Flash Player 9
Discussion in 'Other PC Software' started by abm, 2009/09/08.
  1. 2009/09/08
    abm
    abm Inactive Thread Starter
    How can I tell whether I have Flash Player 9 on my Windows XP computer? Thank you. user 470
    abm,
  2. 2009/09/08
    Hi abm. To find out what version of flash player you have on the computer, click Start< Control Panel< Add/Remove Programs< Highlight Flash Player and then click the link that says Click here for support information. If you are using Flash Player 9 then I would recommend that you upgrade to Adobe Flash Player 10 which is available for download here.
