Generic Host Process for Win32 Services has encountered a problem and needs
Discussion in 'Windows XP' started by jperota, 2008/03/17.
  1. 2008/03/17
    jperota
    jperota Inactive Thread Starter
    After many hours of searching for the solution to this problem, I came across some of my old notes from about 5 years ago.
    I had forgotten I had this problem the 1st year I installed XP sp2 and during that time tech support offered me this as a solution.
    Reboot the computer:
    Press F8:
    Select: Safe mode with Networking
    Select: administrator
    (Windows now opens in safe mode)
    Go to: Start
    Select: Run
    Type in: services.msc
    (Look for)
    SSDP discovering Service Properties
    (go to) Startup
    (change your settings from Manual to Disable)
    exit and reboot
    Problem is now solved.
    No need for (BS) virus protection **** or updates from microsoft
    Which I was suckered into trying these last few days.
    Happy computing!
  2. 2008/03/17
    jperota
    Generic Host Process for Win 32
    Well it would appear I spoke too soon.
    Previously I would be online from 15 to 30 min and then this error message would appear.
    Once I attempted this so called repair that I posted earlier I remained online for almost 2 hours.
    Now it has crashed again!
    I should mention that the only program I installed prior to this was Micro softs
    Malicious Software Removal Tools and what a surprise, something has gone wrong?
    BTW my other computer (and friends computers that I have built up) does not have this program installed and has been running smoothly now for years.
    I dont have any Spyware or Virus programs on the other computer and everything is working great!
    I thought this would be a great program to have and decided to give it a try.
