File Types Problem.
Discussion in 'Windows XP' started by degasvegas, 2004/08/16.
  1. 2004/08/16
    degasvegas
    degasvegas Inactive Thread Starter
    Basically, what I did was, I went into the "File Types" window, and somehow, ******* around with the:
    Drive, File Folder and Folder filetypes. Initially I only meant to try and change the icons of these filetypes, but it didnt work so I just changed them back to the default.
    However, now, none of my drives or folders open, they go directly to the search window when clicked. I now have to right-click and hit "open ".
    Now I try and click on the filetype and go "advanced" - however there is no "open" option, and there is no way for me to change these back to default.
    Any idea's? This seems to be a lot different than changing a .JPG or .MP3 filetype because they system files.
    I could format, but **** there has to be a solution for this.
    Thanks for reading.
    Dan.
  2. 2004/08/16
    Zander
    Zander Geek Member Alumni
    Have you tried system restore? This is one of those things that's made to order for it. I'd be surprised if it wouldn't fix it.
