Ghost switches problem
Discussion in 'Other PC Software' started by Grunty, 2005/03/02.
  1. 2005/03/02
    Grunty
    Grunty Inactive Thread Starter
    I have created a ghost image successfully using the line "ghost.exe -clone,MODE=dump,SRC=2,DST=X:\filename.gho -sure "
    The image was much larger than others I have created manually from similarly configured machines and wondered if the automatically created one was being compressed.
    Are there any other switches I can use to force maximum compression? I have looked at the Symantec website but can't see anything to help.
    Ta.
  2. 2005/03/02
    Grunty
    S'ok, I think I found it: -Zx where x is compression level 1-9.
    Not sure if it works or about the syntax yet as I havent tested it - will give it a go.
