Floppy drive problems!!!
Discussion in 'Windows XP' started by -Z--K-, 2003/01/14.
  1. 2003/01/14
    -Z--K-
    -Z--K- Inactive Thread Starter
    Hi,
    I will try to explane my problem.
    Ok... when windows start up, they everytime "check" floopy drive. How can I disable this?
    I have Windows XP Professional, I also have Roxio GoBack Deluxe...
    I´m open for any suggestion!
    Thank You
    Best Regards
  2. 2003/01/14
    Dennis L Inactive Alumni
    Hi -Z--K-
    Technically you do not have a problem. In the event of HDD failure, your computer can read from the floppy drive to begin the restore process. You can change this sequence of settings from your BIOS.
    My settings for available drives for bootup reads are as follows......
    Check HDD, if available STOP drive search, begin drive read.
    Check CD, if available STOP drive search, begin drive read.
    Check floppy drive.....ect.
    With the above approach, computer searches for a drive until it finds a "working drive ". If you configure with HDD, then checking CD, disabling floppy is acceptable. It still is accesable if needed. If this is first time in BIOS changes, please have an experienced friend walk you through. This is NOT an area you want mistakes.
    -Z--K-
    Thank You
  5. 2003/01/14
    Your most welcome :)
