Settings\a\My Documents\DWRemote5.0.7.1Setup.exe
    [2009/08/13 15:02:04 | 000,608,344 | ---- | M] () -- C:\Documents and Settings\a\My Documents\MCPR.exe
    [2009/04/23 18:29:05 | 043,724,069 | ---- | M] () -- C:\Documents and Settings\a\My Documents\WestecRemote5.0.8.2.exe
    < %USERPROFILE%\*.exe >
    < %systemroot%\ADDINS\*.* >
    [2004/08/03 16:00:00 | 000,000,791 | ---- | M] () -- C:\WINDOWS\addins\fxsext.ecf
    < %systemroot%\assembly\*.bak2 >
    < %systemroot%\Config\*.* >
    < %systemroot%\REPAIR\*.bak2 >
    < %systemroot%\SECURITY\Database\*.sdb /x >
    < %systemroot%\SYSTEM\*.bak2 >
    < %systemroot%\Web\*.bak2 >
    < %systemroot%\Driver Cache\*.* >
    [2006/08/21 05:19:33 | 000,004,128 | ---- | M] () -- C:\WINDOWS\Driver Cache\INFCACHE.1
    < %PROGRAMFILES%\Mozilla Firefox\0*.exe >
    < %ProgramFiles%\Microsoft Common\*.* >
    < %ProgramFiles%\TinyProxy. >
    < %USERPROFILE%\Favorites\*.url /x >
    [2007/08/07 15:23:21 | 000,000,122 | -HS- | M] () -- C:\Documents and Settings\a\Favorites\Desktop.ini
    < %systemroot%\system32\*.bk >
    < %systemroot%\*.te >
    < %systemroot%\system32\system32\*.* >
    < %ALLUSERSPROFILE%\*.dat /x >
    < %systemroot%\system32\drivers\*.rmv >
    < dir /b "%systemroot%\system32\*.exe" | find /i " " /c >
    < dir /b "%systemroot%\*.exe" | find /i " " /c >
    < %PROGRAMFILES%\Microsoft\*.* >
    < %systemroot%\System32\Wbem\proquota.exe >
    < %PROGRAMFILES%\Mozilla Firefox\*.dat >
    < %USERPROFILE%\Cookies\*.txt /x >
    [2010/11/11 07:32:53 | 000,032,768 | ---- | M] () -- C:\Documents and Settings\a\Cookies\index.dat
    < %SystemRoot%\system32\fonts\*.* >
    < %systemroot%\system32\winlog\*.* >
    < %systemroot%\system32\Language\*.* >
    < %systemroot%\system32\Settings\*.* >
    < %systemroot%\system32\*.quo >
    < %SYSTEMROOT%\AppPatch\*.exe >
    < %SYSTEMROOT%\inf\*.exe >
    [2004/08/11 03:45:04 | 000,192,512 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\inf\unregmp2.exe
    < %SYSTEMROOT%\Installer\*.exe >
    [2005/08/01 16:24:00 | 001,003,215 | ---- | M] () -- C:\WINDOWS\Installer\ms_office_trial.exe
    [2005/10/03 14:51:04 | 004,673,840 | ---- | M] () -- C:\WINDOWS\Installer\welcomeTour.exe
    < %systemroot%\system32\config\*.bak2 >
    < %systemroot%\system32\Computers\*.* >
    < %SystemRoot%\system32\Sound\*.* >
    < %SystemRoot%\system32\SpecialImg\*.* >
    < %SystemRoot%\system32\code\*.* >
    < %SystemRoot%\system32\draft\*.* >
    < %SystemRoot%\system32\MSSSys\*.* >
    < %ProgramFiles%\Javascript\*.* >
    < %systemroot%\pchealth\helpctr\System\*.exe /s >
    < %systemroot%\Web\*.exe >
    < %systemroot%\system32\msn\*.* >
    < %systemroot%\system32\*.tro >
    < %AppData%\Microsoft\Installer\msupdates\*.* >
    < %ProgramFiles%\Messenger\*.* >
    [2004/08/03 16:00:00 | 000,028,672 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\custsat.dll
    [2004/08/04 03:06:34 | 000,004,821 | ---- | M] () -- C:\Program Files\Messenger\logowin.gif
    [2004/08/04 03:06:34 | 000,007,047 | ---- | M] () -- C:\Program Files\Messenger\lvback.gif
    [2008/05/02 09:22:02 | 000,083,968 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgsc.dll
    [2004/08/04 03:06:34 | 000,180,224 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgslang.dll
    [2004/10/13 11:24:37 | 001,694,208 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msmsgs.exe
    [2004/08/04 03:06:36 | 000,002,882 | ---- | M] () -- C:\Program Files\Messenger\newalert.wav
    [2004/08/04 03:06:36 | 000,006,156 | ---- | M] () -- C:\Program Files\Messenger\newemail.wav
    [2004/08/04 03:06:36 | 000,006,160 | ---- | M] () -- C:\Program Files\Messenger\online.wav
    [2004/08/04 03:06:36 | 000,004,454 | ---- | M] () -- C:\Program Files\Messenger\type.wav
    [2004/08/04 03:06:36 | 000,115,981 | ---- | M] () -- C:\Program Files\Messenger\xpmsgr.chm
    < %systemroot%\system32\systhem32\*.* >
    < %systemroot%\system\*.exe >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\ Auto Update\Results\Install|LastSuccessTime /rs >
    < End of report >
  11. 2010/11/11
    atlgman
    OTL Extras logfile created on: 11/11/2010 7:03:53 AM - Run 1
    ========== Extra Registry (SafeList) ==========
    ========== File Associations ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<extension>]
    .html [@ = FirefoxHTML] -- C:\Program Files\Mozilla Firefox\firefox.exe (Mozilla Corporation)
    ========== Shell Spawning ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<key>\shell\[command]\command]
    batfile [open] -- "%1" %*
    cmdfile [open] -- "%1" %*
    htmlfile [edit] -- Reg Error: Key error.
    https [open] -- "C:\Program Files\Mozilla Firefox\firefox.exe" -requestPending -osint -url "%1" (Mozilla Corporation)
    jsfile [edit] -- "C:\Program Files\Macromedia\Dreamweaver 8\dreamweaver.exe" "%1" (Macromedia, Inc.)
    piffile [open] -- "%1" %*
    regfile [merge] -- Reg Error: Key error.
    scrfile [config] -- "%1 "
    scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l (Microsoft Corporation)
    scrfile [open] -- "%1" /S
    txtfile [edit] -- Reg Error: Key error.
    Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1
    Directory [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    Directory [Winamp.Bookmark] -- "C:\Program Files\Winamp\winamp.exe" /BOOKMARK "%1" (Nullsoft)
    Directory [Winamp.Enqueue] -- "C:\Program Files\Winamp\winamp.exe" /ADD "%1" (Nullsoft)
    Directory [Winamp.Play] -- "C:\Program Files\Winamp\winamp.exe" "%1" (Nullsoft)
    Folder [open] -- %SystemRoot%\Explorer.exe /idlist,%I,%L (Microsoft Corporation)
    Folder [explore] -- %SystemRoot%\Explorer.exe /e,/idlist,%I,%L (Microsoft Corporation)
    Drive [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    ========== Security Center Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
    "FirstRunDisabled" = 1
    "UpdatesDisableNotify" = 0
    "AntiVirusOverride" = 0
    "FirewallOverride" = 0
    "AntiVirusDisableNotify" = 0
    "FirewallDisableNotify" = 0
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\AhnlabAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ComputerAssociatesAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\KasperskyAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeAntiVirus]
    "DisableMonitoring" = 1
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SophosAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TinyFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ZoneLabsFirewall]
    ========== System Restore Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore]
    "DisableSR" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Sr]
    "Start" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SrService]
    "Start" = 2
    ========== Firewall Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\DomainProfile]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\StandardProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
    "DisableNotifications" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\GloballyOpenPorts\List]
    "139:TCP" = 139:TCP:*:Enabled:mad:xpsp2res.dll,-22004
    "445:TCP" = 445:TCP:*:Enabled:mad:xpsp2res.dll,-22005
    "137:UDP" = 137:UDP:*:Enabled:mad:xpsp2res.dll,-22001
    "138:UDP" = 138:UDP:*:Enabled:mad:xpsp2res.dll,-22002
    "26675:TCP" = 26675:TCP:169.254.2.0/255.255.255.0:Enabled:ActiveSync Service
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]
    "EnableFirewall" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\GloballyOpenPorts\List]
    "1900:UDP" = 1900:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22007
    "2869:TCP" = 2869:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22008
    "139:TCP" = 139:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22004
    "445:TCP" = 445:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22005
    "137:UDP" = 137:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22001
    "138:UDP" = 138:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22002
    ========== Authorized Applications List ==========
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications\List]
    "C:\Program Files\Microsoft ActiveSync\rapimgr.exe" = C:\Program Files\Microsoft ActiveSync\rapimgr.exe:169.254.2.0/255.255.255.0:Enabled:ActiveSync RAPI Manager -- (Microsoft Corporation)
    "C:\Program Files\Microsoft ActiveSync\wcescomm.exe" = C:\Program Files\Microsoft ActiveSync\wcescomm.exe:169.254.2.0/255.255.255.0:Enabled:ActiveSync Connection Manager -- (Microsoft Corporation)
    "C:\Program Files\Microsoft ActiveSync\WCESMgr.exe" = C:\Program Files\Microsoft ActiveSync\WCESMgr.exe:169.254.2.0/255.255.255.0:Enabled:ActiveSync Application -- (Microsoft Corporation)
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List]
    "C:\TOSHIBA\ivp\NetInt\Netint.exe" = C:\TOSHIBA\ivp\NetInt\Netint.exe:*:Enabled:NIE - Toshiba Software Upgrade Engine -- (TOSHIBA Corporation)
    "C:\TOSHIBA\Ivp\ISM\pinger.exe" = C:\TOSHIBA\IVP\ISM\pinger.exe:*:Enabled:Toshiba Software Upgrades Pinger -- (TOSHIBA Corporation)
    "C:\Program Files\Common Files\AOL\Loader\aolload.exe" = C:\Program Files\Common Files\AOL\Loader\aolload.exe:*:Enabled:AOL Application Loader -- (America Online, Inc.)
    "C:\Program Files\Common Files\AOL\ACS\AOLDial.exe" = C:\Program Files\Common Files\AOL\ACS\AOLDial.exe:*:Enabled:AOL -- (America Online)
    "C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe" = C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe:*:Enabled:AOL -- (America Online)
    "C:\Program Files\America Online 9.0\waol.exe" = C:\Program Files\America Online 9.0\waol.exe:*:Enabled:AOL -- (America Online, Inc.)
    "C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe" = C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe:*:Enabled:AOLTsMon -- (America Online, Inc)
    "C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltpspd.exe" = C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltpspd.exe:*:Enabled:AOLTopSpeed -- (America Online Inc)
    "C:\Program Files\Common Files\AOL\1156187317\EE\AOLServiceHost.exe" = C:\Program Files\Common Files\AOL\1156187317\EE\AOLServiceHost.exe:*:Enabled:AOL -- (America Online, Inc.)
    "C:\Program Files\Common Files\AOL\System Information\sinf.exe" = C:\Program Files\Common Files\AOL\System Information\sinf.exe:*:Enabled:AOL -- (America Online Inc.)
    "C:\Program Files\Common Files\AOL\AOL Spyware Protection\AOLSP Scheduler.exe" = C:\Program Files\Common Files\AOL\AOL Spyware Protection\AOLSP Scheduler.exe:*:Enabled:AOL -- ()
    "C:\Program Files\Common Files\AOL\AOL Spyware Protection\asp.exe" = C:\Program Files\Common Files\AOL\AOL Spyware Protection\asp.exe:*:Enabled:AOL -- (AOL Spyware Protection)
    "C:\Program Files\Common Files\AolCoach\en_en\player\AOLNySEV.exe" = C:\Program Files\Common Files\AolCoach\en_en\player\AOLNySEV.exe:*:Enabled:AOL -- (Gteko Ltd.)
    "C:\Program Files\Yahoo!\Yahoo! Music Engine\YahooMusicEngine.exe" = C:\Program Files\Yahoo!\Yahoo! Music Engine\YahooMusicEngine.exe:*:Enabled:Yahoo! Music Engine -- (Yahoo!)
    "C:\Program Files\iTunes\iTunes.exe" = C:\Program Files\iTunes\iTunes.exe:*:Enabled:iTunes -- (Apple Computer, Inc.)
    "C:\Program Files\Nero\Nero 7\Nero Home\NeroHome.exe" = C:\Program Files\Nero\Nero 7\Nero Home\NeroHome.exe:*:Disabled:Nero Home -- (Nero AG)
    "C:\WINDOWS\system32\spool\drivers\w32x86\3\SAGENT4.EXE" = C:\WINDOWS\system32\spool\drivers\w32x86\3\SAGENT4.EXE:*:Enabled:SAgent4 -- (SEIKO EPSON CORPORATION)
    "C:\Program Files\Kinko's\FPFK\FPKMain.exe" = C:\Program Files\Kinko's\FPFK\FPKMain.exe:*:Enabled:File, Print FedEx Kinko's -- (FedEx Kinko's)
    "C:\Program Files\Kinko's\FPFK\Kinkos.Jupiter.GUI.Queue.exe" = C:\Program Files\Kinko's\FPFK\Kinkos.Jupiter.GUI.Queue.exe:*:Enabled:File, Print FedEx Kinko's System Tray -- ( )
    "C:\Program Files\Avant Browser\avant.exe" = C:\Program Files\Avant Browser\avant.exe:*:Enabled:Avant Browser -- ()
    "C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe" = C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe:*:Enabled:McAfee Shared Service Host -- (McAfee, Inc.)
    ========== HKEY_LOCAL_MACHINE Uninstall List ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "{008D69EB-70FF-46AB-9C75-924620DF191A}" = TOSHIBA Speech System SR Engine(U.S.) Version1.0
    "{01CEC7E5-70FD-4D06-8FAD-BF21DF0CC6DC}" = Adobe Audition 2.0
    "{05832D65-6EDB-4D32-BA78-BCD0E2B91C02}" = Atheros Wireless LAN MiniPCI/PCIe card Driver
    "{0837A661-FEC3-48B3-876C-91E7D32048A9}" = Macromedia Dreamweaver 8
    "{099D12EC-0321-4CAC-A0CC-33D020156FCD}" = Toshiba Utility
    "{0B7DDCD3-D6D8-4366-A6D8-9B6495A2925E}" = ScanSoft OmniPage 15.0
    "{0BEDBD4E-2D34-47B5-9973-57E62B29307C}" = ATI Control Panel
    "{11C98E1A-EC91-4B38-B44C-C562292D8453}" = Adobe Premiere Elements 2.0
    "{12B3A009-A080-4619-9A2A-C6DB151D8D67}" = TOSHIBA Assist
    "{18455581-E099-4BA8-BC6B-F34B2F06600C}" = Google Toolbar for Internet Explorer
    "{18D10072035C4515918F7E37EAFAACFC}" = AutoUpdate
    "{1CCBCF78-EF12-4137-B3CA-99F30A2E7D21}" = CuteFTP 7 Professional
    "{2318C2B1-4965-11d4-9B18-009027A5CD4F}" = Google Toolbar for Internet Explorer
    "{236BB7C4-4419-42FD-0409-1E257A25E34D}" = Adobe Photoshop CS2
    "{26A24AE4-039D-4CA4-87B4-2F83216022FF}" = Java(TM) 6 Update 22
    "{29042B1C-0713-4575-B7CA-5C8E7B0899D4}" = MyODBC
    "{2BD5C305-1B27-4D41-B690-7A61172D2FEB}" = Macromedia Flash 8
    "{2C38F661-26B7-445D-B87D-B53FE2D3BD42}" = TOSHIBA PC Diagnostic Tool
    "{30161931-E14F-42B5-BFC0-1AB5ADE4459B}" = muvee autoProducer 5.0
    "{350C97B0-3D7C-4EE8-BAA9-00BCB3D54227}" = WebFldrs XP
    "{3FBF6F99-8EC6-41B4-8527-0A32241B5496}" = TOSHIBA Speech System TTS Engine(U.S.) Version1.0
    "{400830CA-F056-4BBE-80A3-9DF9CA4FB889}" = TOSHIBA Direct Disc Writer
    "{425A2BC2-AA64-4107-9C29-484245BBEA05}" = TOSHIBA Software Upgrades
    "{446DBFFA-4088-48E3-8932-74316BA4CAE4}" = iTunes
    "{47D2103B-FD51-4017-9C20-DD408B17D726}" = Office 2003 Trial Assistant
    "{4A03706F-666A-4037-7777-5F2748764D10}" = Java Auto Updater
    "{4C24A8C1-7CFA-4650-AF15-732F5BD7B46D}" = Macromedia Fireworks 8
    "{4D826618-59C6-11D4-976E-00C04F8EEB39}" = Macromedia FreeHand 10
    "{50D8FFDD-90CD-4859-841F-AA1961C7767A}" = QuickTime
    "{529DDE6B-4F31-438B-B218-F36266ABD8C0}" = TOSHIBA Disc Creator
    "{5546CDB5-2CE2-498B-B059-5B3BF81FC41F}" = Macromedia Extension Manager
    "{5D96E2B1-D9AC-46E0-9073-425C5F63E338}" = Touch and Launch
    "{602A205F-8D02-48EE-8782-262B2103B984}" = ScanSoft PDF Converter 3.0
    "{64212898-097F-4F3F-AECA-6D34A7EF82DF}" = TOSHIBA Zooming Utility
    "{6B2715ED-7DBF-4BF1-9009-FE4D66421033}" = Nero 7 Ultra Edition
    "{71D658CF-4E0D-4DA8-AA67-8C0B6F1C01FE}" = Atheros Client Utility
    "{786C5747-1033-0000-B58E-000000000001}" = Adobe Stock Photos 1.0
    "{7B63B2922B174135AFC0E1377DD81EC2}" = DivX Codec
    "{8ADFC4160D694100B5B8A22DE9DCABD9}" = DivX Player
    "{8BF2C401-02CE-424D-BC26-6C4F9FB446B6}" = Macromedia Flash 8 Video Encoder
    "{8EDBA74D-0686-4C99-BFDD-F894678E5B39}" = Adobe Common File Installer
    "{90110409-6000-11D3-8CFE-0150048383C9}" = Microsoft Office Professional Edition 2003
    "{90170409-6000-11D3-8CFE-0150048383C9}" = Microsoft Office FrontPage 2003
    "{91057632-CA70-413C-B628-2D3CDBBB906B}" = Macromedia Flash Player 8 Plugin
    "{91810AFC-A4F8-4EBA-A5AA-B198BBC81144}" = InterVideo WinDVD for TOSHIBA
    "{9D765FA6-F2BC-40AF-8145-50808F9BDF4E}" = DVD-RAM Driver
    "{9FE35071-CAB2-4E79-93E7-BFC6A2DC5C5D}" = CD/DVD Drive Acoustic Silencer
    "{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}" = Microsoft .NET Framework 3.0 Service Pack 2
    "{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}" = Google Update Helper
    "{AC76BA86-1033-F400-7760-000000000002}" = Adobe Acrobat 7.0 Professional - English, Français, Deutsch
    "{ACCA20B0-C4D1-4BF5-BF21-0A0EB5EF9730}" = REALTEK GbE & FE Ethernet PCI NIC Driver
    "{AD1D8B40-F83C-41CA-BA08-9DB8D1653316}" = ScanSoft PDF Create 3.0
    "{B208806F-A231-4FA0-AB3F-5C1B8979223E}" = Microsoft ActiveSync 4.0
    "{B74D4E10-1033-0000-0000-000000000001}" = Adobe Bridge 1.0
    "{BA2D4D22-0B99-4D63-BCEE-D2EA4736F27F}" = LogMeIn
    "{BDD83DC9-BEE9-4654-A5DA-CC46C250088D}" = TOSHIBA ConfigFree
    "{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}" = Microsoft .NET Framework 2.0 Service Pack 2
    "{CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}" = Microsoft .NET Framework 1.1
    "{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}" = SUPERAntiSpyware
    "{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}" = Microsoft .NET Framework 3.5 SP1
    "{D0A05EB3-1A5E-45EF-B2AB-E3ABD2B86130}" = Toshiba Hotkey Utility
    "{E9787678-1033-0000-8E67-000000000001}" = Adobe Help Center 1.0
    "{EBA09A1B-8D0A-4D65-BF5F-96186DAA6628}" = File, Print FedEx Kinko's
    "{EE033C1F-443E-41EC-A0E2-559B539A4E4D}" = TOSHIBA Speech System Applications
    "{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}" = Realtek High Definition Audio Driver
    "{F6C405D2-C50D-4D10-B89E-73A233A14D74}" = Toshiba Registration
    "{F77890F3-774A-4CBE-A2E3-7BB0DC71D1FA}" = Toshiba Touchpad Utility
    "{F977FD4B-C9A6-4BAA-B4BB-DE3023288253}" = Macromedia FlashPaper 2
    "Adobe Acrobat 7.0 Professional - EFG" = Adobe Acrobat 7.0 Professional - English, Français, Deutsch
    "Adobe Audition 2.0" = Adobe Audition 2.0
    "Adobe Flash Player ActiveX" = Adobe Flash Player ActiveX
    "Adobe Flash Player Plugin" = Adobe Flash Player 10 Plugin
    "Adobe InDesign 2.0" = Adobe InDesign 2.0
    "Adobe Photoshop CS2 - {236BB7C4-4419-42FD-0409-1E257A25E34D}" = Adobe Photoshop CS2
    "Adobe SVG Viewer" = Adobe SVG Viewer 3.0
    "America Online us" = America Online (Choose which version to remove)
    "AOL Connectivity Services" = AOL Connectivity Services
    "AOL Spyware Protection" = AOL Spyware Protection
    "AOL YGP Screensaver" = AOL You've Got Pictures Screensaver
    "AolCoach2_en" = AOL Coach Version 2.0(Build:20041026.5 en)
    "ATI Display Driver" = ATI Display Driver
    "AvantBrowser" = Avant Browser (remove only)
    "AviSynth" = AviSynth 2.5
    "Campaign Enterprise 9" = Campaign Enterprise 9
    "Desktop Dialer" = Desktop Dialer
    "DirectVobSub" = DirectVobSub (remove only)
    "DVD Shrink_is1" = DVD Shrink 3.2
    "Google Chrome" = Google Chrome
    "Google Desktop" = Google Desktop
    "InstallShield_{099D12EC-0321-4CAC-A0CC-33D020156FCD}" = Toshiba Utility
    "InstallShield_{2C38F661-26B7-445D-B87D-B53FE2D3BD42}" = TOSHIBA PC Diagnostic Tool
    "InstallShield_{F77890F3-774A-4CBE-A2E3-7BB0DC71D1FA}" = Toshiba Touchpad Utility
    "InterActual Player" = InterActual Player
    "Malwarebytes' Anti-Malware_is1" = Malwarebytes' Anti-Malware
    "Microsoft .NET Framework 1.1 (1033)" = Microsoft .NET Framework 1.1
    "Microsoft .NET Framework 3.5 SP1" = Microsoft .NET Framework 3.5 SP1
    "Mozilla Firefox (3.6.12)" = Mozilla Firefox (3.6.12)
    "MSC" = McAfee Total Protection
    "MSNINST" = MSN
    "Picasa2" = Picasa 2
    "Port Magic" = Pure Networks Port Magic
    "Power Saver" = TOSHIBA Power Saver
    "PremElem20" = Adobe Premiere Elements 2.0
    "RealPlayer 12.0" = RealPlayer
    "Remote_Witness_5.0.5.0" = Westec Remote
    "SynTPDeinstKey" = Synaptics Pointing Device Driver
    "TOSHIBA Game Console" = TOSHIBA Game Console
    "TOSHIBA Software Modem" = TOSHIBA Software Modem
    "Videora iPod Converter" = Videora iPod Converter 0.91
    "ViewpointMediaPlayer" = Viewpoint Media Player
    "WIC" = Windows Imaging Component
    "WildTangent CDA" = WildTangent Web Driver
    "Winamp" = Winamp (remove only)
    "Windows Media Format Runtime" = Windows Media Format Runtime
    "Windows Media Player" = Windows Media Player 10
    "WinRAR archiver" = WinRAR archiver
    "WT004723" = Blasterball 2 Revolution
    "WT004829" = Polar Golfer
    "WT006066" = FATE
    "WT009503" = Penguins!
    "WT009954" = SCRABBLE
    "Yahoo! Music Engine" = Yahoo! Music Engine
    ========== HKEY_CURRENT_USER Uninstall List ==========
    [HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "airfrance" = Widget by Air France
    ========== Last 10 Event Log Errors ==========
    [ Application Events ]
    Error - 10/18/2010 2:09:20 PM | Computer Name = MSIMIC | Source = crypt32 | ID = 131080
    Description = Failed auto update retrieval of third-party root list sequence number
    from: <http://www.download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/authrootseq.txt>
    with error: This network connection does not exist.
    Error - 10/18/2010 2:09:27 PM | Computer Name = MSIMIC | Source = crypt32 | ID = 131080
    Error - 10/18/2010 2:48:30 PM | Computer Name = MSIMIC | Source = crypt32 | ID = 131080
    with error: This operation returned because the timeout period expired.
    [ System Events ]
    Error - 11/10/2010 8:29:16 PM | Computer Name = MSIMIC | Source = Service Control Manager | ID = 7023
    Description = The Computer Browser service terminated with the following error:
    %%1460
    Error - 11/10/2010 8:31:48 PM | Computer Name = MSIMIC | Source = DCOM | ID = 10010
    Description = The server {209500FC-6B45-4693-8871-6296C4843751} did not register
    with DCOM within the required timeout.
    Error - 11/10/2010 8:32:21 PM | Computer Name = MSIMIC | Source = DCOM | ID = 10010
    Error - 11/10/2010 11:51:07 PM | Computer Name = MSIMIC | Source = Service Control Manager | ID = 7034
    Description = The Atheros Configuration Service service terminated unexpectedly.
    It has done this 1 time(s).
    Description = The Swupdtmr service terminated unexpectedly. It has done this 1
    time(s).
    Error - 11/11/2010 12:18:12 AM | Computer Name = MSIMIC | Source = Service Control Manager | ID = 7022
    Description = The McShield service hung on starting.
    Error - 11/11/2010 12:22:26 AM | Computer Name = MSIMIC | Source = DCOM | ID = 10010
    Description = The server {3A185DDE-E020-4985-A8F2-E27CDC4A0F3A} did not register
    Error - 11/11/2010 12:28:16 AM | Computer Name = MSIMIC | Source = DCOM | ID = 10010
    Error - 11/11/2010 12:29:00 AM | Computer Name = MSIMIC | Source = DCOM | ID = 10010
    Error - 11/11/2010 12:30:02 AM | Computer Name = MSIMIC | Source = DCOM | ID = 10010
    < End of report >
    I am sorry for the double post for the OTL Log. The redirection, pop ups, slow browser and computer is killing me. Also I do not always see the menu when I right click my mouse or tabs. Firefox, Google Chrome, and Internet Explorer are still redirecting.
    Thank you, Broni
  12. 2010/11/11
    OK, we have a DNS hijacker here:
    Go Start>Run (Start search in Vista), type in:
    cmd
    Click OK (in Vista and Windows 7, while holding CTRL, and SHIFT, press Enter).
    In Command Prompt window, type in following commands, and hit Enter after each one:
    ipconfig /flushdns
    ipconfig /registerdns
    ipconfig /release
    ipconfig /renew
    net stop "dns client "
    net start "dns client "
    Turn the computer off.
    On your router, you'll find a pinhole marked "Reset ".
    Keep pushing the hole, using a pencil, or a paperclip until all lights briefly come off and on.
    Restart computer and check for redirections.
    NOTE. You may need to re-check your router security settings, as described HERE
  13. 2010/11/12
    atlgman
    atlgman Inactive Thread Starter
    Good news, I did what you said and no more redirecting on all browser. But I am having some issues now with the slow laptop. Droopy mouse that does not react like it is supposed too. When I right click on a link or tab and try to open it in new window it does not work. Any suggestion.
    Thank you Broni
  14. 2010/11/12
    Good job :)
    We're not done yet, so we'll try to find out what's going on.
    Please, re-run OTL with the same script as in my reply #8 and post fresh log.
    Only one log will be produced.
  15. 2010/11/12
    atlgman
    OTL logfile created on: 11/12/2010 11:09:20 AM - Run 2
    OTL by OldTimer - Version 3.2.17.3 Folder = C:\Documents and Settings\a\Desktop
    Windows XP Home Edition Service Pack 2 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 6.0.2900.2180)
    Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
    1.00 Gb Total Physical Memory | 1.00 Gb Available Physical Memory | 55.00% Memory free
    2.00 Gb Paging File | 1.00 Gb Available in Paging File | 67.00% Paging File free
    Paging file location(s): C:\pagefile.sys 576 1152 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 55.88 Gb Total Space | 21.16 Gb Free Space | 37.87% Space Free | Partition Type: NTFS
    Computer Name: MSIMIC | User Name: a | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: Current user | Quick Scan
    Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
    PRC - [2010/11/11 06:48:10 | 000,575,488 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\a\Desktop\OTL.exe
    PRC - [2010/10/29 16:37:48 | 000,016,856 | ---- | M] (Mozilla Corporation) -- C:\Program Files\Mozilla Firefox\plugin-container.exe
    PRC - [2010/10/29 16:37:47 | 000,912,344 | ---- | M] (Mozilla Corporation) -- C:\Program Files\Mozilla Firefox\firefox.exe
    PRC - [2010/10/13 21:28:54 | 000,188,136 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Common Files\Mcafee\SystemCore\mfefire.exe
    PRC - [2010/10/13 21:28:54 | 000,141,792 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\system32\mfevtps.exe
    PRC - [2010/09/30 12:10:36 | 001,193,848 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee.com\Agent\mcagent.exe
    PRC - [2010/08/24 13:57:38 | 000,171,168 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Common Files\Mcafee\SystemCore\mcshield.exe
    PRC - [2010/03/10 09:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe
    PRC - [2009/12/30 21:37:23 | 000,198,160 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files\Common Files\Real\Update_OB\realsched.exe
    PRC - [2009/04/29 18:21:00 | 007,927,044 | ---- | M] () -- C:\Documents and Settings\a\Local Settings\Application Data\Djingle\Widget by Air France (US)\bin\WidgetAirFranceUS.exe
    PRC - [2007/07/27 18:40:32 | 000,068,856 | ---- | M] (Google Inc.) -- C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
    PRC - [2007/06/13 05:23:07 | 001,033,216 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
    PRC - [2006/11/21 12:38:22 | 000,035,328 | ---- | M] () -- C:\Program Files\Winamp\winampa.exe
    PRC - [2006/10/06 19:55:48 | 000,303,864 | ---- | M] (LogMeIn, Inc.) -- C:\Program Files\LogMeIn\LogMeInSystray.exe
    PRC - [2006/08/01 12:57:06 | 001,773,568 | ---- | M] (TOSHIBA Inc.) -- C:\Program Files\TOSHIBA\Windows Utilities\Hotkey.exe
    PRC - [2006/06/20 22:36:22 | 001,207,080 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft ActiveSync\wcescomm.exe
    PRC - [2006/06/20 22:36:00 | 000,187,176 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft ActiveSync\rapimgr.exe
    PRC - [2006/05/25 20:30:16 | 000,114,688 | ---- | M] (TOSHIBA Corporation) -- C:\WINDOWS\system32\TODDSrv.exe
    PRC - [2006/05/19 14:13:38 | 000,798,720 | ---- | M] (TOSHIBA CORPORATION) -- C:\Program Files\TOSHIBA\ConfigFree\CFSServ.exe
    PRC - [2006/03/16 15:58:50 | 000,974,848 | ---- | M] (TOSHIBA CORPORATION) -- C:\Program Files\TOSHIBA\ConfigFree\NDSTray.exe
    PRC - [2005/12/16 04:41:28 | 000,188,416 | ---- | M] (Agere Systems) -- C:\Program Files\ltmoh\ltmoh.exe
    PRC - [2005/12/06 00:06:10 | 001,077,322 | ---- | M] (TOSHIBA) -- C:\Program Files\TOSHIBA\Touch and Launch\PadExe.exe
    PRC - [2005/09/26 14:22:28 | 000,036,864 | ---- | M] () -- C:\WINDOWS\system32\acs.exe
    PRC - [2005/07/12 19:14:42 | 000,040,960 | ---- | M] () -- c:\TOSHIBA\IVP\swupdate\swupdtmr.exe
    PRC - [2005/07/06 00:58:36 | 000,069,632 | ---- | M] (ScanSoft, Inc.) -- C:\Program Files\ScanSoft\OmniPage15.0\OpWare15.exe
    PRC - [2005/05/31 23:00:12 | 000,282,624 | ---- | M] (TOSHIBA Corporation) -- C:\WINDOWS\system32\TPSMain.exe
    PRC - [2005/05/31 22:59:58 | 000,045,056 | ---- | M] (TOSHIBA Corporation) -- C:\WINDOWS\system32\TPSBattM.exe
    PRC - [2005/04/26 18:13:20 | 000,122,880 | ---- | M] (TOSHIBA Corporation) -- C:\Program Files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe
    PRC - [2005/01/17 18:38:38 | 000,040,960 | ---- | M] (TOSHIBA CORPORATION) -- C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe
    PRC - [2004/12/30 02:32:20 | 000,065,536 | ---- | M] (TOSHIBA) -- C:\Program Files\TOSHIBA\TOSCDSPD\TOSCDSPD.exe
    PRC - [2004/12/14 02:12:02 | 000,483,328 | ---- | M] (Adobe Systems Inc.) -- C:\Program Files\Adobe\Acrobat 7.0\Distillr\acrotray.exe
    PRC - [2004/10/20 08:40:04 | 000,010,328 | R--- | M] (America Online) -- C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe
    PRC - [2004/10/15 15:54:14 | 000,100,016 | ---- | M] (America Online, Inc) -- C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
    PRC - [2004/10/15 15:54:12 | 000,046,768 | ---- | M] (America Online Inc) -- C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltpspd.exe
    PRC - [2004/08/28 02:37:00 | 000,155,648 | ---- | M] (Matsushita Electric Industrial Co., Ltd.) -- C:\WINDOWS\system32\RAMASST.exe
    PRC - [2004/08/28 02:33:00 | 000,110,592 | ---- | M] (Matsushita Electric Industrial Co., Ltd.) -- C:\WINDOWS\system32\DVDRAMSV.exe
    PRC - [2004/08/09 05:03:38 | 000,081,920 | ---- | M] (InstallShield Software Corporation) -- C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
    MOD - [2010/11/11 06:48:10 | 000,575,488 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\a\Desktop\OTL.exe
    MOD - [2009/12/30 21:38:21 | 000,102,400 | ---- | M] (RealPlayer) -- c:\Program Files\real\realplayer\browserrecord\chrome\hook\rpchromebrowserrecordhelper.dll
    MOD - [2009/08/13 08:55:04 | 001,748,992 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6001.22319_x-ww_f0b4c2df\GdiPlus.dll
    MOD - [2006/08/25 10:45:55 | 001,054,208 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl32.dll
    MOD - [2005/07/06 00:58:14 | 000,135,168 | ---- | M] (ScanSoft, Inc.) -- C:\Program Files\ScanSoft\OmniPage15.0\OpHook15.dll
    SRV - File not found [On_Demand | Stopped] -- C:\WINDOWS\System32\appmgmts.dll -- (AppMgmt)
    SRV - [2010/10/13 21:28:54 | 000,188,136 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\McAfee\SystemCore\mfefire.exe -- (mfefire)
    SRV - [2010/10/13 21:28:54 | 000,141,792 | ---- | M] (McAfee, Inc.) [Unknown | Running] -- C:\WINDOWS\system32\mfevtps.exe -- (mfevtp)
    SRV - [2010/10/07 20:34:28 | 000,364,216 | ---- | M] (McAfee, Inc.) [On_Demand | Stopped] -- C:\Program Files\McAfee\VirusScan\mcods.exe -- (McODS)
    SRV - [2010/08/24 13:57:38 | 000,171,168 | ---- | M] () [Unknown | Running] -- C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe -- (McShield)
    SRV - [2010/03/10 09:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (McProxy)
    SRV - [2010/03/10 09:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (McNASvc)
    SRV - [2010/03/10 09:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (McNaiAnn)
    SRV - [2010/03/10 09:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (mcmscsvc)
    SRV - [2010/03/10 09:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (McMPFSvc)
    SRV - [2007/04/17 13:03:50 | 000,063,040 | ---- | M] (LogMeIn, Inc.) [Disabled | Stopped] -- C:\Program Files\LogMeIn\x86\LogMeIn.exe -- (LogMeIn)
    SRV - [2006/12/27 01:19:09 | 000,069,632 | ---- | M] (Macromedia) [On_Demand | Stopped] -- C:\Program Files\Common Files\Macromedia Shared\Service\Macromedia Licensing.exe -- (Macromedia Licensing Service)
    SRV - [2006/10/06 19:55:54 | 000,062,200 | ---- | M] (LogMeIn, Inc.) [Disabled | Stopped] -- C:\Program Files\LogMeIn\RaMaint.exe -- (LMIMaint)
    SRV - [2006/05/25 20:30:16 | 000,114,688 | ---- | M] (TOSHIBA Corporation) [Auto | Running] -- C:\WINDOWS\system32\TODDSrv.exe -- (TODDSrv)
    SRV - [2005/09/26 14:22:28 | 000,036,864 | ---- | M] () [Auto | Running] -- C:\WINDOWS\system32\acs.exe -- (ACS)
    SRV - [2005/09/14 11:53:32 | 001,896,448 | ---- | M] (Arial Software, LLC) [On_Demand | Stopped] -- C:\Program Files\CampaignEnterprise9\Campaign9.exe -- (CampaignEnterprise9)
    SRV - [2005/07/12 19:14:42 | 000,040,960 | ---- | M] () [Auto | Running] -- c:\TOSHIBA\IVP\swupdate\swupdtmr.exe -- (Swupdtmr)
    SRV - [2005/01/17 18:38:38 | 000,040,960 | ---- | M] (TOSHIBA CORPORATION) [Auto | Running] -- C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe -- (CFSvcs)
    SRV - [2004/10/20 08:40:04 | 000,010,328 | R--- | M] (America Online) [Auto | Running] -- C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe -- (AOL ACS)
    SRV - [2004/10/15 15:54:14 | 000,100,016 | ---- | M] (America Online, Inc) [Auto | Running] -- C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe -- (AOL TopSpeedMonitor)
    SRV - [2004/08/28 02:33:00 | 000,110,592 | ---- | M] (Matsushita Electric Industrial Co., Ltd.) [Auto | Running] -- C:\WINDOWS\system32\DVDRAMSV.exe -- (DVD-RAM_Service)
    DRV - File not found [Kernel | On_Demand | Stopped] -- C:\ComboFix\catchme.sys -- (catchme)
    DRV - [2010/10/13 21:28:54 | 000,386,840 | ---- | M] (McAfee, Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\drivers\mfehidk.sys -- (mfehidk)
    DRV - [2010/10/13 21:28:54 | 000,313,288 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfefirek.sys -- (mfefirek)
    DRV - [2010/10/13 21:28:54 | 000,152,960 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfeavfk.sys -- (mfeavfk)
    DRV - [2010/10/13 21:28:54 | 000,095,600 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfeapfk.sys -- (mfeapfk)
    DRV - [2010/10/13 21:28:54 | 000,088,544 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfendisk.sys -- (mfendiskmp)
    DRV - [2010/10/13 21:28:54 | 000,088,544 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mfendisk.sys -- (mfendisk)
    DRV - [2010/10/13 21:28:54 | 000,084,264 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mferkdet.sys -- (mferkdet)
    DRV - [2010/10/13 21:28:54 | 000,084,072 | ---- | M] (McAfee, Inc.) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\mfetdi2k.sys -- (mfetdi2k)
    DRV - [2010/10/13 21:28:54 | 000,055,840 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\cfwids.sys -- (cfwids)
    DRV - [2010/10/13 21:28:54 | 000,052,104 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfebopk.sys -- (mfebopk)
    DRV - [2010/05/10 13:41:30 | 000,067,656 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS -- (SASKUTIL)
    DRV - [2010/02/17 13:25:48 | 000,012,872 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\sasdifsv.sys -- (SASDIFSV)
    DRV - [2006/10/06 19:56:02 | 000,011,120 | ---- | M] (3am Labs Ltd.) [Kernel | Auto | Running] -- C:\Program Files\LogMeIn\rainfo.sys -- (LMIInfo)
    DRV - [2006/09/06 18:04:12 | 004,377,600 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\RtkHDAud.Sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
    DRV - [2006/06/28 13:50:00 | 000,098,816 | ---- | M] (TOSHIBA Corporation) [File_System | Auto | Running] -- C:\WINDOWS\system32\drivers\tdudf.sys -- (tdudf)
    DRV - [2006/04/07 18:18:46 | 000,193,056 | ---- | M] (Synaptics, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\SynTP.sys -- (SynTP)
    DRV - [2006/04/01 20:46:28 | 000,471,264 | ---- | M] (Atheros Communications, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ar5211.sys -- (AR5211)
    DRV - [2006/03/18 09:36:42 | 001,155,584 | ---- | M] (Agere Systems) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\AGRSM.sys -- (AgereSoftModem)
    DRV - [2006/03/02 20:49:50 | 000,015,360 | ---- | M] (TOSHIBA Corporation.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\tdcmdpst.sys -- (tdcmdpst)
    DRV - [2006/02/27 07:46:20 | 000,081,408 | ---- | M] (Realtek Semiconductor Corporation ) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\Rtnicxp.sys -- (RTL8023xp)
    DRV - [2006/01/19 20:41:52 | 000,010,368 | R--- | M] (Padus, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\pfc.sys -- (pfc)
    DRV - [2006/01/12 18:21:18 | 000,031,872 | ---- | M] (Quanta Computer, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\qkbfiltr.sys -- (qkbfiltr)
    DRV - [2005/12/12 01:40:44 | 001,414,656 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ati2mtag.sys -- (ati2mtag)
    DRV - [2005/08/24 17:20:28 | 000,009,472 | ---- | M] () [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\tbiosdrv.sys -- (tbiosdrv)
    DRV - [2005/06/10 23:42:00 | 000,005,504 | ---- | M] (Quanta Computer Corp) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\BoiHwSetup.sys -- (BoiHwsetup)
    DRV - [2005/06/02 05:33:00 | 000,102,384 | ---- | M] (Matsushita Electric Industrial Co.,Ltd.) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\meiudf.sys -- (meiudf)
    DRV - [2005/05/05 16:27:38 | 000,007,936 | ---- | M] (Quanta Computer, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\qmofiltr.sys -- (qmofiltr)
    DRV - [2005/01/11 12:05:46 | 000,204,160 | ---- | M] (TOSHIBA CORPORATION) [Kernel | Boot | Running] -- C:\WINDOWS\system32\drivers\KR10N.sys -- (KR10N)
    DRV - [2005/01/07 19:07:18 | 000,138,752 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\Hdaudbus.sys -- (HDAudBus)
    DRV - [2004/08/03 17:31:34 | 000,020,992 | ---- | M] (Realtek Semiconductor Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\RTL8139.sys -- (rtl8139) Realtek RTL8139(A/B/C)
    DRV - [2004/08/03 16:00:00 | 000,052,736 | ---- | M] (Microsoft Corporation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\i8042prt.sy@ -- (i8042prt)
    DRV - [2003/01/29 16:35:00 | 000,012,032 | ---- | M] (TOSHIBA Corporation.) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\Netdevio.sys -- (Netdevio)
    DRV - [2003/01/10 15:13:04 | 000,033,588 | R--- | M] (America Online, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\wanatw4.sys -- (wanatw) WAN Miniport (ATW)
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = %SystemRoot%\system32\blank.htm
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Default_Search_URL = http://www.google.com/ie
    IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = http://www.google.com
    IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://customers.westecnow.com/
    IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant = http://www.google.com/ie
    IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    ========== FireFox ==========
    FF - prefs.js..browser.startup.homepage: "http://www.google.com/ig?hl=en "
    FF - prefs.js..extensions.enabledItems: {ABDE892B-13A8-4d1b-88E6-365A6E755758}:1.0
    FF - prefs.js..extensions.enabledItems: jqs@sun.com:1.0
    FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}:6.0.22
    FF - HKLM\software\mozilla\Mozilla Firefox 3.6.12\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/11/02 15:26:56 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Mozilla Firefox 3.6.12\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/10/29 16:37:58 | 000,000,000 | ---D | M]
    [2008/06/17 16:32:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\a\Application Data\Mozilla\Extensions
    [2009/09/03 11:05:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\a\Application Data\Mozilla\Firefox\Profiles\xgptojz1.default\extensions
    [2009/09/03 10:59:24 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\Documents and Settings\a\Application Data\Mozilla\Firefox\Profiles\xgptojz1.default\extensions\{20a82645-c095-46ed-80e3-08825760534b}(2)
    [2010/11/12 09:07:40 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
    [2010/11/06 13:52:15 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}
    [2010/10/13 21:28:54 | 000,024,376 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Mozilla Firefox\components\Scriptff.dll
    [2010/11/06 13:51:48 | 000,472,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npdeployJava1.dll
    [2009/04/29 18:21:00 | 000,107,008 | ---- | M] (DJINGLE) -- C:\Program Files\Mozilla Firefox\plugins\npdjingleplugin-airfrance.dll
    O1 HOSTS File: ([2010/11/10 23:14:37 | 000,000,027 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
    O2 - BHO: (AcroIEHlprObj Class) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll (Adobe Systems Incorporated)
    O2 - BHO: (RealPlayer Download and Record Plugin for Internet Explorer) - {3049C3E9-B461-4BC5-8870-4C09146192CA} - c:\Program Files\real\realplayer\rpbrowserrecordplugin.dll (RealPlayer)
    O2 - BHO: (scriptproxy) - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\Common Files\Mcafee\SystemCore\ScriptSn.20101102162656.dll (McAfee, Inc.)
    O2 - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
    O2 - BHO: (AcroIEToolbarHelper Class) - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.6.5805.1910\swg.dll (Google Inc.)
    O3 - HKLM\..\Toolbar: (Google Toolbar) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
    O3 - HKLM\..\Toolbar: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O3 - HKCU\..\Toolbar\ShellBrowser: (Google Toolbar) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
    O3 - HKCU\..\Toolbar\ShellBrowser: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O3 - HKCU\..\Toolbar\WebBrowser: (Google Toolbar) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
    O3 - HKCU\..\Toolbar\WebBrowser: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O4 - HKLM..\Run: [Acrobat Assistant 7.0] C:\Program Files\Adobe\Acrobat 7.0\Distillr\Acrotray.exe (Adobe Systems Inc.)
    O4 - HKLM..\Run: [CFSServ.exe] File not found
    O4 - HKLM..\Run: [ISUSPM Startup] C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe (InstallShield Software Corporation)
    O4 - HKLM..\Run: [ISUSScheduler] C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe (InstallShield Software Corporation)
    O4 - HKLM..\Run: [LogMeIn GUI] C:\Program Files\LogMeIn\LogMeInSystray.exe (LogMeIn, Inc.)
    O4 - HKLM..\Run: [LtMoh] C:\Program Files\ltmoh\ltmoh.exe (Agere Systems)
    O4 - HKLM..\Run: [mcui_exe] C:\Program Files\McAfee.com\Agent\mcagent.exe (McAfee, Inc.)
    O4 - HKLM..\Run: [NDSTray.exe] File not found
    O4 - HKLM..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe (Nero AG)
    O4 - HKLM..\Run: [Opware15] C:\Program Files\ScanSoft\OmniPage15.0\Opware15.exe (ScanSoft, Inc.)
    O4 - HKLM..\Run: [PadTouch] C:\Program Files\TOSHIBA\Touch and Launch\PadExe.exe (TOSHIBA)
    O4 - HKLM..\Run: [PDF3 Registry Controller] C:\Program Files\ScanSoft\OmniPage15.0\PDFConverter3\RegistryController.exe (ScanSoft, Inc.)
    O4 - HKLM..\Run: [Pinger] c:\toshiba\ivp\ism\pinger.exe (TOSHIBA Corporation)
    O4 - HKLM..\Run: [ScanSoft OmniPage 15.0-reminder] C:\Program Files\ScanSoft\OmniPage15.0\Ereg\ereg.exe (ScanSoft, Inc.)
    O4 - HKLM..\Run: [SkyTel] C:\WINDOWS\SkyTel.exe (Realtek Semiconductor Corp.)
    O4 - HKLM..\Run: [SmoothView] C:\Program Files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe (TOSHIBA Corporation)
    O4 - HKLM..\Run: [SSBkgdUpdate] C:\Program Files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe (Scansoft, Inc.)
    O4 - HKLM..\Run: [TkBellExe] C:\Program Files\Common Files\Real\Update_OB\realsched.exe (RealNetworks, Inc.)
    O4 - HKLM..\Run: [Toshiba Hotkey Utility] c:\Program Files\Toshiba\Windows Utilities\Hotkey.exe (TOSHIBA Inc.)
    O4 - HKLM..\Run: [TPSMain] C:\WINDOWS\System32\TPSMain.exe (TOSHIBA Corporation)
    O4 - HKLM..\Run: [WinampAgent] C:\Program Files\Winamp\winampa.exe ()
    O4 - HKCU..\Run: [airfrance] C:\Documents and Settings\a\Local Settings\Application Data\Djingle\Widget by Air France (US)\bin\autorun.lnk ()
    O4 - HKCU..\Run: [H/PC Connection Agent] C:\Program Files\Microsoft ActiveSync\wcescomm.exe (Microsoft Corporation)
    O4 - HKCU..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe (Google Inc.)
    O4 - HKCU..\Run: [TOSCDSPD] C:\Program Files\TOSHIBA\TOSCDSPD\TOSCDSPD.exe (TOSHIBA)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Acrobat Speed Launcher.lnk = C:\WINDOWS\Installer\{AC76BA86-1033-F400-7760-000000000002}\SC_Acrobat.exe ()
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe (Adobe Systems, Inc.)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\RAMASST.lnk = C:\WINDOWS\system32\RAMASST.exe (Matsushita Electric Industrial Co., Ltd.)
    O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
    O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
    O8 - Extra context menu item: Convert link target to Adobe PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert link target to existing PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert selected links to Adobe PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert selected links to existing PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert selection to Adobe PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert selection to existing PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert to Adobe PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert to existing PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Google Sidewiki... - C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_950DF09FAB501E03.dll (Google Inc.)
    O8 - Extra context menu item: Open with Scansoft PDF Converter 3.0 - C:\Program Files\ScanSoft\OmniPage15.0\PDFConverter3\IEShellExt.dll (ScanSoft, Inc.)
    O9 - Extra Button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\Program Files\Microsoft ActiveSync\INetRepl.dll (Microsoft Corporation)
    O9 - Extra 'Tools' menuitem : Create Mobile Favorite... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\Program Files\Microsoft ActiveSync\INetRepl.dll (Microsoft Corporation)
    O15 - HKCU\..Trusted Domains: westec.net ([]http in Trusted sites)
    O15 - HKCU\..Trusted Domains: westecnow.com ([]http in Trusted sites)
    O16 - DPF: {079CBF9B-A2EF-47DF-B0A6-266FFE46210B} http://customers.westecnow.com/activex/westec.cab (WWVLive Control)
    O16 - DPF: {76CA9E30-5094-46F9-BE90-D47AD59C2C2C} https://bte.radiantenterprise.com/02.103.0130.26/pe/clientdownloads/SuperCab.cab (CClientInfo Object)
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab (Java Plug-in 1.6.0_22)
    O16 - DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} http://fpdownload.macromedia.com/get/flashplayer/current/ultrashim.cab (Reg Error: Key error.)
    O16 - DPF: {CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab (Java Plug-in 1.6.0_22)
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab (Java Plug-in 1.6.0_22)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 68.87.68.166 68.87.74.166
    O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\WINDOWS\explorer.exe (Microsoft Corporation)
    O20 - Winlogon\Notify\!SASWinLogon: DllName - C:\Program Files\SUPERAntiSpyware\SASWINLO.DLL - C:\Program Files\SUPERAntiSpyware\SASWINLO.DLL (SUPERAntiSpyware.com)
    O20 - Winlogon\Notify\AtiExtEvent: DllName - Ati2evxx.dll - C:\WINDOWS\System32\ati2evxx.dll (ATI Technologies Inc.)
    O20 - Winlogon\Notify\LMIinit: DllName - LMIinit.dll - C:\WINDOWS\System32\LMIinit.dll (LogMeIn, Inc.)
    O24 - Desktop WallPaper: C:\WINDOWS\Toshiba.bmp
    O24 - Desktop BackupWallPaper: C:\WINDOWS\Toshiba.bmp
    O28 - HKLM ShellExecuteHooks: {5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} - C:\Program Files\SUPERAntiSpyware\SASSEH.DLL (SuperAdBlocker.com)
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2006/12/27 02:44:14 | 000,000,050 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
    O37 - HKLM\...com [@ = ComFile] -- "%1" %*
    NetSvcs: 6to4 - File not found
    NetSvcs: AppMgmt - C:\WINDOWS\System32\appmgmts.dll File not found
    NetSvcs: Ias - File not found
    NetSvcs: Iprip - File not found
    NetSvcs: Irmon - File not found
    NetSvcs: NWCWorkstation - File not found
    NetSvcs: Nwsapagent - File not found
    NetSvcs: WmdmPmSp - File not found
    Drivers32: msacm.iac2 - C:\WINDOWS\system32\iac25_32.ax (Intel Corporation)
    Drivers32: msacm.l3acm - C:\WINDOWS\system32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: msacm.sl_anet - C:\WINDOWS\System32\sl_anet.acm (Sipro Lab Telecom Inc.)
    Drivers32: msacm.trspch - C:\WINDOWS\System32\tssoft32.acm (DSP GROUP, INC.)
    Drivers32: vidc.cvid - C:\WINDOWS\System32\iccvid.dll (Radius Inc.)
    Drivers32: vidc.DIVX - C:\WINDOWS\System32\DivX.dll (DivX, Inc.)
    Drivers32: vidc.iv31 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv32 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv41 - C:\WINDOWS\System32\ir41_32.ax (Intel Corporation)
    Drivers32: vidc.iv50 - C:\WINDOWS\System32\ir50_32.dll (Intel Corporation)
    Drivers32: vidc.yv12 - C:\WINDOWS\System32\DivX.dll (DivX, Inc.)
    CREATERESTOREPOINT
    Restore point Set: OTL Restore Point (16620578542714880)
    ========== Files/Folders - Created Within 30 Days ==========
    [2010/11/11 06:47:46 | 000,575,488 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\a\Desktop\OTL.exe
    [2010/11/10 22:47:51 | 000,000,000 | RHSD | C] -- C:\cmdcons
    [2010/11/10 22:43:40 | 000,212,480 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWXCACLS.exe
    [2010/11/10 22:43:40 | 000,161,792 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWREG.exe
    [2010/11/10 22:43:40 | 000,136,704 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWSC.exe
    [2010/11/10 22:43:40 | 000,031,232 | ---- | C] (NirSoft) -- C:\WINDOWS\NIRCMD.exe
    [2010/11/10 22:43:29 | 000,000,000 | ---D | C] -- C:\WINDOWS\ERDNT
    [2010/11/10 22:42:52 | 000,000,000 | ---D | C] -- C:\Qoobox
    [2010/11/09 22:36:32 | 000,000,000 | ---D | C] -- C:\Documents and Settings\a\Application Data\Malwarebytes
    [2010/11/09 22:36:21 | 000,038,224 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
    [2010/11/09 22:36:20 | 000,020,952 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
    [2010/11/09 22:36:20 | 000,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
    [2010/11/09 22:36:20 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Malwarebytes
    [2010/11/09 22:34:27 | 006,153,352 | ---- | C] (Malwarebytes Corporation ) -- C:\Documents and Settings\a\Desktop\mapp.exe.exe
    [2010/11/09 22:32:22 | 000,000,000 | ---D | C] -- C:\Documents and Settings\a\Desktop\old
    [2010/11/06 13:52:42 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Java
    [2010/10/24 13:11:27 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Temp
    [2010/10/20 11:38:38 | 000,000,000 | --SD | C] -- C:\Documents and Settings\a\UserData
    [2010/10/18 10:19:24 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\SUPERAntiSpyware.com
    [2010/10/18 10:19:23 | 000,000,000 | ---D | C] -- C:\Documents and Settings\a\Application Data\SUPERAntiSpyware.com
    [2010/10/18 10:19:10 | 000,000,000 | ---D | C] -- C:\Program Files\SUPERAntiSpyware
    [2010/10/15 15:31:32 | 000,000,000 | ---D | C] -- C:\spoolerlogs
    [1 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
    ========== Files - Modified Within 30 Days ==========
    [2010/11/12 11:11:02 | 000,000,886 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
    [2010/11/12 01:49:58 | 000,002,335 | ---- | M] () -- C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Acrobat Speed Launcher.lnk
    [2010/11/12 01:48:55 | 000,001,637 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\McAfee Total Protection.lnk
    [2010/11/12 01:44:07 | 000,000,882 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
    [2010/11/12 01:43:07 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
    [2010/11/12 01:42:36 | 1474,473,984 | -HS- | M] () -- C:\hiberfil.sys
    [2010/11/11 20:38:26 | 000,000,484 | ---- | M] () -- C:\WINDOWS\ODBC.INI
    [2010/11/10 23:14:37 | 000,000,027 | ---- | M] () -- C:\WINDOWS\System32\drivers\etc\hosts
    [2010/11/10 22:48:07 | 000,000,327 | RHS- | M] () -- C:\boot.ini
    [2010/11/10 10:26:39 | 000,630,272 | ---- | M] () -- C:\Documents and Settings\a\Desktop\dds.scr
    [2010/11/10 10:25:05 | 000,080,384 | ---- | M] () -- C:\Documents and Settings\a\Desktop\MBRCheck.exe
    [2010/11/10 06:48:07 | 000,296,448 | ---- | M] () -- C:\Documents and Settings\a\Desktop\dpuozhfk.exe
    [2010/11/10 06:46:42 | 000,001,158 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
    [2010/11/09 22:36:24 | 000,000,738 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
    [2010/11/09 22:35:06 | 006,153,352 | ---- | M] (Malwarebytes Corporation ) -- C:\Documents and Settings\a\Desktop\mapp.exe.exe
    [2010/11/08 15:17:10 | 000,001,855 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Google Chrome.lnk
    [2010/11/08 01:20:24 | 000,089,088 | ---- | M] () -- C:\WINDOWS\MBR.exe
    [2010/11/07 19:37:35 | 000,445,938 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
    [2010/11/07 19:37:35 | 000,072,978 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
    [2010/10/31 19:39:40 | 000,002,497 | ---- | M] () -- C:\Documents and Settings\a\Desktop\Microsoft Office Word 2003.lnk
    [2010/10/19 12:29:52 | 000,000,195 | ---- | M] () -- C:\WINDOWS\System32\MRT.INI
    [2010/10/18 10:19:14 | 000,001,720 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\SUPERAntiSpyware Free Edition.lnk
    [2010/10/13 22:18:44 | 000,000,116 | ---- | M] () -- C:\WINDOWS\NeroDigital.ini
    [2010/10/13 21:28:54 | 000,386,840 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfehidk.sys
    [2010/10/13 21:28:54 | 000,313,288 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfefirek.sys
    [2010/10/13 21:28:54 | 000,152,960 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfeavfk.sys
    [2010/10/13 21:28:54 | 000,141,792 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\mfevtps.exe
    [2010/10/13 21:28:54 | 000,095,600 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfeapfk.sys
    [2010/10/13 21:28:54 | 000,088,544 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfendisk.sys
    [2010/10/13 21:28:54 | 000,084,264 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mferkdet.sys
    [2010/10/13 21:28:54 | 000,084,072 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfetdi2k.sys
    [2010/10/13 21:28:54 | 000,055,840 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\cfwids.sys
    [2010/10/13 21:28:54 | 000,052,104 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfebopk.sys
    [2010/10/13 21:28:54 | 000,009,344 | ---- | M] (McAfee, Inc.) -- C:\WINDOWS\System32\drivers\mfeclnk.sys
    [2010/11/12 01:48:16 | 000,001,637 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\McAfee Total Protection.lnk
    [2010/11/10 22:48:07 | 000,000,211 | ---- | C] () -- C:\Boot.bak
    [2010/11/10 22:48:01 | 000,260,272 | RHS- | C] () -- C:\cmldr
    [2010/11/10 22:43:40 | 000,256,512 | ---- | C] () -- C:\WINDOWS\PEV.exe
    [2010/11/10 22:43:40 | 000,098,816 | ---- | C] () -- C:\WINDOWS\sed.exe
    [2010/11/10 22:43:40 | 000,089,088 | ---- | C] () -- C:\WINDOWS\MBR.exe
    [2010/11/10 22:43:40 | 000,080,412 | ---- | C] () -- C:\WINDOWS\grep.exe
    [2010/11/10 22:43:40 | 000,068,096 | ---- | C] () -- C:\WINDOWS\zip.exe
    [2010/11/10 10:26:34 | 000,630,272 | ---- | C] () -- C:\Documents and Settings\a\Desktop\dds.scr
    [2010/11/10 10:25:00 | 000,080,384 | ---- | C] () -- C:\Documents and Settings\a\Desktop\MBRCheck.exe
    [2010/11/10 06:48:00 | 000,296,448 | ---- | C] () -- C:\Documents and Settings\a\Desktop\dpuozhfk.exe
    [2010/11/09 22:36:24 | 000,000,738 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
    [2010/10/19 12:29:52 | 000,000,195 | ---- | C] () -- C:\WINDOWS\System32\MRT.INI
    [2010/10/18 10:19:14 | 000,001,720 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\SUPERAntiSpyware Free Edition.lnk
    [2009/04/01 17:56:24 | 000,007,680 | ---- | C] () -- C:\Documents and Settings\a\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2008/05/13 22:37:08 | 000,000,000 | ---- | C] () -- C:\WINDOWS\iPlayer.INI
    [2008/01/21 20:57:38 | 000,000,050 | ---- | C] () -- C:\WINDOWS\cdplayer.ini
    [2007/11/29 17:30:28 | 003,596,288 | ---- | C] () -- C:\WINDOWS\System32\qt-dx331.dll
    [2007/11/28 16:52:32 | 000,012,288 | ---- | C] () -- C:\WINDOWS\System32\DivXWMPExtType.dll
    [2007/08/07 15:26:40 | 000,002,508 | ---- | C] () -- C:\Documents and Settings\a\Application Data\$_hpcst$.hpc
    [2007/08/07 15:25:38 | 000,000,116 | ---- | C] () -- C:\WINDOWS\NeroDigital.ini
    [2007/08/07 15:24:29 | 000,000,124 | ---- | C] () -- C:\Documents and Settings\a\Local Settings\Application Data\fusioncache.dat
    [2007/06/15 08:50:04 | 000,000,026 | ---- | C] () -- C:\WINDOWS\FPKPMSV.INI
    [2006/12/27 03:44:13 | 000,000,399 | ---- | C] () -- C:\WINDOWS\MAXLINK.INI
    [2006/12/27 02:34:02 | 000,034,308 | ---- | C] () -- C:\WINDOWS\System32\BASSMOD.dll
    [2006/09/09 14:29:20 | 000,204,800 | ---- | C] () -- C:\WINDOWS\System32\IVIresizeW7.dll
    [2006/09/09 14:29:20 | 000,200,704 | ---- | C] () -- C:\WINDOWS\System32\IVIresizeA6.dll
    [2006/09/09 14:29:20 | 000,192,512 | ---- | C] () -- C:\WINDOWS\System32\IVIresizeP6.dll
    [2006/09/09 14:29:20 | 000,192,512 | ---- | C] () -- C:\WINDOWS\System32\IVIresizeM6.dll
    [2006/09/09 14:29:20 | 000,188,416 | ---- | C] () -- C:\WINDOWS\System32\IVIresizePX.dll
    [2006/09/09 14:29:20 | 000,020,480 | ---- | C] () -- C:\WINDOWS\System32\IVIresize.dll
    [2006/09/09 14:28:14 | 000,128,113 | ---- | C] () -- C:\WINDOWS\System32\csellang.ini
    [2006/09/09 14:28:14 | 000,045,056 | ---- | C] () -- C:\WINDOWS\System32\csellang.dll
    [2006/09/09 14:28:14 | 000,010,165 | ---- | C] () -- C:\WINDOWS\System32\tosmreg.ini
    [2006/09/09 14:28:14 | 000,007,671 | ---- | C] () -- C:\WINDOWS\System32\cseltbl.ini
    [2006/09/09 14:25:07 | 000,143,360 | ---- | C] () -- C:\WINDOWS\System32\RtlCPAPI.dll
    [2006/08/21 18:44:11 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
    [2006/08/21 13:54:33 | 000,000,000 | ---- | C] () -- C:\WINDOWS\NDSTray.INI
    [2006/08/21 13:53:47 | 000,011,122 | ---- | C] () -- C:\WINDOWS\HWSetupStr.ini
    [2006/08/21 13:53:47 | 000,002,036 | ---- | C] () -- C:\WINDOWS\SVPW32Str.ini
    [2006/08/21 12:30:37 | 000,000,484 | ---- | C] () -- C:\WINDOWS\ODBC.INI
    [2006/08/21 12:22:29 | 000,001,793 | ---- | C] () -- C:\WINDOWS\System32\fxsperf.ini
    [2006/08/21 12:06:11 | 000,000,341 | ---- | C] () -- C:\WINDOWS\System32\OEMINFO.INI
    [2006/08/21 05:18:50 | 000,004,328 | ---- | C] () -- C:\WINDOWS\ODBCINST.INI
    [2006/08/01 12:56:40 | 000,122,880 | ---- | C] () -- C:\WINDOWS\System32\TPeculiarity.dll
    [2005/12/08 13:56:50 | 000,151,552 | ---- | C] () -- C:\WINDOWS\System32\tsbwls.dll
    [2005/08/24 17:20:28 | 000,009,472 | ---- | C] () -- C:\WINDOWS\System32\drivers\tbiosdrv.sys
    [2005/02/03 19:59:44 | 002,129,920 | ---- | C] () -- C:\WINDOWS\System32\myodbc3S.dll
    [2004/09/16 15:24:26 | 003,375,104 | ---- | C] () -- C:\WINDOWS\System32\qt-mt331.dll
    [2003/01/07 15:05:08 | 000,002,695 | ---- | C] () -- C:\WINDOWS\System32\OUTLPERF.INI
    [2006/09/09 15:05:17 | 000,000,000 | ---D | M] -- C:\Documents and Settings\a\Application Data\InterVideo
    [2009/04/01 17:58:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\a\Application Data\ScanSoft
    [2006/08/21 13:48:20 | 000,000,000 | ---D | M] -- C:\Documents and Settings\a\Application Data\toshiba
    [2006/12/27 02:40:19 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\muvee Technologies
    [2006/12/27 03:48:28 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\ScanSoft
    [2006/08/21 14:09:10 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Viewpoint
    [2006/11/25 06:10:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\WildTangent
    [2006/08/21 14:12:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\YAHOO
    [2006/12/27 03:48:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\zeon
    ========== Custom Scans ==========
    < %SYSTEMDRIVE%\*.* >
    [2006/12/27 01:32:14 | 000,001,024 | ---- | M] () -- C:\.rnd
    [2007/01/09 22:24:10 | 000,024,174 | ---- | M] () -- C:\ASLog.txt
    [2006/12/27 02:44:14 | 000,000,050 | ---- | M] () -- C:\AUTOEXEC.BAT
    [2006/11/25 06:05:11 | 000,000,211 | ---- | M] () -- C:\Boot.bak
    [2004/08/03 23:00:00 | 000,260,272 | RHS- | M] () -- C:\cmldr
    [2010/11/10 23:41:22 | 000,023,702 | ---- | M] () -- C:\ComboFix.txt
    [2006/08/21 12:25:45 | 000,000,000 | ---- | M] () -- C:\CONFIG.SYS
    [2006/08/21 12:25:45 | 000,000,000 | RHS- | M] () -- C:\IO.SYS
    [2006/08/21 14:10:02 | 000,001,186 | -H-- | M] () -- C:\IPH.PH
    [2006/08/21 12:25:45 | 000,000,000 | RHS- | M] () -- C:\MSDOS.SYS
    [2002/01/05 03:38:38 | 000,054,784 | ---- | M] (Microsoft Corporation) -- C:\msvci70.dll
    [2004/08/03 16:00:00 | 000,047,564 | RHS- | M] () -- C:\NTDETECT.COM
    [2004/08/03 16:00:00 | 000,250,032 | RHS- | M] () -- C:\ntldr
    [2010/11/12 01:42:04 | 603,979,776 | -HS- | M] () -- C:\pagefile.sys
    [2009/08/08 21:44:06 | 000,000,640 | ---- | M] () -- C:\wgpro7.txt
    < %systemroot%\Fonts\*.com >
    [2006/04/18 14:39:28 | 000,026,040 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalMonospace.CompositeFont
    [2006/06/29 13:53:56 | 000,026,489 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSansSerif.CompositeFont
    [2006/04/18 14:39:28 | 000,029,779 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSerif.CompositeFont
    [2006/06/29 13:58:52 | 000,030,808 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalUserInterface.CompositeFont
    < %systemroot%\Fonts\*.dll >
    < %systemroot%\Fonts\*.ini >
    [2006/08/21 12:25:16 | 000,000,067 | -HS- | M] () -- C:\WINDOWS\Fonts\desktop.ini
    < %systemroot%\Fonts\*.ini2 >
    < %systemroot%\Fonts\*.exe >
    < %systemroot%\system32\spool\prtprocs\w32x86\*.* >
    [2008/07/06 07:06:10 | 000,089,088 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\filterpipelineprintproc.dll
    [2006/10/06 19:56:14 | 000,025,840 | ---- | M] (3am Labs Ltd.) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\LMIproc.dll
    [2003/06/18 17:31:48 | 000,018,944 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\mdippr.dll
    [2008/07/06 05:50:03 | 000,597,504 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\printfilterpipelinesvc.exe
    < %systemroot%\REPAIR\*.bak1 >
    < %systemroot%\REPAIR\*.ini >
    < %systemroot%\system32\*.jpg >
    < %systemroot%\*.jpg >
    < %systemroot%\*.png >
    < %systemroot%\*.scr >
    [2004/12/08 18:04:46 | 000,045,056 | ---- | M] (TOSHIBA) -- C:\WINDOWS\cfdemo.scr
    < %systemroot%\*._sy >
    < %APPDATA%\Adobe\Update\*.* >
    < %ALLUSERSPROFILE%\Favorites\*.* >
    < %APPDATA%\Microsoft\*.* >
    < %PROGRAMFILES%\*.* >
    < %APPDATA%\Update\*.* >
    < %systemroot%\*. /mp /s >
    < %systemroot%\System32\config\*.sav >
    [2006/08/21 05:17:25 | 000,094,208 | ---- | M] () -- C:\WINDOWS\system32\config\default.sav
    [2006/08/21 05:17:25 | 000,634,880 | ---- | M] () -- C:\WINDOWS\system32\config\software.sav
    [2006/08/21 05:17:25 | 000,876,544 | ---- | M] () -- C:\WINDOWS\system32\config\system.sav
    < %PROGRAMFILES%\bak. /s >
    < %systemroot%\system32\bak. /s >
    < %ALLUSERSPROFILE%\Start Menu\*.lnk /x >
    [2006/08/21 12:25:52 | 000,000,294 | -HS- | M] () -- C:\Documents and Settings\All Users\Start Menu\desktop.ini
    < %systemroot%\system32\config\systemprofile\*.dat /x >
    < %systemroot%\*.config >
    < %systemroot%\system32\*.db >
    < %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x >
    [2007/08/07 15:23:22 | 000,000,119 | -HS- | M] () -- C:\Documents and Settings\a\Application Data\Microsoft\Internet Explorer\Quick Launch\desktop.ini
    [2002/05/05 22:19:46 | 000,000,079 | ---- | M] () -- C:\Documents and Settings\a\Application Data\Microsoft\Internet Explorer\Quick Launch\Show Desktop.scf
    < %USERPROFILE%\Desktop\*.exe >
    [2010/07/08 14:11:00 | 000,216,045 | ---- | M] (Oleg N. Scherbakov) -- C:\Documents and Settings\a\Desktop\rds.exe
    < %PROGRAMFILES%\Common Files\*.* >
    < %systemroot%\*.src >
    < %systemroot%\install\*.* >
    < %systemroot%\system32\DLL\*.* >
    < %systemroot%\system32\HelpFiles\*.* >
    < %systemroot%\system32\rundll\*.* >
    < %systemroot%\winn32\*.* >
    < %systemroot%\Java\*.* >
    < %systemroot%\system32\test\*.* >
    < %systemroot%\system32\Rundll32\*.* >
    < %systemroot%\AppPatch\Custom\*.* >
    < %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x >
    < %PROGRAMFILES%\PC-Doctor\Downloads\*.* >
    < %PROGRAMFILES%\Internet Explorer\*.tmp >
    < %PROGRAMFILES%\Internet Explorer\*.dat >
    < %USERPROFILE%\My Documents\*.exe >
    [2009/04/23 17:35:03 | 038,692,440 | ---- | M] () -- C:\Documents and Settings\a\My Documents\DWRemote5.0.7.1Setup.exe
    [2009/08/13 15:02:04 | 000,608,344 | ---- | M] () -- C:\Documents and Settings\a\My Documents\MCPR.exe
    [2009/04/23 18:29:05 | 043,724,069 | ---- | M] () -- C:\Documents and Settings\a\My Documents\WestecRemote5.0.8.2.exe
    < %USERPROFILE%\*.exe >
    < %systemroot%\ADDINS\*.* >
    [2004/08/03 16:00:00 | 000,000,791 | ---- | M] () -- C:\WINDOWS\addins\fxsext.ecf
    < %systemroot%\assembly\*.bak2 >
    < %systemroot%\Config\*.* >
    < %systemroot%\REPAIR\*.bak2 >
    < %systemroot%\SECURITY\Database\*.sdb /x >
    < %systemroot%\SYSTEM\*.bak2 >
    < %systemroot%\Web\*.bak2 >
    < %systemroot%\Driver Cache\*.* >
    [2006/08/21 05:19:33 | 000,004,128 | ---- | M] () -- C:\WINDOWS\Driver Cache\INFCACHE.1
    < %PROGRAMFILES%\Mozilla Firefox\0*.exe >
    < %ProgramFiles%\Microsoft Common\*.* >
    < %ProgramFiles%\TinyProxy. >
    < %USERPROFILE%\Favorites\*.url /x >
    [2007/08/07 15:23:21 | 000,000,122 | -HS- | M] () -- C:\Documents and Settings\a\Favorites\Desktop.ini
    < %systemroot%\system32\*.bk >
    < %systemroot%\*.te >
    < %systemroot%\system32\system32\*.* >
    < %ALLUSERSPROFILE%\*.dat /x >
    < %systemroot%\system32\drivers\*.rmv >
    < dir /b "%systemroot%\system32\*.exe" | find /i " " /c >
    < dir /b "%systemroot%\*.exe" | find /i " " /c >
    < %PROGRAMFILES%\Microsoft\*.* >
    < %systemroot%\System32\Wbem\proquota.exe >
    < %PROGRAMFILES%\Mozilla Firefox\*.dat >
    < %USERPROFILE%\Cookies\*.txt /x >
    [2010/11/12 10:55:20 | 000,032,768 | ---- | M] () -- C:\Documents and Settings\a\Cookies\index.dat
    < %SystemRoot%\system32\fonts\*.* >
    < %systemroot%\system32\winlog\*.* >
    < %systemroot%\system32\Language\*.* >
    < %systemroot%\system32\Settings\*.* >
    < %systemroot%\system32\*.quo >
    < %SYSTEMROOT%\AppPatch\*.exe >
    < %SYSTEMROOT%\inf\*.exe >
    [2004/08/11 03:45:04 | 000,192,512 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\inf\unregmp2.exe
    < %SYSTEMROOT%\Installer\*.exe >
    [2005/08/01 16:24:00 | 001,003,215 | ---- | M] () -- C:\WINDOWS\Installer\ms_office_trial.exe
    [2005/10/03 14:51:04 | 004,673,840 | ---- | M] () -- C:\WINDOWS\Installer\welcomeTour.exe
    < %systemroot%\system32\config\*.bak2 >
    < %systemroot%\system32\Computers\*.* >
    < %SystemRoot%\system32\Sound\*.* >
    < %SystemRoot%\system32\SpecialImg\*.* >
    < %SystemRoot%\system32\code\*.* >
    < %SystemRoot%\system32\draft\*.* >
    < %SystemRoot%\system32\MSSSys\*.* >
    < %ProgramFiles%\Javascript\*.* >
    < %systemroot%\pchealth\helpctr\System\*.exe /s >
    < %systemroot%\Web\*.exe >
    < %systemroot%\system32\msn\*.* >
    < %systemroot%\system32\*.tro >
    < %AppData%\Microsoft\Installer\msupdates\*.* >
    < %ProgramFiles%\Messenger\*.* >
    [2004/08/03 16:00:00 | 000,028,672 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\custsat.dll
    [2004/08/04 03:06:34 | 000,004,821 | ---- | M] () -- C:\Program Files\Messenger\logowin.gif
    [2004/08/04 03:06:34 | 000,007,047 | ---- | M] () -- C:\Program Files\Messenger\lvback.gif
    [2008/05/02 09:22:02 | 000,083,968 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgsc.dll
    [2004/08/04 03:06:34 | 000,180,224 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgslang.dll
    [2004/10/13 11:24:37 | 001,694,208 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msmsgs.exe
    [2004/08/04 03:06:36 | 000,002,882 | ---- | M] () -- C:\Program Files\Messenger\newalert.wav
    [2004/08/04 03:06:36 | 000,006,156 | ---- | M] () -- C:\Program Files\Messenger\newemail.wav
    [2004/08/04 03:06:36 | 000,006,160 | ---- | M] () -- C:\Program Files\Messenger\online.wav
    [2004/08/04 03:06:36 | 000,004,454 | ---- | M] () -- C:\Program Files\Messenger\type.wav
    [2004/08/04 03:06:36 | 000,115,981 | ---- | M] () -- C:\Program Files\Messenger\xpmsgr.chm
    < %systemroot%\system32\systhem32\*.* >
    < %systemroot%\system\*.exe >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\ Auto Update\Results\Install|LastSuccessTime /rs >
    < End of report >
  16. 2010/11/12
    Run OTL
      :OTL
      :Services
      :Reg
      [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeAntiVirus]
       "DisableMonitoring" =-
      [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeFirewall]
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    • Open OTL again and click the Quick Scan button. Post the log it produces in your next reply. Only one log will be created.
    Last scans...
    1. Download Security Check from HERE, and save it to your Desktop.
    • Double-click SecurityCheck.exe
    • Follow the onscreen instructions inside of the black box.
    • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
      NOTE SecurityCheck may produce some false warning(s), so leave the results reading to me.
    2. Download Temp File Cleaner (TFC)
    • Double click on TFC.exe to run the program.
    • Click on Start button to begin cleaning process.
    • TFC will close all running programs, and it may ask you to restart computer.
    3. Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Tick the box next to YES, I accept the Terms of Use
    • Click Start
    • IMPORTANT! UN-check Remove found threats
    • Accept any security warnings from your browser.
    • Check Scan archives
    • Click Start
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, push List of found threats
    • Click on Export to text file , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
    • NOTE. If Eset won't find any threats, it won't produce any log.
  17. 2010/11/13
    atlgman
    All processes killed
    ========== OTL ==========
    Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\CFSServ.exe deleted successfully.
    Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\NDSTray.exe deleted successfully.
    C:\WINDOWS\System32\CONFIG.TMP deleted successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\UserShell\AOL9Plus folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\UserShell\AOL9 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\UserShell folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint folder moved successfully.
    Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeAntiVirus\\DisableMonitoring deleted successfully.
    Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeFirewall\\DisableMonitoring deleted successfully.
    ========== FILES ==========
    [EMPTYTEMP]
    User: a
    ->Temp folder emptied: 661371 bytes
    ->Temporary Internet Files folder emptied: 6002250 bytes
    ->Java cache emptied: 78658106 bytes
    ->FireFox cache emptied: 95610212 bytes
    ->Google Chrome cache emptied: 72597391 bytes
    ->Flash cache emptied: 58027 bytes
    User: All Users
    User: Default User
    ->Temporary Internet Files folder emptied: 32902 bytes
    User: Guest
    ->Temporary Internet Files folder emptied: 67 bytes
    User: LocalService
    ->Temporary Internet Files folder emptied: 49286 bytes
    ->Flash cache emptied: 14320 bytes
    User: NetworkService
    Windows Temp folder emptied: 345 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33170 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 242.00 mb
    OTL logfile created on: 11/13/2010 12:23:59 AM - Run 3
    1.00 Gb Total Physical Memory | 1.00 Gb Available Physical Memory | 61.00% Memory free
    2.00 Gb Paging File | 1.00 Gb Available in Paging File | 73.00% Paging File free
    Drive C: | 55.88 Gb Total Space | 21.22 Gb Free Space | 37.97% Space Free | Partition Type: NTFS
    PRC - [2004/12/14 02:12:46 | 000,196,608 | ---- | M] (Adobe Systems Incorporated.) -- C:\Program Files\Adobe\Acrobat 7.0\Distillr\acrodist.exe
    [2010/11/13 00:06:45 | 000,000,000 | -HSD | C] -- C:\RECYCLER
    [2010/11/13 00:04:52 | 000,000,000 | ---D | C] -- C:\_OTL
    [2010/11/13 01:11:54 | 000,000,886 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
    [2010/11/13 00:22:09 | 000,003,178 | ---- | M] () -- C:\Documents and Settings\a\Desktop\after run otl.rtf
    [2010/11/13 00:21:23 | 000,002,335 | ---- | M] () -- C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Acrobat Speed Launcher.lnk
    [2010/11/13 00:14:59 | 000,001,637 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\McAfee Total Protection.lnk
    [2010/11/13 00:11:28 | 000,000,882 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
    [2010/11/13 00:10:27 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
    [2010/11/13 00:09:56 | 1474,473,984 | -HS- | M] () -- C:\hiberfil.sys
    [2010/11/12 23:13:11 | 000,000,484 | ---- | M] () -- C:\WINDOWS\ODBC.INI
    [2010/11/13 00:22:03 | 000,003,178 | ---- | C] () -- C:\Documents and Settings\a\Desktop\after run otl.rtf
    [2010/11/13 00:14:53 | 000,001,637 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\McAfee Total Protection.lnk
    < End of report >
    Results of screen317's Security Check version 0.99.5
    Windows XP Service Pack 2
    Out of date service pack!!
    Internet Explorer 6 Out of date!
    Antivirus/Firewall Check:
    Windows Firewall Disabled!
    Anti-malware/Other Utilities Check:
    Java(TM) 6 Update 22
    Out of date Java installed!
    Adobe Flash Player 10.0.22.87
    Mozilla Firefox (3.6.12) Firefox Out of Date!
    Process Check:
    objlist.exe by Laurent
    mcafee VIRUSS~1 mcvsshld.exe
    DNS Vulnerability Check:
    GREAT! (Not vulnerable to DNS cache poisoning)
    ``````````End of Log````````````
    C:\Documents and Settings\All Users\Documents\other\divx\DivX_Pro_6.8.rar probably a variant of Win32/Agent.KTGYKTG trojan
    C:\Documents and Settings\All Users\Documents\other\divx\DVT-Keymaker.exe probably a variant of Win32/Agent.KTGYKTG trojan
    Thank you, Broni
  18. 2010/11/13
    Run OTL
      :OTL
      :Services
      :Reg
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how is your computer doing.
  19. 2010/11/13
    atlgman
    C:\Documents and Settings\All Users\Documents\other\divx\DivX_Pro_6.8.rar moved successfully.
    C:\Documents and Settings\All Users\Documents\other\divx\DVT-Keymaker.exe moved successfully.
    [EMPTYTEMP]
    User: a
    ->Temp folder emptied: 587923 bytes
    ->Temporary Internet Files folder emptied: 6850732 bytes
    ->Java cache emptied: 0 bytes
    ->FireFox cache emptied: 45357627 bytes
    ->Google Chrome cache emptied: 8394497 bytes
    ->Flash cache emptied: 994 bytes
    User: All Users
    User: Default User
    User: Guest
    User: LocalService
    Total Files Cleaned = 58.00 mb
    [EMPTYFLASH]
    User: a
    User: All Users
    User: Default User
    User: Guest
    User: LocalService
    OTL by OldTimer - Version 3.2.17.3 log created on 11132010_154942
    C:\WINDOWS\temp\T30DebugLogFile.txt moved successfully.
    [EMPTYTEMP]
    User: a
    ->Temp folder emptied: 588072 bytes
    ->Temporary Internet Files folder emptied: 75539 bytes
    ->FireFox cache emptied: 0 bytes
    ->Google Chrome cache emptied: 6399162 bytes
    ->Flash cache emptied: 9785 bytes
    User: All Users
    User: Default User
    User: Guest
    User: LocalService
    Windows Temp folder emptied: 255 bytes
    Total Files Cleaned = 7.00 mb
    [EMPTYFLASH]
    User: a
    User: All Users
    User: Default User
    User: Guest
    User: LocalService
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.17.3 log created on 11132010_160807
    It is doing much better. However, it is still slow and delays are occurring. Especially, the mouse. It is not as fluid as it once was. I believe the performance deterirated after runing Malwarebytes the first time.
    Thank you for all of your help, Broni
  20. 2010/11/13
    Good :)
    I'd suggest trying another mouse, or/and reinstalling mouse driver.
    Good luck and stay safe :)
