Flash macromedia 9
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by Sportsaholic, 2007/03/30.
  1. 2007/03/30
    Sportsaholic
    Sportsaholic Inactive Thread Starter
    Does anyone know where i can d/l a copy of this so I can view mlb.com with firefox, please?
    tia
  2. 2007/03/31
    charlesvar
    charlesvar Inactive Alumni
    Hi Sportsaholic,
    http://www.adobe.com/downloads/ scroll down a bit.
    I took the liberty of editing your title from micromedia to macromedia :)
    Regards - Charles
    Sportsaholic
    tried that d/l yesterday but it didn't work. Thanks though.
  5. 2007/03/31
    charlesvar
    Didn't work with Firefox?
    If that's the case, I'll move the thread so the FF folks can look at this.
    Regards - Charles
  6. 2007/03/31
    Sportsaholic
    ok, but I have a thread going on in a FF forum and they haven't answered me yet. thanks
  7. 2007/03/31
    charlesvar
    Done :)
    Regards - Charles
  8. 2007/03/31
    Ramona
    Ramona Geek Member Alumni
    Sportsaholic,
    I just tried the mlb.com site, using Flash Player, Ver. 9,0,28,0, and had no problems with the site working. Is this the Ver. of Flash Player that you downloaded?
    If not, then you can download here: Shockwave Flash Player. Then go to this site to test the player: http://www.adobe.com/shockwave/welcome/
    I would uninstall the current version before reinstalling. It should be listed in Add/Remove, and can be uninstalled there. However, if you have problems, or the program doesn't uninstall, then you can download an uninstaller at the Adobe site: Uninstaller
  9. 2007/03/31
    Sportsaholic
    Ramona, I used the uninstaller to remove flash completely from my system and tried installing the program from the link you provided but when I try installing it I keep on getting the following error" windows can't find c:\progra~\mozill~1\firefox.exe -url "%1'. How do I fix this please?
    Update....Ok, I now installed abobe flash again and the firefox version of it which you provided and what I get is what I originally was getting. See here
    http://img251.imageshack.us/img251/2726/mlbtk5.png
  10. 2007/03/31
    Ramona
    Sportsaholic
    hi Ramona, Sounds like a pain on all the things they want to do to fix it or trying things. I never had any problems with it until 2 days ago and I never changed anything so i don't know why this is happening. Someone wrote a vb script for me where I can use IE to open blb.com shortcut which i can use so thanks anyway.
