Resolved Ghost drive F: keeps appearing
Discussion in 'Windows 10' started by alboy, 2017/04/02.
  1. 2017/04/02
    alboy
    alboy Well-Known Member Thread Starter
    For some time now every so often I get a ghost usb drive appear as drive F: it has been the system drive in the past and I have removed it in disk management by removing the drive letter but it has now reappeared as a unallocated drive with the letter F: but when I go into disk management there is no drive shown with that drive letter and when I double click the icon it wants you to insert a disk, any help would be very welcome.
  2. 2017/04/02
    alboy
    Have found the problem it is my Samsung usb connected printer if no usb drive is inserted at the same time it grabs drive F:
    In Folder Options > View > you can select "Hide empty drives in computer folder...
  5. 2017/04/02
    alboy
    I do not seem to have " Hide empty drives in computer folder " as an option in folder options view
  6. 2017/04/02
    Should be in .....
    Control Panel > File Explorer Options > View tab > Hide empty drives.
  7. 2017/04/02
    alboy
    Thanks PeteC that seems to have done the trick
  8. 2017/04/02
    You're welcome :)
    BTW - looks as if your signature requires updating?
  9. 2017/04/03
    alboy
    My signature has been updated it is a pity I can't do the same for myself I could certainly use an update.
    again many thanks for your help
    alboy
  10. 2017/04/03
    I know the feeling :D
