File Transfer through router problem
Discussion in 'Networking (Hardware & Software)' started by satkeith, 2005/08/21.
  1. 2005/08/21
    satkeith
    satkeith Inactive Thread Starter
    I have 3 Computers networked using a
    Linksys BEFSR41 v2 Wired Cable Router (firmware:1.45.7)
    All 3 access the internet at blazing speeds.
    Computer 1 transfers files to and from
    to computer 2 or 3 at REALLY Slow rates.
    But Computer 2 or 3 can transfers files to and from
    each other at FAST Speeds.
    The Router is 4 years old, all the CAT 5 cables are New
    and have been tested individual..
    Computer 1 is brand new ( I just built it )
    The Network Port on Computer 1 is built into the ASUS Motherboard
    its a Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller
    Computer 2 & 3 both use SOHOware 10/100 PCI Network Adapter Card
    Is the problem the Router ? or the Network built into the Motherboard ?
    Thanks,
    Mod edit - we do not respond by email on a one to one basis - all problems are dealt with on the BBS for the benefit of all. Email address removed for security (your security) reasons.
  2. 2005/08/21
    Scott Smith
    Scott Smith Inactive Alumni
    Have you tried swapping around ports on the linksys?
    To rule out the linksys hook all the PCs to a switch and connect the switch to the linksys,
    satkeith
    All Fixed
    It was the Network Speed/Duplex setting (on my new motherboard)
    I had it set to 100Mbps, but had to change it to auto-sense
