Front Page and N7
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by broni, 2002/09/07.
  1. 2002/09/07
    broni Moderator Malware Analyst Thread Starter
    when i use annimation in Front Page 2000, it will show correctly in IE6, N4.77, but in N7 it won't move at all...any suggestion?
    Broni
  2. 2002/09/07
    Antony
    Antony Inactive
    Sorry, have to disappoint you.
    My recommendation is don't use it. We don't recommend creating webpages by using FrontPage. FrontPage is very good at create webpages unreadable by Netscape.
    why DOES it work with 4.7 buit not 7?...
    i'm not a real fan of Microsoft, but Front Page is pretty simple to use...what other program would u recommend?
    Broni
  5. 2002/09/08
    Antony
    Antony Inactive
    Why works on v4.7 but not v7?
    Easy.
    The FrontPage writes some codes that is not standard, and it simply works for two versions MSIE4+ and NS4.xx
    It depends on what sort of webpage you want to create, generally Dreamweaver is not difficult to use and produce pretty good codes. (Standard compliance).
    (It will cost you a bit.)
  6. 2002/09/08
    Ramona
    Ramona Geek Member Alumni
    Hi broni,
    Have you used Netscape's Composer? I know quite a few people who use this component and are quite satisfied.
    Then there's always Notepad! ;)
    Ramona :D
  7. 2002/09/08
    thanks guys
    actually i have Dreanweaver on my system installed
    i will give it a shot
    Broni
