Google Adwords problem
Discussion in 'Other PC Software' started by rigsby, 2008/02/19.
  1. 2008/02/19
    rigsby
    rigsby Inactive Thread Starter
    Need some help please re. Adwords. This is the address FYI :-
    https://adwords.google.co.uk/select/KeywordToolExternal
    "Google Adwords" was working fine until this week. Now it does absolutely nothing when I complete the fields & press the button "Get Keyword Ideas" . It's the same in Firefox and IE. My computer is up to date with all patches etc.
    I've tried disabling the firewall completely, to no avail.
    I don't know if this is related or a separate problem but I'll mention it here. If I display the webpage in Firefox as an IE webpage OR I run IE and display the webpage, I get various "A Runtime error has occurred. Do you wish to debug" popups. The last of which says :-
    'kpKeywordPlanner.getActiveProvider()' is null or not an object
    If anybody has any thoughts as to whats occurring I'd be very grateful. Thanks.
  2. 2008/02/19
    rigsby - Welcome to the Board :)
    Sounds to me like the problem is at their end and not yours.
    rigsby
    Thanks - but I disagree
    Thanks, but a friend of mine has no problems with it. (He tried it within the hour). Mine still doesn't work.
  5. 2008/02/20
    Fair comment :)
    Check out these settings in IE ....
    Tools > Internet Options > Advanced .....
    Disable script debugging (IE) - should be checked
    Disable script debugging (other) - should be unchecked
    Display a notification about every script error - should be unchecked
  6. 2008/02/20
    rigsby
    The settings are as per your advice.
    When I go into the site in IE, a popup appears immediately -
    An error has occurred in the script on this page
    Line 1006
    Char 2
    Error Object Expected
    Code 0
    URL https://adwords.google.co.uk/select/KeywordToolExternal
    Do you wish to continue running scripts on this page ?
    Yes / No
    Upon pressing the "Get Keyword Ideas" button, I repeatedly get a similar popup to the one above but with
    as the Error.
    I live in Thailand. I have a feeling it may be a problem with my ISP. My friend is with a different provider and has no such problems.
  7. 2008/02/21
    That is always possible - clearly it is an error in the script - have you tried Adwords in a different language?
  8. 2008/02/21
    rigsby
    Thanks for the advice, but just tried 'Adwords' in Thai and French and the result is always the same. :mad:
