Solved File assocaition problem.
Discussion in 'Malware and Virus Removal Archive' started by Moghedien21, 2008/01/18.
  1. 2008/01/18
    Moghedien21
    Moghedien21 Inactive Thread Starter
    [Resolved] File assocaition problem.
    My computer has recently been having errors with opening .exe, telling me that the file association is not found, and i need to set it up. some programs, such as firefox or IE, will work if i right click the link and open as administrator, however some will not. I ran adware,spyware and antivirus software, and discovered i had a trojan, which i believe to be the cause. The virus is gone, but the program asociations are still missing. i Then downloaded a program designed to fixx the problem from this same site, but it will not open either. any idea of what i should do?
  2. 2008/01/18
    Moghedien21 - Welcome to the Board :)
    Try running 'Exe File Association fix' from Doug Knox
    Moghedien21
    Thanks for the welcome. :)
    Okay, my file associations are messed up for .exe, .com, and .reg files. And probably more. So I can't use the above fiix because I can't open the .reg file. Windows tells me to set an association for it.
    Suggestions?
  5. 2008/01/18
    noahdfear
    noahdfear Inactive
    I've seen this run despite file associations being borked, so lets give it a try. Download Deckard's System Scanner (dss.exe) and save it to your desktop.
    • Close all applications and windows.
    • Double click on dss.exe to run it and follow the prompts.
    • When the scan is complete, two text files will open; main.txt, which will be maximized and extra.txt, which will be minimized.
    Post the contents of main.txt only for now.
  6. 2008/01/19
    Moghedien21
    When I clicked to open the system scanner it told me I needed to set associations, but it let me run the scan when I right-clicked and selected run as administrator. yay. This is the main.txt:
    Deckard's System Scanner v20071014.68
    Run by MMM on 2008-01-19 08:51:41
    Computer is in Normal Mode.
    -- Last 5 Restore Point(s) --
    11: 2008-01-19 01:15:49 UTC - RP127 - Scheduled Checkpoint
    10: 2008-01-18 11:45:50 UTC - RP126 - Windows Update
    9: 2008-01-17 18:19:55 UTC - RP125 - Windows Update
    8: 2008-01-17 11:44:55 UTC - RP124 - Installed Ad-Aware 2007
    7: 2008-01-16 23:08:40 UTC - RP123 - Scheduled Checkpoint
    -- First Restore Point --
    1: 2008-01-09 08:01:24 UTC - RP117 - Windows Update
    Backed up registry hives.
    Performed disk cleanup.
    -- HijackThis Clone ------------------------------------------------------------
    Emulating logfile of Trend Micro HijackThis v2.0.2
    Scan saved at 2008-01-19 08:54:13
    Platform: Windows Vista (6.00.6000)
    MSIE: Internet Explorer (7.00.6000.16386)
    C:\Windows\System32\taskeng.exe
    C:\Program Files\Bioscrypt\VeriSoft\Bin\asghost.exe
    C:\Windows\System32\wisptis.exe
    C:\Windows\System32\dwm.exe
    C:\Program Files\Common Files\microsoft shared\ink\TabTip.exe
    C:\Windows\explorer.exe
    C:\Program Files\Common Files\microsoft shared\ink\InputPersonalization.exe
    C:\Users\MMM\Desktop\dss.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=73&bd=Pavilion&pf=laptop
    R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=73&bd=Pavilion&pf=laptop
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=73&bd=Pavilion&pf=laptop
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
    O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
    O2 - BHO: VeriSoft Access Manager - {DF21F1DB-80C6-11D3-9483-B03D0EC10000} - C:\Program Files\Bioscrypt\VeriSoft\Bin\ItIEAddIn.dll
    O4 - HKLM\..\Run: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
    O4 - HKLM\..\Run: [SMSERIAL] C:\Program Files\Motorola\SMSERIAL\sm56hlpr.exe
    O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
    O4 - HKLM\..\Run: [RtHDVCpl] RtHDVCpl.exe
    O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\Hp\HP Software Update\HPWuSchd2.exe
    O4 - HKLM\..\Run: [QPService] "C:\Program Files\HP\QuickPlay\QPService.exe "
    O4 - HKLM\..\Run: [QlbCtrl] %ProgramFiles%\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe /Start
    O4 - HKLM\..\Run: [HP Health Check Scheduler] C:\Program Files\Hewlett-Packard\HP Health Check\HPHC_Scheduler.exe
    O4 - HKLM\..\Run: [hpWirelessAssistant] %ProgramFiles%\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe
    O4 - HKLM\..\Run: [WAWifiMessage] %ProgramFiles%\Hewlett-Packard\HP Wireless Assistant\WiFiMsg.exe
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe "
    O4 - HKLM\..\Run: [CognizanceTS] rundll32.exe c:\PROGRA~1\BIOSCR~1\VeriSoft\Bin\ASTSVCC.dll,RegisterModule
    O4 - HKLM\..\Run: [NvSvc] RUNDLL32.EXE C:\Windows\system32\nvsvc.dll,nvsvcStart
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\Windows\system32\NvCpl.dll,NvStartup
    O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\Windows\system32\NvMcTray.dll,NvTaskbarInit
    O4 - HKLM\..\Run: [Symantec PIF AlertEng] "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" /a /m "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\AlertEng.dll "
    O4 - HKLM\..\Run: [avgnt] "C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe" /min
    O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
    O4 - HKLM\..\Run: [SynTPStart] C:\Program Files\Synaptics\SynTP\SynTPStart.exe
    O4 - HKCU\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
    O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
    O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    O4 - HKCU\..\Run: [uTorrent] "C:\Program Files\uTorrent\uTorrent.exe "
    O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
    O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
    O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
    O4 - HKUS\S-1-5-20\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'NETWORK SERVICE')
    O4 - Startup: MEMonitor.lnk = C:\Program Files\Verizon Wireless\V CAST Music Manager\MEMonitor.exe
    O4 - Startup: OneNote 2007 Screen Clipper and Launcher.lnk = C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE
    O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Reader 8.0\Reader\reader_sl.exe
    O4 - Global Startup: Adobe Reader Synchronizer.lnk = C:\Program Files\Adobe\Reader 8.0\Reader\AdobeCollabSync.exe
    O4 - Global Startup: Bluetooth.lnk = C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office12\EXCEL.EXE/3000
    O8 - Extra context menu item: Send image to &Bluetooth Device... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
    O8 - Extra context menu item: Send page to &Bluetooth Device... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
    O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office12\ONBttnIE.dll
    O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office12\ONBttnIE.dll
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - (file missing)
    O9 - Extra button: (no name) - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
    O9 - Extra 'Tools' menuitem: @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
    O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O18 - Protocol: ms-help - {314111c7-a502-11d2-bbca-00c04f8ec294} - C:\Program Files\Common Files\microsoft shared\Help\hxds.dll
    O18 - Protocol: ms-itss - {0A9007C0-4076-11D3-8789-0000F8105754} - C:\Program Files\Common Files\microsoft shared\Information Retrieval\msitss.dll
    O18 - Filter: text/xml - {807563E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\microsoft shared\OFFICE12\MSOXMLMF.DLL
    O20 - AppInit_DLLs: APSHook.dll
    O23 - Service: Ad-Aware 2007 Service (aawservice) - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware 2007\aawservice.exe
    O23 - Service: AddFiltr - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\AddFiltr.exe
    O23 - Service: AntiVir PersonalEdition Classic Scheduler (AntiVirScheduler) - Avira GmbH - C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
    O23 - Service: AntiVir PersonalEdition Classic Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
    O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
    O23 - Service: CyberLink Background Capture Service (CBCS) (CLCapSvc) - Unknown owner - C:\Program Files\Hp\QuickPlay\Kernel\TV\CLCapSvc.exe
    O23 - Service: CyberLink Task Scheduler (CTS) (CLSched) - Unknown owner - C:\Program Files\Hp\QuickPlay\Kernel\TV\CLSched.exe
    O23 - Service: HP Health Check Service - Hewlett-Packard - C:\Program Files\Hewlett-Packard\HP Health Check\HPHC_Service.exe
    O23 - Service: hpqwmiex - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\Shared\hpqwmiex.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Roxio\Roxio MyDVD Basic v9\InstallShield\Driver\1050\Intel 32\IDriverT.exe
    O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
    O23 - Service: LiveUpdate - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\LuComServer_3_2.EXE
    O23 - Service: LiveUpdate Notice Service Ex (LiveUpdate Notice Ex) - Unknown owner - c:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: LiveUpdate Notice Service - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe
    O23 - Service: RoxMediaDB9 - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe
    O23 - Service: SBSD Security Center Service (SBSDWSCService) - Safer Networking Ltd. - C:\Program Files\Spybot - Search & Destroy\SDWinSec.exe
    O23 - Service: stllssvr - MicroVision Development, Inc. - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe
    O23 - Service: Viewpoint Manager Service - Viewpoint Corporation - C:\Program Files\Viewpoint\Common\ViewpointService.exe
    End of file - 9756 bytes
    -- File Associations -----------------------------------------------------------
    .bat - batfile - shell\open\command - unable to read value
    .cmd - cmdfile - shell\open\command - unable to read value
    .com - comfile - shell\open\command - unable to read value
    .exe - exefile - shell\open\command - unable to read value
    .pif - piffile - shell\open\command - unable to read value
    .reg - regfile - shell\open\command - unable to read value
    .scr - scrfile - shell\open\command - unable to read value
    -- Drivers: 0-Boot, 1-System, 2-Auto, 3-Demand, 4-Disabled ---------------------
    All drivers whitelisted.
    -- Services: 0-Boot, 1-System, 2-Auto, 3-Demand, 4-Disabled --------------------
    R2 AntiVirScheduler (AntiVir PersonalEdition Classic Scheduler) - "c:\program files\avira\antivir personaledition classic\sched.exe" <Not Verified; Avira GmbH; Scheduler>
    R2 CLCapSvc (CyberLink Background Capture Service (CBCS)) - "c:\program files\hp\quickplay\kernel\tv\clcapsvc.exe" <Not Verified; ; CLCapSvc Module>
    R2 CLSched (CyberLink Task Scheduler (CTS)) - "c:\program files\hp\quickplay\kernel\tv\clsched.exe" <Not Verified; ; CLSched Module>
    R2 Viewpoint Manager Service - "c:\program files\viewpoint\common\viewpointservice.exe" <Not Verified; Viewpoint Corporation; Viewpoint Manager>
    S2 LiveUpdate Notice Ex (LiveUpdate Notice Service Ex) - "c:\program files\common files\symantec shared\ccsvchst.exe" /h cccommon (file missing)
    -- Device Manager: Disabled ----------------------------------------------------
    No disabled devices found.
    -- Files created between 2007-12-19 and 2008-01-19 -----------------------------
    2008-01-18 06:48:03 1732 --a------ C:\Windows\system32\drivers\nvphy.bin
    2008-01-17 16:12:42 0 d--hs---- C:\Users\Molly\Templates
    2008-01-17 16:12:42 0 d--hs---- C:\Users\Molly\Start Menu
    2008-01-17 16:12:42 0 d--hs---- C:\Users\Molly\SendTo
    2008-01-17 16:12:42 0 d--hs---- C:\Users\Molly\Recent
    2008-01-17 16:12:42 0 d--hs---- C:\Users\Molly\PrintHood
    2008-01-17 16:12:42 0 d--hs---- C:\Users\Molly\NetHood
    2008-01-17 16:12:42 0 d--hs---- C:\Users\Molly\My Documents
    2008-01-17 16:12:42 0 d--hs---- C:\Users\Molly\Local Settings
    2008-01-17 16:12:42 0 d--hs---- C:\Users\Molly\Cookies
    2008-01-17 16:12:42 0 d--hs---- C:\Users\Molly\Application Data
    2008-01-17 16:12:41 0 dr------- C:\Users\Molly\Videos
    2008-01-17 16:12:41 0 d-------- C:\Users\Molly\Saved Games
    2008-01-17 16:12:41 0 dr------- C:\Users\Molly\Pictures
    2008-01-17 16:12:41 1572864 --ahs---- C:\Users\Molly\NTUSER.DAT
    2008-01-17 16:12:41 0 dr------- C:\Users\Molly\Music
    2008-01-17 16:12:41 0 dr------- C:\Users\Molly\Links
    2008-01-17 16:12:41 0 dr------- C:\Users\Molly\Favorites
    2008-01-17 16:12:41 0 dr------- C:\Users\Molly\Downloads
    2008-01-17 16:12:41 0 dr------- C:\Users\Molly\Documents
    2008-01-17 16:12:41 0 dr------- C:\Users\Molly\Desktop
    2008-01-17 16:12:41 0 d--h----- C:\Users\Molly\AppData
    2008-01-17 06:45:36 0 d-------- C:\Program Files\Lavasoft
    2008-01-17 06:45:35 0 d-------- C:\Users\All Users\Lavasoft
    2008-01-17 06:30:01 0 d-------- C:\Program Files\Common Files\Wise Installation Wizard
    2008-01-10 18:04:08 0 d-------- C:\Program Files\QuickTime
    2008-01-10 18:04:07 0 d-------- C:\Users\All Users\Apple Computer
    2008-01-06 10:10:35 0 d-------- C:\Program Files\uTorrent
    2008-01-05 21:14:25 0 d-------- C:\Users\All Users\Viewpoint
    2008-01-05 21:14:24 0 d-------- C:\Program Files\Viewpoint
    2008-01-05 21:14:03 0 d-------- C:\Users\All Users\AOL
    2008-01-05 21:14:03 0 d-------- C:\Users\All Users\AOL OCP
    -- Find3M Report ---------------------------------------------------------------
    2008-01-19 08:44:50 0 d-------- C:\Users\MMM\AppData\Roaming\uTorrent
    2008-01-18 20:55:44 12 --a------ C:\Windows\bthservsdp.dat
    2008-01-17 20:56:01 12931 --a------ C:\Users\MMM\AppData\Roaming\nvModes.001
    2008-01-17 20:23:48 0 d-------- C:\Users\MMM\AppData\Roaming\True Sword
    2008-01-17 06:41:41 0 d-------- C:\Program Files\Common Files
    2008-01-16 20:59:52 0 d-------- C:\Users\MMM\AppData\Roaming\LimeWire
    2008-01-14 16:36:35 0 d-------- C:\Users\MMM\AppData\Roaming\Real
    2008-01-14 16:36:35 0 d-------- C:\Program Files\Real
    2008-01-14 16:36:35 0 d-------- C:\Program Files\Common Files\Real
    2008-01-09 20:45:54 2468 --a------ C:\Users\MMM\AppData\Roaming\wklnhst.dat
    2008-01-09 03:11:01 0 d-------- C:\Program Files\Windows Mail
    2008-01-09 03:11:00 0 d-------- C:\Program Files\Windows Sidebar
    2008-01-06 08:31:27 12931 --a------ C:\Users\MMM\AppData\Roaming\nvModes.dat
    2007-12-30 14:21:55 0 d-------- C:\Users\MMM\AppData\Roaming\InstallShield
    2007-12-30 14:08:02 0 d-------- C:\Users\MMM\AppData\Roaming\Hewlett-Packard
    2007-12-24 21:00:02 0 d-------- C:\Program Files\Common Files\Symantec Shared
    2007-12-24 20:57:57 0 d-------- C:\Program Files\Symantec
    2007-12-11 16:44:22 0 d-------- C:\Program Files\Avira
    2007-12-03 19:14:36 0 d-------- C:\Users\MMM\AppData\Roaming\Adobe
    2007-12-01 10:34:42 0 d-------- C:\Program Files\Realtek
    2007-12-01 10:34:17 315392 --a------ C:\Windows\HideWin.exe <Not Verified; Realtek Semiconductor Corp.; HD Audio Hide windows program>
    2007-11-27 18:36:49 0 d--h----- C:\Program Files\InstallShield Installation Information
    2007-11-27 18:36:02 0 d-------- C:\Program Files\Samsung
    2007-11-27 18:35:34 0 d-------- C:\Program Files\Common Files\InstallShield
    2007-11-27 18:34:43 0 d-------- C:\Program Files\Verizon Wireless
    -- Registry Dump ---------------------------------------------------------------
    "Windows Defender "= "C:\Program Files\Windows Defender\MSASCui.exe" [06/14/2007 12:25 PM]
    "SMSERIAL "= "C:\Program Files\Motorola\SMSERIAL\sm56hlpr.exe" [10/08/2006 11:43 PM]
    "SynTPEnh "= "C:\Program Files\Synaptics\SynTP\SynTPEnh.exe" [09/15/2007 02:50 AM]
    "RtHDVCpl "= "RtHDVCpl.exe" [03/01/2007 03:38 PM C:\Windows\RtHDVCpl.exe]
    "HP Software Update "= "C:\Program Files\Hp\HP Software Update\HPWuSchd2.exe" [02/17/2005 01:11 AM]
    "QPService "= "C:\Program Files\HP\QuickPlay\QPService.exe" [03/28/2007 07:45 PM]
    "QlbCtrl "= "C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe" [11/06/2006 12:58 PM]
    "HP Health Check Scheduler "= "C:\Program Files\Hewlett-Packard\HP Health Check\HPHC_Scheduler.exe" [03/12/2007 01:54 PM]
    "hpWirelessAssistant "= "C:\Program Files\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe" [03/01/2007 03:18 PM]
    "WAWifiMessage "= "C:\Program Files\Hewlett-Packard\HP Wireless Assistant\WiFiMsg.exe" [01/10/2007 06:12 PM]
    "SunJavaUpdateSched "= "C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe" [09/25/2007 12:11 AM]
    "CognizanceTS "= "c:\PROGRA~1\BIOSCR~1\VeriSoft\Bin\ASTSVCC.dll" [12/22/2003 02:12 PM]
    "NvSvc "= "C:\Windows\system32\nvsvc.dll" [02/26/2007 02:26 PM]
    "NvCplDaemon "= "C:\Windows\system32\NvCpl.dll" [02/26/2007 02:26 PM]
    "NvMediaCenter "= "C:\Windows\system32\NvMcTray.dll" [02/26/2007 02:26 PM]
    "Symantec PIF AlertEng "= "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" [11/28/2007 07:51 PM]
    "avgnt "= "C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe" [12/11/2007 04:47 PM]
    "QuickTime Task "= "C:\Program Files\QuickTime\QTTask.exe" [12/11/2007 10:56 AM]
    "SynTPStart "= "C:\Program Files\Synaptics\SynTP\SynTPStart.exe" [09/15/2007 02:29 AM]
    "Sidebar "= "C:\Program Files\Windows Sidebar\sidebar.exe" [01/09/2008 03:01 AM]
    "ehTray.exe "= "C:\Windows\ehome\ehTray.exe" [11/02/2006 07:35 AM]
    "SpybotSD TeaTimer "= "C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe" [08/31/2007 04:46 PM]
    "uTorrent "= "C:\Program Files\uTorrent\uTorrent.exe" [01/17/2008 07:14 PM]
    C:\Users\MMM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
    MEMonitor.lnk - C:\Program Files\Verizon Wireless\V CAST Music Manager\MEMonitor.exe [11/27/2007 6:34:46 PM]
    OneNote 2007 Screen Clipper and Launcher.lnk - C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE [10/26/2006 10:24:54 PM]
    C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
    Adobe Reader Speed Launch.lnk - C:\Program Files\Adobe\Reader 8.0\Reader\reader_sl.exe [10/23/2006 3:48:20 AM]
    Adobe Reader Synchronizer.lnk - C:\Program Files\Adobe\Reader 8.0\Reader\AdobeCollabSync.exe [10/23/2006 2:01:50 AM]
    Bluetooth.lnk - C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe [12/20/2006 2:27:40 PM]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
    "ConsentPromptBehaviorAdmin "=2 (0x2)
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\windows]
    "appinit_dlls "=APSHook.dll
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa]
    "Notification Packages "= scecli ASWLNPkg
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\aawservice]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\AppInfo]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\KeyIso]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\NTDS]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ProfSvc]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\sacsvr]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SWPRV]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\TabletInputService]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\TBS]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\TrustedInstaller]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\VDS]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\volmgr.sys]
    @= "Driver "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\volmgrx.sys]
    @= "Driver "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{533C5B84-EC70-11D2-9505-00C04F79DEAF}]
    @= "Volume shadow copy "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{6BDD1FC1-810F-11D0-BEC7-08002BE2092F}]
    @= "IEEE 1394 Bus host controllers "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{D48179BE-EC20-11D1-B6B8-00C04FA372A7}]
    @= "SBP2 IEEE 1394 Devices "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{D94EE5D8-D189-4994-83D2-F68D7D41B0E6}]
    @= "SecurityDevices "
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
    LocalSystemNetworkRestricted hidserv UxSms WdiSystemHost Netman trkwks AudioEndpointBuilder WUDFSvc irmon sysmain IPBusEnum dot3svc PcaSvc EMDMgmt TabletInputService wlansvc WPDBusEnum
    bthsvcs BthServ
    Cognizance ASBroker ASChannel
    GPSvcGroup GPSvc
    [HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{8b6471e4-8e3e-11dc-8aa4-001a6b8116e6}]
    AutoRun\command- G:\LaunchU3.exe -a
    [HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\>{22d6f312-b0f6-11d0-94ab-0080c74c7e95}]
    C:\Windows\system32\unregmp2.exe /ShowWMP
    [HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{6BF52A52-394A-11d3-B153-00C04F79FAA6}]
    %SystemRoot%\system32\unregmp2.exe /FirstLogon /Shortcuts /RegBrowsers /ResetMUI
    -- Hosts -----------------------------------------------------------------------
    127.0.0.1 007guard.com
    127.0.0.1 www.007guard.com
    127.0.0.1 008i.com
    127.0.0.1 008k.com
    127.0.0.1 www.008k.com
    127.0.0.1 00hq.com
    127.0.0.1 www.00hq.com
    127.0.0.1 010402.com
    127.0.0.1 032439.com
    127.0.0.1 www.032439.com
    7694 more entries in hosts file.
    -- End of Deckard's System Scanner: finished at 2008-01-19 08:55:23 ------------
  7. 2008/01/19
    noahdfear
    noahdfear Inactive
    Lets see if Deckard's can fix those associations. Click Start>Run and type or paste the following bolded command, then hit enter.
    C:\Users\MMM\Desktop\dss.exe /daft
    The Deckard's interface should open. Click scan. Any broken associations should come up in the window. Check the box for each then click Fix.
    See if files are opening properly now.
  8. 2008/01/20
    Moghedien21
    I tried to run the command you posted, but when I tried it the same window about file associations came up. :(
  9. 2008/01/20
    noahdfear
    noahdfear Inactive
    Open the Control Panel and select Default Programs (or just Default Programs on the Start Menu if it exists).
    Select 'Associate a file type or protocol with a program'.
    Scroll down to .reg and select it, then click Change Program.
    Click Browse and navigate to, then select C:\Windows\regedit.exe and click OK.
    Now download the exe fix from here, extract the registry file from the zip, then right click it and select Merge.
    Try running dss again using the command in my last post.
  10. 2008/01/20
    Moghedien21
    It worked! Yay! Thanks for your help. It looks like eveything's fixed. :)
  11. 2008/01/20
    noahdfear
    noahdfear Inactive
    That's great! I don't see anything suspicious in your logs either.
    You're most welcome. Glad I could help. :)
