Formatting OS without CD drive
Discussion in 'Legacy Windows' started by kanishkaroy07, 2013/10/09.
  1. 2013/10/09
    kanishkaroy07
    kanishkaroy07 Inactive Thread Starter
    I am using a windows 8 OS. My usb drive is suddenly not recognizing any devices after windows installed an update. Further during a recent home shifting my CD drive got damaged. I want to know whether I should format my system. If yes how can I format my system without a CD drive & USB drives. However I have another computer connected in a LAN. Will it be of any help.
    Please give me a solution. Thanks in advance.
  2. 2013/10/09
    Hi kanishkaroy07, Welcome to Windowsbbs. :)
    Have you tried Deleting the Update?
    Go to Control Panel > Windows Update > view update history > installed updates to carry out Removal. Neil
    I wouldn't format the drive just to fix an issue with the USB.
    If the above idea doesn't work - look in Device Manager to see if there are any errors regarding the USB.
    Could also consider replacing the DVD drive. You're going to need to use it someday;)
  5. 2013/10/09
    kanishkaroy07
    thank you for ur suggestion.... i will try it & get back to you :)
  6. 2013/10/09
    kanishkaroy07
    actually when I was trying to connect my external drive it wasn't getting connected. I checked in Device Manager & it showed USB mass storage driver is corrupted. I thought the problem might be the device but it worked fine in my other computer. So i think the problem is actually the USB drivers if I am not wrong.
    Any more suggestions?????
  7. 2013/10/09
    Uninstall them and then reboot and let windows reinstall them.
  8. 2013/10/11
    kanishkaroy07
    thanx to everyone 4 their suggestions. Uninstalling the updates wasn't working. so I went 4 system restore & it worked. thanx again!!!!!!!!!!!!
