Frontpage Theme Problem
Discussion in 'Other PC Software' started by fsiaca, 2002/05/15.
  1. 2002/05/15
    fsiaca
    fsiaca Well-Known Member Thread Starter
    :confused: A web page was created using Frontpage98. When the page was uploaded, the theme used, along with the colors, do not show up. We've tried using different themes with no luck. The related theme GIFs show up in the web folder.
    This is very confusing. Any ideas would be welcome. Thanks
  2. 2002/05/15
    Daizy
    Daizy Inactive
    Hi fsiaca
    Does your host use front page extensions?
    Daizy
    fsiaca
    Thanks for the response. Yes, the host server uses FrontPage extensions.
  5. 2002/05/15
    Daizy
    Daizy Inactive
    Ok...that eiliminated that. Waht are you using to upload your pages? Did you look to see if everything is infact sitting there?
    Daizy
  6. 2002/05/17
    fsiaca
    Daizy:
    Thanks for the response. I could not get back to you sooner because it's been a bit hectic.
    We use FtontPage's Web Publishing wizard to upload the files. We cannot actually see what's in the folder. We've been trying different approaches to this. One of us can load everything; the other cannot, and they are the same files from the same folder! If my coworker tries to upload modified pages, the orginal themes are gone. I then have to gon in and upload them!
    To complete the job I uploaded the files because I was not having the problems, but we would really like to know why this is happening. My co-worker is located in another office, but we are connected to the same LAN system. Thanks.
