Front USB Port
Discussion in 'PC Hardware' started by hawk22, 2006/06/16.
  1. 2006/06/16
    hawk22
    hawk22 Geek Member Thread Starter
    Hi, Any System Builders here,,I am having a bit of a problem wiring up a new Case with front USB and Audio. It seems to me that I have to experiment a bit with the connectors on the mobo I would like to now if I will damage the board by connecting it wrong while trying out the correct wires to pin.
    Hawk22
  2. 2006/06/16
    Hi,
    You need to post the header ID's (from the motherboard manual) and the ID's on the connectors.
    Because there is no convention for the system I could not guarantee that anybody will be able to match them.
    And...if you do get them matched (Google searches will help) please post back with the combination. You could see how helpful it may be to others :rolleyes:
    coolwaters
    coolwaters Inactive
    re
    No m8 wouldnt worry Ive messed around and got them wrong before and it didnt affect anything. Get your motherboards pdf from the site or if u have the cd it should be on there.
  5. 2006/06/17
    hawk22
    Thanks guy's I have now downloaded a Manual for the mobo 64 pages :eek: and when I get the Machine back I'd say next weekend I will try and match them. At least now I don't have to worry about damaging the mobo if I don't get it right the first time. So thanks for that Guy's a load of my mind.:D
    hawk22
