General Protection Fault
Discussion in 'Internet Explorer & Microsoft Edge' started by sttonk, 2003/08/02.
  1. 2003/08/02
    sttonk
    sttonk Inactive Thread Starter
    I keep getting EXPLORER caused a general protection fault
    in module USER.EXE at 0003:00001022. This usually occurs when I am typing in an address or in the address bar to do a search. Any ideas? Thanks, John
  2. 2003/08/02
    Adele2001
    Adele2001 Inactive
    Hi, I recently had this problem too. Have you recently downloaded and installed any programs? I had downloaded an update of Blubster recently and my problem seems to have been solved by getting rid of all spyware on my computer which came with that program using Spybot Search & Destroy. I downloaded the most recent one which got rid of lots more than the old version I had.
    Let me know if it works for you as, so far, it seems to have worked for me.
    Good luck!
  5. 2003/08/25
    sttonk
    General Protection Error
    Thanks for the help. Tried both of the recommendations but still receiving error.
  6. 2003/08/28
    irdreed
    irdreed Inactive
