general protection faults
Discussion in 'Other PC Software' started by scootr, 2002/02/14.
  1. 2002/02/14
    scootr
    scootr Inactive Thread Starter
    I just had a new processor put into my machine, I now have a intel celeron 600 mhz, with 128 megs of ram. When I try to open Amipro I get an error message that reads: AMIPRO caused a general protection fault
    in module GDI.EXE at 0001:0000293e.
    Registers:
    EAX=003145fe CS=052f EIP=0000293e EFLGS=00000282
    EBX=000055b6 SS=932f ESP=000060c0 EBP=00006144
    ECX=00008001 DS=069f ESI=00002df2 FS=0000
    EDX=0001069f ES=069f EDI=00002dda GS=0000
    Bytes at CS:EIP:
    ff 5f 10 66 5f 66 5e c3 b8 01 01 33 c9 33 d2 f6
    Stack dump:
    00000000 932f61e2 932f6232 45fe8001 2dda069f 2df20000 26c80000 66ac21ab 02270001 0377081c 006f4547 75522620 0072656c 00000003 20080018 61120003
    I also can't print, from my Quickverse, which is a computer Bible program. This is what I get there: QVWIN caused a general protection fault
    Registers:
    EAX=0031cbbe CS=052f EIP=0000293e EFLGS=00000246
    EBX=00008cca SS=6497 ESP=0000f63a EBP=0000f6be
    ECX=00000001 DS=069f ESI=00002de2 FS=0000
    EDX=0001069f ES=069f EDI=00002dea GS=0000
    Bytes at CS:EIP:
    Stack dump:
    00000000 6497f733 6497f70e cbbe0001 2dea069f 2de20000 26c80000 f72d21ab 0227f70e 000000e6 00004547 010f0000 00e63a48 14de0000 01770000 5f30f6a0
    If I try to print from internet explorer I get a script error message. Do you want to continue to run scripts? No matter what my answer, the print doesn't happen.
    This is what happens if I try to run a printer test page: RUNDLL32 caused a general protection fault
    Registers:
    EAX=0032ba26 CS=052f EIP=0000293e EFLGS=00000246
    EBX=0000863a SS=5c9f ESP=000089d4 EBP=00008a58
    ECX=00000001 DS=069f ESI=0000243a FS=0000
    EDX=0001069f ES=069f EDI=0000241a GS=0000
    Bytes at CS:EIP:
    Stack dump:
    00000000 75970000 61670000 ba260001 241a069f 243a0000 26c80000 018721ab 02277557 350b0001 00b74547 00e600e6 00e61c00 000000e6 00e635cc 00e60001
    Thank you for your time.
  2. 2002/02/16
    Brenda J
    Brenda J Inactive
