Firefox connection problems
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by Scottd, 2008/02/18.
  1. 2008/02/18
    Scottd
    Scottd Inactive Thread Starter
    Used to use Firefox, now it won't work. Error message says " The proxy server is refusing connections ".
    How do I correct this? Thanks.
  2. 2008/02/18
    Ramona
    Ramona Geek Member Alumni
    Scottd,
    Do you actually require a proxy connection? If not, check the proxy settings in Tools | Options | Advanced | Network Tab | Settings
    Then select the first setting: Direct Connection
    Also, if your computer is protected by a firewall, ensure that Firefox is permitted to access the Web.
    Scottd
    Jeez.......
    It's simple, when you know how........it worked!!! I don't know how it ever got changed, but thanks, Ramona, for fixing it!!!
  5. 2008/02/18
    Ramona
    Terrific! :D
