GoBack 3.1 is incompatible with an upgrade to XP pro?
Discussion in 'Other PC Software' started by jazzbo, 2003/04/16.
  1. 2003/04/16
    jazzbo
    jazzbo Inactive Thread Starter
    I cannot install XP Pro,with GoBack on my PC,thats the error,while trying to upgrade to XP pro
    i also have WK2 as major OS, with a W98 dual boot,i want to replace with XP pro
    id hate to remove GOBAck 3.1,as its saved my ass many times
  2. 2003/04/17
    Hi jazzbo,
    I don't have this app, but your first port of call should be the Roxio (?) website to check for patches, updates, compatibility, etc.
    You could try uninstalling it, installing SP1 and then re-installing it.
    Dennis L Inactive Alumni
    Hi jassbo
    Had GoBack 3.1 on my XP Pro when first purchased (SP1 already installed). Have ugdated current to v3.11.59. Has worked flawlessly. Would suggest checking out the home site. Ahem to GoBack saving my butt!!!!
  5. 2003/04/17
    Zander
    Zander Geek Member Alumni
    GoBack 3.1 is compatible with your xp upgrade. However, in order to install xp you have to first uninstall GoBack, then install xp and then reinstall GoBack. I read about this a while ago at Roxio's web site. I'll see if I can find the page for you.
  6. 2003/04/17
    Zander
