Gmer?
Discussion in 'Security and Privacy' started by Davezilla, 2010/01/03.
  1. 2010/01/03
    Davezilla
    Davezilla Well-Known Member Thread Starter
    Does anyone use the GMER root-kit detector? If so, is it any better than SUPERAntiSpyware or Malwarebytes MBAM?
  2. 2010/01/03
    Geri Lifetime Subscription
    Geri Inactive Alumni
    Hi
    GMER is as you state a Root Kit detector, and is not in the same category as MBAM or SAS, which are malware detectors and removers.
    Geri
    Geri,
    Adding to Geri's...it's a scanner only. It doesn't fix anything by itself, like those two others.
    You can use GMER to manually fix some issues, but you have to really know, what you're doing.
  5. 2010/01/03
    Davezilla
    OK, thanks for the information.
