Flash Drive and USB 2.0
Discussion in 'PC Hardware' started by BreezyCricket, 2008/12/13.
  1. 2008/12/13
    BreezyCricket Lifetime Subscription
    BreezyCricket Well-Known Member Thread Starter
    When I plug my Flash Drive into a USB Port I get a message to the effect that it could operate faster if I plugged it into a USB 2.0 Port.
    Would anyone know how I can do this?
  2. 2008/12/13
    FastTracker
    FastTracker Banned
    What type of machine are you running? Older machines did not have 2.0 capability built in. You can purchase a plug in card for that though. Check at your local computer store.
    Thank you for the reply.
    I have fairly new equipment and have received this message on a number of machines.
    They all support USB 2.0 but I don't know how to get the flash drive to use it.
  5. 2008/12/13
    FastTracker
    FastTracker Banned
    Check in Device Manager. Click Start
    Control Panel
    Administrative Tools
    Computer Management
    Device Manager.
    Scroll towards the bottom to Universal Serial Bus controllers
    click on + sign to expand.
    See if USB 2.0 Enhanced is listed at top
  6. 2008/12/13
    911
    911 Inactive
    #5
  7. 2008/12/15
    FastTracker
    FastTracker Banned
    Are you plugging into the front panel slots? on my machine, 2.0 doesn.t work but regular USB does. If I insert into a rear panel slot, 2.0 works fine.
